RTEMS 6.1
CMSIS Cortex-Mx Device Peripheral Access Layer System Source File. More...
| #define | HSE_VALUE ((uint32_t)25000000) |
| #define | CSI_VALUE ((uint32_t)4000000) |
| #define | HSI_VALUE ((uint32_t)64000000) |
| #define | VECT_TAB_OFFSET 0x00000000UL |
| void | SystemInit (void) |
| Setup the microcontroller system Initialize the FPU setting and vector table location configuration. | |
| void | SystemCoreClockUpdate (void) |
| Update SystemCoreClock variable according to Clock Register Values. The SystemCoreClock variable contains the core clock , it can be used by the user application to setup the SysTick timer or configure other parameters. | |
| uint32_t | SystemCoreClock = 64000000 |
| System clock frequency (core clock) | |
| uint32_t | SystemD2Clock = 64000000 |
| const uint8_t | D1CorePrescTable [16] = {0, 0, 0, 0, 1, 2, 3, 4, 1, 2, 3, 4, 6, 7, 8, 9} |
This file provides two functions and one global variable to be called from user application:
Copyright (c) 2019 STMicroelectronics. All rights reserved.
