RTEMS 6.1
component_pio.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_PIO_COMPONENT_
31#define _SAMV71_PIO_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __O uint32_t PIO_PER;
43 __O uint32_t PIO_PDR;
44 __I uint32_t PIO_PSR;
45 __I uint32_t Reserved1[1];
46 __O uint32_t PIO_OER;
47 __O uint32_t PIO_ODR;
48 __I uint32_t PIO_OSR;
49 __I uint32_t Reserved2[1];
50 __O uint32_t PIO_IFER;
51 __O uint32_t PIO_IFDR;
52 __I uint32_t PIO_IFSR;
53 __I uint32_t Reserved3[1];
54 __O uint32_t PIO_SODR;
55 __O uint32_t PIO_CODR;
56 __IO uint32_t PIO_ODSR;
57 __I uint32_t PIO_PDSR;
58 __O uint32_t PIO_IER;
59 __O uint32_t PIO_IDR;
60 __I uint32_t PIO_IMR;
61 __I uint32_t PIO_ISR;
62 __O uint32_t PIO_MDER;
63 __O uint32_t PIO_MDDR;
64 __I uint32_t PIO_MDSR;
65 __I uint32_t Reserved4[1];
66 __O uint32_t PIO_PUDR;
67 __O uint32_t PIO_PUER;
68 __I uint32_t PIO_PUSR;
69 __I uint32_t Reserved5[1];
70 __IO uint32_t PIO_ABCDSR[2];
71 __I uint32_t Reserved6[2];
72 __O uint32_t PIO_IFSCDR;
73 __O uint32_t PIO_IFSCER;
74 __I uint32_t PIO_IFSCSR;
75 __IO uint32_t PIO_SCDR;
76 __O uint32_t PIO_PPDDR;
77 __O uint32_t PIO_PPDER;
78 __I uint32_t PIO_PPDSR;
79 __I uint32_t Reserved7[1];
80 __O uint32_t PIO_OWER;
81 __O uint32_t PIO_OWDR;
82 __I uint32_t PIO_OWSR;
83 __I uint32_t Reserved8[1];
84 __O uint32_t PIO_AIMER;
85 __O uint32_t PIO_AIMDR;
86 __I uint32_t PIO_AIMMR;
87 __I uint32_t Reserved9[1];
88 __O uint32_t PIO_ESR;
89 __O uint32_t PIO_LSR;
90 __I uint32_t PIO_ELSR;
91 __I uint32_t Reserved10[1];
92 __O uint32_t PIO_FELLSR;
93 __O uint32_t PIO_REHLSR;
94 __I uint32_t PIO_FRLHSR;
95 __I uint32_t Reserved11[1];
96 __I uint32_t PIO_LOCKSR;
97 __IO uint32_t PIO_WPMR;
98 __I uint32_t PIO_WPSR;
99 __I uint32_t Reserved12[4];
100 __I uint32_t PIO_VERSION;
101 __IO uint32_t PIO_SCHMITT;
102 __I uint32_t Reserved13[5];
103 __IO uint32_t PIO_DRIVER;
104 __I uint32_t Reserved14[13];
105 __IO uint32_t PIO_PCMR;
106 __O uint32_t PIO_PCIER;
107 __O uint32_t PIO_PCIDR;
108 __I uint32_t PIO_PCIMR;
109 __I uint32_t PIO_PCISR;
110 __I uint32_t PIO_PCRHR;
111} Pio;
112#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
113/* -------- PIO_PER : (PIO Offset: 0x0000) PIO Enable Register -------- */
114#define PIO_PER_P0 (0x1u << 0)
115#define PIO_PER_P1 (0x1u << 1)
116#define PIO_PER_P2 (0x1u << 2)
117#define PIO_PER_P3 (0x1u << 3)
118#define PIO_PER_P4 (0x1u << 4)
119#define PIO_PER_P5 (0x1u << 5)
120#define PIO_PER_P6 (0x1u << 6)
121#define PIO_PER_P7 (0x1u << 7)
122#define PIO_PER_P8 (0x1u << 8)
123#define PIO_PER_P9 (0x1u << 9)
124#define PIO_PER_P10 (0x1u << 10)
125#define PIO_PER_P11 (0x1u << 11)
126#define PIO_PER_P12 (0x1u << 12)
127#define PIO_PER_P13 (0x1u << 13)
128#define PIO_PER_P14 (0x1u << 14)
129#define PIO_PER_P15 (0x1u << 15)
130#define PIO_PER_P16 (0x1u << 16)
131#define PIO_PER_P17 (0x1u << 17)
132#define PIO_PER_P18 (0x1u << 18)
133#define PIO_PER_P19 (0x1u << 19)
134#define PIO_PER_P20 (0x1u << 20)
135#define PIO_PER_P21 (0x1u << 21)
136#define PIO_PER_P22 (0x1u << 22)
137#define PIO_PER_P23 (0x1u << 23)
138#define PIO_PER_P24 (0x1u << 24)
139#define PIO_PER_P25 (0x1u << 25)
140#define PIO_PER_P26 (0x1u << 26)
141#define PIO_PER_P27 (0x1u << 27)
142#define PIO_PER_P28 (0x1u << 28)
143#define PIO_PER_P29 (0x1u << 29)
144#define PIO_PER_P30 (0x1u << 30)
145#define PIO_PER_P31 (0x1u << 31)
146/* -------- PIO_PDR : (PIO Offset: 0x0004) PIO Disable Register -------- */
147#define PIO_PDR_P0 (0x1u << 0)
148#define PIO_PDR_P1 (0x1u << 1)
149#define PIO_PDR_P2 (0x1u << 2)
150#define PIO_PDR_P3 (0x1u << 3)
151#define PIO_PDR_P4 (0x1u << 4)
152#define PIO_PDR_P5 (0x1u << 5)
153#define PIO_PDR_P6 (0x1u << 6)
154#define PIO_PDR_P7 (0x1u << 7)
155#define PIO_PDR_P8 (0x1u << 8)
156#define PIO_PDR_P9 (0x1u << 9)
157#define PIO_PDR_P10 (0x1u << 10)
158#define PIO_PDR_P11 (0x1u << 11)
159#define PIO_PDR_P12 (0x1u << 12)
160#define PIO_PDR_P13 (0x1u << 13)
161#define PIO_PDR_P14 (0x1u << 14)
162#define PIO_PDR_P15 (0x1u << 15)
163#define PIO_PDR_P16 (0x1u << 16)
164#define PIO_PDR_P17 (0x1u << 17)
165#define PIO_PDR_P18 (0x1u << 18)
166#define PIO_PDR_P19 (0x1u << 19)
167#define PIO_PDR_P20 (0x1u << 20)
168#define PIO_PDR_P21 (0x1u << 21)
169#define PIO_PDR_P22 (0x1u << 22)
170#define PIO_PDR_P23 (0x1u << 23)
171#define PIO_PDR_P24 (0x1u << 24)
172#define PIO_PDR_P25 (0x1u << 25)
173#define PIO_PDR_P26 (0x1u << 26)
174#define PIO_PDR_P27 (0x1u << 27)
175#define PIO_PDR_P28 (0x1u << 28)
176#define PIO_PDR_P29 (0x1u << 29)
177#define PIO_PDR_P30 (0x1u << 30)
178#define PIO_PDR_P31 (0x1u << 31)
179/* -------- PIO_PSR : (PIO Offset: 0x0008) PIO Status Register -------- */
180#define PIO_PSR_P0 (0x1u << 0)
181#define PIO_PSR_P1 (0x1u << 1)
182#define PIO_PSR_P2 (0x1u << 2)
183#define PIO_PSR_P3 (0x1u << 3)
184#define PIO_PSR_P4 (0x1u << 4)
185#define PIO_PSR_P5 (0x1u << 5)
186#define PIO_PSR_P6 (0x1u << 6)
187#define PIO_PSR_P7 (0x1u << 7)
188#define PIO_PSR_P8 (0x1u << 8)
189#define PIO_PSR_P9 (0x1u << 9)
190#define PIO_PSR_P10 (0x1u << 10)
191#define PIO_PSR_P11 (0x1u << 11)
192#define PIO_PSR_P12 (0x1u << 12)
193#define PIO_PSR_P13 (0x1u << 13)
194#define PIO_PSR_P14 (0x1u << 14)
195#define PIO_PSR_P15 (0x1u << 15)
196#define PIO_PSR_P16 (0x1u << 16)
197#define PIO_PSR_P17 (0x1u << 17)
198#define PIO_PSR_P18 (0x1u << 18)
199#define PIO_PSR_P19 (0x1u << 19)
200#define PIO_PSR_P20 (0x1u << 20)
201#define PIO_PSR_P21 (0x1u << 21)
202#define PIO_PSR_P22 (0x1u << 22)
203#define PIO_PSR_P23 (0x1u << 23)
204#define PIO_PSR_P24 (0x1u << 24)
205#define PIO_PSR_P25 (0x1u << 25)
206#define PIO_PSR_P26 (0x1u << 26)
207#define PIO_PSR_P27 (0x1u << 27)
208#define PIO_PSR_P28 (0x1u << 28)
209#define PIO_PSR_P29 (0x1u << 29)
210#define PIO_PSR_P30 (0x1u << 30)
211#define PIO_PSR_P31 (0x1u << 31)
212/* -------- PIO_OER : (PIO Offset: 0x0010) Output Enable Register -------- */
213#define PIO_OER_P0 (0x1u << 0)
214#define PIO_OER_P1 (0x1u << 1)
215#define PIO_OER_P2 (0x1u << 2)
216#define PIO_OER_P3 (0x1u << 3)
217#define PIO_OER_P4 (0x1u << 4)
218#define PIO_OER_P5 (0x1u << 5)
219#define PIO_OER_P6 (0x1u << 6)
220#define PIO_OER_P7 (0x1u << 7)
221#define PIO_OER_P8 (0x1u << 8)
222#define PIO_OER_P9 (0x1u << 9)
223#define PIO_OER_P10 (0x1u << 10)
224#define PIO_OER_P11 (0x1u << 11)
225#define PIO_OER_P12 (0x1u << 12)
226#define PIO_OER_P13 (0x1u << 13)
227#define PIO_OER_P14 (0x1u << 14)
228#define PIO_OER_P15 (0x1u << 15)
229#define PIO_OER_P16 (0x1u << 16)
230#define PIO_OER_P17 (0x1u << 17)
231#define PIO_OER_P18 (0x1u << 18)
232#define PIO_OER_P19 (0x1u << 19)
233#define PIO_OER_P20 (0x1u << 20)
234#define PIO_OER_P21 (0x1u << 21)
235#define PIO_OER_P22 (0x1u << 22)
236#define PIO_OER_P23 (0x1u << 23)
237#define PIO_OER_P24 (0x1u << 24)
238#define PIO_OER_P25 (0x1u << 25)
239#define PIO_OER_P26 (0x1u << 26)
240#define PIO_OER_P27 (0x1u << 27)
241#define PIO_OER_P28 (0x1u << 28)
242#define PIO_OER_P29 (0x1u << 29)
243#define PIO_OER_P30 (0x1u << 30)
244#define PIO_OER_P31 (0x1u << 31)
245/* -------- PIO_ODR : (PIO Offset: 0x0014) Output Disable Register -------- */
246#define PIO_ODR_P0 (0x1u << 0)
247#define PIO_ODR_P1 (0x1u << 1)
248#define PIO_ODR_P2 (0x1u << 2)
249#define PIO_ODR_P3 (0x1u << 3)
250#define PIO_ODR_P4 (0x1u << 4)
251#define PIO_ODR_P5 (0x1u << 5)
252#define PIO_ODR_P6 (0x1u << 6)
253#define PIO_ODR_P7 (0x1u << 7)
254#define PIO_ODR_P8 (0x1u << 8)
255#define PIO_ODR_P9 (0x1u << 9)
256#define PIO_ODR_P10 (0x1u << 10)
257#define PIO_ODR_P11 (0x1u << 11)
258#define PIO_ODR_P12 (0x1u << 12)
259#define PIO_ODR_P13 (0x1u << 13)
260#define PIO_ODR_P14 (0x1u << 14)
261#define PIO_ODR_P15 (0x1u << 15)
262#define PIO_ODR_P16 (0x1u << 16)
263#define PIO_ODR_P17 (0x1u << 17)
264#define PIO_ODR_P18 (0x1u << 18)
265#define PIO_ODR_P19 (0x1u << 19)
266#define PIO_ODR_P20 (0x1u << 20)
267#define PIO_ODR_P21 (0x1u << 21)
268#define PIO_ODR_P22 (0x1u << 22)
269#define PIO_ODR_P23 (0x1u << 23)
270#define PIO_ODR_P24 (0x1u << 24)
271#define PIO_ODR_P25 (0x1u << 25)
272#define PIO_ODR_P26 (0x1u << 26)
273#define PIO_ODR_P27 (0x1u << 27)
274#define PIO_ODR_P28 (0x1u << 28)
275#define PIO_ODR_P29 (0x1u << 29)
276#define PIO_ODR_P30 (0x1u << 30)
277#define PIO_ODR_P31 (0x1u << 31)
278/* -------- PIO_OSR : (PIO Offset: 0x0018) Output Status Register -------- */
279#define PIO_OSR_P0 (0x1u << 0)
