RTEMS 6.1
status.h
2
12/*
13 * Copyright (c) 2016 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_SCORE_STATUS_H
38#define _RTEMS_SCORE_STATUS_H
39
41
42#include <errno.h>
43#include <pthread.h>
44
45#ifdef __cplusplus
46extern "C" {
47#endif /* __cplusplus */
48
64typedef enum {
65 STATUS_CLASSIC_INCORRECT_STATE = 14,
66 STATUS_CLASSIC_INTERNAL_ERROR = 25,
67 STATUS_CLASSIC_INVALID_ADDRESS = 9,
68 STATUS_CLASSIC_INVALID_ID = 4,
69 STATUS_CLASSIC_INVALID_NAME = 3,
70 STATUS_CLASSIC_INVALID_NODE = 21,
71 STATUS_CLASSIC_INVALID_NUMBER = 10,
72 STATUS_CLASSIC_INVALID_PRIORITY = 19,
73 STATUS_CLASSIC_INVALID_SIZE = 8,
74 STATUS_CLASSIC_NO_MEMORY = 26,
75 STATUS_CLASSIC_NOT_DEFINED = 11,
76 STATUS_CLASSIC_NOT_OWNER_OF_RESOURCE = 23,
77 STATUS_CLASSIC_OBJECT_WAS_DELETED = 7,
78 STATUS_CLASSIC_PROXY_BLOCKING = 29,
79 STATUS_CLASSIC_RESOURCE_IN_USE = 12,
80 STATUS_CLASSIC_SUCCESSFUL = 0,
81 STATUS_CLASSIC_TIMEOUT = 6,
82 STATUS_CLASSIC_TOO_MANY = 5,
83 STATUS_CLASSIC_UNSATISFIED = 13
85
91#define STATUS_BUILD( classic_status, posix_status ) \
92 ( ( ( posix_status ) * 256 ) | ( classic_status ) )
93
97#define STATUS_GET_CLASSIC( status ) \
98 ( ( status ) & 0xff )
99
105#define STATUS_GET_POSIX( status ) \
106 ( ( status ) / 256 )
107
111typedef enum {
112 STATUS_BARRIER_AUTOMATICALLY_RELEASED =
113 STATUS_BUILD( STATUS_CLASSIC_SUCCESSFUL, PTHREAD_BARRIER_SERIAL_THREAD ),
114 STATUS_DEADLOCK =
115 STATUS_BUILD( STATUS_CLASSIC_INCORRECT_STATE, EDEADLK ),
116 STATUS_FLUSHED =
117 STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, EAGAIN ),
118 STATUS_INCORRECT_STATE =
119 STATUS_BUILD( STATUS_CLASSIC_INCORRECT_STATE, EINVAL ),
120 STATUS_INTERRUPTED =
121 STATUS_BUILD( STATUS_CLASSIC_INTERNAL_ERROR, EINTR ),
122 STATUS_INTERNAL_ERROR =
123 STATUS_BUILD( STATUS_CLASSIC_INTERNAL_ERROR, ENOTSUP ),
124 STATUS_INVALID_ADDRESS =
125 STATUS_BUILD( STATUS_CLASSIC_INVALID_ADDRESS, EFAULT ),
126 STATUS_INVALID_ID =
127 STATUS_BUILD( STATUS_CLASSIC_INVALID_ID, EINVAL ),
128 STATUS_INVALID_NODE =
129 STATUS_BUILD( STATUS_CLASSIC_INVALID_NODE, EINVAL ),
130 STATUS_INVALID_NAME =
131 STATUS_BUILD( STATUS_CLASSIC_INVALID_NAME, EINVAL ),
132 STATUS_INVALID_NUMBER =
133 STATUS_BUILD( STATUS_CLASSIC_INVALID_NUMBER, EINVAL ),
134 STATUS_INVALID_PRIORITY =
135 STATUS_BUILD( STATUS_CLASSIC_INVALID_PRIORITY, EINVAL ),
136 STATUS_INVALID_SIZE =
137 STATUS_BUILD( STATUS_CLASSIC_INVALID_SIZE, EINVAL ),
