RTEMS 6.1
HAL time base based on the hardware RTC_WAKEUP Template. More...
#include "stm32h7xx_hal.h"Macros | |
| #define | RTC_CLOCK_SOURCE_HSE |
| #define | RTC_ASYNCH_PREDIV 99U |
| #define | RTC_SYNCH_PREDIV 9U |
| #define | RCC_RTCCLKSOURCE_1MHZ ((uint32_t)((uint32_t)RCC_BDCR_RTCSEL | (uint32_t)((HSE_VALUE/1000000U) << 12U))) |
| void | RTC_WKUP_IRQHandler (void) |
| This function handles WAKE UP TIMER interrupt request. | |
| HAL_StatusTypeDef | HAL_InitTick (uint32_t TickPriority) |
| This function configures the RTC_WKUP as a time base source. The time source is configured to have 1ms time base with a dedicated Tick interrupt priority. Wakeup Time base = ((RTC_ASYNCH_PREDIV + 1) * (RTC_SYNCH_PREDIV + 1)) / RTC_CLOCK = 1ms Wakeup Time = WakeupTimebase * WakeUpCounter (0 + 1) = 1 ms. | |
| void | HAL_SuspendTick (void) |
| Suspend Tick increment. | |
| void | HAL_ResumeTick (void) |
| Resume Tick increment. | |
| void | HAL_RTCEx_WakeUpTimerEventCallback (RTC_HandleTypeDef *hrtc) |
| Wake Up Timer Event Callback in non blocking mode. | |
##### How to use this driver #####
This file must be copied to the application folder and modified as follows:
(#) Rename it to 'stm32h7xx_hal_timebase_rtc_wakeup.c'
(#) Add this file and the RTC HAL drivers to your project and uncomment
HAL_RTC_MODULE_ENABLED define in stm32h7xx_hal_conf.h
(@) HAL RTC alarm and HAL RTC wakeup drivers can not be used with low power modes:
The wake up capability of the RTC may be intrusive in case of prior low power mode
configuration requiring different wake up sources.
Application/Example behavior is no more guaranteed
(@) The stm32h7xx_hal_timebase_tim use is recommended for the Applications/Examples
requiring low power modes