280#define PIO_OSR_P1 (0x1u << 1)
281#define PIO_OSR_P2 (0x1u << 2)
282#define PIO_OSR_P3 (0x1u << 3)
283#define PIO_OSR_P4 (0x1u << 4)
284#define PIO_OSR_P5 (0x1u << 5)
285#define PIO_OSR_P6 (0x1u << 6)
286#define PIO_OSR_P7 (0x1u << 7)
287#define PIO_OSR_P8 (0x1u << 8)
288#define PIO_OSR_P9 (0x1u << 9)
289#define PIO_OSR_P10 (0x1u << 10)
290#define PIO_OSR_P11 (0x1u << 11)
291#define PIO_OSR_P12 (0x1u << 12)
292#define PIO_OSR_P13 (0x1u << 13)
293#define PIO_OSR_P14 (0x1u << 14)
294#define PIO_OSR_P15 (0x1u << 15)
295#define PIO_OSR_P16 (0x1u << 16)
296#define PIO_OSR_P17 (0x1u << 17)
297#define PIO_OSR_P18 (0x1u << 18)
298#define PIO_OSR_P19 (0x1u << 19)
299#define PIO_OSR_P20 (0x1u << 20)
300#define PIO_OSR_P21 (0x1u << 21)
301#define PIO_OSR_P22 (0x1u << 22)
302#define PIO_OSR_P23 (0x1u << 23)
303#define PIO_OSR_P24 (0x1u << 24)
304#define PIO_OSR_P25 (0x1u << 25)
305#define PIO_OSR_P26 (0x1u << 26)
306#define PIO_OSR_P27 (0x1u << 27)
307#define PIO_OSR_P28 (0x1u << 28)
308#define PIO_OSR_P29 (0x1u << 29)
309#define PIO_OSR_P30 (0x1u << 30)
310#define PIO_OSR_P31 (0x1u << 31)
311/* -------- PIO_IFER : (PIO Offset: 0x0020) Glitch Input Filter Enable Register -------- */
312#define PIO_IFER_P0 (0x1u << 0)
313#define PIO_IFER_P1 (0x1u << 1)
314#define PIO_IFER_P2 (0x1u << 2)
315#define PIO_IFER_P3 (0x1u << 3)
316#define PIO_IFER_P4 (0x1u << 4)
317#define PIO_IFER_P5 (0x1u << 5)
318#define PIO_IFER_P6 (0x1u << 6)
319#define PIO_IFER_P7 (0x1u << 7)
320#define PIO_IFER_P8 (0x1u << 8)
321#define PIO_IFER_P9 (0x1u << 9)
322#define PIO_IFER_P10 (0x1u << 10)
323#define PIO_IFER_P11 (0x1u << 11)
324#define PIO_IFER_P12 (0x1u << 12)
325#define PIO_IFER_P13 (0x1u << 13)
326#define PIO_IFER_P14 (0x1u << 14)
327#define PIO_IFER_P15 (0x1u << 15)
328#define PIO_IFER_P16 (0x1u << 16)
329#define PIO_IFER_P17 (0x1u << 17)
330#define PIO_IFER_P18 (0x1u << 18)
331#define PIO_IFER_P19 (0x1u << 19)
332#define PIO_IFER_P20 (0x1u << 20)
333#define PIO_IFER_P21 (0x1u << 21)
334#define PIO_IFER_P22 (0x1u << 22)
335#define PIO_IFER_P23 (0x1u << 23)
336#define PIO_IFER_P24 (0x1u << 24)
337#define PIO_IFER_P25 (0x1u << 25)
338#define PIO_IFER_P26 (0x1u << 26)
339#define PIO_IFER_P27 (0x1u << 27)
340#define PIO_IFER_P28 (0x1u << 28)
341#define PIO_IFER_P29 (0x1u << 29)
342#define PIO_IFER_P30 (0x1u << 30)
343#define PIO_IFER_P31 (0x1u << 31)
344/* -------- PIO_IFDR : (PIO Offset: 0x0024) Glitch Input Filter Disable Register -------- */
345#define PIO_IFDR_P0 (0x1u << 0)
346#define PIO_IFDR_P1 (0x1u << 1)
347#define PIO_IFDR_P2 (0x1u << 2)
348#define PIO_IFDR_P3 (0x1u << 3)
349#define PIO_IFDR_P4 (0x1u << 4)
350#define PIO_IFDR_P5 (0x1u << 5)
351#define PIO_IFDR_P6 (0x1u << 6)
352#define PIO_IFDR_P7 (0x1u << 7)
353#define PIO_IFDR_P8 (0x1u << 8)
354#define PIO_IFDR_P9 (0x1u << 9)
355#define PIO_IFDR_P10 (0x1u << 10)
356#define PIO_IFDR_P11 (0x1u << 11)
357#define PIO_IFDR_P12 (0x1u << 12)
358#define PIO_IFDR_P13 (0x1u << 13)
359#define PIO_IFDR_P14 (0x1u << 14)
360#define PIO_IFDR_P15 (0x1u << 15)
361#define PIO_IFDR_P16 (0x1u << 16)
362#define PIO_IFDR_P17 (0x1u << 17)
363#define PIO_IFDR_P18 (0x1u << 18)
364#define PIO_IFDR_P19 (0x1u << 19)
365#define PIO_IFDR_P20 (0x1u << 20)
366#define PIO_IFDR_P21 (0x1u << 21)
367#define PIO_IFDR_P22 (0x1u << 22)
368#define PIO_IFDR_P23 (0x1u << 23)
369#define PIO_IFDR_P24 (0x1u << 24)
370#define PIO_IFDR_P25 (0x1u << 25)
371#define PIO_IFDR_P26 (0x1u << 26)
372#define PIO_IFDR_P27 (0x1u << 27)
373#define PIO_IFDR_P28 (0x1u << 28)
374#define PIO_IFDR_P29 (0x1u << 29)
375#define PIO_IFDR_P30 (0x1u << 30)
376#define PIO_IFDR_P31 (0x1u << 31)
377/* -------- PIO_IFSR : (PIO Offset: 0x0028) Glitch Input Filter Status Register -------- */
378#define PIO_IFSR_P0 (0x1u << 0)
379#define PIO_IFSR_P1 (0x1u << 1)
380#define PIO_IFSR_P2 (0x1u << 2)
381#define PIO_IFSR_P3 (0x1u << 3)
382#define PIO_IFSR_P4 (0x1u << 4)
383#define PIO_IFSR_P5 (0x1u << 5)
384#define PIO_IFSR_P6 (0x1u << 6)
385#define PIO_IFSR_P7 (0x1u << 7)
386#define PIO_IFSR_P8 (0x1u << 8)
387#define PIO_IFSR_P9 (0x1u << 9)
388#define PIO_IFSR_P10 (0x1u << 10)
389#define PIO_IFSR_P11 (0x1u << 11)
390#define PIO_IFSR_P12 (0x1u << 12)
391#define PIO_IFSR_P13 (0x1u << 13)
392#define PIO_IFSR_P14 (0x1u << 14)
393#define PIO_IFSR_P15 (0x1u << 15)
394#define PIO_IFSR_P16 (0x1u << 16)
395#define PIO_IFSR_P17 (0x1u << 17)
396#define PIO_IFSR_P18 (0x1u << 18)
397#define PIO_IFSR_P19 (0x1u << 19)
398#define PIO_IFSR_P20 (0x1u << 20)
399#define PIO_IFSR_P21 (0x1u << 21)
400#define PIO_IFSR_P22 (0x1u << 22)
401#define PIO_IFSR_P23 (0x1u << 23)
402#define PIO_IFSR_P24 (0x1u << 24)
403#define PIO_IFSR_P25 (0x1u << 25)
404#define PIO_IFSR_P26 (0x1u << 26)
405#define PIO_IFSR_P27 (0x1u << 27)
406#define PIO_IFSR_P28 (0x1u << 28)
407#define PIO_IFSR_P29 (0x1u << 29)
408#define PIO_IFSR_P30 (0x1u << 30)
409#define PIO_IFSR_P31 (0x1u << 31)
410/* -------- PIO_SODR : (PIO Offset: 0x0030) Set Output Data Register -------- */
411#define PIO_SODR_P0 (0x1u << 0)
412#define PIO_SODR_P1 (0x1u << 1)
413#define PIO_SODR_P2 (0x1u << 2)
414#define PIO_SODR_P3 (0x1u << 3)
415#define PIO_SODR_P4 (0x1u << 4)
416#define PIO_SODR_P5 (0x1u << 5)
417#define PIO_SODR_P6 (0x1u << 6)
418#define PIO_SODR_P7 (0x1u << 7)
419#define PIO_SODR_P8 (0x1u << 8)
420#define PIO_SODR_P9 (0x1u << 9)
421#define PIO_SODR_P10 (0x1u << 10)
422#define PIO_SODR_P11 (0x1u << 11)
423#define PIO_SODR_P12 (0x1u << 12)
424#define PIO_SODR_P13 (0x1u << 13)
425#define PIO_SODR_P14 (0x1u << 14)
426#define PIO_SODR_P15 (0x1u << 15)
427#define PIO_SODR_P16 (0x1u << 16)
428#define PIO_SODR_P17 (0x1u << 17)
429#define PIO_SODR_P18 (0x1u << 18)
430#define PIO_SODR_P19 (0x1u << 19)
431#define PIO_SODR_P20 (0x1u << 20)
432#define PIO_SODR_P21 (0x1u << 21)
433#define PIO_SODR_P22 (0x1u << 22)
434#define PIO_SODR_P23 (0x1u << 23)
435#define PIO_SODR_P24 (0x1u << 24)
436#define PIO_SODR_P25 (0x1u << 25)
437#define PIO_SODR_P26 (0x1u << 26)
438#define PIO_SODR_P27 (0x1u << 27)
439#define PIO_SODR_P28 (0x1u << 28)
440#define PIO_SODR_P29 (0x1u << 29)
441#define PIO_SODR_P30 (0x1u << 30)
442#define PIO_SODR_P31 (0x1u << 31)
443/* -------- PIO_CODR : (PIO Offset: 0x0034) Clear Output Data Register -------- */
444#define PIO_CODR_P0 (0x1u << 0)
445#define PIO_CODR_P1 (0x1u << 1)
446#define PIO_CODR_P2 (0x1u << 2)
447#define PIO_CODR_P3 (0x1u << 3)
448#define PIO_CODR_P4 (0x1u << 4)
449#define PIO_CODR_P5 (0x1u << 5)
450#define PIO_CODR_P6 (0x1u << 6)
451#define PIO_CODR_P7 (0x1u << 7)
452#define PIO_CODR_P8 (0x1u << 8)
453#define PIO_CODR_P9 (0x1u << 9)
454#define PIO_CODR_P10 (0x1u << 10)
455#define PIO_CODR_P11 (0x1u << 11)
456#define PIO_CODR_P12 (0x1u << 12)
457#define PIO_CODR_P13 (0x1u << 13)
458#define PIO_CODR_P14 (0x1u << 14)
459#define PIO_CODR_P15 (0x1u << 15)
460#define PIO_CODR_P16 (0x1u << 16)
461#define PIO_CODR_P17 (0x1u << 17)
462#define PIO_CODR_P18 (0x1u << 18)
463#define PIO_CODR_P19 (0x1u << 19)
464#define PIO_CODR_P20 (0x1u << 20)
465#define PIO_CODR_P21 (0x1u << 21)
466#define PIO_CODR_P22 (0x1u << 22)
467#define PIO_CODR_P23 (0x1u << 23)
468#define PIO_CODR_P24 (0x1u << 24)
469#define PIO_CODR_P25 (0x1u << 25)
470#define PIO_CODR_P26 (0x1u << 26)
471#define PIO_CODR_P27 (0x1u << 27)
472#define PIO_CODR_P28 (0x1u << 28)
473#define PIO_CODR_P29 (0x1u << 29)
474#define PIO_CODR_P30 (0x1u << 30)
475#define PIO_CODR_P31 (0x1u << 31)
476/* -------- PIO_ODSR : (PIO Offset: 0x0038) Output Data Status Register -------- */
477#define PIO_ODSR_P0 (0x1u << 0)
478#define PIO_ODSR_P1 (0x1u << 1)
479#define PIO_ODSR_P2 (0x1u << 2)
480#define PIO_ODSR_P3 (0x1u << 3)
481#define PIO_ODSR_P4 (0x1u << 4)
482#define PIO_ODSR_P5 (0x1u << 5)
483#define PIO_ODSR_P6 (0x1u << 6)
484#define PIO_ODSR_P7 (0x1u << 7)
485#define PIO_ODSR_P8 (0x1u << 8)
486#define PIO_ODSR_P9 (0x1u << 9)
487#define PIO_ODSR_P10 (0x1u << 10)
488#define PIO_ODSR_P11 (0x1u << 11)
489#define PIO_ODSR_P12 (0x1u << 12)
490#define PIO_ODSR_P13 (0x1u << 13)
491#define PIO_ODSR_P14 (0x1u << 14)
492#define PIO_ODSR_P15 (0x1u << 15)
493#define PIO_ODSR_P16 (0x1u << 16)
494#define PIO_ODSR_P17 (0x1u << 17)
495#define PIO_ODSR_P18 (0x1u << 18)
496#define PIO_ODSR_P19 (0x1u << 19)
497#define PIO_ODSR_P20 (0x1u << 20)
498#define PIO_ODSR_P21 (0x1u << 21)
499#define PIO_ODSR_P22 (0x1u << 22)
