RTEMS 6.1
sdma.h
1#ifndef __MGT5200_SDMA_H
2#define __MGT5200_SDMA_H
3
4/******************************************************************************
5*
6* Copyright (c) 2004 Freescale Semiconductor, Inc.
7*
8* Permission is hereby granted, free of charge, to any person obtaining a
9* copy of this software and associated documentation files (the "Software"),
10* to deal in the Software without restriction, including without limitation
11* the rights to use, copy, modify, merge, publish, distribute, sublicense,
12* and/or sell copies of the Software, and to permit persons to whom the
13* Software is furnished to do so, subject to the following conditions:
14*
15* The above copyright notice and this permission notice shall be included
16* in all copies or substantial portions of the Software.
17*
18* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
19* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
20* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
21* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR
22* OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
23* ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
24* OTHER DEALINGS IN THE SOFTWARE.
25*
26******************************************************************************/
27
28typedef struct sdma_register_set {
29 volatile uint32 taskBar; /* MBAR_SDMA + 0x00 sdTpb */
30 volatile uint32 currentPointer; /* MBAR_SDMA + 0x04 sdMdeComplex */
31 volatile uint32 endPointer; /* MBAR_SDMA + 0x08 sdMdeComplex */
32 volatile uint32 variablePointer; /* MBAR_SDMA + 0x0c sdMdeComplex */
33
34 volatile uint8 IntVect1; /* MBAR_SDMA + 0x10 sdPtd */
35 volatile uint8 IntVect2; /* MBAR_SDMA + 0x11 sdPtd */
36 volatile uint16 PtdCntrl; /* MBAR_SDMA + 0x12 sdPtd */
37
38 volatile uint32 IntPend; /* MBAR_SDMA + 0x14 sdPtd */
39 volatile uint32 IntMask; /* MBAR_SDMA + 0x18 sdPtd */
40
41 volatile uint32 TCR01; /* MBAR_SDMA + 0x1c sdPtd */
42 volatile uint32 TCR23; /* MBAR_SDMA + 0x20 sdPtd */
43 volatile uint32 TCR45; /* MBAR_SDMA + 0x24 sdPtd */
44 volatile uint32 TCR67; /* MBAR_SDMA + 0x28 sdPtd */
45 volatile uint32 TCR89; /* MBAR_SDMA + 0x2c sdPtd */
46 volatile uint32 TCRAB; /* MBAR_SDMA + 0x30 sdPtd */
47 volatile uint32 TCRCD; /* MBAR_SDMA + 0x34 sdPtd */
48 volatile uint32 TCREF; /* MBAR_SDMA + 0x38 sdPtd */
49
50 volatile uint8 IPR0; /* MBAR_SDMA + 0x3c sdPtd */
51 volatile uint8 IPR1; /* MBAR_SDMA + 0x3d sdPtd */
52 volatile uint8 IPR2; /* MBAR_SDMA + 0x3e sdPtd */
53 volatile uint8 IPR3; /* MBAR_SDMA + 0x3f sdPtd */
54 volatile uint8 IPR4; /* MBAR_SDMA + 0x40 sdPtd */
55 volatile uint8 IPR5; /* MBAR_SDMA + 0x41 sdPtd */
56 volatile uint8 IPR6; /* MBAR_SDMA + 0x42 sdPtd */
57 volatile uint8 IPR7; /* MBAR_SDMA + 0x43 sdPtd */
58 volatile uint8 IPR8; /* MBAR_SDMA + 0x44 sdPtd */
59 volatile uint8 IPR9; /* MBAR_SDMA + 0x45 sdPtd */
60 volatile uint8 IPR10; /* MBAR_SDMA + 0x46 sdPtd */
61 volatile uint8 IPR11; /* MBAR_SDMA + 0x47 sdPtd */
62 volatile uint8 IPR12; /* MBAR_SDMA + 0x48 sdPtd */
63 volatile uint8 IPR13; /* MBAR_SDMA + 0x49 sdPtd */
64 volatile uint8 IPR14; /* MBAR_SDMA + 0x4a sdPtd */
65 volatile uint8 IPR15; /* MBAR_SDMA + 0x4b sdPtd */
66 volatile uint8 IPR16; /* MBAR_SDMA + 0x4c sdPtd */
67 volatile uint8 IPR17; /* MBAR_SDMA + 0x4d sdPtd */
68 volatile uint8 IPR18; /* MBAR_SDMA + 0x4e sdPtd */
69 volatile uint8 IPR19; /* MBAR_SDMA + 0x4f sdPtd */
70 volatile uint8 IPR20; /* MBAR_SDMA + 0x50 sdPtd */
71 volatile uint8 IPR21; /* MBAR_SDMA + 0x51 sdPtd */
72 volatile uint8 IPR22; /* MBAR_SDMA + 0x52 sdPtd */
73 volatile uint8 IPR23; /* MBAR_SDMA + 0x53 sdPtd */
74 volatile uint8 IPR24; /* MBAR_SDMA + 0x54 sdPtd */
75 volatile uint8 IPR25; /* MBAR_SDMA + 0x55 sdPtd */
76 volatile uint8 IPR26; /* MBAR_SDMA + 0x56 sdPtd */
