RTEMS 6.1
elf_machdep.h
1/* $NetBSD: elf_machdep.h,v 1.7 2009/05/30 05:56:53 skrll Exp $ */
2
3#define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
4#define ELF32_MACHDEP_ID_CASES \
5 case EM_SPARC: \
6 case EM_SPARC32PLUS: \
7 break;
8
9#define ELF64_MACHDEP_ENDIANNESS ELFDATA2MSB
10#define ELF64_MACHDEP_ID_CASES \
11 case EM_SPARC32PLUS: \
12 case EM_SPARCV9: \
13 /* no 64-bit ELF machine types supported */
14
15#define ELF32_MACHDEP_ID EM_SPARC /* XXX right? */
16
17#define ARCH_ELFSIZE 32 /* MD native binary size */
18
19#define R_SPARC_NONE 0
20#define R_SPARC_8 1
21#define R_SPARC_16 2
22#define R_SPARC_32 3
23#define R_SPARC_DISP8 4
24#define R_SPARC_DISP16 5
25#define R_SPARC_DISP32 6
26#define R_SPARC_WDISP30 7
27#define R_SPARC_WDISP22 8
28#define R_SPARC_HI22 9
29#define R_SPARC_22 10
30#define R_SPARC_13 11
31#define R_SPARC_LO10 12
32#define R_SPARC_GOT10 13
33#define R_SPARC_GOT13 14
34#define R_SPARC_GOT22 15
35#define R_SPARC_PC10 16
36#define R_SPARC_PC22 17
37#define R_SPARC_WPLT30 18
38#define R_SPARC_COPY 19
39#define R_SPARC_GLOB_DAT 20
40#define R_SPARC_JMP_SLOT 21
41#define R_SPARC_RELATIVE 22
42#define R_SPARC_UA32 23
43#define R_SPARC_PLT32 24
44#define R_SPARC_HIPLT22 25
45#define R_SPARC_LOPLT10 26
46#define R_SPARC_PCPLT32 27
47#define R_SPARC_PCPLT22 28
48#define R_SPARC_PCPLT10 29
49#define R_SPARC_10 30
50#define R_SPARC_11 31
51#define R_SPARC_64 32
52#define R_SPARC_OLO10 33
53#define R_SPARC_HH22 34
54#define R_SPARC_HM10 35
55#define R_SPARC_LM22 36
56#define R_SPARC_PC_HH22 37
57#define R_SPARC_PC_HM10 38
58#define R_SPARC_PC_LM22 39
59#define R_SPARC_WDISP16 40
60#define R_SPARC_WDISP19 41
61#define R_SPARC_GLOB_JMP 42
62#define R_SPARC_7 43
63#define R_SPARC_5 44
64#define R_SPARC_6 45
65
66/* TLS relocations */
67#define R_SPARC_TLS_GD_HI22 56
68#define R_SPARC_TLS_GD_LO10 57
69#define R_SPARC_TLS_GD_ADD 58
70#define R_SPARC_TLS_GD_CALL 59
71#define R_SPARC_TLS_LDM_HI22 60
72#define R_SPARC_TLS_LDM_LO10 61
73#define R_SPARC_TLS_LDM_ADD 62
74#define R_SPARC_TLS_LDM_CALL 63
75#define R_SPARC_TLS_LDO_HIX22 64
76#define R_SPARC_TLS_LDO_LOX10 65
77#define R_SPARC_TLS_LDO_ADD 66
78#define R_SPARC_TLS_IE_HI22 67
79#define R_SPARC_TLS_IE_LO10 68
80#define R_SPARC_TLS_IE_LD 69
81#define R_SPARC_TLS_IE_LDX 70
82#define R_SPARC_TLS_IE_ADD 71
83#define R_SPARC_TLS_LE_HIX22 72
84#define R_SPARC_TLS_LE_LOX10 73
85#define R_SPARC_TLS_DTPMOD32 74
86#define R_SPARC_TLS_DTPMOD64 75
87#define R_SPARC_TLS_DTPOFF32 76
88#define R_SPARC_TLS_DTPOFF64 77
89#define R_SPARC_TLS_TPOFF32 78
90#define R_SPARC_TLS_TPOFF64 79
91
92#define R_TYPE(name) __CONCAT(R_SPARC_,name)
