RTEMS 6.1
stm32h7xx_hal_cordic.c File Reference
CORDIC HAL module driver. This file provides firmware functions to manage the following functionalities of the CORDIC peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • Peripheral Control functions
  • Callback functions
  • IRQ handler management
  • Peripheral State functions
Attention
          ##### How to use this driver #####
    The CORDIC HAL driver can be used as follows:
    (#) Initialize the CORDIC low level resources by implementing the HAL_CORDIC_MspInit():
       (++) Enable the CORDIC interface clock using __HAL_RCC_CORDIC_CLK_ENABLE()
       (++) In case of using interrupts (e.g. HAL_CORDIC_Calculate_IT())
           (+++) Configure the CORDIC interrupt priority using HAL_NVIC_SetPriority()
           (+++) Enable the CORDIC IRQ handler using HAL_NVIC_EnableIRQ()
           (+++) In CORDIC IRQ handler, call HAL_CORDIC_IRQHandler()
       (++) In case of using DMA to control data transfer (e.g. HAL_CORDIC_Calculate_DMA())
           (+++) Enable the DMA2 interface clock using
               __HAL_RCC_DMA2_CLK_ENABLE()
           (+++) Configure and enable two DMA channels one for managing data transfer from
               memory to peripheral (input channel) and another channel for managing data
               transfer from peripheral to memory (output channel)
           (+++) Associate the initialized DMA handle to the CORDIC DMA handle
               using __HAL_LINKDMA()
           (+++) Configure the priority and enable the NVIC for the transfer complete
               interrupt on the two DMA channels.
               Resort to HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ()
    (#) Initialize the CORDIC HAL using HAL_CORDIC_Init(). This function
       (++) resorts to HAL_CORDIC_MspInit() for low-level initialization,
    (#) Configure CORDIC processing (calculation) using HAL_CORDIC_Configure().
        This function configures:
       (++) Processing functions: Cosine, Sine, Phase, Modulus, Arctangent,
            Hyperbolic cosine, Hyperbolic sine, Hyperbolic arctangent,
            Natural log, Square root
       (++) Scaling factor: 1 to 2exp(-7)
       (++) Width of input data: 32 bits input data size (Q1.31 format) or 16 bits
            input data size (Q1.15 format)
       (++) Width of output data: 32 bits output data size (Q1.31 format) or 16 bits
            output data size (Q1.15 format)
       (++) Number of 32-bit write expected for one calculation: One 32-bits write
            or Two 32-bit write
       (++) Number of 32-bit read expected after one calculation: One 32-bits read
            or Two 32-bit read
       (++) Precision: 1 to 15 cycles for calculation (the more cycles, the better precision)
    (#) Four processing (calculation) functions are available:
       (++) Polling mode: processing API is blocking function
            i.e. it processes the data and wait till the processing is finished
            API is HAL_CORDIC_Calculate
       (++) Polling Zero-overhead mode: processing API is blocking function
            A bit faster than standard polling mode, but blocking also AHB bus
            API is HAL_CORDIC_CalculateZO
       (++) Interrupt mode: processing API is not blocking functions
            i.e. it processes the data under interrupt
            API is HAL_CORDIC_Calculate_IT
       (++) DMA mode: processing API is not blocking functions and the CPU is
            not used for data transfer,
            i.e. the data transfer is ensured by DMA
            API is HAL_CORDIC_Calculate_DMA
    (#) Call HAL_CORDIC_DeInit() to de-initialize the CORDIC peripheral. This function
       (++) resorts to HAL_CORDIC_MspDeInit() for low-level de-initialization,
*** Callback registration ***
The compilation define  USE_HAL_CORDIC_REGISTER_CALLBACKS when set to 1
allows the user to configure dynamically the driver callbacks.
Use Function HAL_CORDIC_RegisterCallback() to register an interrupt callback.
Function HAL_CORDIC_RegisterCallback() allows to register following callbacks:
  (+) ErrorCallback             : Error Callback.
  (+) CalculateCpltCallback     : Calculate complete Callback.
  (+) MspInitCallback           : CORDIC MspInit.
  (+) MspDeInitCallback         : CORDIC MspDeInit.
This function takes as parameters the HAL peripheral handle, the Callback ID
and a pointer to the user callback function.
Use function HAL_CORDIC_UnRegisterCallback() to reset a callback to the default
weak function.
HAL_CORDIC_UnRegisterCallback takes as parameters the HAL peripheral handle,
and the Callback ID.
This function allows to reset following callbacks:
By default, after the HAL_CORDIC_Init() and when the state is HAL_CORDIC_STATE_RESET,
all callbacks are set to the corresponding weak functions:
examples HAL_CORDIC_ErrorCallback(), HAL_CORDIC_CalculateCpltCallback().
Exception done for MspInit and MspDeInit functions that are
reset to the legacy weak function in the HAL_CORDIC_Init()/ HAL_CORDIC_DeInit() only when
these callbacks are null (not registered beforehand).
if not, MspInit or MspDeInit are not null, the HAL_CORDIC_Init()/ HAL_CORDIC_DeInit()
keep and use the user MspInit/MspDeInit callbacks (registered beforehand)
Callbacks can be registered/unregistered in HAL_CORDIC_STATE_READY state only.
Exception done MspInit/MspDeInit that can be registered/unregistered
in HAL_CORDIC_STATE_READY or HAL_CORDIC_STATE_RESET state,
thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit.
In that case first register the MspInit/MspDeInit user callbacks
using HAL_CORDIC_RegisterCallback() before calling HAL_CORDIC_DeInit()
or HAL_CORDIC_Init() function.
When The compilation define USE_HAL_CORDIC_REGISTER_CALLBACKS is set to 0 or
not defined, the callback registration feature is not available and all callbacks
are set to the corresponding weak functions.
