RTEMS 6.1
sha512t.h
1/*-
2 * Copyright (c) 2015 Allan Jude <allanjude@FreeBSD.org>
3 * All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 *
14 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24 * SUCH DAMAGE.
25 *
26 * $FreeBSD$
27 */
28
29#ifndef _SHA512T_H_
30#define _SHA512T_H_
31
32#include "sha512.h"
33
34#ifndef _KERNEL
35#include <sys/types.h>
36#endif
37
38#define SHA512_224_DIGEST_LENGTH 28
39#define SHA512_224_DIGEST_STRING_LENGTH (SHA512_224_DIGEST_LENGTH * 2 + 1)
40#define SHA512_256_DIGEST_LENGTH 32
41#define SHA512_256_DIGEST_STRING_LENGTH (SHA512_256_DIGEST_LENGTH * 2 + 1)
42
43__BEGIN_DECLS
44
45void SHA512_224_Init(SHA512_CTX *);
46void SHA512_224_Update(SHA512_CTX *, const void *, size_t);
47void SHA512_224_Final(unsigned char [__min_size(SHA512_224_DIGEST_LENGTH)],
48 SHA512_CTX *);
49#ifndef _KERNEL
50char *SHA512_224_End(SHA512_CTX *, char *);
51char *SHA512_224_Data(const void *, unsigned int, char *);
52char *SHA512_224_File(const char *, char *);
53char *SHA512_224_FileChunk(const char *, char *, off_t, off_t);
54#endif
55void SHA512_256_Init(SHA512_CTX *);
56void SHA512_256_Update(SHA512_CTX *, const void *, size_t);
57void SHA512_256_Final(unsigned char [__min_size(SHA512_256_DIGEST_LENGTH)],
58 SHA512_CTX *);
59#ifndef _KERNEL
60char *SHA512_256_End(SHA512_CTX *, char *);
61char *SHA512_256_Data(const void *, unsigned int, char *);
62char *SHA512_256_File(const char *, char *);
63char *SHA512_256_FileChunk(const char *, char *, off_t, off_t);
64#endif
65
66__END_DECLS
67
68#endif /* !_SHA512T_H_ */
This header file contains interfaces of the SHA512 hash algorithm support.
Definition: sha512.h:40