138 STATUS_MAXIMUM_COUNT_EXCEEDED =
139 STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, EOVERFLOW ),
140 STATUS_MESSAGE_INVALID_SIZE =
141 STATUS_BUILD( STATUS_CLASSIC_INVALID_SIZE, EMSGSIZE ),
142 STATUS_MESSAGE_QUEUE_INVALID_NUMBER =
143 STATUS_BUILD( STATUS_CLASSIC_INVALID_NUMBER, ENOSPC ),
144 STATUS_MESSAGE_QUEUE_INVALID_SIZE =
145 STATUS_BUILD( STATUS_CLASSIC_INVALID_SIZE, ENOSPC ),
146 STATUS_MESSAGE_QUEUE_NO_MEMORY =
147 STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, ENOSPC ),
148 STATUS_MESSAGE_QUEUE_WAIT_IN_ISR =
149 STATUS_BUILD( STATUS_CLASSIC_INTERNAL_ERROR, EAGAIN ),
150 STATUS_MESSAGE_QUEUE_WAS_DELETED =
151 STATUS_BUILD( STATUS_CLASSIC_OBJECT_WAS_DELETED, EBADF ),
152 STATUS_MINUS_ONE =
153 -1,
154 STATUS_MUTEX_CEILING_VIOLATED =
155 STATUS_BUILD( STATUS_CLASSIC_INVALID_PRIORITY, EINVAL ),
156 STATUS_NESTING_NOT_ALLOWED =
157 STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, EDEADLK ),
158 STATUS_NO_MEMORY =
159 STATUS_BUILD( STATUS_CLASSIC_NO_MEMORY, EINVAL ),
160 STATUS_NOT_DEFINED =
161 STATUS_BUILD( STATUS_CLASSIC_NOT_DEFINED, EINVAL ),
162 STATUS_NOT_OWNER =
163 STATUS_BUILD( STATUS_CLASSIC_NOT_OWNER_OF_RESOURCE, EPERM ),
164 STATUS_OBJECT_WAS_DELETED =
165 STATUS_BUILD( STATUS_CLASSIC_OBJECT_WAS_DELETED, EINVAL ),
166 STATUS_PROXY_BLOCKING =
167 STATUS_BUILD( STATUS_CLASSIC_PROXY_BLOCKING, EINVAL ),
168 STATUS_RESOURCE_IN_USE =
169 STATUS_BUILD( STATUS_CLASSIC_RESOURCE_IN_USE, EBUSY ),
170 STATUS_RESULT_TOO_LARGE =
171 STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, ERANGE ),
172 STATUS_SUCCESSFUL =
173 STATUS_BUILD( STATUS_CLASSIC_SUCCESSFUL, 0 ),
174 STATUS_TIMEOUT =
175 STATUS_BUILD( STATUS_CLASSIC_TIMEOUT, ETIMEDOUT ),
176 STATUS_TOO_MANY =
177 STATUS_BUILD( STATUS_CLASSIC_TOO_MANY, EAGAIN ),
178 STATUS_UNAVAILABLE =
179 STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, EBUSY ),
180 STATUS_UNSATISFIED =
181 STATUS_BUILD( STATUS_CLASSIC_UNSATISFIED, EAGAIN )
183
186#ifdef __cplusplus
187}
188#endif /* __cplusplus */
189
190#endif /* _RTEMS_SCORE_STATUS_H */
This header file provides basic definitions used by the API and the implementation.
#define STATUS_BUILD(classic_status, posix_status)
Macro to build a status code from Classic and POSIX API parts.
Definition: status.h:91
Status_Control
Status codes.
Definition: status.h:111
Status_Classic
Status code parts for the Classic API.
Definition: status.h:64
POSIX Threads Private Support.
