RTEMS 6.1
component_twihs.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_TWIHS_COMPONENT_
31#define _SAMV71_TWIHS_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __O uint32_t TWIHS_CR;
43 __IO uint32_t TWIHS_MMR;
44 __IO uint32_t TWIHS_SMR;
45 __IO uint32_t TWIHS_IADR;
46 __IO uint32_t TWIHS_CWGR;
47 __I uint32_t Reserved1[3];
48 __I uint32_t TWIHS_SR;
49 __O uint32_t TWIHS_IER;
50 __O uint32_t TWIHS_IDR;
51 __I uint32_t TWIHS_IMR;
52 __I uint32_t TWIHS_RHR;
53 __O uint32_t TWIHS_THR;
54 __IO uint32_t TWIHS_SMBTR;
55 __I uint32_t Reserved2[2];
56 __IO uint32_t TWIHS_FILTR;
57 __I uint32_t Reserved3[1];
58 __IO uint32_t TWIHS_SWMR;
59 __I uint32_t Reserved4[32];
60 __I uint32_t TWIHS_DR;
61 __I uint32_t Reserved5[4];
62 __IO uint32_t TWIHS_WPMR;
63 __I uint32_t TWIHS_WPSR;
64 __I uint32_t Reserved6[4];
65 __I uint32_t TWIHS_VER;
66} Twihs;
67#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
68/* -------- TWIHS_CR : (TWIHS Offset: 0x00) Control Register -------- */
69#define TWIHS_CR_START (0x1u << 0)
70#define TWIHS_CR_STOP (0x1u << 1)
71#define TWIHS_CR_MSEN (0x1u << 2)
72#define TWIHS_CR_MSDIS (0x1u << 3)
73#define TWIHS_CR_SVEN (0x1u << 4)
74#define TWIHS_CR_SVDIS (0x1u << 5)
75#define TWIHS_CR_QUICK (0x1u << 6)
76#define TWIHS_CR_SWRST (0x1u << 7)
77#define TWIHS_CR_HSEN (0x1u << 8)
78#define TWIHS_CR_HSDIS (0x1u << 9)
79#define TWIHS_CR_SMBEN (0x1u << 10)
80#define TWIHS_CR_SMBDIS (0x1u << 11)
81#define TWIHS_CR_PECEN (0x1u << 12)
82#define TWIHS_CR_PECDIS (0x1u << 13)
83#define TWIHS_CR_PECRQ (0x1u << 14)
84#define TWIHS_CR_CLEAR (0x1u << 15)
85/* -------- TWIHS_MMR : (TWIHS Offset: 0x04) Master Mode Register -------- */
86#define TWIHS_MMR_IADRSZ_Pos 8
87#define TWIHS_MMR_IADRSZ_Msk (0x3u << TWIHS_MMR_IADRSZ_Pos)
88#define TWIHS_MMR_IADRSZ(value) ((TWIHS_MMR_IADRSZ_Msk & ((value) << TWIHS_MMR_IADRSZ_Pos)))
89#define TWIHS_MMR_IADRSZ_NONE (0x0u << 8)
90#define TWIHS_MMR_IADRSZ_1_BYTE (0x1u << 8)
91#define TWIHS_MMR_IADRSZ_2_BYTE (0x2u << 8)
92#define TWIHS_MMR_IADRSZ_3_BYTE (0x3u << 8)
93#define TWIHS_MMR_MREAD (0x1u << 12)
94#define TWIHS_MMR_DADR_Pos 16
95#define TWIHS_MMR_DADR_Msk (0x7fu << TWIHS_MMR_DADR_Pos)
96#define TWIHS_MMR_DADR(value) ((TWIHS_MMR_DADR_Msk & ((value) << TWIHS_MMR_DADR_Pos)))
97/* -------- TWIHS_SMR : (TWIHS Offset: 0x08) Slave Mode Register -------- */
98#define TWIHS_SMR_NACKEN (0x1u << 0)
99#define TWIHS_SMR_SMDA (0x1u << 2)
100#define TWIHS_SMR_SMHH (0x1u << 3)
101#define TWIHS_SMR_SCLWSDIS (0x1u << 6)
102#define TWIHS_SMR_MASK_Pos 8
103#define TWIHS_SMR_MASK_Msk (0x7fu << TWIHS_SMR_MASK_Pos)
104#define TWIHS_SMR_MASK(value) ((TWIHS_SMR_MASK_Msk & ((value) << TWIHS_SMR_MASK_Pos)))
105#define TWIHS_SMR_SADR_Pos 16
106#define TWIHS_SMR_SADR_Msk (0x7fu << TWIHS_SMR_SADR_Pos)
