RTEMS 6.1
stackalloc.h
2
11/*
12 * Copyright (C) 2009, 2012 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_SHARED_STACK_ALLOC_H
37#define LIBBSP_SHARED_STACK_ALLOC_H
38
39#include <stddef.h>
40#include <stdint.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
71void bsp_stack_allocate_init(size_t stack_space_size);
72
79void *bsp_stack_allocate(size_t size);
80
84void bsp_stack_free(void *stack);
85
89#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT bsp_stack_allocate_init
90
94#define CONFIGURE_TASK_STACK_ALLOCATOR bsp_stack_allocate
95
99#define CONFIGURE_TASK_STACK_DEALLOCATOR bsp_stack_free
100
103#ifdef __cplusplus
104}
105#endif /* __cplusplus */
106
107#endif /* LIBBSP_SHARED_STACK_ALLOC_H */
Task stack allocator initialization for CONFIGURE_TASK_STACK_ALLOCATOR_INIT.
Definition: stackalloc.c:46
Task stack free function for CONFIGURE_TASK_STACK_DEALLOCATOR.
Definition: stackalloc.c:71
void * bsp_stack_allocate(size_t size)
Task stack allocator for CONFIGURE_TASK_STACK_ALLOCATOR.
Definition: stackalloc.c:56
