RTEMS 6.1
Header file of IRDA HAL module. More...
| struct | IRDA_InitTypeDef |
| IRDA Init Structure definition. More... | |
| struct | IRDA_HandleTypeDef |
| IRDA handle Structure definition. More... | |
| #define | HAL_IRDA_STATE_RESET 0x00000000U |
| #define | HAL_IRDA_STATE_READY 0x00000020U |
| #define | HAL_IRDA_STATE_BUSY 0x00000024U |
| #define | HAL_IRDA_STATE_BUSY_TX 0x00000021U |
| #define | HAL_IRDA_STATE_BUSY_RX 0x00000022U |
| #define | HAL_IRDA_STATE_BUSY_TX_RX 0x00000023U |
| #define | HAL_IRDA_STATE_TIMEOUT 0x000000A0U |
| #define | HAL_IRDA_STATE_ERROR 0x000000E0U |
| #define | HAL_IRDA_ERROR_NONE (0x00000000U) |
| #define | HAL_IRDA_ERROR_PE (0x00000001U) |
| #define | HAL_IRDA_ERROR_NE (0x00000002U) |
| #define | HAL_IRDA_ERROR_FE (0x00000004U) |
| #define | HAL_IRDA_ERROR_ORE (0x00000008U) |
| #define | HAL_IRDA_ERROR_DMA (0x00000010U) |
| #define | HAL_IRDA_ERROR_BUSY (0x00000020U) |
| #define | IRDA_PARITY_NONE 0x00000000U |
| #define | IRDA_PARITY_EVEN USART_CR1_PCE |
| #define | IRDA_PARITY_ODD (USART_CR1_PCE | USART_CR1_PS) |
| #define | IRDA_MODE_RX USART_CR1_RE |
| #define | IRDA_MODE_TX USART_CR1_TE |
| #define | IRDA_MODE_TX_RX (USART_CR1_TE |USART_CR1_RE) |
| #define | IRDA_POWERMODE_NORMAL 0x00000000U |
| #define | IRDA_POWERMODE_LOWPOWER USART_CR3_IRLP |
| #define | IRDA_PRESCALER_DIV1 0x00000000U |
| #define | IRDA_PRESCALER_DIV2 0x00000001U |
| #define | IRDA_PRESCALER_DIV4 0x00000002U |
| #define | IRDA_PRESCALER_DIV6 0x00000003U |
| #define | IRDA_PRESCALER_DIV8 0x00000004U |
| #define | IRDA_PRESCALER_DIV10 0x00000005U |
| #define | IRDA_PRESCALER_DIV12 0x00000006U |
| #define | IRDA_PRESCALER_DIV16 0x00000007U |
| #define | IRDA_PRESCALER_DIV32 0x00000008U |
| #define | IRDA_PRESCALER_DIV64 0x00000009U |
| #define | IRDA_PRESCALER_DIV128 0x0000000AU |
| #define | IRDA_PRESCALER_DIV256 0x0000000BU |
| #define | IRDA_STATE_DISABLE 0x00000000U |
| #define | IRDA_STATE_ENABLE USART_CR1_UE |
| #define | IRDA_MODE_DISABLE 0x00000000U |
| #define | IRDA_MODE_ENABLE USART_CR3_IREN |
| #define | IRDA_ONE_BIT_SAMPLE_DISABLE 0x00000000U |
| #define | IRDA_ONE_BIT_SAMPLE_ENABLE USART_CR3_ONEBIT |
| #define | IRDA_DMA_TX_DISABLE 0x00000000U |
| #define | IRDA_DMA_TX_ENABLE USART_CR3_DMAT |
| #define | IRDA_DMA_RX_DISABLE 0x00000000U |
| #define | IRDA_DMA_RX_ENABLE USART_CR3_DMAR |
| #define | IRDA_AUTOBAUD_REQUEST USART_RQR_ABRRQ |
| #define | IRDA_RXDATA_FLUSH_REQUEST USART_RQR_RXFRQ |
| #define | IRDA_TXDATA_FLUSH_REQUEST USART_RQR_TXFRQ |
| #define | IRDA_FLAG_REACK USART_ISR_REACK |
| #define | IRDA_FLAG_TEACK USART_ISR_TEACK |
| #define | IRDA_FLAG_BUSY USART_ISR_BUSY |
| #define | IRDA_FLAG_ABRF USART_ISR_ABRF |
| #define | IRDA_FLAG_ABRE USART_ISR_ABRE |
| #define | IRDA_FLAG_TXE USART_ISR_TXE_TXFNF |
| #define | IRDA_FLAG_TC USART_ISR_TC |
| #define | IRDA_FLAG_RXNE USART_ISR_RXNE_RXFNE |
| #define | IRDA_FLAG_ORE USART_ISR_ORE |
| #define | IRDA_FLAG_NE USART_ISR_NE |
| #define | IRDA_FLAG_FE USART_ISR_FE |
| #define | IRDA_FLAG_PE USART_ISR_PE |
| #define | IRDA_IT_PE 0x0028U |
| #define | IRDA_IT_TXE 0x0727U |
| #define | IRDA_IT_TC 0x0626U |
| #define | IRDA_IT_RXNE 0x0525U |
| #define | IRDA_IT_IDLE 0x0424U |
| #define | IRDA_IT_ERR 0x0060U |
| #define | IRDA_IT_ORE 0x0300U |
| #define | IRDA_IT_NE 0x0200U |
| #define | IRDA_IT_FE 0x0100U |
| #define | IRDA_CLEAR_PEF USART_ICR_PECF |
| #define | IRDA_CLEAR_FEF USART_ICR_FECF |
| #define | IRDA_CLEAR_NEF USART_ICR_NECF |
