RTEMS 6.1
spurious.h
2
9/*
10 * COPYRIGHT (c) 1989-2011.
11 * On-Line Applications Research Corporation (OAR).
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#ifndef _RTEMS_SPURIOUS_H
36#define _RTEMS_SPURIOUS_H
37
38#include <rtems/rtems/types.h> /* rtems_id */
39#include <rtems/io.h> /* rtems_device_driver */
40
41#ifdef __cplusplus
42extern "C" {
43#endif
44
45#define SPURIOUS_DRIVER_TABLE_ENTRY \
46 { Spurious_Initialize, NULL, NULL, NULL, NULL, NULL }
47
48rtems_device_driver Spurious_Initialize(
51 void *,
53 uint32_t *
54);
55
56#ifdef __cplusplus
57}
58#endif
59
60#endif
61/* end of include file */
This header file defines the IO Manager API.
This header file provides types used by the Classic API.
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
