RTEMS 6.1
Typedefs | Enumerations
priorityimpl.h File Reference
This header file provides interfaces of the Priority Handler which are only used by the implementation. More...
#include <rtems/score/priority.h>
typedef void(* Priority_Add_handler) (Priority_Aggregation *aggregation, Priority_Actions *actions, void *arg)
typedef void(* Priority_Change_handler) (Priority_Aggregation *aggregation, Priority_Group_order group_order, Priority_Actions *actions, void *arg)
typedef void(* Priority_Remove_handler) (Priority_Aggregation *aggregation, Priority_Actions *actions, void *arg)
enum  Priority_Group_order { PRIORITY_GROUP_FIRST = 0 , PRIORITY_GROUP_LAST = 1 }
 The priority group order determines if a priority node is inserted as the first or last node into its priority group. More...
