RTEMS 6.1
spinlockimpl.h
2
12/*
13 * COPYRIGHT (c) 1989-2011.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Copyright (c) 2016 embedded brains GmbH & Co. KG
17 *
18 * Redistribution and use in source and binary forms, with or without
19 * modification, are permitted provided that the following conditions
20 * are met:
21 * 1. Redistributions of source code must retain the above copyright
22 * notice, this list of conditions and the following disclaimer.
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in the
25 * documentation and/or other materials provided with the distribution.
26 *
27 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _RTEMS_POSIX_SPINLOCKIMPL_H
41#define _RTEMS_POSIX_SPINLOCKIMPL_H
42
43#include <pthread.h>
44
46
47#if defined(RTEMS_SMP)
48#include <rtems/score/percpu.h>
50#endif
51
52#ifdef __cplusplus
53extern "C" {
54#endif
55
56typedef struct {
57#if defined(RTEMS_SMP)
58 SMP_ticket_lock_Control Lock;
59#else
60 unsigned int reserved[ 2 ];
61#endif
62 ISR_Level interrupt_state;
64
65static inline POSIX_Spinlock_Control *_POSIX_Spinlock_Get(
66 pthread_spinlock_t *lock
67)
68{
69 return (POSIX_Spinlock_Control *) lock;
70}
71
72#ifdef __cplusplus
73}
74#endif
75
76#endif
77/* end of include file */
uint32_t ISR_Level
Definition: isrlevel.h:60
This header file provides the ISR_Level related interfaces of the ISR Handler.
POSIX Threads Private Support.
This header file provides the interfaces of the Per-CPU Information.
This header file provides the interfaces of the SMP Locks related to ticket locks.
Definition: spinlockimpl.h:56