| #define | IRDA_CLEAR_OREF USART_ICR_ORECF |
| #define | IRDA_CLEAR_IDLEF USART_ICR_IDLECF |
| #define | IRDA_CLEAR_TCF USART_ICR_TCCF |
| #define | IRDA_IT_MASK 0x001FU |
| #define | IRDA_CR_MASK 0x00E0U |
| #define | IRDA_CR_POS 5U |
| #define | IRDA_ISR_MASK 0x1F00U |
| #define | IRDA_ISR_POS 8U |
| #define | __HAL_IRDA_RESET_HANDLE_STATE(__HANDLE__) |
| Reset IRDA handle state. | |
| #define | __HAL_IRDA_FLUSH_DRREGISTER(__HANDLE__) |
| Flush the IRDA DR register. | |
| #define | __HAL_IRDA_CLEAR_FLAG(__HANDLE__, __FLAG__) ((__HANDLE__)->Instance->ICR = (__FLAG__)) |
| Clear the specified IRDA pending flag. | |
| #define | __HAL_IRDA_CLEAR_PEFLAG(__HANDLE__) __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_PEF) |
| Clear the IRDA PE pending flag. | |
| #define | __HAL_IRDA_CLEAR_FEFLAG(__HANDLE__) __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_FEF) |
| Clear the IRDA FE pending flag. | |
| #define | __HAL_IRDA_CLEAR_NEFLAG(__HANDLE__) __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_NEF) |
| Clear the IRDA NE pending flag. | |
| #define | __HAL_IRDA_CLEAR_OREFLAG(__HANDLE__) __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_OREF) |
| Clear the IRDA ORE pending flag. | |
| #define | __HAL_IRDA_CLEAR_IDLEFLAG(__HANDLE__) __HAL_IRDA_CLEAR_FLAG((__HANDLE__), IRDA_CLEAR_IDLEF) |
| Clear the IRDA IDLE pending flag. | |
| #define | __HAL_IRDA_GET_FLAG(__HANDLE__, __FLAG__) (((__HANDLE__)->Instance->ISR & (__FLAG__)) == (__FLAG__)) |
| Check whether the specified IRDA flag is set or not. | |
| #define | __HAL_IRDA_ENABLE_IT(__HANDLE__, __INTERRUPT__) |
| Enable the specified IRDA interrupt. | |
| #define | __HAL_IRDA_DISABLE_IT(__HANDLE__, __INTERRUPT__) |
| Disable the specified IRDA interrupt. | |
| #define | __HAL_IRDA_GET_IT(__HANDLE__, __INTERRUPT__) ((((__HANDLE__)->Instance->ISR& (0x01U << (((__INTERRUPT__) & IRDA_ISR_MASK)>>IRDA_ISR_POS))) != 0U) ? SET : RESET) |
| Check whether the specified IRDA interrupt has occurred or not. | |
| #define | __HAL_IRDA_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
| Check whether the specified IRDA interrupt source is enabled or not. | |
| #define | __HAL_IRDA_CLEAR_IT(__HANDLE__, __IT_CLEAR__) ((__HANDLE__)->Instance->ICR = (uint32_t)(__IT_CLEAR__)) |
| Clear the specified IRDA ISR flag, in setting the proper ICR register flag. | |
| #define | __HAL_IRDA_SEND_REQ(__HANDLE__, __REQ__) ((__HANDLE__)->Instance->RQR |= (uint16_t)(__REQ__)) |
| Set a specific IRDA request flag. | |
| #define | __HAL_IRDA_ONE_BIT_SAMPLE_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR3|= USART_CR3_ONEBIT) |
| Enable the IRDA one bit sample method. | |
| #define | __HAL_IRDA_ONE_BIT_SAMPLE_DISABLE(__HANDLE__) |
| Disable the IRDA one bit sample method. | |
| #define | __HAL_IRDA_ENABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 |= USART_CR1_UE) |
| Enable UART/USART associated to IRDA Handle. | |
| #define | __HAL_IRDA_DISABLE(__HANDLE__) ((__HANDLE__)->Instance->CR1 &= ~USART_CR1_UE) |
| Disable UART/USART associated to IRDA Handle. | |
| #define | IS_IRDA_BAUDRATE(__BAUDRATE__) ((__BAUDRATE__) < 115201U) |
| Ensure that IRDA Baud rate is less or equal to maximum value. | |
| #define | IS_IRDA_PRESCALER(__PRESCALER__) ((__PRESCALER__) > 0U) |
| Ensure that IRDA prescaler value is strictly larger than 0. | |
| #define | IS_IRDA_PARITY(__PARITY__) |
| Ensure that IRDA frame parity is valid. | |
| #define | IS_IRDA_TX_RX_MODE(__MODE__) |
| Ensure that IRDA communication mode is valid. | |
