RTEMS 6.1
This header file provides the interfaces of the Simple Priority SMP Scheduler. More...
#include <rtems/score/schedulerpriority.h>
#include <rtems/score/schedulersmp.h>
struct  Scheduler_simple_SMP_Context
#define SCHEDULER_SIMPLE_SMP_MAXIMUM_PRIORITY   255
#define SCHEDULER_SIMPLE_SMP_ENTRY_POINTS
 Entry points for the Simple SMP Scheduler.
void _Scheduler_simple_SMP_Initialize (const Scheduler_Control *scheduler)
 Initializes the scheduler's context.
void _Scheduler_simple_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes the node with the given attributes.
void _Scheduler_simple_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Blocks a thread.
void _Scheduler_simple_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Unblocks a thread.
void _Scheduler_simple_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Updates the priority of the node.
bool _Scheduler_simple_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Asks for help.
void _Scheduler_simple_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Reconsiders help.
void _Scheduler_simple_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
 Withdraws node.
void _Scheduler_simple_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Makes the node sticky.
void _Scheduler_simple_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Cleans the sticky property from the node.
void _Scheduler_simple_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle)
 Adds idle to scheduler.
Thread_Control_Scheduler_simple_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu)
 Removes an idle thread from the given cpu.
void _Scheduler_simple_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
