RTEMS 6.1
#include <arch/asm.h>#include <arch/barrier.h>#include <arch/types.h>Go to the source code of this file.
| #define | ASI_IMMU 0x50 |
| #define | ASI_IMMU_TSB_8KB_PTR_REG 0x51 |
| #define | ASI_IMMU_TSB_64KB_PTR_REG 0x52 |
| #define | ASI_ITLB_DATA_IN_REG 0x54 |
| #define | ASI_ITLB_DATA_ACCESS_REG 0x55 |
| #define | ASI_ITLB_TAG_READ_REG 0x56 |
| #define | ASI_IMMU_DEMAP 0x57 |
| #define | VA_IMMU_TSB_TAG_TARGET 0x0 |
| #define | VA_IMMU_SFSR 0x18 |
| #define | VA_IMMU_TSB_BASE 0x28 |
| #define | VA_IMMU_TAG_ACCESS 0x30 |
| #define | ASI_DMMU 0x58 |
| #define | ASI_DMMU_TSB_8KB_PTR_REG 0x59 |
| #define | ASI_DMMU_TSB_64KB_PTR_REG 0x5a |
| #define | ASI_DMMU_TSB_DIRECT_PTR_REG 0x5b |
| #define | ASI_DTLB_DATA_IN_REG 0x5c |
| #define | ASI_DTLB_DATA_ACCESS_REG 0x5d |
| #define | ASI_DTLB_TAG_READ_REG 0x5e |
| #define | ASI_DMMU_DEMAP 0x5f |
| #define | VA_DMMU_TSB_TAG_TARGET 0x0 |
| #define | VA_PRIMARY_CONTEXT_REG 0x8 |
| #define | VA_SECONDARY_CONTEXT_REG 0x10 |
| #define | VA_DMMU_SFSR 0x18 |
| #define | VA_DMMU_SFAR 0x20 |
| #define | VA_DMMU_TSB_BASE 0x28 |
| #define | VA_DMMU_TAG_ACCESS 0x30 |
| #define | VA_DMMU_VA_WATCHPOINT_REG 0x38 |
| #define | VA_DMMU_PA_WATCHPOINT_REG 0x40 |