500#define PIO_ODSR_P23 (0x1u << 23)
501#define PIO_ODSR_P24 (0x1u << 24)
502#define PIO_ODSR_P25 (0x1u << 25)
503#define PIO_ODSR_P26 (0x1u << 26)
504#define PIO_ODSR_P27 (0x1u << 27)
505#define PIO_ODSR_P28 (0x1u << 28)
506#define PIO_ODSR_P29 (0x1u << 29)
507#define PIO_ODSR_P30 (0x1u << 30)
508#define PIO_ODSR_P31 (0x1u << 31)
509/* -------- PIO_PDSR : (PIO Offset: 0x003C) Pin Data Status Register -------- */
510#define PIO_PDSR_P0 (0x1u << 0)
511#define PIO_PDSR_P1 (0x1u << 1)
512#define PIO_PDSR_P2 (0x1u << 2)
513#define PIO_PDSR_P3 (0x1u << 3)
514#define PIO_PDSR_P4 (0x1u << 4)
515#define PIO_PDSR_P5 (0x1u << 5)
516#define PIO_PDSR_P6 (0x1u << 6)
517#define PIO_PDSR_P7 (0x1u << 7)
518#define PIO_PDSR_P8 (0x1u << 8)
519#define PIO_PDSR_P9 (0x1u << 9)
520#define PIO_PDSR_P10 (0x1u << 10)
521#define PIO_PDSR_P11 (0x1u << 11)
522#define PIO_PDSR_P12 (0x1u << 12)
523#define PIO_PDSR_P13 (0x1u << 13)
524#define PIO_PDSR_P14 (0x1u << 14)
525#define PIO_PDSR_P15 (0x1u << 15)
526#define PIO_PDSR_P16 (0x1u << 16)
527#define PIO_PDSR_P17 (0x1u << 17)
528#define PIO_PDSR_P18 (0x1u << 18)
529#define PIO_PDSR_P19 (0x1u << 19)
530#define PIO_PDSR_P20 (0x1u << 20)
531#define PIO_PDSR_P21 (0x1u << 21)
532#define PIO_PDSR_P22 (0x1u << 22)
533#define PIO_PDSR_P23 (0x1u << 23)
534#define PIO_PDSR_P24 (0x1u << 24)
535#define PIO_PDSR_P25 (0x1u << 25)
536#define PIO_PDSR_P26 (0x1u << 26)
537#define PIO_PDSR_P27 (0x1u << 27)
538#define PIO_PDSR_P28 (0x1u << 28)
539#define PIO_PDSR_P29 (0x1u << 29)
540#define PIO_PDSR_P30 (0x1u << 30)
541#define PIO_PDSR_P31 (0x1u << 31)
542/* -------- PIO_IER : (PIO Offset: 0x0040) Interrupt Enable Register -------- */
543#define PIO_IER_P0 (0x1u << 0)
544#define PIO_IER_P1 (0x1u << 1)
545#define PIO_IER_P2 (0x1u << 2)
546#define PIO_IER_P3 (0x1u << 3)
547#define PIO_IER_P4 (0x1u << 4)
548#define PIO_IER_P5 (0x1u << 5)
549#define PIO_IER_P6 (0x1u << 6)
550#define PIO_IER_P7 (0x1u << 7)
551#define PIO_IER_P8 (0x1u << 8)
552#define PIO_IER_P9 (0x1u << 9)
553#define PIO_IER_P10 (0x1u << 10)
554#define PIO_IER_P11 (0x1u << 11)
555#define PIO_IER_P12 (0x1u << 12)
556#define PIO_IER_P13 (0x1u << 13)
557#define PIO_IER_P14 (0x1u << 14)
558#define PIO_IER_P15 (0x1u << 15)
559#define PIO_IER_P16 (0x1u << 16)
560#define PIO_IER_P17 (0x1u << 17)
561#define PIO_IER_P18 (0x1u << 18)
562#define PIO_IER_P19 (0x1u << 19)
563#define PIO_IER_P20 (0x1u << 20)
564#define PIO_IER_P21 (0x1u << 21)
565#define PIO_IER_P22 (0x1u << 22)
566#define PIO_IER_P23 (0x1u << 23)
567#define PIO_IER_P24 (0x1u << 24)
568#define PIO_IER_P25 (0x1u << 25)
569#define PIO_IER_P26 (0x1u << 26)
570#define PIO_IER_P27 (0x1u << 27)
571#define PIO_IER_P28 (0x1u << 28)
572#define PIO_IER_P29 (0x1u << 29)
573#define PIO_IER_P30 (0x1u << 30)
574#define PIO_IER_P31 (0x1u << 31)
575/* -------- PIO_IDR : (PIO Offset: 0x0044) Interrupt Disable Register -------- */
576#define PIO_IDR_P0 (0x1u << 0)
577#define PIO_IDR_P1 (0x1u << 1)
578#define PIO_IDR_P2 (0x1u << 2)
579#define PIO_IDR_P3 (0x1u << 3)
580#define PIO_IDR_P4 (0x1u << 4)
581#define PIO_IDR_P5 (0x1u << 5)
582#define PIO_IDR_P6 (0x1u << 6)
583#define PIO_IDR_P7 (0x1u << 7)
584#define PIO_IDR_P8 (0x1u << 8)
585#define PIO_IDR_P9 (0x1u << 9)
586#define PIO_IDR_P10 (0x1u << 10)
587#define PIO_IDR_P11 (0x1u << 11)
588#define PIO_IDR_P12 (0x1u << 12)
589#define PIO_IDR_P13 (0x1u << 13)
590#define PIO_IDR_P14 (0x1u << 14)
591#define PIO_IDR_P15 (0x1u << 15)
592#define PIO_IDR_P16 (0x1u << 16)
593#define PIO_IDR_P17 (0x1u << 17)
594#define PIO_IDR_P18 (0x1u << 18)
595#define PIO_IDR_P19 (0x1u << 19)
596#define PIO_IDR_P20 (0x1u << 20)
597#define PIO_IDR_P21 (0x1u << 21)
598#define PIO_IDR_P22 (0x1u << 22)
599#define PIO_IDR_P23 (0x1u << 23)
600#define PIO_IDR_P24 (0x1u << 24)
601#define PIO_IDR_P25 (0x1u << 25)
602#define PIO_IDR_P26 (0x1u << 26)
603#define PIO_IDR_P27 (0x1u << 27)
604#define PIO_IDR_P28 (0x1u << 28)
605#define PIO_IDR_P29 (0x1u << 29)
606#define PIO_IDR_P30 (0x1u << 30)
607#define PIO_IDR_P31 (0x1u << 31)
608/* -------- PIO_IMR : (PIO Offset: 0x0048) Interrupt Mask Register -------- */
609#define PIO_IMR_P0 (0x1u << 0)
610#define PIO_IMR_P1 (0x1u << 1)
611#define PIO_IMR_P2 (0x1u << 2)
612#define PIO_IMR_P3 (0x1u << 3)
613#define PIO_IMR_P4 (0x1u << 4)
614#define PIO_IMR_P5 (0x1u << 5)
615#define PIO_IMR_P6 (0x1u << 6)
616#define PIO_IMR_P7 (0x1u << 7)
617#define PIO_IMR_P8 (0x1u << 8)
618#define PIO_IMR_P9 (0x1u << 9)
619#define PIO_IMR_P10 (0x1u << 10)
620#define PIO_IMR_P11 (0x1u << 11)
621#define PIO_IMR_P12 (0x1u << 12)
622#define PIO_IMR_P13 (0x1u << 13)
623#define PIO_IMR_P14 (0x1u << 14)
624#define PIO_IMR_P15 (0x1u << 15)
625#define PIO_IMR_P16 (0x1u << 16)
626#define PIO_IMR_P17 (0x1u << 17)
627#define PIO_IMR_P18 (0x1u << 18)
628#define PIO_IMR_P19 (0x1u << 19)
629#define PIO_IMR_P20 (0x1u << 20)
630#define PIO_IMR_P21 (0x1u << 21)
631#define PIO_IMR_P22 (0x1u << 22)
632#define PIO_IMR_P23 (0x1u << 23)
633#define PIO_IMR_P24 (0x1u << 24)
634#define PIO_IMR_P25 (0x1u << 25)
635#define PIO_IMR_P26 (0x1u << 26)
636#define PIO_IMR_P27 (0x1u << 27)
637#define PIO_IMR_P28 (0x1u << 28)
638#define PIO_IMR_P29 (0x1u << 29)
639#define PIO_IMR_P30 (0x1u << 30)
640#define PIO_IMR_P31 (0x1u << 31)
641/* -------- PIO_ISR : (PIO Offset: 0x004C) Interrupt Status Register -------- */
642#define PIO_ISR_P0 (0x1u << 0)
643#define PIO_ISR_P1 (0x1u << 1)
644#define PIO_ISR_P2 (0x1u << 2)
645#define PIO_ISR_P3 (0x1u << 3)
646#define PIO_ISR_P4 (0x1u << 4)
647#define PIO_ISR_P5 (0x1u << 5)
648#define PIO_ISR_P6 (0x1u << 6)
649#define PIO_ISR_P7 (0x1u << 7)
650#define PIO_ISR_P8 (0x1u << 8)
651#define PIO_ISR_P9 (0x1u << 9)
652#define PIO_ISR_P10 (0x1u << 10)
653#define PIO_ISR_P11 (0x1u << 11)
654#define PIO_ISR_P12 (0x1u << 12)
655#define PIO_ISR_P13 (0x1u << 13)
656#define PIO_ISR_P14 (0x1u << 14)
657#define PIO_ISR_P15 (0x1u << 15)
658#define PIO_ISR_P16 (0x1u << 16)
659#define PIO_ISR_P17 (0x1u << 17)
660#define PIO_ISR_P18 (0x1u << 18)
661#define PIO_ISR_P19 (0x1u << 19)
662#define PIO_ISR_P20 (0x1u << 20)
663#define PIO_ISR_P21 (0x1u << 21)
664#define PIO_ISR_P22 (0x1u << 22)
665#define PIO_ISR_P23 (0x1u << 23)
666#define PIO_ISR_P24 (0x1u << 24)
667#define PIO_ISR_P25 (0x1u << 25)
668#define PIO_ISR_P26 (0x1u << 26)
669#define PIO_ISR_P27 (0x1u << 27)
670#define PIO_ISR_P28 (0x1u << 28)
671#define PIO_ISR_P29 (0x1u << 29)
672#define PIO_ISR_P30 (0x1u << 30)
673#define PIO_ISR_P31 (0x1u << 31)
674/* -------- PIO_MDER : (PIO Offset: 0x0050) Multi-driver Enable Register -------- */
675#define PIO_MDER_P0 (0x1u << 0)
676#define PIO_MDER_P1 (0x1u << 1)
677#define PIO_MDER_P2 (0x1u << 2)
678#define PIO_MDER_P3 (0x1u << 3)
679#define PIO_MDER_P4 (0x1u << 4)
680#define PIO_MDER_P5 (0x1u << 5)
681#define PIO_MDER_P6 (0x1u << 6)
682#define PIO_MDER_P7 (0x1u << 7)
683#define PIO_MDER_P8 (0x1u << 8)
684#define PIO_MDER_P9 (0x1u << 9)
685#define PIO_MDER_P10 (0x1u << 10)
686#define PIO_MDER_P11 (0x1u << 11)
687#define PIO_MDER_P12 (0x1u << 12)
688#define PIO_MDER_P13 (0x1u << 13)
689#define PIO_MDER_P14 (0x1u << 14)
690#define PIO_MDER_P15 (0x1u << 15)
691#define PIO_MDER_P16 (0x1u << 16)
692#define PIO_MDER_P17 (0x1u << 17)
693#define PIO_MDER_P18 (0x1u << 18)
694#define PIO_MDER_P19 (0x1u << 19)
695#define PIO_MDER_P20 (0x1u << 20)
696#define PIO_MDER_P21 (0x1u << 21)
697#define PIO_MDER_P22 (0x1u << 22)
698#define PIO_MDER_P23 (0x1u << 23)
699#define PIO_MDER_P24 (0x1u << 24)
700#define PIO_MDER_P25 (0x1u << 25)
701#define PIO_MDER_P26 (0x1u << 26)
702#define PIO_MDER_P27 (0x1u << 27)
703#define PIO_MDER_P28 (0x1u << 28)
704#define PIO_MDER_P29 (0x1u << 29)
705#define PIO_MDER_P30 (0x1u << 30)
706#define PIO_MDER_P31 (0x1u << 31)
707/* -------- PIO_MDDR : (PIO Offset: 0x0054) Multi-driver Disable Register -------- */
708#define PIO_MDDR_P0 (0x1u << 0)
709#define PIO_MDDR_P1 (0x1u << 1)
710#define PIO_MDDR_P2 (0x1u << 2)
711#define PIO_MDDR_P3 (0x1u << 3)
712#define PIO_MDDR_P4 (0x1u << 4)
713#define PIO_MDDR_P5 (0x1u << 5)
714#define PIO_MDDR_P6 (0x1u << 6)
715#define PIO_MDDR_P7 (0x1u << 7)
716#define PIO_MDDR_P8 (0x1u << 8)
717#define PIO_MDDR_P9 (0x1u << 9)
718#define PIO_MDDR_P10 (0x1u << 10)
719#define PIO_MDDR_P11 (0x1u << 11)
720#define PIO_MDDR_P12 (0x1u << 12)
721#define PIO_MDDR_P13 (0x1u << 13)
722#define PIO_MDDR_P14 (0x1u << 14)
