RTEMS 6.1
CORTEX HAL module driver. This file provides firmware functions to manage the following functionalities of the CORTEX: More...
#include "stm32h7xx_hal.h"CORTEX HAL module driver. This file provides firmware functions to manage the following functionalities of the CORTEX:
##### How to use this driver #####
*** How to configure Interrupts using CORTEX HAL driver ***
This section provides functions allowing to configure the NVIC interrupts (IRQ).
The Cortex-M exceptions are managed by CMSIS functions.
(#) Configure the NVIC Priority Grouping using HAL_NVIC_SetPriorityGrouping()
function according to the following table.
(#) Configure the priority of the selected IRQ Channels using HAL_NVIC_SetPriority().
(#) Enable the selected IRQ Channels using HAL_NVIC_EnableIRQ().
(#) please refer to programming manual for details in how to configure priority.
-@- When the NVIC_PRIORITYGROUP_0 is selected, IRQ preemption is no more possible.
The pending IRQ priority will be managed only by the sub priority.
-@- IRQ priority order (sorted by highest to lowest priority):
(+@) Lowest preemption priority
(+@) Lowest sub priority
(+@) Lowest hardware priority (IRQ number)
*** How to configure Systick using CORTEX HAL driver ***
Setup SysTick Timer for time base.
(+) The HAL_SYSTICK_Config() function calls the SysTick_Config() function which
is a CMSIS function that:
(++) Configures the SysTick Reload register with value passed as function parameter.
(++) Configures the SysTick IRQ priority to the lowest value (0x0F).
(++) Resets the SysTick Counter register.
(++) Configures the SysTick Counter clock source to be Core Clock Source (HCLK).
(++) Enables the SysTick Interrupt.
(++) Starts the SysTick Counter.
(+) You can change the SysTick Clock source to be HCLK_Div8 by calling the macro
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK_DIV8) just after the
HAL_SYSTICK_Config() function call. The HAL_SYSTICK_CLKSourceConfig() macro is defined
inside the stm32h7xx_hal_cortex.h file.
(+) You can change the SysTick IRQ priority by calling the
HAL_NVIC_SetPriority(SysTick_IRQn,...) function just after the HAL_SYSTICK_Config() function
call. The HAL_NVIC_SetPriority() call the NVIC_SetPriority() function which is a CMSIS function.
(+) To adjust the SysTick time base, use the following formula:
Reload Value = SysTick Counter Clock (Hz) x Desired Time base (s)
(++) Reload Value is the parameter to be passed for HAL_SYSTICK_Config() function
(++) Reload Value should not exceed 0xFFFFFFCopyright (c) 2017 STMicroelectronics. All rights reserved.
