volatile uint32_t | ic_con |
volatile uint32_t | ic_tar |
volatile uint32_t | ic_sar |
volatile uint32_t | _pad_0xc_0xf |
volatile uint32_t | ic_data_cmd |
volatile uint32_t | ic_ss_scl_hcnt |
volatile uint32_t | ic_ss_scl_lcnt |
volatile uint32_t | ic_fs_scl_hcnt |
volatile uint32_t | ic_fs_scl_lcnt |
volatile uint32_t | _pad_0x24_0x2b [2] |
volatile uint32_t | ic_intr_stat |
volatile uint32_t | ic_intr_mask |
volatile uint32_t | ic_raw_intr_stat |
volatile uint32_t | ic_rx_tl |
volatile uint32_t | ic_tx_tl |
volatile uint32_t | ic_clr_intr |
volatile uint32_t | ic_clr_rx_under |
volatile uint32_t | ic_clr_rx_over |
volatile uint32_t | ic_clr_tx_over |
volatile uint32_t | ic_clr_rd_req |
volatile uint32_t | ic_clr_tx_abrt |
volatile uint32_t | ic_clr_rx_done |
volatile uint32_t | ic_clr_activity |
volatile uint32_t | ic_clr_stop_det |
volatile uint32_t | ic_clr_start_det |
volatile uint32_t | ic_clr_gen_call |
volatile uint32_t | ic_enable |
volatile uint32_t | ic_status |
volatile uint32_t | ic_txflr |
volatile uint32_t | ic_rxflr |
volatile uint32_t | ic_sda_hold |
volatile uint32_t | ic_tx_abrt_source |
volatile uint32_t | ic_slv_data_nack_only |
volatile uint32_t | ic_dma_cr |
volatile uint32_t | ic_dma_tdlr |
volatile uint32_t | ic_dma_rdlr |
volatile uint32_t | ic_sda_setup |
volatile uint32_t | ic_ack_general_call |
volatile uint32_t | ic_enable_status |
volatile uint32_t | ic_fs_spklen |
volatile uint32_t | _pad_0xa4_0xf3 [20] |
volatile uint32_t | ic_comp_param_1 |
volatile uint32_t | ic_comp_version |
volatile uint32_t | ic_comp_type |
- bsps/arm/altera-cyclone-v/include/bsp/socal/alt_i2c.h
