RTEMS 6.1
signalmp.h
2
12/* COPYRIGHT (c) 1989-2013.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_RTEMS_SIGNALMP_H
38#define _RTEMS_RTEMS_SIGNALMP_H
39
40#ifndef _RTEMS_RTEMS_SIGNALIMPL_H
41# error "Never use <rtems/rtems/signalmp.h> directly; include <rtems/rtems/signalimpl.h> instead."
42#endif
43
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
62/*
63 * @brief Signal_MP_Send_process_packet
64 *
65 * This routine performs a remote procedure call so that a
66 * process operation can be performed on another node.
67 *
68 * This routine is not needed since there are no process
69 * packets to be sent by this manager.
70 */
71
76 rtems_id id,
77 rtems_signal_set signal_set
78);
79
87 rtems_packet_prefix *the_packet_prefix
88);
89
90/*
91 * @brief Signal_MP_Send_object_was_deleted
92 *
93 * This routine is invoked indirectly by the thread queue
94 * when a proxy has been removed from the thread queue and
95 * the remote node must be informed of this.
96 *
97 * This routine is not needed since there are no objects
98 * deleted by this manager.
99 */
100
101/*
102 * @brief Signal_MP_Send_extract_proxy
103 *
104 * This routine is invoked when a task is deleted and it
105 * has a proxy which must be removed from a thread queue and
106 * the remote node must be informed of this.
107 *
108 * This routine is not needed since there are no objects
109 * deleted by this manager.
110 */
111
114#ifdef __cplusplus
115}
116#endif
117
118#endif
119/* end of file */
uint32_t rtems_signal_set
This integer type represents a bit field which can hold exactly 32 individual signals.
Definition: asr.h:87
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
void _Signal_MP_Process_packet(rtems_packet_prefix *the_packet_prefix)
Signal MP Process Packet.
Definition: signalmp.c:150
rtems_status_code _Signal_MP_Send(rtems_id id, rtems_signal_set signal_set)
Issues a remote rtems_signal_send() request.
Definition: signalmp.c:90
This header file provides interfaces of the MPCI Handler which are only used by the implementation.
