struct drvmgr_dev * | dev |
char | devName [52] |
unsigned int | baseaddr |
unsigned int | ram_base |
struct grcan_regs * | regs |
int | irq |
int | minor |
int | open |
int | started |
unsigned int | channel |
int | flushing |
unsigned int | corefreq_hz |
int | fd_capable |
void * | _rx |
void * | _rx_hw |
void * | _tx |
void * | _tx_hw |
void * | txbuf_adr |
void * | rxbuf_adr |
struct grcan_msg * | rx |
struct grcan_msg * | tx |
unsigned int | rxbuf_size |
unsigned int | txbuf_size |
int | txblock |
int | rxblock |
int | txcomplete |
int | rxcomplete |
struct grcan_filter | sfilter |
struct grcan_filter | afilter |
int | config_changed |
struct grcan_config | config |
struct grcan_stats | stats |
rtems_id | rx_sem |
rtems_id | tx_sem |
rtems_id | txempty_sem |
rtems_id | dev_sem |
