unsigned char | mode |
unsigned short | frame_length |
unsigned short | limit |
unsigned int | as_marker |
unsigned short | phy_subrate |
unsigned short | phy_symbolrate |
unsigned char | phy_opts |
unsigned char | code_rsdep |
unsigned char | code_ce_rate |
unsigned char | code_csel |
unsigned int | code_opts |
unsigned char | all_izlen |
unsigned char | all_opts |
unsigned char | mf_opts |
unsigned short | idle_scid |
unsigned char | idle_vcid |
unsigned char | idle_opts |
unsigned int | enable_cnt |
int | isr_desc_proc |
int | blocking |
rtems_interval | timeout |
