RTEMS 6.1
spi-gpio.h
2
11/*
12 * Copyright (C) 2024 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _RTEMS_DEV_SPI_SPI_GPIO_H
37#define _RTEMS_DEV_SPI_SPI_GPIO_H
38
39#include <rtems.h>
40#include <stdbool.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
67#define SPI_GPIO_MAX_CS 4
68
75typedef void (spi_gpio_set_pin_fn) (void *arg, bool level);
76
83typedef bool (spi_gpio_get_pin_fn) (void *arg);
84
105 spi_gpio_set_pin_fn *set_cs[SPI_GPIO_MAX_CS];
107 void *set_cs_arg[SPI_GPIO_MAX_CS];
108
114 bool cs_idle[SPI_GPIO_MAX_CS];
115};
116
127 const char *device,
128 const struct spi_gpio_params *params
129 );
130
133#ifdef __cplusplus
134}
135#endif /* __cplusplus */
136
137#endif /* _RTEMS_DEV_SPI_SPI_GPIO_H */
rtems_status_code
Definition: status.h:85
bool() spi_gpio_get_pin_fn(void *arg)
Type of the functions that read pins.
Definition: spi-gpio.h:83
rtems_status_code spi_gpio_init(const char *device, const struct spi_gpio_params *params)
Definition: spi-gpio.c:198
void() spi_gpio_set_pin_fn(void *arg, bool level)
Type of the functions that set pins.
Definition: spi-gpio.h:75
Parameters for the driver.
Definition: spi-gpio.h:91
spi_gpio_set_pin_fn * set_clk
Definition: spi-gpio.h:93
void * set_cs_arg[SPI_GPIO_MAX_CS]
Definition: spi-gpio.h:107
void * set_mosi_arg
Definition: spi-gpio.h:99
spi_gpio_set_pin_fn * set_mosi
Definition: spi-gpio.h:97
void * get_miso_arg
Definition: spi-gpio.h:103
Definition: spi-gpio.h:114
void * set_clk_arg
Definition: spi-gpio.h:95
spi_gpio_set_pin_fn * set_cs[SPI_GPIO_MAX_CS]
Definition: spi-gpio.h:105
spi_gpio_get_pin_fn * get_miso
Definition: spi-gpio.h:101
