volatile uint32_t | Control |
volatile uint32_t | Software_Reset |
volatile uint32_t | Power_Down |
volatile uint32_t | Unimplemented_0 |
volatile uint32_t | Memory_Configuration |
volatile uint32_t | IO_Configuration |
volatile uint32_t | Wait_State_Configuration |
volatile uint32_t | Unimplemented_1 |
volatile uint32_t | Memory_Access_0 |
volatile uint32_t | Memory_Access_1 |
volatile uint32_t | Unimplemented_2 [7] |
volatile uint32_t | Interrupt_Shape |
volatile uint32_t | Interrupt_Pending |
volatile uint32_t | Interrupt_Mask |
volatile uint32_t | Interrupt_Clear |
volatile uint32_t | Interrupt_Force |
volatile uint32_t | Unimplemented_3 [2] |
volatile uint32_t | Watchdog_Program_and_Timeout_Acknowledge |
volatile uint32_t | Watchdog_Trap_Door_Set |
volatile uint32_t | Unimplemented_4 [6] |
volatile uint32_t | Real_Time_Clock_Counter |
volatile uint32_t | Real_Time_Clock_Scalar |
volatile uint32_t | General_Purpose_Timer_Counter |
volatile uint32_t | General_Purpose_Timer_Scalar |
volatile uint32_t | Unimplemented_5 [2] |
volatile uint32_t | Timer_Control |
volatile uint32_t | Unimplemented_6 |
volatile uint32_t | System_Fault_Status |
volatile uint32_t | First_Failing_Address |
volatile uint32_t | First_Failing_Data |
volatile uint32_t | First_Failing_Syndrome_and_Check_Bits |
volatile uint32_t | Error_and_Reset_Status |
volatile uint32_t | Error_Mask |
volatile uint32_t | Unimplemented_7 [2] |
volatile uint32_t | Debug_Control |
volatile uint32_t | Breakpoint |
volatile uint32_t | Watchpoint |
volatile uint32_t | Unimplemented_8 |
volatile uint32_t | Test_Control |
volatile uint32_t | Test_Data |
volatile uint32_t | Unimplemented_9 [2] |
volatile uint32_t | UART_Channel_A |
volatile uint32_t | UART_Channel_B |
volatile uint32_t | UART_Status |