723#define PIO_MDDR_P15 (0x1u << 15)
724#define PIO_MDDR_P16 (0x1u << 16)
725#define PIO_MDDR_P17 (0x1u << 17)
726#define PIO_MDDR_P18 (0x1u << 18)
727#define PIO_MDDR_P19 (0x1u << 19)
728#define PIO_MDDR_P20 (0x1u << 20)
729#define PIO_MDDR_P21 (0x1u << 21)
730#define PIO_MDDR_P22 (0x1u << 22)
731#define PIO_MDDR_P23 (0x1u << 23)
732#define PIO_MDDR_P24 (0x1u << 24)
733#define PIO_MDDR_P25 (0x1u << 25)
734#define PIO_MDDR_P26 (0x1u << 26)
735#define PIO_MDDR_P27 (0x1u << 27)
736#define PIO_MDDR_P28 (0x1u << 28)
737#define PIO_MDDR_P29 (0x1u << 29)
738#define PIO_MDDR_P30 (0x1u << 30)
739#define PIO_MDDR_P31 (0x1u << 31)
740/* -------- PIO_MDSR : (PIO Offset: 0x0058) Multi-driver Status Register -------- */
741#define PIO_MDSR_P0 (0x1u << 0)
742#define PIO_MDSR_P1 (0x1u << 1)
743#define PIO_MDSR_P2 (0x1u << 2)
744#define PIO_MDSR_P3 (0x1u << 3)
745#define PIO_MDSR_P4 (0x1u << 4)
746#define PIO_MDSR_P5 (0x1u << 5)
747#define PIO_MDSR_P6 (0x1u << 6)
748#define PIO_MDSR_P7 (0x1u << 7)
749#define PIO_MDSR_P8 (0x1u << 8)
750#define PIO_MDSR_P9 (0x1u << 9)
751#define PIO_MDSR_P10 (0x1u << 10)
752#define PIO_MDSR_P11 (0x1u << 11)
753#define PIO_MDSR_P12 (0x1u << 12)
754#define PIO_MDSR_P13 (0x1u << 13)
755#define PIO_MDSR_P14 (0x1u << 14)
756#define PIO_MDSR_P15 (0x1u << 15)
757#define PIO_MDSR_P16 (0x1u << 16)
758#define PIO_MDSR_P17 (0x1u << 17)
759#define PIO_MDSR_P18 (0x1u << 18)
760#define PIO_MDSR_P19 (0x1u << 19)
761#define PIO_MDSR_P20 (0x1u << 20)
762#define PIO_MDSR_P21 (0x1u << 21)
763#define PIO_MDSR_P22 (0x1u << 22)
764#define PIO_MDSR_P23 (0x1u << 23)
765#define PIO_MDSR_P24 (0x1u << 24)
766#define PIO_MDSR_P25 (0x1u << 25)
767#define PIO_MDSR_P26 (0x1u << 26)
768#define PIO_MDSR_P27 (0x1u << 27)
769#define PIO_MDSR_P28 (0x1u << 28)
770#define PIO_MDSR_P29 (0x1u << 29)
771#define PIO_MDSR_P30 (0x1u << 30)
772#define PIO_MDSR_P31 (0x1u << 31)
773/* -------- PIO_PUDR : (PIO Offset: 0x0060) Pull-up Disable Register -------- */
774#define PIO_PUDR_P0 (0x1u << 0)
775#define PIO_PUDR_P1 (0x1u << 1)
776#define PIO_PUDR_P2 (0x1u << 2)
777#define PIO_PUDR_P3 (0x1u << 3)
778#define PIO_PUDR_P4 (0x1u << 4)
779#define PIO_PUDR_P5 (0x1u << 5)
780#define PIO_PUDR_P6 (0x1u << 6)
781#define PIO_PUDR_P7 (0x1u << 7)
782#define PIO_PUDR_P8 (0x1u << 8)
783#define PIO_PUDR_P9 (0x1u << 9)
784#define PIO_PUDR_P10 (0x1u << 10)
785#define PIO_PUDR_P11 (0x1u << 11)
786#define PIO_PUDR_P12 (0x1u << 12)
787#define PIO_PUDR_P13 (0x1u << 13)
788#define PIO_PUDR_P14 (0x1u << 14)
789#define PIO_PUDR_P15 (0x1u << 15)
790#define PIO_PUDR_P16 (0x1u << 16)
791#define PIO_PUDR_P17 (0x1u << 17)
792#define PIO_PUDR_P18 (0x1u << 18)
793#define PIO_PUDR_P19 (0x1u << 19)
794#define PIO_PUDR_P20 (0x1u << 20)
795#define PIO_PUDR_P21 (0x1u << 21)
796#define PIO_PUDR_P22 (0x1u << 22)
797#define PIO_PUDR_P23 (0x1u << 23)
798#define PIO_PUDR_P24 (0x1u << 24)
799#define PIO_PUDR_P25 (0x1u << 25)
800#define PIO_PUDR_P26 (0x1u << 26)
801#define PIO_PUDR_P27 (0x1u << 27)
802#define PIO_PUDR_P28 (0x1u << 28)
803#define PIO_PUDR_P29 (0x1u << 29)
804#define PIO_PUDR_P30 (0x1u << 30)
805#define PIO_PUDR_P31 (0x1u << 31)
806/* -------- PIO_PUER : (PIO Offset: 0x0064) Pull-up Enable Register -------- */
807#define PIO_PUER_P0 (0x1u << 0)
808#define PIO_PUER_P1 (0x1u << 1)
809#define PIO_PUER_P2 (0x1u << 2)
810#define PIO_PUER_P3 (0x1u << 3)
811#define PIO_PUER_P4 (0x1u << 4)
812#define PIO_PUER_P5 (0x1u << 5)
813#define PIO_PUER_P6 (0x1u << 6)
814#define PIO_PUER_P7 (0x1u << 7)
815#define PIO_PUER_P8 (0x1u << 8)
816#define PIO_PUER_P9 (0x1u << 9)
817#define PIO_PUER_P10 (0x1u << 10)
818#define PIO_PUER_P11 (0x1u << 11)
819#define PIO_PUER_P12 (0x1u << 12)
820#define PIO_PUER_P13 (0x1u << 13)
821#define PIO_PUER_P14 (0x1u << 14)
822#define PIO_PUER_P15 (0x1u << 15)
823#define PIO_PUER_P16 (0x1u << 16)
824#define PIO_PUER_P17 (0x1u << 17)
825#define PIO_PUER_P18 (0x1u << 18)
826#define PIO_PUER_P19 (0x1u << 19)
827#define PIO_PUER_P20 (0x1u << 20)
828#define PIO_PUER_P21 (0x1u << 21)
829#define PIO_PUER_P22 (0x1u << 22)
830#define PIO_PUER_P23 (0x1u << 23)
831#define PIO_PUER_P24 (0x1u << 24)
832#define PIO_PUER_P25 (0x1u << 25)
833#define PIO_PUER_P26 (0x1u << 26)
834#define PIO_PUER_P27 (0x1u << 27)
835#define PIO_PUER_P28 (0x1u << 28)
836#define PIO_PUER_P29 (0x1u << 29)
837#define PIO_PUER_P30 (0x1u << 30)
838#define PIO_PUER_P31 (0x1u << 31)
839/* -------- PIO_PUSR : (PIO Offset: 0x0068) Pad Pull-up Status Register -------- */
840#define PIO_PUSR_P0 (0x1u << 0)
841#define PIO_PUSR_P1 (0x1u << 1)
842#define PIO_PUSR_P2 (0x1u << 2)
843#define PIO_PUSR_P3 (0x1u << 3)
844#define PIO_PUSR_P4 (0x1u << 4)
845#define PIO_PUSR_P5 (0x1u << 5)
846#define PIO_PUSR_P6 (0x1u << 6)
847#define PIO_PUSR_P7 (0x1u << 7)
848#define PIO_PUSR_P8 (0x1u << 8)
849#define PIO_PUSR_P9 (0x1u << 9)
850#define PIO_PUSR_P10 (0x1u << 10)
851#define PIO_PUSR_P11 (0x1u << 11)
852#define PIO_PUSR_P12 (0x1u << 12)
853#define PIO_PUSR_P13 (0x1u << 13)
854#define PIO_PUSR_P14 (0x1u << 14)
855#define PIO_PUSR_P15 (0x1u << 15)
856#define PIO_PUSR_P16 (0x1u << 16)
857#define PIO_PUSR_P17 (0x1u << 17)
858#define PIO_PUSR_P18 (0x1u << 18)
859#define PIO_PUSR_P19 (0x1u << 19)
860#define PIO_PUSR_P20 (0x1u << 20)
861#define PIO_PUSR_P21 (0x1u << 21)
862#define PIO_PUSR_P22 (0x1u << 22)
863#define PIO_PUSR_P23 (0x1u << 23)
864#define PIO_PUSR_P24 (0x1u << 24)
865#define PIO_PUSR_P25 (0x1u << 25)
866#define PIO_PUSR_P26 (0x1u << 26)
867#define PIO_PUSR_P27 (0x1u << 27)
868#define PIO_PUSR_P28 (0x1u << 28)
869#define PIO_PUSR_P29 (0x1u << 29)
870#define PIO_PUSR_P30 (0x1u << 30)
871#define PIO_PUSR_P31 (0x1u << 31)
872/* -------- PIO_ABCDSR[2] : (PIO Offset: 0x0070) Peripheral Select Register -------- */
873#define PIO_ABCDSR_P0 (0x1u << 0)
874#define PIO_ABCDSR_P1 (0x1u << 1)
875#define PIO_ABCDSR_P2 (0x1u << 2)
876#define PIO_ABCDSR_P3 (0x1u << 3)
877#define PIO_ABCDSR_P4 (0x1u << 4)
878#define PIO_ABCDSR_P5 (0x1u << 5)
879#define PIO_ABCDSR_P6 (0x1u << 6)
880#define PIO_ABCDSR_P7 (0x1u << 7)
881#define PIO_ABCDSR_P8 (0x1u << 8)
882#define PIO_ABCDSR_P9 (0x1u << 9)
883#define PIO_ABCDSR_P10 (0x1u << 10)
884#define PIO_ABCDSR_P11 (0x1u << 11)
885#define PIO_ABCDSR_P12 (0x1u << 12)
886#define PIO_ABCDSR_P13 (0x1u << 13)
887#define PIO_ABCDSR_P14 (0x1u << 14)
888#define PIO_ABCDSR_P15 (0x1u << 15)
889#define PIO_ABCDSR_P16 (0x1u << 16)
890#define PIO_ABCDSR_P17 (0x1u << 17)
891#define PIO_ABCDSR_P18 (0x1u << 18)
892#define PIO_ABCDSR_P19 (0x1u << 19)
893#define PIO_ABCDSR_P20 (0x1u << 20)
894#define PIO_ABCDSR_P21 (0x1u << 21)
895#define PIO_ABCDSR_P22 (0x1u << 22)
896#define PIO_ABCDSR_P23 (0x1u << 23)
897#define PIO_ABCDSR_P24 (0x1u << 24)
898#define PIO_ABCDSR_P25 (0x1u << 25)
899#define PIO_ABCDSR_P26 (0x1u << 26)
900#define PIO_ABCDSR_P27 (0x1u << 27)
901#define PIO_ABCDSR_P28 (0x1u << 28)
902#define PIO_ABCDSR_P29 (0x1u << 29)
903#define PIO_ABCDSR_P30 (0x1u << 30)
904#define PIO_ABCDSR_P31 (0x1u << 31)
905/* -------- PIO_IFSCDR : (PIO Offset: 0x0080) Input Filter Slow Clock Disable Register -------- */
906#define PIO_IFSCDR_P0 (0x1u << 0)
907#define PIO_IFSCDR_P1 (0x1u << 1)
908#define PIO_IFSCDR_P2 (0x1u << 2)
909#define PIO_IFSCDR_P3 (0x1u << 3)
910#define PIO_IFSCDR_P4 (0x1u << 4)
911#define PIO_IFSCDR_P5 (0x1u << 5)
912#define PIO_IFSCDR_P6 (0x1u << 6)
913#define PIO_IFSCDR_P7 (0x1u << 7)
914#define PIO_IFSCDR_P8 (0x1u << 8)
915#define PIO_IFSCDR_P9 (0x1u << 9)
916#define PIO_IFSCDR_P10 (0x1u << 10)
917#define PIO_IFSCDR_P11 (0x1u << 11)
918#define PIO_IFSCDR_P12 (0x1u << 12)
919#define PIO_IFSCDR_P13 (0x1u << 13)
920#define PIO_IFSCDR_P14 (0x1u << 14)
921#define PIO_IFSCDR_P15 (0x1u << 15)
922#define PIO_IFSCDR_P16 (0x1u << 16)
923#define PIO_IFSCDR_P17 (0x1u << 17)
924#define PIO_IFSCDR_P18 (0x1u << 18)
925#define PIO_IFSCDR_P19 (0x1u << 19)
926#define PIO_IFSCDR_P20 (0x1u << 20)
927#define PIO_IFSCDR_P21 (0x1u << 21)
928#define PIO_IFSCDR_P22 (0x1u << 22)
929#define PIO_IFSCDR_P23 (0x1u << 23)
930#define PIO_IFSCDR_P24 (0x1u << 24)
931#define PIO_IFSCDR_P25 (0x1u << 25)
932#define PIO_IFSCDR_P26 (0x1u << 26)
933#define PIO_IFSCDR_P27 (0x1u << 27)
934#define PIO_IFSCDR_P28 (0x1u << 28)
935#define PIO_IFSCDR_P29 (0x1u << 29)
936#define PIO_IFSCDR_P30 (0x1u << 30)
937#define PIO_IFSCDR_P31 (0x1u << 31)
