RTEMS 6.1
stm32h747i_eval_conf.h
1/* SPDX-License-Identifier: BSD-3-Clause */
19/*
20 * RTEMS committer clarification comment on license above:
21 *
22 * This file comes from STM32CubeH7 project and is located here:
23 * https://github.com/STMicroelectronics/STM32CubeH7/blob/master/Drivers/BSP/STM32H747I-EVAL/stm32h747i_eval_conf_template.h
24 *
25 * The file root directory is:
26 * https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Drivers/BSP/STM32H747I-EVAL
27 *
28 * This directory contains LICENSE.md file with a following license text:
29 *
30 * Copyright 2019 STMicroelectronics.
31 * All rights reserved.
32 *
33 * Redistribution and use in source and binary forms, with or without modification,
34 * are permitted provided that the following conditions are met:
35 *
36 * 1. Redistributions of source code must retain the above copyright notice, this
37 * list of conditions and the following disclaimer.
38 *
39 * 2. Redistributions in binary form must reproduce the above copyright notice,
40 * this list of conditions and the following disclaimer in the documentation and/or
41 * other materials provided with the distribution.
42 *
43 * 3. Neither the name of the copyright holder nor the names of its contributors
44 * may be used to endorse or promote products derived from this software without
45 * specific prior written permission.
46 *
47 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
48 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
49 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
51 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
52 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
53 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
54 * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
55 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
56 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
57 */
58
59/* Define to prevent recursive inclusion -------------------------------------*/
60#ifndef STM32H747I_EVAL_CONFIG_H
61#define STM32H747I_EVAL_CONFIG_H
62
63#ifdef __cplusplus
64 extern "C" {
65#endif
66
67/* Includes ------------------------------------------------------------------*/
68#include "stm32h7xx_hal.h"
69
70 /* COM define */
71#define USE_COM_LOG 0U
72
73 /* IO class usage define */
74#define USE_BSP_IO_CLASS 1U
75
76 /* JOY usage define */
77#define USE_BSP_JOY_FEATURE 1U
78
79 /* POT usage define */
80#define USE_BSP_POT_FEATURE 1U
81
82 /* LCD controllers defines */
83#define USE_LCD_CTRL_OTM8009A 1U
84#define USE_LCD_CTRL_ADV7533 1U
85#define LCD_LAYER_0_ADDRESS 0xD0000000U
86#define LCD_LAYER_1_ADDRESS 0xD0200000U
87
88 /* SD high performance usage define */
89#define USE_SD_HIGH_PERFORMANCE 0U
90
91 /*DMA2D to fill RGB rectangle usage define*/
92#define USE_DMA2D_TO_FILL_RGB_RECT 0U
93
94 /* Audio codecs defines */
95#define USE_AUDIO_CODEC_WM8994 1U
96#define USE_AUDIO_CODEC_ADV7533 1U
97
98 /* Default Audio IN internal buffer size */
99#define DEFAULT_AUDIO_IN_BUFFER_SIZE 256U
100
101/* TS supported features defines */
102#define USE_TS_GESTURE 1U
103#define USE_TS_MULTI_TOUCH 1U
104
105/* Default TS touch number */
106#define TS_TOUCH_NBR 2U
107
108/* Default EEPROM max trials */
109#define EEPROM_MAX_TRIALS 3000U
110
111/* IRQ priorities */
112#define BSP_SRAM_IT_PRIORITY 15U
113#define BSP_SDRAM_IT_PRIORITY 15U
114#define BSP_IOEXPANDER_IT_PRIORITY 15U
115#define BSP_BUTTON_USER_IT_PRIORITY 15U
116#define BSP_BUTTON_WAKEUP_IT_PRIORITY 15U
117#define BSP_BUTTON_TAMPER_IT_PRIORITY 15U
118#define BSP_AUDIO_OUT_IT_PRIORITY 14U
119#define BSP_AUDIO_IN_IT_PRIORITY 15U
120#define BSP_SD_IT_PRIORITY 14U
121#define BSP_SD_RX_IT_PRIORITY 14U
122#define BSP_SD_TX_IT_PRIORITY 15U
123#define BSP_TS_IT_PRIORITY 15U
124
125#ifdef __cplusplus
126}
127#endif
128
129#endif /* STM32H747I_EVAL_CONFIG_H */
130
This file contains all the functions prototypes for the HAL module driver.
