RTEMS 6.1
Macros | Functions
timespec.h File Reference
This header file provides the interfaces of the Timespec Helpers. More...
#include <stdbool.h>
#include <stdint.h>
#include <time.h>
#define _Timespec_Set(_time, _seconds, _nanoseconds)
 Set timespec to seconds nanosecond.
#define _Timespec_Set_to_zero(_time)
 Sets the Timespec to Zero.
#define _Timespec_Get_seconds(_time)    ((_time)->tv_sec)
 Get seconds portion of timespec.
#define _Timespec_Get_nanoseconds(_time)    ((_time)->tv_nsec)
 Get nanoseconds portion of timespec.
#define _Timespec_Greater_than(_lhs, _rhs)    _Timespec_Less_than( _rhs, _lhs )
 The Timespec "greater than" operator.
#define _Timespec_Equal_to(lhs, rhs)
 The Timespec "equal to" operator.
uint64_t _Timespec_Get_as_nanoseconds (const struct timespec *time)
 Gets the timestamp as nanoseconds.
bool _Timespec_Is_non_negative (const struct timespec *time)
 Checks if the values in time are non-negative.
bool _Timespec_Is_valid (const struct timespec *time)
 Checks if timespec is valid.
bool _Timespec_Less_than (const struct timespec *lhs, const struct timespec *rhs)
 Checks if the left hand side timespec is less than the right one.
time_t _Timespec_Add_to (struct timespec *time, const struct timespec *add)
 Adds two timespecs.
uint32_t _Timespec_To_ticks (const struct timespec *time)
 Converts timespec to number of ticks.
void _Timespec_From_ticks (uint32_t ticks, struct timespec *time)
 Converts ticks to timespec.
void _Timespec_Subtract (const struct timespec *start, const struct timespec *end, struct timespec *result)
 Subtracts two timespec.
void _Timespec_Divide_by_integer (const struct timespec *time, uint32_t iterations, struct timespec *result)
 Divides timespec by an integer.
void _Timespec_Divide (const struct timespec *lhs, const struct timespec *rhs, uint32_t *ival_percentage, uint32_t *fval_percentage)
 Divides a timespec by another timespec.
