RTEMS 6.1
Typedefs | Enumerations | Functions
schedulersmpimpl.h File Reference
This header file provides interfaces of the SMP Scheduler which are only used by the implementation. More...
#include <rtems/score/schedulersmp.h>
#include <rtems/bspIo.h>
typedef bool(* Scheduler_SMP_Has_ready) (Scheduler_Context *context)
typedef Scheduler_Node *(* Scheduler_SMP_Get_highest_ready) (Scheduler_Context *context, Scheduler_Node *filter)
typedef Scheduler_Node *(* Scheduler_SMP_Get_lowest_ready) (Scheduler_Context *context)
typedef Scheduler_Node *(* Scheduler_SMP_Get_lowest_scheduled) (Scheduler_Context *context, Scheduler_Node *filter)
typedef void(* Scheduler_SMP_Extract) (Scheduler_Context *context, Scheduler_Node *node_to_extract)
typedef void(* Scheduler_SMP_Insert) (Scheduler_Context *context, Scheduler_Node *node_to_insert, Priority_Control insert_priority)
typedef void(* Scheduler_SMP_Move) (Scheduler_Context *context, Scheduler_Node *node_to_move)
typedef bool(* Scheduler_SMP_Ask_for_help) (Scheduler_Context *context, Thread_Control *thread, Scheduler_Node *node)
typedef void(* Scheduler_SMP_Update) (Scheduler_Context *context, Scheduler_Node *node_to_update, Priority_Control new_priority)
typedef void(* Scheduler_SMP_Set_affinity) (Scheduler_Context *context, Scheduler_Node *node, void *arg)
typedef bool(* Scheduler_SMP_Enqueue) (Scheduler_Context *context, Scheduler_Node *node_to_enqueue, Priority_Control priority)
typedef void(* Scheduler_SMP_Enqueue_scheduled) (Scheduler_Context *context, Scheduler_Node *node_to_enqueue, Priority_Control priority)
typedef void(* Scheduler_SMP_Allocate_processor) (Scheduler_Context *context, Scheduler_Node *scheduled, Per_CPU_Control *cpu)
typedef void(* Scheduler_SMP_Register_idle) (Scheduler_Context *context, Scheduler_Node *idle, Per_CPU_Control *cpu)
enum  Scheduler_SMP_Action { SCHEDULER_SMP_DO_SCHEDULE , SCHEDULER_SMP_DO_NOT_SCHEDULE }
 This enumeration defines what a scheduler should do with a node which could be scheduled.
void _Scheduler_SMP_Remove_ask_for_help_from_processor (Thread_Control *thread, Per_CPU_Control *cpu)
 Removes the thread's ask for help request from the processor.
