RTEMS 6.1
This header file provides interfaces of the Timecounter Handler which are used by the implementation and the API. More...
#include <sys/time.h>#include <sys/timetc.h>#include <machine/_timecounter.h>#include <rtems/score/isrlock.h>Go to the source code of this file.
| #define | _Timecounter_Acquire(lock_context) _ISR_lock_ISR_disable_and_acquire( &_Timecounter_Lock, lock_context ) |
| Acquires the timecounter lock. | |
| #define | _Timecounter_Release(lock_context) _ISR_lock_Release_and_ISR_enable(&_Timecounter_Lock, lock_context) |
| Releases the timecounter lock. | |
Typedefs | |
| typedef void(* | Timecounter_NTP_update_second) (int64_t *adjustment, time_t *newsec) |
| Handler doing the NTP update second processing shall have this type. | |
| void | _Timecounter_Bintime (struct bintime *bt) |
| Returns the wall clock time in the bintime format. | |
| void | _Timecounter_Nanotime (struct timespec *ts) |
| Returns the wall clock time in the timespec format. | |
| void | _Timecounter_Microtime (struct timeval *tv) |
| Returns the wall clock time in the timeval format. | |
| void | _Timecounter_Binuptime (struct bintime *bt) |
| Returns the uptime in the bintime format. | |
| int64_t | _Timecounter_Sbinuptime (void) |
| Returns the uptime in the sbintime_t format. | |
| void | _Timecounter_Nanouptime (struct timespec *ts) |
| Returns the uptime in the timespec format. | |
| void | _Timecounter_Microuptime (struct timeval *tv) |
| Returns the uptime in the timeval format. | |
| void | _Timecounter_Getbintime (struct bintime *bt) |
| void | _Timecounter_Getnanotime (struct timespec *ts) |
| void | _Timecounter_Getmicrotime (struct timeval *tv) |
| void | _Timecounter_Getbinuptime (struct bintime *bt) |
| void | _Timecounter_Getnanouptime (struct timespec *ts) |
| void | _Timecounter_Getmicrouptime (struct timeval *tv) |
| void | _Timecounter_Getboottime (struct timeval *tv) |
| Returns the boot time in the timeval format. | |
| void | _Timecounter_Getboottimebin (struct bintime *bt) |
| Returns the boot time in the bintime format. | |
| void | _Timecounter_Install (struct timecounter *tc) |
| Installs the timecounter. | |
| void | _Timecounter_Tick (void) |
| Performs a timecounter tick. | |
| void | _Timecounter_Tick_simple (uint32_t delta, uint32_t offset, ISR_lock_Context *lock_context) |
| Performs a simple timecounter tick. | |
| void | _Timecounter_Set_NTP_update_second (Timecounter_NTP_update_second handler) |
| Sets the NTP update second handler. | |
| void | _Timecounter_NTP_update_second (int64_t *adjustment, time_t *newsec) |
| Updates the time adjustment and seconds according to the NTP state. | |
| uint64_t | _Timecounter_Get_frequency (void) |
| Gets the frequency in Hz of the current timecounter at some time point during the call. | |
| void | _Timecounter_Discipline (struct timespec *tsp, long nsec) |
| Updates the timecounter frequency adjustment used by _Timecounter_Set_NTP_update_second(). | |
| volatile time_t | _Timecounter_Time_second |
| The wall clock time in seconds. | |
| volatile int32_t | _Timecounter_Time_uptime |
| The uptime in seconds. | |
| struct timecounter * | _Timecounter |
| The current timecounter. | |