| #define | IS_IRDA_POWERMODE(__MODE__) |
| Ensure that IRDA power mode is valid. | |
| #define | IS_IRDA_CLOCKPRESCALER(__CLOCKPRESCALER__) |
| Ensure that IRDA clock Prescaler is valid. | |
| #define | IS_IRDA_STATE(__STATE__) |
| Ensure that IRDA state is valid. | |
| #define | IS_IRDA_MODE(__MODE__) |
| Ensure that IRDA associated UART/USART mode is valid. | |
| #define | IS_IRDA_ONE_BIT_SAMPLE(__ONEBIT__) |
| Ensure that IRDA sampling rate is valid. | |
| #define | IS_IRDA_DMA_TX(__DMATX__) |
| Ensure that IRDA DMA TX mode is valid. | |
| #define | IS_IRDA_DMA_RX(__DMARX__) |
| Ensure that IRDA DMA RX mode is valid. | |
| #define | IS_IRDA_REQUEST_PARAMETER(__PARAM__) |
| Ensure that IRDA request is valid. | |
Typedefs | |
| typedef uint32_t | HAL_IRDA_StateTypeDef |
| HAL IRDA State definition. | |
Enumerations | |
| enum | IRDA_ClockSourceTypeDef { IRDA_CLOCKSOURCE_D2PCLK1 = 0x11U , IRDA_CLOCKSOURCE_D2PCLK2 = 0x12U , IRDA_CLOCKSOURCE_PLL2Q = 0x14U , IRDA_CLOCKSOURCE_PLL3Q = 0x18U , IRDA_CLOCKSOURCE_HSI = 0x02U , IRDA_CLOCKSOURCE_CSI = 0x08U , IRDA_CLOCKSOURCE_LSE = 0x10U , IRDA_CLOCKSOURCE_UNDEFINED = 0x20U } |
| IRDA clock sources definition. More... | |
| HAL_StatusTypeDef | HAL_IRDA_Init (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_DeInit (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_MspInit (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_MspDeInit (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_Transmit (IRDA_HandleTypeDef *hirda, const uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_IRDA_Receive (IRDA_HandleTypeDef *hirda, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
| HAL_StatusTypeDef | HAL_IRDA_Transmit_IT (IRDA_HandleTypeDef *hirda, const uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_IRDA_Receive_IT (IRDA_HandleTypeDef *hirda, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_IRDA_Transmit_DMA (IRDA_HandleTypeDef *hirda, const uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_IRDA_Receive_DMA (IRDA_HandleTypeDef *hirda, uint8_t *pData, uint16_t Size) |
| HAL_StatusTypeDef | HAL_IRDA_DMAPause (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_DMAResume (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_DMAStop (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_Abort (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_AbortTransmit (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_AbortReceive (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_Abort_IT (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_AbortTransmit_IT (IRDA_HandleTypeDef *hirda) |
| HAL_StatusTypeDef | HAL_IRDA_AbortReceive_IT (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_IRQHandler (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_TxCpltCallback (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_RxCpltCallback (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_TxHalfCpltCallback (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_RxHalfCpltCallback (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_ErrorCallback (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_AbortCpltCallback (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_AbortTransmitCpltCallback (IRDA_HandleTypeDef *hirda) |
| void | HAL_IRDA_AbortReceiveCpltCallback (IRDA_HandleTypeDef *hirda) |
| HAL_IRDA_StateTypeDef | HAL_IRDA_GetState (const IRDA_HandleTypeDef *hirda) |
| uint32_t | HAL_IRDA_GetError (const IRDA_HandleTypeDef *hirda) |
