#define | BSP_ERROR_NONE 0 |
#define | BSP_ERROR_NO_INIT -1 |
#define | BSP_ERROR_WRONG_PARAM -2 |
#define | BSP_ERROR_BUSY -3 |
#define | BSP_ERROR_PERIPH_FAILURE -4 |
#define | BSP_ERROR_COMPONENT_FAILURE -5 |
#define | BSP_ERROR_UNKNOWN_FAILURE -6 |
#define | BSP_ERROR_UNKNOWN_COMPONENT -7 |
#define | BSP_ERROR_BUS_FAILURE -8 |
#define | BSP_ERROR_CLOCK_FAILURE -9 |
#define | BSP_ERROR_MSP_FAILURE -10 |
#define | BSP_ERROR_FEATURE_NOT_SUPPORTED -11 |
#define | BSP_ERROR_QSPI_ASSIGN_FAILURE -24 |
#define | BSP_ERROR_QSPI_SETUP_FAILURE -25 |
#define | BSP_ERROR_QSPI_MMP_LOCK_FAILURE -26 |
#define | BSP_ERROR_QSPI_MMP_UNLOCK_FAILURE -27 |
#define | BSP_ERROR_TS_TOUCH_NOT_DETECTED -30 |
#define | BSP_ERROR_BUS_TRANSACTION_FAILURE -100 |
#define | BSP_ERROR_BUS_ARBITRATION_LOSS -101 |
#define | BSP_ERROR_BUS_ACKNOWLEDGE_FAILURE -102 |
#define | BSP_ERROR_BUS_PROTOCOL_FAILURE -103 |
#define | BSP_ERROR_BUS_MODE_FAULT -104 |
#define | BSP_ERROR_BUS_FRAME_ERROR -105 |
#define | BSP_ERROR_BUS_CRC_ERROR -106 |
#define | BSP_ERROR_BUS_DMA_FAILURE -107 |
Error Code.
- Author
- MCD Application Team
- Attention
Copyright (c) 2019 STMicroelectronics. All rights reserved.
