RTEMS 6.1
Header file of UTILS LL module. More...
| struct | LL_UTILS_PLLInitTypeDef |
| UTILS PLL structure definition. More... | |
| struct | LL_UTILS_ClkInitTypeDef |
| UTILS System, AHB and APB buses clock configuration structure definition. More... | |
| #define | LL_MAX_DELAY 0xFFFFFFFFU |
| #define | UID_BASE_ADDRESS UID_BASE |
| Unique device ID register base address. | |
| #define | FLASHSIZE_BASE_ADDRESS FLASHSIZE_BASE |
| Flash size data register base address. | |
| #define | PACKAGE_BASE_ADDRESS PACKAGE_BASE |
| Package data register base address. | |
| #define | LL_UTILS_HSEBYPASS_OFF 0x00000000U |
| #define | LL_UTILS_HSEBYPASS_ON 0x00000001U |
| __STATIC_INLINE uint32_t | LL_GetUID_Word0 (void) |
| Get Word0 of the unique device identifier (UID based on 96 bits) | |
| __STATIC_INLINE uint32_t | LL_GetUID_Word1 (void) |
| Get Word1 of the unique device identifier (UID based on 96 bits) | |
| __STATIC_INLINE uint32_t | LL_GetUID_Word2 (void) |
| Get Word2 of the unique device identifier (UID based on 96 bits) | |
| __STATIC_INLINE uint32_t | LL_GetFlashSize (void) |
| Get Flash memory size. | |
| __STATIC_INLINE uint32_t | LL_GetPackageType (void) |
| Get Package type. | |
| __STATIC_INLINE void | LL_InitTick (uint32_t HCLKFrequency, uint32_t Ticks) |
| This function configures the Cortex-M SysTick source of the time base. | |
| void | LL_Init1msTick (uint32_t CPU_Frequency) |
| This function configures the Cortex-M SysTick source to have 1ms time base. | |
| void | LL_mDelay (uint32_t Delay) |
| This function provides accurate delay (in milliseconds) based on SysTick counter flag. | |
| void | LL_SetSystemCoreClock (uint32_t CPU_Frequency) |
| This function sets directly SystemCoreClock CMSIS variable. | |
| ErrorStatus | LL_PLL_ConfigSystemClock_HSI (LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
| This function configures system clock at maximum frequency with HSI as clock source of the PLL. | |
| ErrorStatus | LL_PLL_ConfigSystemClock_HSE (uint32_t HSEFrequency, uint32_t HSEBypass, LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
| This function configures system clock with HSE as clock source of the PLL. | |
| ErrorStatus | LL_SetFlashLatency (uint32_t HCLK_Frequency) |
| Update number of Flash wait states in line with new frequency and current voltage range. | |
##### How to use this driver #####
The LL UTILS driver contains a set of generic APIs that can be
used by user:
(+) Device electronic signature
(+) Timing functions
(+) PLL configuration functions
