RTEMS 6.1
Header file of RAMECC HAL module. More...
#include "stm32h7xx_hal_def.h"Go to the source code of this file.
| struct | RAMECC_HandleTypeDef |
| RAMECC handle Structure definition. More... | |
| #define | HAL_RAMECC_ERROR_NONE 0x00000000U |
| #define | HAL_RAMECC_ERROR_TIMEOUT 0x00000001U |
| #define | HAL_RAMECC_ERROR_BUSY 0x00000002U |
| #define | HAL_RAMECC_NO_ERROR 0x00000000U |
| #define | HAL_RAMECC_SINGLEERROR_DETECTED 0x00000001U |
| #define | HAL_RAMECC_DOUBLEERROR_DETECTED 0x00000002U |
| #define | RAMECC_IT_GLOBAL_ID 0x10000000UL |
| #define | RAMECC_IT_MONITOR_ID 0x20000000UL |
| #define | RAMECC_IT_GLOBAL_ENABLE (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GIE) |
| #define | RAMECC_IT_GLOBAL_SINGLEERR_R (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GECCSEIE) |
| #define | RAMECC_IT_GLOBAL_DOUBLEERR_R (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GECCDEIE) |
| #define | RAMECC_IT_GLOBAL_DOUBLEERR_W (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GECCDEBWIE) |
| #define | RAMECC_IT_GLOBAL_ALL (RAMECC_IT_GLOBAL_ID | RAMECC_IER_GIE | RAMECC_IER_GECCSEIE | RAMECC_IER_GECCDEIE | RAMECC_IER_GECCDEBWIE) |
| #define | RAMECC_IT_MONITOR_SINGLEERR_R (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCSEIE) |
| #define | RAMECC_IT_MONITOR_DOUBLEERR_R (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCDEIE) |
| #define | RAMECC_IT_MONITOR_DOUBLEERR_W (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCDEBWIE) |
| #define | RAMECC_IT_MONITOR_ALL (RAMECC_IT_MONITOR_ID | RAMECC_CR_ECCDEBWIE | RAMECC_CR_ECCDEIE | RAMECC_CR_ECCSEIE) |
| #define | RAMECC_FLAG_SINGLEERR_R RAMECC_SR_SEDCF |
| #define | RAMECC_FLAG_DOUBLEERR_R RAMECC_SR_DEDF |
| #define | RAMECC_FLAG_DOUBLEERR_W RAMECC_SR_DEBWDF |
| #define | RAMECC_FLAGS_ALL (RAMECC_SR_SEDCF | RAMECC_SR_DEDF | RAMECC_SR_DEBWDF) |
| #define | __HAL_RAMECC_ENABLE_GLOBAL_IT(__HANDLE__, __INTERRUPT__) ((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) |= ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) |
| #define | __HAL_RAMECC_ENABLE_MONITOR_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR |= ((__INTERRUPT__) & ~RAMECC_IT_MONITOR_ID)) |
| #define | __HAL_RAMECC_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified RAMECC interrupts. | |
| #define | __HAL_RAMECC_DISABLE_GLOBAL_IT(__HANDLE__, __INTERRUPT__) ((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) &= ~((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) |
| #define | __HAL_RAMECC_DISABLE_MONITOR_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->CR &= ~((__INTERRUPT__) & ~RAMECC_IT_MONITOR_ID)) |
| #define | __HAL_RAMECC_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified RAMECC interrupts. | |
| #define | __HAL_RAMECC_GET_GLOBAL_IT_SOURCE(__HANDLE__, __INTERRUPT__) (((((RAMECC_TypeDef *)((uint32_t)(__HANDLE__)->Instance & 0xFFFFFF00U))->IER) & ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) ? SET : RESET) |
| #define | __HAL_RAMECC_GET_MONITOR_IT_SOURCE(__HANDLE__, __INTERRUPT__) ((((__HANDLE__)->Instance->CR) & ((__INTERRUPT__) & ~RAMECC_IT_GLOBAL_ID)) ? SET : RESET) |
| #define | __HAL_RAMECC_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified RAMECC interrupt source is enabled or not. | |
| #define | __HAL_RAMECC_GET_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->SR &= (__FLAG__)) |
| Get the RAMECC pending flags. | |
| #define | __HAL_RAMECC_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->SR &= ~(__FLAG__)) |
| Clear the RAMECC pending flags. | |
| #define | __HAL_RAMECC_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_RAMECC_STATE_RESET) |
| Reset the RAMECC handle state. | |
| #define | IS_RAMECC_GLOBAL_INTERRUPT(INTERRUPT) |
| #define | IS_RAMECC_MONITOR_INTERRUPT(INTERRUPT) |
| #define | IS_RAMECC_INTERRUPT(INTERRUPT) |
Enumerations | |
| enum | HAL_RAMECC_StateTypeDef { HAL_RAMECC_STATE_RESET = 0x00U , HAL_RAMECC_STATE_READY = 0x01U , HAL_RAMECC_STATE_BUSY = 0x02U , HAL_RAMECC_STATE_ERROR = 0x03U } |
| HAL RAMECC State structures definition. More... | |
| HAL_StatusTypeDef | HAL_RAMECC_Init (RAMECC_HandleTypeDef *hramecc) |
| HAL_StatusTypeDef | HAL_RAMECC_DeInit (RAMECC_HandleTypeDef *hramecc) |
| HAL_StatusTypeDef | HAL_RAMECC_StartMonitor (RAMECC_HandleTypeDef *hramecc) |
| HAL_StatusTypeDef | HAL_RAMECC_StopMonitor (RAMECC_HandleTypeDef *hramecc) |
| HAL_StatusTypeDef | HAL_RAMECC_EnableNotification (RAMECC_HandleTypeDef *hramecc, uint32_t Notifications) |
| HAL_StatusTypeDef | HAL_RAMECC_DisableNotification (RAMECC_HandleTypeDef *hramecc, uint32_t Notifications) |
| void | HAL_RAMECC_IRQHandler (RAMECC_HandleTypeDef *hramecc) |
| void | HAL_RAMECC_DetectErrorCallback (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_GetFailingAddress (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_GetFailingDataLow (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_GetFailingDataHigh (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_GetHammingErrorCode (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_IsECCSingleErrorDetected (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_IsECCDoubleErrorDetected (RAMECC_HandleTypeDef *hramecc) |
| HAL_RAMECC_StateTypeDef | HAL_RAMECC_GetState (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_GetError (RAMECC_HandleTypeDef *hramecc) |
| uint32_t | HAL_RAMECC_GetRAMECCError (RAMECC_HandleTypeDef *hramecc) |
