RTEMS 6.1
flash_bank_ops Struct Reference
int(* get_id )(struct bankdesc *b, uint32_t addr, uint32_t *pVendorId, uint32_t *pDeviceId)
void(* unlock_block )(struct bankdesc *b, uint32_t addr)
void(* lock_block )(struct bankdesc *b, uint32_t addr)
int(* erase_block )(struct bankdesc *b, uint32_t addr)
uint32_t(* check_ready )(struct bankdesc *b, uint32_t addr)
void(* print_stat )(struct bankdesc *b, uint32_t sta, int verbose)
void(* array_mode )(struct bankdesc *b, uint32_t addr)
uint32_t(* write_line )(struct bankdesc *b, uint32_t addr, const char *src, uint32_t N)