107#define TWIHS_SMR_SADR(value) ((TWIHS_SMR_SADR_Msk & ((value) << TWIHS_SMR_SADR_Pos)))
108#define TWIHS_SMR_SADR1EN (0x1u << 28)
109#define TWIHS_SMR_SADR2EN (0x1u << 29)
110#define TWIHS_SMR_SADR3EN (0x1u << 30)
111#define TWIHS_SMR_DATAMEN (0x1u << 31)
112/* -------- TWIHS_IADR : (TWIHS Offset: 0x0C) Internal Address Register -------- */
113#define TWIHS_IADR_IADR_Pos 0
114#define TWIHS_IADR_IADR_Msk (0xffffffu << TWIHS_IADR_IADR_Pos)
115#define TWIHS_IADR_IADR(value) ((TWIHS_IADR_IADR_Msk & ((value) << TWIHS_IADR_IADR_Pos)))
116/* -------- TWIHS_CWGR : (TWIHS Offset: 0x10) Clock Waveform Generator Register -------- */
117#define TWIHS_CWGR_CLDIV_Pos 0
118#define TWIHS_CWGR_CLDIV_Msk (0xffu << TWIHS_CWGR_CLDIV_Pos)
119#define TWIHS_CWGR_CLDIV(value) ((TWIHS_CWGR_CLDIV_Msk & ((value) << TWIHS_CWGR_CLDIV_Pos)))
120#define TWIHS_CWGR_CHDIV_Pos 8
121#define TWIHS_CWGR_CHDIV_Msk (0xffu << TWIHS_CWGR_CHDIV_Pos)
122#define TWIHS_CWGR_CHDIV(value) ((TWIHS_CWGR_CHDIV_Msk & ((value) << TWIHS_CWGR_CHDIV_Pos)))
123#define TWIHS_CWGR_CKDIV_Pos 16
124#define TWIHS_CWGR_CKDIV_Msk (0x7u << TWIHS_CWGR_CKDIV_Pos)
125#define TWIHS_CWGR_CKDIV(value) ((TWIHS_CWGR_CKDIV_Msk & ((value) << TWIHS_CWGR_CKDIV_Pos)))
126#define TWIHS_CWGR_HOLD_Pos 24
127#define TWIHS_CWGR_HOLD_Msk (0x1fu << TWIHS_CWGR_HOLD_Pos)
128#define TWIHS_CWGR_HOLD(value) ((TWIHS_CWGR_HOLD_Msk & ((value) << TWIHS_CWGR_HOLD_Pos)))
129/* -------- TWIHS_SR : (TWIHS Offset: 0x20) Status Register -------- */
130#define TWIHS_SR_TXCOMP (0x1u << 0)
131#define TWIHS_SR_RXRDY (0x1u << 1)
132#define TWIHS_SR_TXRDY (0x1u << 2)
133#define TWIHS_SR_SVREAD (0x1u << 3)
134#define TWIHS_SR_SVACC (0x1u << 4)
135#define TWIHS_SR_GACC (0x1u << 5)
136#define TWIHS_SR_OVRE (0x1u << 6)
137#define TWIHS_SR_UNRE (0x1u << 7)
138#define TWIHS_SR_NACK (0x1u << 8)
139#define TWIHS_SR_ARBLST (0x1u << 9)
140#define TWIHS_SR_SCLWS (0x1u << 10)
141#define TWIHS_SR_EOSACC (0x1u << 11)
142#define TWIHS_SR_MCACK (0x1u << 16)
143#define TWIHS_SR_TOUT (0x1u << 18)
144#define TWIHS_SR_PECERR (0x1u << 19)
145#define TWIHS_SR_SMBDAM (0x1u << 20)
146#define TWIHS_SR_SMBHHM (0x1u << 21)
147#define TWIHS_SR_SCL (0x1u << 24)
148#define TWIHS_SR_SDA (0x1u << 25)
149/* -------- TWIHS_IER : (TWIHS Offset: 0x24) Interrupt Enable Register -------- */
150#define TWIHS_IER_TXCOMP (0x1u << 0)
151#define TWIHS_IER_RXRDY (0x1u << 1)
152#define TWIHS_IER_TXRDY (0x1u << 2)
153#define TWIHS_IER_SVACC (0x1u << 4)
154#define TWIHS_IER_GACC (0x1u << 5)
155#define TWIHS_IER_OVRE (0x1u << 6)
156#define TWIHS_IER_UNRE (0x1u << 7)
157#define TWIHS_IER_NACK (0x1u << 8)
158#define TWIHS_IER_ARBLST (0x1u << 9)
159#define TWIHS_IER_SCL_WS (0x1u << 10)
160#define TWIHS_IER_EOSACC (0x1u << 11)
161#define TWIHS_IER_MCACK (0x1u << 16)
162#define TWIHS_IER_TOUT (0x1u << 18)
163#define TWIHS_IER_PECERR (0x1u << 19)
