RTEMS 6.1
CTU_struct_tag Struct Reference
CTU_TGSISR_32B_tag TGSISR
CTU_TGSCR_16B_tag TGSCR
union {
   CTU_TCR_16B_tag   TCR [8]
   struct {
      CTU_TCR_16B_tag   T0CR
      CTU_TCR_16B_tag   T1CR
      CTU_TCR_16B_tag   T2CR
      CTU_TCR_16B_tag   T3CR
      CTU_TCR_16B_tag   T4CR
      CTU_TCR_16B_tag   T5CR
      CTU_TCR_16B_tag   T6CR
      CTU_TCR_16B_tag   T7CR
CTU_TGSCCR_16B_tag TGSCCR
CTU_TGSCRR_16B_tag TGSCRR
int8_t CTU_reserved_001A [2]
CTU_CLCR1_32B_tag CLCR1
CTU_CLCR2_32B_tag CLCR2
CTU_THCR1_32B_tag THCR1
CTU_THCR2_32B_tag THCR2
union {
   CTU_CLR_SCM_16B_tag   CLR [24]
   CTU_CLR_SCM_16B_tag   CLR_SCM [24]
   CTU_CLR_DCM_16B_tag   CLR_DCM [24]
   struct {
      CTU_CLR_SCM_16B_tag   CLR_SCM1
      CTU_CLR_SCM_16B_tag   CLR_SCM2
      CTU_CLR_SCM_16B_tag   CLR_SCM3
      CTU_CLR_SCM_16B_tag   CLR_SCM4
      CTU_CLR_SCM_16B_tag   CLR_SCM5
      CTU_CLR_SCM_16B_tag   CLR_SCM6
      CTU_CLR_SCM_16B_tag   CLR_SCM7
      CTU_CLR_SCM_16B_tag   CLR_SCM8
      CTU_CLR_SCM_16B_tag   CLR_SCM9
      CTU_CLR_SCM_16B_tag   CLR_SCM10
      CTU_CLR_SCM_16B_tag   CLR_SCM11
      CTU_CLR_SCM_16B_tag   CLR_SCM12
      CTU_CLR_SCM_16B_tag   CLR_SCM13
      CTU_CLR_SCM_16B_tag   CLR_SCM14
      CTU_CLR_SCM_16B_tag   CLR_SCM15
      CTU_CLR_SCM_16B_tag   CLR_SCM16
      CTU_CLR_SCM_16B_tag   CLR_SCM17
      CTU_CLR_SCM_16B_tag   CLR_SCM18
      CTU_CLR_SCM_16B_tag   CLR_SCM19
      CTU_CLR_SCM_16B_tag   CLR_SCM20
      CTU_CLR_SCM_16B_tag   CLR_SCM21
      CTU_CLR_SCM_16B_tag   CLR_SCM22
      CTU_CLR_SCM_16B_tag   CLR_SCM23
      CTU_CLR_SCM_16B_tag   CLR_SCM24
   struct {
      CTU_CLR_DCM_16B_tag   CLR_DCM1
      CTU_CLR_DCM_16B_tag   CLR_DCM2
      CTU_CLR_DCM_16B_tag   CLR_DCM3
      CTU_CLR_DCM_16B_tag   CLR_DCM4
      CTU_CLR_DCM_16B_tag   CLR_DCM5
      CTU_CLR_DCM_16B_tag   CLR_DCM6
      CTU_CLR_DCM_16B_tag   CLR_DCM7
      CTU_CLR_DCM_16B_tag   CLR_DCM8
      CTU_CLR_DCM_16B_tag   CLR_DCM9
      CTU_CLR_DCM_16B_tag   CLR_DCM10
      CTU_CLR_DCM_16B_tag   CLR_DCM11
      CTU_CLR_DCM_16B_tag   CLR_DCM12
      CTU_CLR_DCM_16B_tag   CLR_DCM13
      CTU_CLR_DCM_16B_tag   CLR_DCM14
      CTU_CLR_DCM_16B_tag   CLR_DCM15
      CTU_CLR_DCM_16B_tag   CLR_DCM16
      CTU_CLR_DCM_16B_tag   CLR_DCM17
      CTU_CLR_DCM_16B_tag   CLR_DCM18
      CTU_CLR_DCM_16B_tag   CLR_DCM19
      CTU_CLR_DCM_16B_tag   CLR_DCM20
      CTU_CLR_DCM_16B_tag   CLR_DCM21
      CTU_CLR_DCM_16B_tag   CLR_DCM22
      CTU_CLR_DCM_16B_tag   CLR_DCM23
      CTU_CLR_DCM_16B_tag   CLR_DCM24
int8_t CTU_reserved_005C [16]
CTU_CR_16B_tag CR
int8_t CTU_reserved_006E [2]
CTU_FCR_32B_tag FCR
CTU_TH1_32B_tag TH1
CTU_TH2_32B_tag TH2
union {
   CTU_STS_32B_tag   STS
   CTU_STS_32B_tag   STATUS
union {
   CTU_FRA_32B_tag   FRA [8]
   CTU_FR_32B_tag   FR [8]
   struct {
      CTU_FR_32B_tag   FR0
      CTU_FR_32B_tag   FR1
      CTU_FR_32B_tag   FR2
      CTU_FR_32B_tag   FR3
      CTU_FR_32B_tag   FR4
      CTU_FR_32B_tag   FR5
      CTU_FR_32B_tag   FR6
      CTU_FR_32B_tag   FR7
union {
   CTU_FLA_32B_tag   FLA [8]
   CTU_FL_32B_tag   FL [8]
   struct {
      CTU_FL_32B_tag   FL0
      CTU_FL_32B_tag   FL1
      CTU_FL_32B_tag   FL2
      CTU_FL_32B_tag   FL3
      CTU_FL_32B_tag   FL4
      CTU_FL_32B_tag   FL5
      CTU_FL_32B_tag   FL6
      CTU_FL_32B_tag   FL7
CTU_CTUEFR_16B_tag CTUEFR
CTU_CTUIFR_16B_tag CTUIFR
CTU_CTUIR_16B_tag CTUIR
CTU_COTR_16B_tag COTR
CTU_CTUCR_16B_tag CTUCR
union {
   CTU_FILTER_16B_tag   FILTER
   CTU_FILTER_16B_tag   CTUFILTER
CTU_EXPECTED_A_16B_tag EXPECTED_A
CTU_EXPECTED_B_16B_tag EXPECTED_B
CTU_CNT_RANGE_16B_tag CNT_RANGE