938/* -------- PIO_IFSCER : (PIO Offset: 0x0084) Input Filter Slow Clock Enable Register -------- */
939#define PIO_IFSCER_P0 (0x1u << 0)
940#define PIO_IFSCER_P1 (0x1u << 1)
941#define PIO_IFSCER_P2 (0x1u << 2)
942#define PIO_IFSCER_P3 (0x1u << 3)
943#define PIO_IFSCER_P4 (0x1u << 4)
944#define PIO_IFSCER_P5 (0x1u << 5)
945#define PIO_IFSCER_P6 (0x1u << 6)
946#define PIO_IFSCER_P7 (0x1u << 7)
947#define PIO_IFSCER_P8 (0x1u << 8)
948#define PIO_IFSCER_P9 (0x1u << 9)
949#define PIO_IFSCER_P10 (0x1u << 10)
950#define PIO_IFSCER_P11 (0x1u << 11)
951#define PIO_IFSCER_P12 (0x1u << 12)
952#define PIO_IFSCER_P13 (0x1u << 13)
953#define PIO_IFSCER_P14 (0x1u << 14)
954#define PIO_IFSCER_P15 (0x1u << 15)
955#define PIO_IFSCER_P16 (0x1u << 16)
956#define PIO_IFSCER_P17 (0x1u << 17)
957#define PIO_IFSCER_P18 (0x1u << 18)
958#define PIO_IFSCER_P19 (0x1u << 19)
959#define PIO_IFSCER_P20 (0x1u << 20)
960#define PIO_IFSCER_P21 (0x1u << 21)
961#define PIO_IFSCER_P22 (0x1u << 22)
962#define PIO_IFSCER_P23 (0x1u << 23)
963#define PIO_IFSCER_P24 (0x1u << 24)
964#define PIO_IFSCER_P25 (0x1u << 25)
965#define PIO_IFSCER_P26 (0x1u << 26)
966#define PIO_IFSCER_P27 (0x1u << 27)
967#define PIO_IFSCER_P28 (0x1u << 28)
968#define PIO_IFSCER_P29 (0x1u << 29)
969#define PIO_IFSCER_P30 (0x1u << 30)
970#define PIO_IFSCER_P31 (0x1u << 31)
971/* -------- PIO_IFSCSR : (PIO Offset: 0x0088) Input Filter Slow Clock Status Register -------- */
972#define PIO_IFSCSR_P0 (0x1u << 0)
973#define PIO_IFSCSR_P1 (0x1u << 1)
974#define PIO_IFSCSR_P2 (0x1u << 2)
975#define PIO_IFSCSR_P3 (0x1u << 3)
976#define PIO_IFSCSR_P4 (0x1u << 4)
977#define PIO_IFSCSR_P5 (0x1u << 5)
978#define PIO_IFSCSR_P6 (0x1u << 6)
979#define PIO_IFSCSR_P7 (0x1u << 7)
980#define PIO_IFSCSR_P8 (0x1u << 8)
981#define PIO_IFSCSR_P9 (0x1u << 9)
982#define PIO_IFSCSR_P10 (0x1u << 10)
983#define PIO_IFSCSR_P11 (0x1u << 11)
984#define PIO_IFSCSR_P12 (0x1u << 12)
985#define PIO_IFSCSR_P13 (0x1u << 13)
986#define PIO_IFSCSR_P14 (0x1u << 14)
987#define PIO_IFSCSR_P15 (0x1u << 15)
988#define PIO_IFSCSR_P16 (0x1u << 16)
989#define PIO_IFSCSR_P17 (0x1u << 17)
990#define PIO_IFSCSR_P18 (0x1u << 18)
991#define PIO_IFSCSR_P19 (0x1u << 19)
992#define PIO_IFSCSR_P20 (0x1u << 20)
993#define PIO_IFSCSR_P21 (0x1u << 21)
994#define PIO_IFSCSR_P22 (0x1u << 22)
995#define PIO_IFSCSR_P23 (0x1u << 23)
996#define PIO_IFSCSR_P24 (0x1u << 24)
997#define PIO_IFSCSR_P25 (0x1u << 25)
998#define PIO_IFSCSR_P26 (0x1u << 26)
999#define PIO_IFSCSR_P27 (0x1u << 27)
1000#define PIO_IFSCSR_P28 (0x1u << 28)
1001#define PIO_IFSCSR_P29 (0x1u << 29)
1002#define PIO_IFSCSR_P30 (0x1u << 30)
1003#define PIO_IFSCSR_P31 (0x1u << 31)
1004/* -------- PIO_SCDR : (PIO Offset: 0x008C) Slow Clock Divider Debouncing Register -------- */
1005#define PIO_SCDR_DIV_Pos 0
1006#define PIO_SCDR_DIV_Msk (0x3fffu << PIO_SCDR_DIV_Pos)
1007#define PIO_SCDR_DIV(value) ((PIO_SCDR_DIV_Msk & ((value) << PIO_SCDR_DIV_Pos)))
1008/* -------- PIO_PPDDR : (PIO Offset: 0x0090) Pad Pull-down Disable Register -------- */
1009#define PIO_PPDDR_P0 (0x1u << 0)
1010#define PIO_PPDDR_P1 (0x1u << 1)
1011#define PIO_PPDDR_P2 (0x1u << 2)
1012#define PIO_PPDDR_P3 (0x1u << 3)
1013#define PIO_PPDDR_P4 (0x1u << 4)
1014#define PIO_PPDDR_P5 (0x1u << 5)
1015#define PIO_PPDDR_P6 (0x1u << 6)
1016#define PIO_PPDDR_P7 (0x1u << 7)
1017#define PIO_PPDDR_P8 (0x1u << 8)
1018#define PIO_PPDDR_P9 (0x1u << 9)
1019#define PIO_PPDDR_P10 (0x1u << 10)
1020#define PIO_PPDDR_P11 (0x1u << 11)
1021#define PIO_PPDDR_P12 (0x1u << 12)
1022#define PIO_PPDDR_P13 (0x1u << 13)
1023#define PIO_PPDDR_P14 (0x1u << 14)
1024#define PIO_PPDDR_P15 (0x1u << 15)
1025#define PIO_PPDDR_P16 (0x1u << 16)
1026#define PIO_PPDDR_P17 (0x1u << 17)
1027#define PIO_PPDDR_P18 (0x1u << 18)
1028#define PIO_PPDDR_P19 (0x1u << 19)
1029#define PIO_PPDDR_P20 (0x1u << 20)
1030#define PIO_PPDDR_P21 (0x1u << 21)
1031#define PIO_PPDDR_P22 (0x1u << 22)
1032#define PIO_PPDDR_P23 (0x1u << 23)
1033#define PIO_PPDDR_P24 (0x1u << 24)
1034#define PIO_PPDDR_P25 (0x1u << 25)
1035#define PIO_PPDDR_P26 (0x1u << 26)
1036#define PIO_PPDDR_P27 (0x1u << 27)
1037#define PIO_PPDDR_P28 (0x1u << 28)
1038#define PIO_PPDDR_P29 (0x1u << 29)
1039#define PIO_PPDDR_P30 (0x1u << 30)
1040#define PIO_PPDDR_P31 (0x1u << 31)
1041/* -------- PIO_PPDER : (PIO Offset: 0x0094) Pad Pull-down Enable Register -------- */
1042#define PIO_PPDER_P0 (0x1u << 0)
1043#define PIO_PPDER_P1 (0x1u << 1)
1044#define PIO_PPDER_P2 (0x1u << 2)
1045#define PIO_PPDER_P3 (0x1u << 3)
1046#define PIO_PPDER_P4 (0x1u << 4)
1047#define PIO_PPDER_P5 (0x1u << 5)
1048#define PIO_PPDER_P6 (0x1u << 6)
1049#define PIO_PPDER_P7 (0x1u << 7)
1050#define PIO_PPDER_P8 (0x1u << 8)
1051#define PIO_PPDER_P9 (0x1u << 9)
1052#define PIO_PPDER_P10 (0x1u << 10)
1053#define PIO_PPDER_P11 (0x1u << 11)
1054#define PIO_PPDER_P12 (0x1u << 12)
1055#define PIO_PPDER_P13 (0x1u << 13)
1056#define PIO_PPDER_P14 (0x1u << 14)
1057#define PIO_PPDER_P15 (0x1u << 15)
1058#define PIO_PPDER_P16 (0x1u << 16)
1059#define PIO_PPDER_P17 (0x1u << 17)
1060#define PIO_PPDER_P18 (0x1u << 18)
1061#define PIO_PPDER_P19 (0x1u << 19)
1062#define PIO_PPDER_P20 (0x1u << 20)
1063#define PIO_PPDER_P21 (0x1u << 21)
1064#define PIO_PPDER_P22 (0x1u << 22)
1065#define PIO_PPDER_P23 (0x1u << 23)
1066#define PIO_PPDER_P24 (0x1u << 24)
1067#define PIO_PPDER_P25 (0x1u << 25)
1068#define PIO_PPDER_P26 (0x1u << 26)
1069#define PIO_PPDER_P27 (0x1u << 27)
1070#define PIO_PPDER_P28 (0x1u << 28)
1071#define PIO_PPDER_P29 (0x1u << 29)
1072#define PIO_PPDER_P30 (0x1u << 30)
1073#define PIO_PPDER_P31 (0x1u << 31)
1074/* -------- PIO_PPDSR : (PIO Offset: 0x0098) Pad Pull-down Status Register -------- */
1075#define PIO_PPDSR_P0 (0x1u << 0)
1076#define PIO_PPDSR_P1 (0x1u << 1)
1077#define PIO_PPDSR_P2 (0x1u << 2)
1078#define PIO_PPDSR_P3 (0x1u << 3)
1079#define PIO_PPDSR_P4 (0x1u << 4)
1080#define PIO_PPDSR_P5 (0x1u << 5)
1081#define PIO_PPDSR_P6 (0x1u << 6)
1082#define PIO_PPDSR_P7 (0x1u << 7)
1083#define PIO_PPDSR_P8 (0x1u << 8)
1084#define PIO_PPDSR_P9 (0x1u << 9)
1085#define PIO_PPDSR_P10 (0x1u << 10)
1086#define PIO_PPDSR_P11 (0x1u << 11)
1087#define PIO_PPDSR_P12 (0x1u << 12)
1088#define PIO_PPDSR_P13 (0x1u << 13)
1089#define PIO_PPDSR_P14 (0x1u << 14)
1090#define PIO_PPDSR_P15 (0x1u << 15)
1091#define PIO_PPDSR_P16 (0x1u << 16)
1092#define PIO_PPDSR_P17 (0x1u << 17)
1093#define PIO_PPDSR_P18 (0x1u << 18)
1094#define PIO_PPDSR_P19 (0x1u << 19)
1095#define PIO_PPDSR_P20 (0x1u << 20)
1096#define PIO_PPDSR_P21 (0x1u << 21)
1097#define PIO_PPDSR_P22 (0x1u << 22)
1098#define PIO_PPDSR_P23 (0x1u << 23)
1099#define PIO_PPDSR_P24 (0x1u << 24)
1100#define PIO_PPDSR_P25 (0x1u << 25)
1101#define PIO_PPDSR_P26 (0x1u << 26)
1102#define PIO_PPDSR_P27 (0x1u << 27)
1103#define PIO_PPDSR_P28 (0x1u << 28)
1104#define PIO_PPDSR_P29 (0x1u << 29)
1105#define PIO_PPDSR_P30 (0x1u << 30)
1106#define PIO_PPDSR_P31 (0x1u << 31)
1107/* -------- PIO_OWER : (PIO Offset: 0x00A0) Output Write Enable -------- */
1108#define PIO_OWER_P0 (0x1u << 0)
1109#define PIO_OWER_P1 (0x1u << 1)
1110#define PIO_OWER_P2 (0x1u << 2)
1111#define PIO_OWER_P3 (0x1u << 3)
1112#define PIO_OWER_P4 (0x1u << 4)
1113#define PIO_OWER_P5 (0x1u << 5)
1114#define PIO_OWER_P6 (0x1u << 6)
1115#define PIO_OWER_P7 (0x1u << 7)
1116#define PIO_OWER_P8 (0x1u << 8)
1117#define PIO_OWER_P9 (0x1u << 9)
1118#define PIO_OWER_P10 (0x1u << 10)
1119#define PIO_OWER_P11 (0x1u << 11)
1120#define PIO_OWER_P12 (0x1u << 12)
1121#define PIO_OWER_P13 (0x1u << 13)
1122#define PIO_OWER_P14 (0x1u << 14)
1123#define PIO_OWER_P15 (0x1u << 15)
1124#define PIO_OWER_P16 (0x1u << 16)
1125#define PIO_OWER_P17 (0x1u << 17)
1126#define PIO_OWER_P18 (0x1u << 18)
1127#define PIO_OWER_P19 (0x1u << 19)
1128#define PIO_OWER_P20 (0x1u << 20)
1129#define PIO_OWER_P21 (0x1u << 21)
1130#define PIO_OWER_P22 (0x1u << 22)
1131#define PIO_OWER_P23 (0x1u << 23)
1132#define PIO_OWER_P24 (0x1u << 24)
1133#define PIO_OWER_P25 (0x1u << 25)
1134#define PIO_OWER_P26 (0x1u << 26)
1135#define PIO_OWER_P27 (0x1u << 27)
1136#define PIO_OWER_P28 (0x1u << 28)
1137#define PIO_OWER_P29 (0x1u << 29)
1138#define PIO_OWER_P30 (0x1u << 30)
1139#define PIO_OWER_P31 (0x1u << 31)
1140/* -------- PIO_OWDR : (PIO Offset: 0x00A4) Output Write Disable -------- */
1141#define PIO_OWDR_P0 (0x1u << 0)
1142#define PIO_OWDR_P1 (0x1u << 1)