164#define TWIHS_IER_SMBDAM (0x1u << 20)
165#define TWIHS_IER_SMBHHM (0x1u << 21)
166/* -------- TWIHS_IDR : (TWIHS Offset: 0x28) Interrupt Disable Register -------- */
167#define TWIHS_IDR_TXCOMP (0x1u << 0)
168#define TWIHS_IDR_RXRDY (0x1u << 1)
169#define TWIHS_IDR_TXRDY (0x1u << 2)
170#define TWIHS_IDR_SVACC (0x1u << 4)
171#define TWIHS_IDR_GACC (0x1u << 5)
172#define TWIHS_IDR_OVRE (0x1u << 6)
173#define TWIHS_IDR_UNRE (0x1u << 7)
174#define TWIHS_IDR_NACK (0x1u << 8)
175#define TWIHS_IDR_ARBLST (0x1u << 9)
176#define TWIHS_IDR_SCL_WS (0x1u << 10)
177#define TWIHS_IDR_EOSACC (0x1u << 11)
178#define TWIHS_IDR_MCACK (0x1u << 16)
179#define TWIHS_IDR_TOUT (0x1u << 18)
180#define TWIHS_IDR_PECERR (0x1u << 19)
181#define TWIHS_IDR_SMBDAM (0x1u << 20)
182#define TWIHS_IDR_SMBHHM (0x1u << 21)
183/* -------- TWIHS_IMR : (TWIHS Offset: 0x2C) Interrupt Mask Register -------- */
184#define TWIHS_IMR_TXCOMP (0x1u << 0)
185#define TWIHS_IMR_RXRDY (0x1u << 1)
186#define TWIHS_IMR_TXRDY (0x1u << 2)
187#define TWIHS_IMR_SVACC (0x1u << 4)
188#define TWIHS_IMR_GACC (0x1u << 5)
189#define TWIHS_IMR_OVRE (0x1u << 6)
190#define TWIHS_IMR_UNRE (0x1u << 7)
191#define TWIHS_IMR_NACK (0x1u << 8)
192#define TWIHS_IMR_ARBLST (0x1u << 9)
193#define TWIHS_IMR_SCL_WS (0x1u << 10)
194#define TWIHS_IMR_EOSACC (0x1u << 11)
195#define TWIHS_IMR_MCACK (0x1u << 16)
196#define TWIHS_IMR_TOUT (0x1u << 18)
197#define TWIHS_IMR_PECERR (0x1u << 19)
198#define TWIHS_IMR_SMBDAM (0x1u << 20)
199#define TWIHS_IMR_SMBHHM (0x1u << 21)
200/* -------- TWIHS_RHR : (TWIHS Offset: 0x30) Receive Holding Register -------- */
201#define TWIHS_RHR_RXDATA_Pos 0
202#define TWIHS_RHR_RXDATA_Msk (0xffu << TWIHS_RHR_RXDATA_Pos)
203/* -------- TWIHS_THR : (TWIHS Offset: 0x34) Transmit Holding Register -------- */
204#define TWIHS_THR_TXDATA_Pos 0
205#define TWIHS_THR_TXDATA_Msk (0xffu << TWIHS_THR_TXDATA_Pos)
206#define TWIHS_THR_TXDATA(value) ((TWIHS_THR_TXDATA_Msk & ((value) << TWIHS_THR_TXDATA_Pos)))
207/* -------- TWIHS_SMBTR : (TWIHS Offset: 0x38) SMBus Timing Register -------- */
208#define TWIHS_SMBTR_PRESC_Pos 0
209#define TWIHS_SMBTR_PRESC_Msk (0xfu << TWIHS_SMBTR_PRESC_Pos)
210#define TWIHS_SMBTR_PRESC(value) ((TWIHS_SMBTR_PRESC_Msk & ((value) << TWIHS_SMBTR_PRESC_Pos)))
211#define TWIHS_SMBTR_TLOWS_Pos 8
212#define TWIHS_SMBTR_TLOWS_Msk (0xffu << TWIHS_SMBTR_TLOWS_Pos)
213#define TWIHS_SMBTR_TLOWS(value) ((TWIHS_SMBTR_TLOWS_Msk & ((value) << TWIHS_SMBTR_TLOWS_Pos)))
214#define TWIHS_SMBTR_TLOWM_Pos 16
215#define TWIHS_SMBTR_TLOWM_Msk (0xffu << TWIHS_SMBTR_TLOWM_Pos)
216#define TWIHS_SMBTR_TLOWM(value) ((TWIHS_SMBTR_TLOWM_Msk & ((value) << TWIHS_SMBTR_TLOWM_Pos)))
217#define TWIHS_SMBTR_THMAX_Pos 24
218#define TWIHS_SMBTR_THMAX_Msk (0xffu << TWIHS_SMBTR_THMAX_Pos)
