| void | _Scheduler_priority_SMP_Initialize (const Scheduler_Control *scheduler) |
| | Initializes the priority SMP scheduler.
| void | _Scheduler_priority_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority) |
| | Initializes the node with the given priority.
| void | _Scheduler_priority_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| | Blocks the thread.
| void | _Scheduler_priority_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| | Unblocks the thread.
| void | _Scheduler_priority_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| | Updates the priority of the node.
| bool | _Scheduler_priority_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| | Asks for help operation.
| void | _Scheduler_priority_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| | Reconsiders help operation.
| void | _Scheduler_priority_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state) |
| | Withdraws node operation.
| void | _Scheduler_priority_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| | Makes the node sticky.
| void | _Scheduler_priority_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| | Cleans the sticky property from the node.
| void | _Scheduler_priority_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle) |
| | Adds idle to scheduler.
| Thread_Control * | _Scheduler_priority_SMP_Remove_processor (const Scheduler_Control *scheduler, struct Per_CPU_Control *cpu) |
| | Removes an idle thread from the given cpu.
| void | _Scheduler_priority_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node) |
| | Performs the yield of a thread.
This header file provides interfaces of the Deterministic Priority SMP Scheduler which are used by the implementation and the Application Configuration.