1143#define PIO_OWDR_P2 (0x1u << 2)
1144#define PIO_OWDR_P3 (0x1u << 3)
1145#define PIO_OWDR_P4 (0x1u << 4)
1146#define PIO_OWDR_P5 (0x1u << 5)
1147#define PIO_OWDR_P6 (0x1u << 6)
1148#define PIO_OWDR_P7 (0x1u << 7)
1149#define PIO_OWDR_P8 (0x1u << 8)
1150#define PIO_OWDR_P9 (0x1u << 9)
1151#define PIO_OWDR_P10 (0x1u << 10)
1152#define PIO_OWDR_P11 (0x1u << 11)
1153#define PIO_OWDR_P12 (0x1u << 12)
1154#define PIO_OWDR_P13 (0x1u << 13)
1155#define PIO_OWDR_P14 (0x1u << 14)
1156#define PIO_OWDR_P15 (0x1u << 15)
1157#define PIO_OWDR_P16 (0x1u << 16)
1158#define PIO_OWDR_P17 (0x1u << 17)
1159#define PIO_OWDR_P18 (0x1u << 18)
1160#define PIO_OWDR_P19 (0x1u << 19)
1161#define PIO_OWDR_P20 (0x1u << 20)
1162#define PIO_OWDR_P21 (0x1u << 21)
1163#define PIO_OWDR_P22 (0x1u << 22)
1164#define PIO_OWDR_P23 (0x1u << 23)
1165#define PIO_OWDR_P24 (0x1u << 24)
1166#define PIO_OWDR_P25 (0x1u << 25)
1167#define PIO_OWDR_P26 (0x1u << 26)
1168#define PIO_OWDR_P27 (0x1u << 27)
1169#define PIO_OWDR_P28 (0x1u << 28)
1170#define PIO_OWDR_P29 (0x1u << 29)
1171#define PIO_OWDR_P30 (0x1u << 30)
1172#define PIO_OWDR_P31 (0x1u << 31)
1173/* -------- PIO_OWSR : (PIO Offset: 0x00A8) Output Write Status Register -------- */
1174#define PIO_OWSR_P0 (0x1u << 0)
1175#define PIO_OWSR_P1 (0x1u << 1)
1176#define PIO_OWSR_P2 (0x1u << 2)
1177#define PIO_OWSR_P3 (0x1u << 3)
1178#define PIO_OWSR_P4 (0x1u << 4)
1179#define PIO_OWSR_P5 (0x1u << 5)
1180#define PIO_OWSR_P6 (0x1u << 6)
1181#define PIO_OWSR_P7 (0x1u << 7)
1182#define PIO_OWSR_P8 (0x1u << 8)
1183#define PIO_OWSR_P9 (0x1u << 9)
1184#define PIO_OWSR_P10 (0x1u << 10)
1185#define PIO_OWSR_P11 (0x1u << 11)
1186#define PIO_OWSR_P12 (0x1u << 12)
1187#define PIO_OWSR_P13 (0x1u << 13)
1188#define PIO_OWSR_P14 (0x1u << 14)
1189#define PIO_OWSR_P15 (0x1u << 15)
1190#define PIO_OWSR_P16 (0x1u << 16)
1191#define PIO_OWSR_P17 (0x1u << 17)
1192#define PIO_OWSR_P18 (0x1u << 18)
1193#define PIO_OWSR_P19 (0x1u << 19)
1194#define PIO_OWSR_P20 (0x1u << 20)
1195#define PIO_OWSR_P21 (0x1u << 21)
1196#define PIO_OWSR_P22 (0x1u << 22)
1197#define PIO_OWSR_P23 (0x1u << 23)
1198#define PIO_OWSR_P24 (0x1u << 24)
1199#define PIO_OWSR_P25 (0x1u << 25)
1200#define PIO_OWSR_P26 (0x1u << 26)
1201#define PIO_OWSR_P27 (0x1u << 27)
1202#define PIO_OWSR_P28 (0x1u << 28)
1203#define PIO_OWSR_P29 (0x1u << 29)
1204#define PIO_OWSR_P30 (0x1u << 30)
1205#define PIO_OWSR_P31 (0x1u << 31)
1206/* -------- PIO_AIMER : (PIO Offset: 0x00B0) Additional Interrupt Modes Enable Register -------- */
1207#define PIO_AIMER_P0 (0x1u << 0)
1208#define PIO_AIMER_P1 (0x1u << 1)
1209#define PIO_AIMER_P2 (0x1u << 2)
1210#define PIO_AIMER_P3 (0x1u << 3)
1211#define PIO_AIMER_P4 (0x1u << 4)
1212#define PIO_AIMER_P5 (0x1u << 5)
1213#define PIO_AIMER_P6 (0x1u << 6)
1214#define PIO_AIMER_P7 (0x1u << 7)
1215#define PIO_AIMER_P8 (0x1u << 8)
1216#define PIO_AIMER_P9 (0x1u << 9)
1217#define PIO_AIMER_P10 (0x1u << 10)
1218#define PIO_AIMER_P11 (0x1u << 11)
1219#define PIO_AIMER_P12 (0x1u << 12)
1220#define PIO_AIMER_P13 (0x1u << 13)
1221#define PIO_AIMER_P14 (0x1u << 14)
1222#define PIO_AIMER_P15 (0x1u << 15)
1223#define PIO_AIMER_P16 (0x1u << 16)
1224#define PIO_AIMER_P17 (0x1u << 17)
1225#define PIO_AIMER_P18 (0x1u << 18)
1226#define PIO_AIMER_P19 (0x1u << 19)
1227#define PIO_AIMER_P20 (0x1u << 20)
1228#define PIO_AIMER_P21 (0x1u << 21)
1229#define PIO_AIMER_P22 (0x1u << 22)
1230#define PIO_AIMER_P23 (0x1u << 23)
1231#define PIO_AIMER_P24 (0x1u << 24)
1232#define PIO_AIMER_P25 (0x1u << 25)
1233#define PIO_AIMER_P26 (0x1u << 26)
1234#define PIO_AIMER_P27 (0x1u << 27)
1235#define PIO_AIMER_P28 (0x1u << 28)
1236#define PIO_AIMER_P29 (0x1u << 29)
1237#define PIO_AIMER_P30 (0x1u << 30)
1238#define PIO_AIMER_P31 (0x1u << 31)
1239/* -------- PIO_AIMDR : (PIO Offset: 0x00B4) Additional Interrupt Modes Disable Register -------- */
1240#define PIO_AIMDR_P0 (0x1u << 0)
1241#define PIO_AIMDR_P1 (0x1u << 1)
1242#define PIO_AIMDR_P2 (0x1u << 2)
1243#define PIO_AIMDR_P3 (0x1u << 3)
1244#define PIO_AIMDR_P4 (0x1u << 4)
1245#define PIO_AIMDR_P5 (0x1u << 5)
1246#define PIO_AIMDR_P6 (0x1u << 6)
1247#define PIO_AIMDR_P7 (0x1u << 7)
1248#define PIO_AIMDR_P8 (0x1u << 8)
1249#define PIO_AIMDR_P9 (0x1u << 9)
1250#define PIO_AIMDR_P10 (0x1u << 10)
1251#define PIO_AIMDR_P11 (0x1u << 11)
1252#define PIO_AIMDR_P12 (0x1u << 12)
1253#define PIO_AIMDR_P13 (0x1u << 13)
1254#define PIO_AIMDR_P14 (0x1u << 14)
1255#define PIO_AIMDR_P15 (0x1u << 15)
1256#define PIO_AIMDR_P16 (0x1u << 16)
1257#define PIO_AIMDR_P17 (0x1u << 17)
1258#define PIO_AIMDR_P18 (0x1u << 18)
1259#define PIO_AIMDR_P19 (0x1u << 19)
1260#define PIO_AIMDR_P20 (0x1u << 20)
1261#define PIO_AIMDR_P21 (0x1u << 21)
1262#define PIO_AIMDR_P22 (0x1u << 22)
1263#define PIO_AIMDR_P23 (0x1u << 23)
1264#define PIO_AIMDR_P24 (0x1u << 24)
1265#define PIO_AIMDR_P25 (0x1u << 25)
1266#define PIO_AIMDR_P26 (0x1u << 26)
1267#define PIO_AIMDR_P27 (0x1u << 27)
1268#define PIO_AIMDR_P28 (0x1u << 28)
1269#define PIO_AIMDR_P29 (0x1u << 29)
1270#define PIO_AIMDR_P30 (0x1u << 30)
1271#define PIO_AIMDR_P31 (0x1u << 31)
1272/* -------- PIO_AIMMR : (PIO Offset: 0x00B8) Additional Interrupt Modes Mask Register -------- */
1273#define PIO_AIMMR_P0 (0x1u << 0)
1274#define PIO_AIMMR_P1 (0x1u << 1)
1275#define PIO_AIMMR_P2 (0x1u << 2)
1276#define PIO_AIMMR_P3 (0x1u << 3)
1277#define PIO_AIMMR_P4 (0x1u << 4)
1278#define PIO_AIMMR_P5 (0x1u << 5)
1279#define PIO_AIMMR_P6 (0x1u << 6)
1280#define PIO_AIMMR_P7 (0x1u << 7)
1281#define PIO_AIMMR_P8 (0x1u << 8)
1282#define PIO_AIMMR_P9 (0x1u << 9)
1283#define PIO_AIMMR_P10 (0x1u << 10)
1284#define PIO_AIMMR_P11 (0x1u << 11)
1285#define PIO_AIMMR_P12 (0x1u << 12)
1286#define PIO_AIMMR_P13 (0x1u << 13)
1287#define PIO_AIMMR_P14 (0x1u << 14)
1288#define PIO_AIMMR_P15 (0x1u << 15)
1289#define PIO_AIMMR_P16 (0x1u << 16)
1290#define PIO_AIMMR_P17 (0x1u << 17)
1291#define PIO_AIMMR_P18 (0x1u << 18)
1292#define PIO_AIMMR_P19 (0x1u << 19)
1293#define PIO_AIMMR_P20 (0x1u << 20)
1294#define PIO_AIMMR_P21 (0x1u << 21)
1295#define PIO_AIMMR_P22 (0x1u << 22)
1296#define PIO_AIMMR_P23 (0x1u << 23)
1297#define PIO_AIMMR_P24 (0x1u << 24)
1298#define PIO_AIMMR_P25 (0x1u << 25)
1299#define PIO_AIMMR_P26 (0x1u << 26)
1300#define PIO_AIMMR_P27 (0x1u << 27)
1301#define PIO_AIMMR_P28 (0x1u << 28)
1302#define PIO_AIMMR_P29 (0x1u << 29)
1303#define PIO_AIMMR_P30 (0x1u << 30)
1304#define PIO_AIMMR_P31 (0x1u << 31)
1305/* -------- PIO_ESR : (PIO Offset: 0x00C0) Edge Select Register -------- */
1306#define PIO_ESR_P0 (0x1u << 0)
1307#define PIO_ESR_P1 (0x1u << 1)
1308#define PIO_ESR_P2 (0x1u << 2)
1309#define PIO_ESR_P3 (0x1u << 3)
1310#define PIO_ESR_P4 (0x1u << 4)
1311#define PIO_ESR_P5 (0x1u << 5)
1312#define PIO_ESR_P6 (0x1u << 6)
1313#define PIO_ESR_P7 (0x1u << 7)
1314#define PIO_ESR_P8 (0x1u << 8)
1315#define PIO_ESR_P9 (0x1u << 9)
1316#define PIO_ESR_P10 (0x1u << 10)
1317#define PIO_ESR_P11 (0x1u << 11)
1318#define PIO_ESR_P12 (0x1u << 12)
1319#define PIO_ESR_P13 (0x1u << 13)
1320#define PIO_ESR_P14 (0x1u << 14)
1321#define PIO_ESR_P15 (0x1u << 15)
1322#define PIO_ESR_P16 (0x1u << 16)
1323#define PIO_ESR_P17 (0x1u << 17)
1324#define PIO_ESR_P18 (0x1u << 18)
1325#define PIO_ESR_P19 (0x1u << 19)
1326#define PIO_ESR_P20 (0x1u << 20)
1327#define PIO_ESR_P21 (0x1u << 21)
1328#define PIO_ESR_P22 (0x1u << 22)
1329#define PIO_ESR_P23 (0x1u << 23)
1330#define PIO_ESR_P24 (0x1u << 24)
1331#define PIO_ESR_P25 (0x1u << 25)
1332#define PIO_ESR_P26 (0x1u << 26)
1333#define PIO_ESR_P27 (0x1u << 27)
1334#define PIO_ESR_P28 (0x1u << 28)
1335#define PIO_ESR_P29 (0x1u << 29)
1336#define PIO_ESR_P30 (0x1u << 30)
1337#define PIO_ESR_P31 (0x1u << 31)
1338/* -------- PIO_LSR : (PIO Offset: 0x00C4) Level Select Register -------- */
1339#define PIO_LSR_P0 (0x1u << 0)
1340#define PIO_LSR_P1 (0x1u << 1)
1341#define PIO_LSR_P2 (0x1u << 2)
1342#define PIO_LSR_P3 (0x1u << 3)
1343#define PIO_LSR_P4 (0x1u << 4)
1344#define PIO_LSR_P5 (0x1u << 5)
1345#define PIO_LSR_P6 (0x1u << 6)
1346#define PIO_LSR_P7 (0x1u << 7)
1347#define PIO_LSR_P8 (0x1u << 8)
1348#define PIO_LSR_P9 (0x1u << 9)
1349#define PIO_LSR_P10 (0x1u << 10)
1350#define PIO_LSR_P11 (0x1u << 11)
1351#define PIO_LSR_P12 (0x1u << 12)
1352#define PIO_LSR_P13 (0x1u << 13)
1353#define PIO_LSR_P14 (0x1u << 14)
1354#define PIO_LSR_P15 (0x1u << 15)
1355#define PIO_LSR_P16 (0x1u << 16)