219#define TWIHS_SMBTR_THMAX(value) ((TWIHS_SMBTR_THMAX_Msk & ((value) << TWIHS_SMBTR_THMAX_Pos)))
220/* -------- TWIHS_FILTR : (TWIHS Offset: 0x44) Filter Register -------- */
221#define TWIHS_FILTR_FILT (0x1u << 0)
222#define TWIHS_FILTR_PADFEN (0x1u << 1)
223#define TWIHS_FILTR_PADFCFG (0x1u << 2)
224#define TWIHS_FILTR_THRES_Pos 8
225#define TWIHS_FILTR_THRES_Msk (0x7u << TWIHS_FILTR_THRES_Pos)
226#define TWIHS_FILTR_THRES(value) ((TWIHS_FILTR_THRES_Msk & ((value) << TWIHS_FILTR_THRES_Pos)))
227/* -------- TWIHS_SWMR : (TWIHS Offset: 0x4C) SleepWalking Matching Register -------- */
228#define TWIHS_SWMR_SADR1_Pos 0
229#define TWIHS_SWMR_SADR1_Msk (0x7fu << TWIHS_SWMR_SADR1_Pos)
230#define TWIHS_SWMR_SADR1(value) ((TWIHS_SWMR_SADR1_Msk & ((value) << TWIHS_SWMR_SADR1_Pos)))
231#define TWIHS_SWMR_SADR2_Pos 8
232#define TWIHS_SWMR_SADR2_Msk (0x7fu << TWIHS_SWMR_SADR2_Pos)
233#define TWIHS_SWMR_SADR2(value) ((TWIHS_SWMR_SADR2_Msk & ((value) << TWIHS_SWMR_SADR2_Pos)))
234#define TWIHS_SWMR_SADR3_Pos 16
235#define TWIHS_SWMR_SADR3_Msk (0x7fu << TWIHS_SWMR_SADR3_Pos)
236#define TWIHS_SWMR_SADR3(value) ((TWIHS_SWMR_SADR3_Msk & ((value) << TWIHS_SWMR_SADR3_Pos)))
237#define TWIHS_SWMR_DATAM_Pos 24
238#define TWIHS_SWMR_DATAM_Msk (0xffu << TWIHS_SWMR_DATAM_Pos)
239#define TWIHS_SWMR_DATAM(value) ((TWIHS_SWMR_DATAM_Msk & ((value) << TWIHS_SWMR_DATAM_Pos)))
240/* -------- TWIHS_DR : (TWIHS Offset: 0xD0) Debug Register -------- */
241#define TWIHS_DR_SWEN (0x1u << 0)
242#define TWIHS_DR_CLKRQ (0x1u << 1)
243#define TWIHS_DR_SWMATCH (0x1u << 2)
244#define TWIHS_DR_TRP (0x1u << 3)
245/* -------- TWIHS_WPMR : (TWIHS Offset: 0xE4) Write Protection Mode Register -------- */
246#define TWIHS_WPMR_WPEN (0x1u << 0)
247#define TWIHS_WPMR_WPKEY_Pos 8
248#define TWIHS_WPMR_WPKEY_Msk (0xffffffu << TWIHS_WPMR_WPKEY_Pos)
249#define TWIHS_WPMR_WPKEY(value) ((TWIHS_WPMR_WPKEY_Msk & ((value) << TWIHS_WPMR_WPKEY_Pos)))
250#define TWIHS_WPMR_WPKEY_PASSWD (0x545749u << 8)
251/* -------- TWIHS_WPSR : (TWIHS Offset: 0xE8) Write Protection Status Register -------- */
252#define TWIHS_WPSR_WPVS (0x1u << 0)
253#define TWIHS_WPSR_WPVSRC_Pos 8
254#define TWIHS_WPSR_WPVSRC_Msk (0xffffffu << TWIHS_WPSR_WPVSRC_Pos)
255/* -------- TWIHS_VER : (TWIHS Offset: 0xFC) Version Register -------- */
256#define TWIHS_VER_VERSION_Pos 0
257#define TWIHS_VER_VERSION_Msk (0xfffu << TWIHS_VER_VERSION_Pos)
258#define TWIHS_VER_MFN_Pos 16
259#define TWIHS_VER_MFN_Msk (0x7u << TWIHS_VER_MFN_Pos)
262
263
264#endif /* _SAMV71_TWIHS_COMPONENT_ */
#define __O
Definition: core_cm4.h:238
#define __IO
Definition: core_cm4.h:239
#define __I
Definition: core_cm4.h:236
Twihs hardware registers.
Definition: component_twihs.h:41
(Twihs Offset: 0xFC) Version Register
Definition: component_twihs.h:65
(Twihs Offset: 0xD0) Debug Register
Definition: component_twihs.h:60