77 volatile uint8 IPR27; /* MBAR_SDMA + 0x57 sdPtd */
78 volatile uint8 IPR28; /* MBAR_SDMA + 0x58 sdPtd */
79 volatile uint8 IPR29; /* MBAR_SDMA + 0x59 sdPtd */
80 volatile uint8 IPR30; /* MBAR_SDMA + 0x5a sdPtd */
81 volatile uint8 IPR31; /* MBAR_SDMA + 0x5b sdPtd */
82
83 volatile uint32 cReqSelect; /* MBAR_SDMA + 0x5c sdPtd */
84 volatile uint32 taskSize0; /* MBAR_SDMA + 0x60 sdPtd */
85 volatile uint32 taskSize1; /* MBAR_SDMA + 0x64 sdPtd */
86 volatile uint32 MDEDebug; /* MBAR_SDMA + 0x68 sdMdeComplex */
87 volatile uint32 ADSDebug; /* MBAR_SDMA + 0x6c sdAdsTop */
88 volatile uint32 Value1; /* MBAR_SDMA + 0x70 sdDbg */
89 volatile uint32 Value2; /* MBAR_SDMA + 0x74 sdDbg */
90 volatile uint32 Control; /* MBAR_SDMA + 0x78 sdDbg */
91 volatile uint32 Status; /* MBAR_SDMA + 0x7c sdDbg */
92 volatile uint32 PTDDebug; /* MBAR_SDMA + 0x80 sdPtd */
93} sdma_regs;
94
95#define SDMA_PTDCNTRL_TI 0x8000
96#define SDMA_PTDCNTRL_TEA 0x4000
97#define SDMA_PTDCNTRL_HE 0x2000
98#define SDMA_PTDCNTRL_PE 0x0001
99
100#define SDMA_CREQSELECT_REQ31_MASK (~0xC0000000UL)
101#define SDMA_CREQSELECT_REQ30_MASK (~0x30000000UL)
102#define SDMA_CREQSELECT_REQ29_MASK (~0x0C000000UL)
103#define SDMA_CREQSELECT_REQ28_MASK (~0x03000000UL)
104#define SDMA_CREQSELECT_REQ27_MASK (~0x00C00000UL)
105#define SDMA_CREQSELECT_REQ26_MASK (~0x00300000UL)
106#define SDMA_CREQSELECT_REQ25_MASK (~0x000C0000UL)
107#define SDMA_CREQSELECT_REQ24_MASK (~0x00030000UL)
108#define SDMA_CREQSELECT_REQ23_MASK (~0x0000C000UL)
109#define SDMA_CREQSELECT_REQ22_MASK (~0x00003000UL)
110#define SDMA_CREQSELECT_REQ21_MASK (~0x00000C00UL)
111#define SDMA_CREQSELECT_REQ20_MASK (~0x00000300UL)
112#define SDMA_CREQSELECT_REQ19_MASK (~0x000000C0UL)
113#define SDMA_CREQSELECT_REQ18_MASK (~0x00000030UL)
114#define SDMA_CREQSELECT_REQ17_MASK (~0x0000000CUL)
115#define SDMA_CREQSELECT_REQ16_MASK (~0x00000003UL)
116
117#define SDMA_CREQSELECT_REQ31_ALWAYS31 0xC0000000UL
118#define SDMA_CREQSELECT_REQ30_ALWAYS30 0x30000000UL
119#define SDMA_CREQSELECT_REQ29_ALWAYS29 0x0C000000UL
120#define SDMA_CREQSELECT_REQ28_ALWAYS28 0x03000000UL
121#define SDMA_CREQSELECT_REQ27_ALWAYS27 0x00C00000UL
122#define SDMA_CREQSELECT_REQ26_ALWAYS26 0x00300000UL
123#define SDMA_CREQSELECT_REQ25_ALWAYS25 0x000C0000UL
124#define SDMA_CREQSELECT_REQ24_ALWAYS24 0x00030000UL
125#define SDMA_CREQSELECT_REQ23_ALWAYS23 0x0000C000UL
126#define SDMA_CREQSELECT_REQ22_ALWAYS22 0x00003000UL
127#define SDMA_CREQSELECT_REQ21_ALWAYS21 0x00000C00UL
128#define SDMA_CREQSELECT_REQ20_ALWAYS20 0x00000300UL
129#define SDMA_CREQSELECT_REQ19_ALWAYS19 0x000000C0UL
130#define SDMA_CREQSELECT_REQ18_ALWAYS18 0x00000030UL
131#define SDMA_CREQSELECT_REQ17_ALWAYS17 0x0000000CUL
132#define SDMA_CREQSELECT_REQ16_ALWAYS16 0x00000003UL
133
134#define SDMA_CREQSELECT_REQ31_SCTIMER7 0x00000000UL
135#define SDMA_CREQSELECT_REQ30_SCTIMER6 0x00000000UL
136#define SDMA_CREQSELECT_REQ29_SCTIMER5 0x00000000UL
137#define SDMA_CREQSELECT_REQ28_SCTIMER4 0x00000000UL
138#define SDMA_CREQSELECT_REQ27_SCTIMER3 0x00000000UL
139#define SDMA_CREQSELECT_REQ26_PSC6_TX 0x00000000UL
140#define SDMA_CREQSELECT_REQ25_PSC6_RX 0x00000000UL
141#define SDMA_CREQSELECT_REQ24_I2C1_TX 0x00000000UL
142#define SDMA_CREQSELECT_REQ23_I2C1_RX 0x00000000UL
143#define SDMA_CREQSELECT_REQ22_I2C2_TX 0x00000000UL
144#define SDMA_CREQSELECT_REQ21_I2C2_RX 0x00000000UL
145#define SDMA_CREQSELECT_REQ20_PSC4_TX 0x00000000UL
146#define SDMA_CREQSELECT_REQ19_PSC4_RX 0x00000000UL
147#define SDMA_CREQSELECT_REQ18_PSC5_TX 0x00000000UL
148#define SDMA_CREQSELECT_REQ17_PSC5_RX 0x00000000UL
149#define SDMA_CREQSELECT_REQ16_LP 0x00000000UL
150
151#define SDMA_CREQSELECT_ALWAYS30 0xC0000000UL
152
153#endif /* __MGT5200_SDMA_H */
Definition: sdma.h:28
