RTEMS 6.1
This header file provides interfaces of the Object Handler which are used by the implementation and the Application Configuration. More...
| union | Objects_Name |
| #define | OBJECTS_INDEX_START_BIT 0U |
| #define | OBJECTS_NODE_START_BIT 16U |
| #define | OBJECTS_API_START_BIT 24U |
| #define | OBJECTS_CLASS_START_BIT 27U |
| #define | OBJECTS_INDEX_MASK (Objects_Id)0x0000ffffU |
| #define | OBJECTS_NODE_MASK (Objects_Id)0x00ff0000U |
| #define | OBJECTS_API_MASK (Objects_Id)0x07000000U |
| #define | OBJECTS_CLASS_MASK (Objects_Id)0xf8000000U |
| #define | OBJECTS_INDEX_VALID_BITS (Objects_Id)0x0000ffffU |
| #define | OBJECTS_NODE_VALID_BITS (Objects_Id)0x000000ffU |
| #define | OBJECTS_API_VALID_BITS (Objects_Id)0x00000007U |
| #define | OBJECTS_CLASS_VALID_BITS (Objects_Id)0x0000001fU |
| #define | OBJECTS_UNLIMITED_OBJECTS 0x80000000U |
| #define | OBJECTS_ID_INITIAL_INDEX (0) |
| #define | OBJECTS_ID_FINAL_INDEX (0xffffU) |
| #define | OBJECTS_APIS_LAST OBJECTS_POSIX_API |
| #define | OBJECTS_ID_NONE 0 |
| #define | OBJECTS_ID_OF_SELF ((Objects_Id) 0) |
| #define | OBJECTS_SEARCH_ALL_NODES 0 |
| #define | OBJECTS_SEARCH_OTHER_NODES 0x7FFFFFFE |
| #define | OBJECTS_SEARCH_LOCAL_NODE 0x7FFFFFFF |
| #define | OBJECTS_WHO_AM_I 0 |
| #define | OBJECTS_ID_INITIAL(_api, _class, _node) _Objects_Build_id( (_api), (_class), (_node), OBJECTS_ID_INITIAL_INDEX ) |
| #define | OBJECTS_ID_FINAL ((Objects_Id)~0) |
| #define | _Objects_Build_name(_C1, _C2, _C3, _C4) |
| #define | _Objects_Build_id(the_api, the_class, node, index) |
| Builds an object ID from its components. | |
| #define | _Objects_Is_unlimited(maximum) ( ( ( maximum ) & OBJECTS_UNLIMITED_OBJECTS ) != 0 ) |
| #define | _Objects_Maximum_per_allocation(maximum) ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS)) |
| #define | _Objects_Local_node ((uint16_t) 1) |
| The local MPCI node number. | |
Typedefs | |
| typedef uint32_t | Objects_Id |
| typedef uint16_t | Objects_Maximum |
Enumerations | |
| enum | Objects_APIs { OBJECTS_NO_API = 0 , OBJECTS_INTERNAL_API = 1 , OBJECTS_CLASSIC_API = 2 , OBJECTS_POSIX_API = 3 , OBJECTS_FAKE_OBJECTS_API = 7 } |
