volatile unsigned int | Memory_Config_1 |
volatile unsigned int | Memory_Config_2 |
volatile unsigned int | Edac_Control |
volatile unsigned int | Failed_Address |
volatile unsigned int | Memory_Status |
volatile unsigned int | Cache_Control |
volatile unsigned int | Power_Down |
volatile unsigned int | Write_Protection_1 |
volatile unsigned int | Write_Protection_2 |
volatile unsigned int | Leon_Configuration |
volatile unsigned int | dummy2 |
volatile unsigned int | dummy3 |
volatile unsigned int | dummy4 |
volatile unsigned int | dummy5 |
volatile unsigned int | dummy6 |
volatile unsigned int | dummy7 |
volatile unsigned int | Timer_Counter_1 |
volatile unsigned int | Timer_Reload_1 |
volatile unsigned int | Timer_Control_1 |
volatile unsigned int | Watchdog |
volatile unsigned int | Timer_Counter_2 |
volatile unsigned int | Timer_Reload_2 |
volatile unsigned int | Timer_Control_2 |
volatile unsigned int | dummy8 |
volatile unsigned int | Scaler_Counter |
volatile unsigned int | Scaler_Reload |
volatile unsigned int | dummy9 |
volatile unsigned int | dummy10 |
volatile unsigned int | UART_Channel_1 |
volatile unsigned int | UART_Status_1 |
volatile unsigned int | UART_Control_1 |
volatile unsigned int | UART_Scaler_1 |
volatile unsigned int | UART_Channel_2 |
volatile unsigned int | UART_Status_2 |
volatile unsigned int | UART_Control_2 |
volatile unsigned int | UART_Scaler_2 |
volatile unsigned int | Interrupt_Mask |
volatile unsigned int | Interrupt_Pending |
volatile unsigned int | Interrupt_Force |
volatile unsigned int | Interrupt_Clear |
volatile unsigned int | PIO_Data |
volatile unsigned int | PIO_Direction |
volatile unsigned int | PIO_Interrupt |
- bsps/sparc/leon2/include/leon.h
