RTEMS 6.1
"SAM V71 Xplained Ultra - PIO definitions"
This pages lists all the PIOs definitions contained in board.h. The constants are named using the following convention: PIN_* for a constant which defines a single Pin instance (but may include several PIOs sharing the same controller), and PINS_* for a list of Pin instances.
UART0
  • PINS_UART0
UART4
  • PINS_UART4
LEDs
  • PIN_LED_0
  • PIN_LED_1
  • PINS_LEDS
Push buttons
  • PIN_PUSHBUTTON_0
  • PIN_PUSHBUTTON_1
  • PINS_PUSHBUTTONS
  • PUSHBUTTON_BP0
  • PUSHBUTTON_BP1
PWMC
  • PIN_PWMC_PWMH0
  • PIN_PWMC_PWMH1
  • PIN_PWM_LED0
  • PIN_PWM_LED1
  • CHANNEL_PWM_LED0
  • CHANNEL_PWM_LED1
SPI
  • PIN_SPI_MISO
  • PIN_SPI_MOSI
  • PIN_SPI_SPCK
  • PINS_SPI
PCK0
  • PIN_PCK0
  • PIN_PCK1
  • PIN_PCK2
PIO PARALLEL CAPTURE
  • PIN_PIODCEN1
  • PIN_PIODCEN2
TWI
  • TWI_V3XX
  • PIN_TWI_TWD0
  • PIN_TWI_TWCK0
  • PINS_TWI0
  • PIN_TWI_TWD1
  • PIN_TWI_TWCK1
  • PINS_TWI1
USART0
  • PIN_USART0_RXD
  • PIN_USART0_TXD
  • PIN_USART0_CTS
  • PIN_USART0_RTS
  • PIN_USART0_SCK
USART1
  • PIN_USART1_RXD
  • PIN_USART1_TXD
  • PIN_USART1_CTS
  • PIN_USART1_RTS
  • PIN_USART1_SCK
USART2
  • PIN_USART2_RXD
  • PIN_USART2_TXD
  • PIN_USART2_CTS
  • PIN_USART2_RTS
  • PIN_USART2_SCK
SSC
  • PIN_SSC_TD
  • PIN_SSC_TK
  • PIN_SSC_TF
  • PIN_SSC_RD
  • PIN_SSC_RK
  • PIN_SSC_RF
  • PIN_SSC_TD
  • PINS_SSC_CODEC
MCAN
  • PIN_MCAN0_TXD
  • PIN_MCAN0_RXD
  • PIN_MCAN1_TXD
  • PIN_MCAN1_RXD