1356#define PIO_LSR_P17 (0x1u << 17)
1357#define PIO_LSR_P18 (0x1u << 18)
1358#define PIO_LSR_P19 (0x1u << 19)
1359#define PIO_LSR_P20 (0x1u << 20)
1360#define PIO_LSR_P21 (0x1u << 21)
1361#define PIO_LSR_P22 (0x1u << 22)
1362#define PIO_LSR_P23 (0x1u << 23)
1363#define PIO_LSR_P24 (0x1u << 24)
1364#define PIO_LSR_P25 (0x1u << 25)
1365#define PIO_LSR_P26 (0x1u << 26)
1366#define PIO_LSR_P27 (0x1u << 27)
1367#define PIO_LSR_P28 (0x1u << 28)
1368#define PIO_LSR_P29 (0x1u << 29)
1369#define PIO_LSR_P30 (0x1u << 30)
1370#define PIO_LSR_P31 (0x1u << 31)
1371/* -------- PIO_ELSR : (PIO Offset: 0x00C8) Edge/Level Status Register -------- */
1372#define PIO_ELSR_P0 (0x1u << 0)
1373#define PIO_ELSR_P1 (0x1u << 1)
1374#define PIO_ELSR_P2 (0x1u << 2)
1375#define PIO_ELSR_P3 (0x1u << 3)
1376#define PIO_ELSR_P4 (0x1u << 4)
1377#define PIO_ELSR_P5 (0x1u << 5)
1378#define PIO_ELSR_P6 (0x1u << 6)
1379#define PIO_ELSR_P7 (0x1u << 7)
1380#define PIO_ELSR_P8 (0x1u << 8)
1381#define PIO_ELSR_P9 (0x1u << 9)
1382#define PIO_ELSR_P10 (0x1u << 10)
1383#define PIO_ELSR_P11 (0x1u << 11)
1384#define PIO_ELSR_P12 (0x1u << 12)
1385#define PIO_ELSR_P13 (0x1u << 13)
1386#define PIO_ELSR_P14 (0x1u << 14)
1387#define PIO_ELSR_P15 (0x1u << 15)
1388#define PIO_ELSR_P16 (0x1u << 16)
1389#define PIO_ELSR_P17 (0x1u << 17)
1390#define PIO_ELSR_P18 (0x1u << 18)
1391#define PIO_ELSR_P19 (0x1u << 19)
1392#define PIO_ELSR_P20 (0x1u << 20)
1393#define PIO_ELSR_P21 (0x1u << 21)
1394#define PIO_ELSR_P22 (0x1u << 22)
1395#define PIO_ELSR_P23 (0x1u << 23)
1396#define PIO_ELSR_P24 (0x1u << 24)
1397#define PIO_ELSR_P25 (0x1u << 25)
1398#define PIO_ELSR_P26 (0x1u << 26)
1399#define PIO_ELSR_P27 (0x1u << 27)
1400#define PIO_ELSR_P28 (0x1u << 28)
1401#define PIO_ELSR_P29 (0x1u << 29)
1402#define PIO_ELSR_P30 (0x1u << 30)
1403#define PIO_ELSR_P31 (0x1u << 31)
1404/* -------- PIO_FELLSR : (PIO Offset: 0x00D0) Falling Edge/Low-Level Select Register -------- */
1405#define PIO_FELLSR_P0 (0x1u << 0)
1406#define PIO_FELLSR_P1 (0x1u << 1)
1407#define PIO_FELLSR_P2 (0x1u << 2)
1408#define PIO_FELLSR_P3 (0x1u << 3)
1409#define PIO_FELLSR_P4 (0x1u << 4)
1410#define PIO_FELLSR_P5 (0x1u << 5)
1411#define PIO_FELLSR_P6 (0x1u << 6)
1412#define PIO_FELLSR_P7 (0x1u << 7)
1413#define PIO_FELLSR_P8 (0x1u << 8)
1414#define PIO_FELLSR_P9 (0x1u << 9)
1415#define PIO_FELLSR_P10 (0x1u << 10)
1416#define PIO_FELLSR_P11 (0x1u << 11)
1417#define PIO_FELLSR_P12 (0x1u << 12)
1418#define PIO_FELLSR_P13 (0x1u << 13)
1419#define PIO_FELLSR_P14 (0x1u << 14)
1420#define PIO_FELLSR_P15 (0x1u << 15)
1421#define PIO_FELLSR_P16 (0x1u << 16)
1422#define PIO_FELLSR_P17 (0x1u << 17)
1423#define PIO_FELLSR_P18 (0x1u << 18)
1424#define PIO_FELLSR_P19 (0x1u << 19)
1425#define PIO_FELLSR_P20 (0x1u << 20)
1426#define PIO_FELLSR_P21 (0x1u << 21)
1427#define PIO_FELLSR_P22 (0x1u << 22)
1428#define PIO_FELLSR_P23 (0x1u << 23)
1429#define PIO_FELLSR_P24 (0x1u << 24)
1430#define PIO_FELLSR_P25 (0x1u << 25)
1431#define PIO_FELLSR_P26 (0x1u << 26)
1432#define PIO_FELLSR_P27 (0x1u << 27)
1433#define PIO_FELLSR_P28 (0x1u << 28)
1434#define PIO_FELLSR_P29 (0x1u << 29)
1435#define PIO_FELLSR_P30 (0x1u << 30)
1436#define PIO_FELLSR_P31 (0x1u << 31)
1437/* -------- PIO_REHLSR : (PIO Offset: 0x00D4) Rising Edge/High-Level Select Register -------- */
1438#define PIO_REHLSR_P0 (0x1u << 0)
1439#define PIO_REHLSR_P1 (0x1u << 1)
1440#define PIO_REHLSR_P2 (0x1u << 2)
1441#define PIO_REHLSR_P3 (0x1u << 3)
1442#define PIO_REHLSR_P4 (0x1u << 4)
1443#define PIO_REHLSR_P5 (0x1u << 5)
1444#define PIO_REHLSR_P6 (0x1u << 6)
1445#define PIO_REHLSR_P7 (0x1u << 7)
1446#define PIO_REHLSR_P8 (0x1u << 8)
1447#define PIO_REHLSR_P9 (0x1u << 9)
1448#define PIO_REHLSR_P10 (0x1u << 10)
1449#define PIO_REHLSR_P11 (0x1u << 11)
1450#define PIO_REHLSR_P12 (0x1u << 12)
1451#define PIO_REHLSR_P13 (0x1u << 13)
1452#define PIO_REHLSR_P14 (0x1u << 14)
1453#define PIO_REHLSR_P15 (0x1u << 15)
1454#define PIO_REHLSR_P16 (0x1u << 16)
1455#define PIO_REHLSR_P17 (0x1u << 17)
1456#define PIO_REHLSR_P18 (0x1u << 18)
1457#define PIO_REHLSR_P19 (0x1u << 19)
1458#define PIO_REHLSR_P20 (0x1u << 20)
1459#define PIO_REHLSR_P21 (0x1u << 21)
1460#define PIO_REHLSR_P22 (0x1u << 22)
1461#define PIO_REHLSR_P23 (0x1u << 23)
1462#define PIO_REHLSR_P24 (0x1u << 24)
1463#define PIO_REHLSR_P25 (0x1u << 25)
1464#define PIO_REHLSR_P26 (0x1u << 26)
1465#define PIO_REHLSR_P27 (0x1u << 27)
1466#define PIO_REHLSR_P28 (0x1u << 28)
1467#define PIO_REHLSR_P29 (0x1u << 29)
1468#define PIO_REHLSR_P30 (0x1u << 30)
1469#define PIO_REHLSR_P31 (0x1u << 31)
1470/* -------- PIO_FRLHSR : (PIO Offset: 0x00D8) Fall/Rise - Low/High Status Register -------- */
1471#define PIO_FRLHSR_P0 (0x1u << 0)
1472#define PIO_FRLHSR_P1 (0x1u << 1)
1473#define PIO_FRLHSR_P2 (0x1u << 2)
1474#define PIO_FRLHSR_P3 (0x1u << 3)
1475#define PIO_FRLHSR_P4 (0x1u << 4)
1476#define PIO_FRLHSR_P5 (0x1u << 5)
1477#define PIO_FRLHSR_P6 (0x1u << 6)
1478#define PIO_FRLHSR_P7 (0x1u << 7)
1479#define PIO_FRLHSR_P8 (0x1u << 8)
1480#define PIO_FRLHSR_P9 (0x1u << 9)
1481#define PIO_FRLHSR_P10 (0x1u << 10)
1482#define PIO_FRLHSR_P11 (0x1u << 11)
1483#define PIO_FRLHSR_P12 (0x1u << 12)
1484#define PIO_FRLHSR_P13 (0x1u << 13)
1485#define PIO_FRLHSR_P14 (0x1u << 14)
1486#define PIO_FRLHSR_P15 (0x1u << 15)
1487#define PIO_FRLHSR_P16 (0x1u << 16)
1488#define PIO_FRLHSR_P17 (0x1u << 17)
1489#define PIO_FRLHSR_P18 (0x1u << 18)
1490#define PIO_FRLHSR_P19 (0x1u << 19)
1491#define PIO_FRLHSR_P20 (0x1u << 20)
1492#define PIO_FRLHSR_P21 (0x1u << 21)
1493#define PIO_FRLHSR_P22 (0x1u << 22)
1494#define PIO_FRLHSR_P23 (0x1u << 23)
1495#define PIO_FRLHSR_P24 (0x1u << 24)
1496#define PIO_FRLHSR_P25 (0x1u << 25)
1497#define PIO_FRLHSR_P26 (0x1u << 26)
1498#define PIO_FRLHSR_P27 (0x1u << 27)
1499#define PIO_FRLHSR_P28 (0x1u << 28)
1500#define PIO_FRLHSR_P29 (0x1u << 29)
1501#define PIO_FRLHSR_P30 (0x1u << 30)
1502#define PIO_FRLHSR_P31 (0x1u << 31)
1503/* -------- PIO_LOCKSR : (PIO Offset: 0x00E0) Lock Status -------- */
1504#define PIO_LOCKSR_P0 (0x1u << 0)
1505#define PIO_LOCKSR_P1 (0x1u << 1)
1506#define PIO_LOCKSR_P2 (0x1u << 2)
1507#define PIO_LOCKSR_P3 (0x1u << 3)
1508#define PIO_LOCKSR_P4 (0x1u << 4)
1509#define PIO_LOCKSR_P5 (0x1u << 5)
1510#define PIO_LOCKSR_P6 (0x1u << 6)
1511#define PIO_LOCKSR_P7 (0x1u << 7)
1512#define PIO_LOCKSR_P8 (0x1u << 8)
1513#define PIO_LOCKSR_P9 (0x1u << 9)
1514#define PIO_LOCKSR_P10 (0x1u << 10)
1515#define PIO_LOCKSR_P11 (0x1u << 11)
1516#define PIO_LOCKSR_P12 (0x1u << 12)
1517#define PIO_LOCKSR_P13 (0x1u << 13)
1518#define PIO_LOCKSR_P14 (0x1u << 14)
1519#define PIO_LOCKSR_P15 (0x1u << 15)
1520#define PIO_LOCKSR_P16 (0x1u << 16)
1521#define PIO_LOCKSR_P17 (0x1u << 17)
1522#define PIO_LOCKSR_P18 (0x1u << 18)
1523#define PIO_LOCKSR_P19 (0x1u << 19)
1524#define PIO_LOCKSR_P20 (0x1u << 20)
1525#define PIO_LOCKSR_P21 (0x1u << 21)
1526#define PIO_LOCKSR_P22 (0x1u << 22)
1527#define PIO_LOCKSR_P23 (0x1u << 23)
1528#define PIO_LOCKSR_P24 (0x1u << 24)
1529#define PIO_LOCKSR_P25 (0x1u << 25)
1530#define PIO_LOCKSR_P26 (0x1u << 26)
1531#define PIO_LOCKSR_P27 (0x1u << 27)
1532#define PIO_LOCKSR_P28 (0x1u << 28)
1533#define PIO_LOCKSR_P29 (0x1u << 29)
1534#define PIO_LOCKSR_P30 (0x1u << 30)
1535#define PIO_LOCKSR_P31 (0x1u << 31)
1536/* -------- PIO_WPMR : (PIO Offset: 0x00E4) Write Protection Mode Register -------- */
1537#define PIO_WPMR_WPEN (0x1u << 0)
1538#define PIO_WPMR_WPKEY_Pos 8
1539#define PIO_WPMR_WPKEY_Msk (0xffffffu << PIO_WPMR_WPKEY_Pos)
1540#define PIO_WPMR_WPKEY(value) ((PIO_WPMR_WPKEY_Msk & ((value) << PIO_WPMR_WPKEY_Pos)))
1541#define PIO_WPMR_WPKEY_PASSWD (0x50494Fu << 8)
1542/* -------- PIO_WPSR : (PIO Offset: 0x00E8) Write Protection Status Register -------- */
1543#define PIO_WPSR_WPVS (0x1u << 0)
1544#define PIO_WPSR_WPVSRC_Pos 8
1545#define PIO_WPSR_WPVSRC_Msk (0xffffu << PIO_WPSR_WPVSRC_Pos)
1546/* -------- PIO_VERSION : (PIO Offset: 0x00FC) Version Register -------- */
1547#define PIO_VERSION_VERSION_Pos 0
1548#define PIO_VERSION_VERSION_Msk (0xfffu << PIO_VERSION_VERSION_Pos)
1549#define PIO_VERSION_MFN_Pos 16
1550#define PIO_VERSION_MFN_Msk (0x7u << PIO_VERSION_MFN_Pos)
1551/* -------- PIO_SCHMITT : (PIO Offset: 0x0100) Schmitt Trigger Register -------- */
1552#define PIO_SCHMITT_SCHMITT0 (0x1u << 0)
