RTEMS 6.1
This source file contains the implementation of _Scheduler_priority_SMP_Add_processor(), _Scheduler_priority_SMP_Ask_for_help(), _Scheduler_priority_SMP_Block(), _Scheduler_priority_SMP_Initialize(), _Scheduler_priority_SMP_Node_initialize(), _Scheduler_priority_SMP_Reconsider_help_request(), _Scheduler_priority_SMP_Remove_processor(), _Scheduler_priority_SMP_Unblock(), _Scheduler_priority_SMP_Update_priority(), _Scheduler_priority_SMP_Withdraw_node(), _Scheduler_priority_SMP_Make_sticky(), _Scheduler_priority_SMP_Clean_sticky(), and _Scheduler_priority_SMP_Yield(). More...
#include <rtems/score/schedulerprioritysmpimpl.h>
void _Scheduler_priority_SMP_Initialize (const Scheduler_Control *scheduler)
 Initializes the priority SMP scheduler.
void _Scheduler_priority_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes the node with the given priority.
void _Scheduler_priority_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Blocks the thread.
void _Scheduler_priority_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Unblocks the thread.
void _Scheduler_priority_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Updates the priority of the node.
bool _Scheduler_priority_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Asks for help operation.
void _Scheduler_priority_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Reconsiders help operation.
void _Scheduler_priority_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
 Withdraws node operation.
void _Scheduler_priority_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Makes the node sticky.
void _Scheduler_priority_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Cleans the sticky property from the node.
void _Scheduler_priority_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle)
 Adds idle to scheduler.
Thread_Control_Scheduler_priority_SMP_Remove_processor (const Scheduler_Control *scheduler, Per_CPU_Control *cpu)
 Removes an idle thread from the given cpu.
void _Scheduler_priority_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Performs the yield of a thread.
