RTEMS 6.1
muteximpl.h
2
12/*
13 * Copyright (C) 2015, 2017 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_SCORE_MUTEXIMPL_H
38#define _RTEMS_SCORE_MUTEXIMPL_H
39
41
42#ifdef __cplusplus
43extern "C" {
44#endif /* __cplusplus */
45
58typedef struct {
61
62typedef struct {
63 Mutex_Control Mutex;
64 unsigned int nest_level;
66
69#ifdef __cplusplus
70}
71#endif /* __cplusplus */
72
73#endif /* _RTEMS_SCORE_MUTEXIMPL_H */
Definition: muteximpl.h:58
Definition: muteximpl.h:62
Thread queue with a layout compatible to struct _Thread_queue_Queue defined in Newlib <sys/lock....
Definition: threadqimpl.h:71
This header file provides interfaces of the Thread Queue Handler which are only used by the implement...