1553#define PIO_SCHMITT_SCHMITT1 (0x1u << 1)
1554#define PIO_SCHMITT_SCHMITT2 (0x1u << 2)
1555#define PIO_SCHMITT_SCHMITT3 (0x1u << 3)
1556#define PIO_SCHMITT_SCHMITT4 (0x1u << 4)
1557#define PIO_SCHMITT_SCHMITT5 (0x1u << 5)
1558#define PIO_SCHMITT_SCHMITT6 (0x1u << 6)
1559#define PIO_SCHMITT_SCHMITT7 (0x1u << 7)
1560#define PIO_SCHMITT_SCHMITT8 (0x1u << 8)
1561#define PIO_SCHMITT_SCHMITT9 (0x1u << 9)
1562#define PIO_SCHMITT_SCHMITT10 (0x1u << 10)
1563#define PIO_SCHMITT_SCHMITT11 (0x1u << 11)
1564#define PIO_SCHMITT_SCHMITT12 (0x1u << 12)
1565#define PIO_SCHMITT_SCHMITT13 (0x1u << 13)
1566#define PIO_SCHMITT_SCHMITT14 (0x1u << 14)
1567#define PIO_SCHMITT_SCHMITT15 (0x1u << 15)
1568#define PIO_SCHMITT_SCHMITT16 (0x1u << 16)
1569#define PIO_SCHMITT_SCHMITT17 (0x1u << 17)
1570#define PIO_SCHMITT_SCHMITT18 (0x1u << 18)
1571#define PIO_SCHMITT_SCHMITT19 (0x1u << 19)
1572#define PIO_SCHMITT_SCHMITT20 (0x1u << 20)
1573#define PIO_SCHMITT_SCHMITT21 (0x1u << 21)
1574#define PIO_SCHMITT_SCHMITT22 (0x1u << 22)
1575#define PIO_SCHMITT_SCHMITT23 (0x1u << 23)
1576#define PIO_SCHMITT_SCHMITT24 (0x1u << 24)
1577#define PIO_SCHMITT_SCHMITT25 (0x1u << 25)
1578#define PIO_SCHMITT_SCHMITT26 (0x1u << 26)
1579#define PIO_SCHMITT_SCHMITT27 (0x1u << 27)
1580#define PIO_SCHMITT_SCHMITT28 (0x1u << 28)
1581#define PIO_SCHMITT_SCHMITT29 (0x1u << 29)
1582#define PIO_SCHMITT_SCHMITT30 (0x1u << 30)
1583#define PIO_SCHMITT_SCHMITT31 (0x1u << 31)
1584/* -------- PIO_DRIVER : (PIO Offset: 0x0118) I/O Drive Register -------- */
1585#define PIO_DRIVER_LINE0 (0x1u << 0)
1586#define PIO_DRIVER_LINE0_LOW_DRIVE (0x0u << 0)
1587#define PIO_DRIVER_LINE0_HIGH_DRIVE (0x1u << 0)
1588#define PIO_DRIVER_LINE1 (0x1u << 1)
1589#define PIO_DRIVER_LINE1_LOW_DRIVE (0x0u << 1)
1590#define PIO_DRIVER_LINE1_HIGH_DRIVE (0x1u << 1)
1591#define PIO_DRIVER_LINE2 (0x1u << 2)
1592#define PIO_DRIVER_LINE2_LOW_DRIVE (0x0u << 2)
1593#define PIO_DRIVER_LINE2_HIGH_DRIVE (0x1u << 2)
1594#define PIO_DRIVER_LINE3 (0x1u << 3)
1595#define PIO_DRIVER_LINE3_LOW_DRIVE (0x0u << 3)
1596#define PIO_DRIVER_LINE3_HIGH_DRIVE (0x1u << 3)
1597#define PIO_DRIVER_LINE4 (0x1u << 4)
1598#define PIO_DRIVER_LINE4_LOW_DRIVE (0x0u << 4)
1599#define PIO_DRIVER_LINE4_HIGH_DRIVE (0x1u << 4)
1600#define PIO_DRIVER_LINE5 (0x1u << 5)
1601#define PIO_DRIVER_LINE5_LOW_DRIVE (0x0u << 5)
1602#define PIO_DRIVER_LINE5_HIGH_DRIVE (0x1u << 5)
1603#define PIO_DRIVER_LINE6 (0x1u << 6)
1604#define PIO_DRIVER_LINE6_LOW_DRIVE (0x0u << 6)
1605#define PIO_DRIVER_LINE6_HIGH_DRIVE (0x1u << 6)
1606#define PIO_DRIVER_LINE7 (0x1u << 7)
1607#define PIO_DRIVER_LINE7_LOW_DRIVE (0x0u << 7)
1608#define PIO_DRIVER_LINE7_HIGH_DRIVE (0x1u << 7)
1609#define PIO_DRIVER_LINE8 (0x1u << 8)
1610#define PIO_DRIVER_LINE8_LOW_DRIVE (0x0u << 8)
1611#define PIO_DRIVER_LINE8_HIGH_DRIVE (0x1u << 8)
1612#define PIO_DRIVER_LINE9 (0x1u << 9)
1613#define PIO_DRIVER_LINE9_LOW_DRIVE (0x0u << 9)
1614#define PIO_DRIVER_LINE9_HIGH_DRIVE (0x1u << 9)
1615#define PIO_DRIVER_LINE10 (0x1u << 10)
1616#define PIO_DRIVER_LINE10_LOW_DRIVE (0x0u << 10)
1617#define PIO_DRIVER_LINE10_HIGH_DRIVE (0x1u << 10)
1618#define PIO_DRIVER_LINE11 (0x1u << 11)
1619#define PIO_DRIVER_LINE11_LOW_DRIVE (0x0u << 11)
1620#define PIO_DRIVER_LINE11_HIGH_DRIVE (0x1u << 11)
1621#define PIO_DRIVER_LINE12 (0x1u << 12)
1622#define PIO_DRIVER_LINE12_LOW_DRIVE (0x0u << 12)
1623#define PIO_DRIVER_LINE12_HIGH_DRIVE (0x1u << 12)
1624#define PIO_DRIVER_LINE13 (0x1u << 13)
1625#define PIO_DRIVER_LINE13_LOW_DRIVE (0x0u << 13)
1626#define PIO_DRIVER_LINE13_HIGH_DRIVE (0x1u << 13)
1627#define PIO_DRIVER_LINE14 (0x1u << 14)
1628#define PIO_DRIVER_LINE14_LOW_DRIVE (0x0u << 14)
1629#define PIO_DRIVER_LINE14_HIGH_DRIVE (0x1u << 14)
1630#define PIO_DRIVER_LINE15 (0x1u << 15)
1631#define PIO_DRIVER_LINE15_LOW_DRIVE (0x0u << 15)
1632#define PIO_DRIVER_LINE15_HIGH_DRIVE (0x1u << 15)
1633#define PIO_DRIVER_LINE16 (0x1u << 16)
1634#define PIO_DRIVER_LINE16_LOW_DRIVE (0x0u << 16)
1635#define PIO_DRIVER_LINE16_HIGH_DRIVE (0x1u << 16)
1636#define PIO_DRIVER_LINE17 (0x1u << 17)
1637#define PIO_DRIVER_LINE17_LOW_DRIVE (0x0u << 17)
1638#define PIO_DRIVER_LINE17_HIGH_DRIVE (0x1u << 17)
1639#define PIO_DRIVER_LINE18 (0x1u << 18)
1640#define PIO_DRIVER_LINE18_LOW_DRIVE (0x0u << 18)
1641#define PIO_DRIVER_LINE18_HIGH_DRIVE (0x1u << 18)
1642#define PIO_DRIVER_LINE19 (0x1u << 19)
1643#define PIO_DRIVER_LINE19_LOW_DRIVE (0x0u << 19)
1644#define PIO_DRIVER_LINE19_HIGH_DRIVE (0x1u << 19)
1645#define PIO_DRIVER_LINE20 (0x1u << 20)
1646#define PIO_DRIVER_LINE20_LOW_DRIVE (0x0u << 20)
1647#define PIO_DRIVER_LINE20_HIGH_DRIVE (0x1u << 20)
1648#define PIO_DRIVER_LINE21 (0x1u << 21)
1649#define PIO_DRIVER_LINE21_LOW_DRIVE (0x0u << 21)
1650#define PIO_DRIVER_LINE21_HIGH_DRIVE (0x1u << 21)
1651#define PIO_DRIVER_LINE22 (0x1u << 22)
1652#define PIO_DRIVER_LINE22_LOW_DRIVE (0x0u << 22)
1653#define PIO_DRIVER_LINE22_HIGH_DRIVE (0x1u << 22)
1654#define PIO_DRIVER_LINE23 (0x1u << 23)
1655#define PIO_DRIVER_LINE23_LOW_DRIVE (0x0u << 23)
1656#define PIO_DRIVER_LINE23_HIGH_DRIVE (0x1u << 23)
1657#define PIO_DRIVER_LINE24 (0x1u << 24)
1658#define PIO_DRIVER_LINE24_LOW_DRIVE (0x0u << 24)
1659#define PIO_DRIVER_LINE24_HIGH_DRIVE (0x1u << 24)
1660#define PIO_DRIVER_LINE25 (0x1u << 25)
1661#define PIO_DRIVER_LINE25_LOW_DRIVE (0x0u << 25)
1662#define PIO_DRIVER_LINE25_HIGH_DRIVE (0x1u << 25)
1663#define PIO_DRIVER_LINE26 (0x1u << 26)
1664#define PIO_DRIVER_LINE26_LOW_DRIVE (0x0u << 26)
1665#define PIO_DRIVER_LINE26_HIGH_DRIVE (0x1u << 26)
1666#define PIO_DRIVER_LINE27 (0x1u << 27)
1667#define PIO_DRIVER_LINE27_LOW_DRIVE (0x0u << 27)
1668#define PIO_DRIVER_LINE27_HIGH_DRIVE (0x1u << 27)
1669#define PIO_DRIVER_LINE28 (0x1u << 28)
1670#define PIO_DRIVER_LINE28_LOW_DRIVE (0x0u << 28)
1671#define PIO_DRIVER_LINE28_HIGH_DRIVE (0x1u << 28)
1672#define PIO_DRIVER_LINE29 (0x1u << 29)
1673#define PIO_DRIVER_LINE29_LOW_DRIVE (0x0u << 29)
1674#define PIO_DRIVER_LINE29_HIGH_DRIVE (0x1u << 29)
1675#define PIO_DRIVER_LINE30 (0x1u << 30)
1676#define PIO_DRIVER_LINE30_LOW_DRIVE (0x0u << 30)
1677#define PIO_DRIVER_LINE30_HIGH_DRIVE (0x1u << 30)
1678#define PIO_DRIVER_LINE31 (0x1u << 31)
1679#define PIO_DRIVER_LINE31_LOW_DRIVE (0x0u << 31)
1680#define PIO_DRIVER_LINE31_HIGH_DRIVE (0x1u << 31)
1681/* -------- PIO_PCMR : (PIO Offset: 0x0150) Parallel Capture Mode Register -------- */
1682#define PIO_PCMR_PCEN (0x1u << 0)
1683#define PIO_PCMR_DSIZE_Pos 4
1684#define PIO_PCMR_DSIZE_Msk (0x3u << PIO_PCMR_DSIZE_Pos)
1685#define PIO_PCMR_DSIZE(value) ((PIO_PCMR_DSIZE_Msk & ((value) << PIO_PCMR_DSIZE_Pos)))
1686#define PIO_PCMR_DSIZE_BYTE (0x0u << 4)
1687#define PIO_PCMR_DSIZE_HALFWORD (0x1u << 4)
1688#define PIO_PCMR_DSIZE_WORD (0x2u << 4)
1689#define PIO_PCMR_ALWYS (0x1u << 9)
1690#define PIO_PCMR_HALFS (0x1u << 10)
1691#define PIO_PCMR_FRSTS (0x1u << 11)
1692/* -------- PIO_PCIER : (PIO Offset: 0x0154) Parallel Capture Interrupt Enable Register -------- */
1693#define PIO_PCIER_DRDY (0x1u << 0)
1694#define PIO_PCIER_OVRE (0x1u << 1)
1695#define PIO_PCIER_ENDRX (0x1u << 2)
1696#define PIO_PCIER_RXBUFF (0x1u << 3)
1697/* -------- PIO_PCIDR : (PIO Offset: 0x0158) Parallel Capture Interrupt Disable Register -------- */
1698#define PIO_PCIDR_DRDY (0x1u << 0)
1699#define PIO_PCIDR_OVRE (0x1u << 1)
1700#define PIO_PCIDR_ENDRX (0x1u << 2)
1701#define PIO_PCIDR_RXBUFF (0x1u << 3)
1702/* -------- PIO_PCIMR : (PIO Offset: 0x015C) Parallel Capture Interrupt Mask Register -------- */
1703#define PIO_PCIMR_DRDY (0x1u << 0)
1704#define PIO_PCIMR_OVRE (0x1u << 1)
1705#define PIO_PCIMR_ENDRX (0x1u << 2)
1706#define PIO_PCIMR_RXBUFF (0x1u << 3)
1707/* -------- PIO_PCISR : (PIO Offset: 0x0160) Parallel Capture Interrupt Status Register -------- */
1708#define PIO_PCISR_DRDY (0x1u << 0)
1709#define PIO_PCISR_OVRE (0x1u << 1)
1710/* -------- PIO_PCRHR : (PIO Offset: 0x0164) Parallel Capture Reception Holding Register -------- */
1711#define PIO_PCRHR_RDATA_Pos 0
1712#define PIO_PCRHR_RDATA_Msk (0xffffffffu << PIO_PCRHR_RDATA_Pos)
1715
1716
1717#endif /* _SAMV71_PIO_COMPONENT_ */
#define __O
Definition: core_cm4.h:238
#define __IO
Definition: core_cm4.h:239
#define __I
Definition: core_cm4.h:236
Pio hardware registers.
Definition: component_pio.h:41
__I uint32_t PIO_VERSION
(Pio Offset: 0x00FC) Version Register
Definition: component_pio.h:100
