RTEMS 6.1
component_afec.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMV71_AFEC_COMPONENT_
31#define _SAMV71_AFEC_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __O uint32_t AFEC_CR;
43 __IO uint32_t AFEC_MR;
44 __IO uint32_t AFEC_EMR;
45 __IO uint32_t AFEC_SEQ1R;
46 __IO uint32_t AFEC_SEQ2R;
47 __O uint32_t AFEC_CHER;
48 __O uint32_t AFEC_CHDR;
49 __I uint32_t AFEC_CHSR;
50 __I uint32_t AFEC_LCDR;
51 __O uint32_t AFEC_IER;
52 __O uint32_t AFEC_IDR;
53 __I uint32_t AFEC_IMR;
54 __I uint32_t AFEC_ISR;
55 __I uint32_t Reserved1[6];
56 __I uint32_t AFEC_OVER;
57 __IO uint32_t AFEC_CWR;
58 __IO uint32_t AFEC_CGR;
59 __I uint32_t Reserved2[2];
60 __IO uint32_t AFEC_DIFFR;
61 __IO uint32_t AFEC_CSELR;
62 __I uint32_t AFEC_CDR;
63 __IO uint32_t AFEC_COCR;
64 __IO uint32_t AFEC_TEMPMR;
65 __IO uint32_t AFEC_TEMPCWR;
66 __I uint32_t Reserved3[7];
67 __IO uint32_t AFEC_ACR;
68 __I uint32_t Reserved4[2];
69 __IO uint32_t AFEC_SHMR;
70 __I uint32_t Reserved5[11];
71 __IO uint32_t AFEC_COSR;
72 __IO uint32_t AFEC_CVR;
73 __IO uint32_t AFEC_CECR;
74 __I uint32_t Reserved6[2];
75 __IO uint32_t AFEC_WPMR;
76 __I uint32_t AFEC_WPSR;
77 __I uint32_t Reserved7[4];
78 __I uint32_t AFEC_VERSION;
79} Afec;
80#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
81/* -------- AFEC_CR : (AFEC Offset: 0x00) AFEC Control Register -------- */
82#define AFEC_CR_SWRST (0x1u << 0)
83#define AFEC_CR_START (0x1u << 1)
84/* -------- AFEC_MR : (AFEC Offset: 0x04) AFEC Mode Register -------- */
85#define AFEC_MR_TRGEN (0x1u << 0)
86#define AFEC_MR_TRGEN_DIS (0x0u << 0)
87#define AFEC_MR_TRGEN_EN (0x1u << 0)
88#define AFEC_MR_TRGSEL_Pos 1
89#define AFEC_MR_TRGSEL_Msk (0x7u << AFEC_MR_TRGSEL_Pos)
90#define AFEC_MR_TRGSEL(value) ((AFEC_MR_TRGSEL_Msk & ((value) << AFEC_MR_TRGSEL_Pos)))
91#define AFEC_MR_TRGSEL_AFEC_TRIG0 (0x0u << 1)
92#define AFEC_MR_TRGSEL_AFEC_TRIG1 (0x1u << 1)
93#define AFEC_MR_TRGSEL_AFEC_TRIG2 (0x2u << 1)
94#define AFEC_MR_TRGSEL_AFEC_TRIG3 (0x3u << 1)
95#define AFEC_MR_TRGSEL_AFEC_TRIG4 (0x4u << 1)
96#define AFEC_MR_TRGSEL_AFEC_TRIG5 (0x5u << 1)
97#define AFEC_MR_TRGSEL_AFEC_TRIG6 (0x6u << 1)
98#define AFEC_MR_SLEEP (0x1u << 5)
99#define AFEC_MR_SLEEP_NORMAL (0x0u << 5)
100#define AFEC_MR_SLEEP_SLEEP (0x1u << 5)
101#define AFEC_MR_FWUP (0x1u << 6)
102#define AFEC_MR_FWUP_OFF (0x0u << 6)
103#define AFEC_MR_FWUP_ON (0x1u << 6)
104#define AFEC_MR_FREERUN (0x1u << 7)
105#define AFEC_MR_FREERUN_OFF (0x0u << 7)
106#define AFEC_MR_FREERUN_ON (0x1u << 7)
107#define AFEC_MR_PRESCAL_Pos 8
108#define AFEC_MR_PRESCAL_Msk (0xffu << AFEC_MR_PRESCAL_Pos)
109#define AFEC_MR_PRESCAL(value) ((AFEC_MR_PRESCAL_Msk & ((value) << AFEC_MR_PRESCAL_Pos)))
110#define AFEC_MR_STARTUP_Pos 16
111#define AFEC_MR_STARTUP_Msk (0xfu << AFEC_MR_STARTUP_Pos)
112#define AFEC_MR_STARTUP(value) ((AFEC_MR_STARTUP_Msk & ((value) << AFEC_MR_STARTUP_Pos)))
113#define AFEC_MR_STARTUP_SUT0 (0x0u << 16)
114#define AFEC_MR_STARTUP_SUT8 (0x1u << 16)
115#define AFEC_MR_STARTUP_SUT16 (0x2u << 16)
116#define AFEC_MR_STARTUP_SUT24 (0x3u << 16)
117#define AFEC_MR_STARTUP_SUT64 (0x4u << 16)
118#define AFEC_MR_STARTUP_SUT80 (0x5u << 16)
119#define AFEC_MR_STARTUP_SUT96 (0x6u << 16)
120#define AFEC_MR_STARTUP_SUT112 (0x7u << 16)
121#define AFEC_MR_STARTUP_SUT512 (0x8u << 16)
122#define AFEC_MR_STARTUP_SUT576 (0x9u << 16)
123#define AFEC_MR_STARTUP_SUT640 (0xAu << 16)
124#define AFEC_MR_STARTUP_SUT704 (0xBu << 16)
125#define AFEC_MR_STARTUP_SUT768 (0xCu << 16)
126#define AFEC_MR_STARTUP_SUT832 (0xDu << 16)
127#define AFEC_MR_STARTUP_SUT896 (0xEu << 16)
128#define AFEC_MR_STARTUP_SUT960 (0xFu << 16)
129#define AFEC_MR_ONE (0x1u << 23)
130#define AFEC_MR_TRACKTIM_Pos 24
131#define AFEC_MR_TRACKTIM_Msk (0xfu << AFEC_MR_TRACKTIM_Pos)
132#define AFEC_MR_TRACKTIM(value) ((AFEC_MR_TRACKTIM_Msk & ((value) << AFEC_MR_TRACKTIM_Pos)))
133#define AFEC_MR_TRANSFER_Pos 28
134#define AFEC_MR_TRANSFER_Msk (0x3u << AFEC_MR_TRANSFER_Pos)
135#define AFEC_MR_TRANSFER(value) ((AFEC_MR_TRANSFER_Msk & ((value) << AFEC_MR_TRANSFER_Pos)))
136#define AFEC_MR_USEQ (0x1u << 31)
137#define AFEC_MR_USEQ_NUM_ORDER (0x0u << 31)
138#define AFEC_MR_USEQ_REG_ORDER (0x1u << 31)
139/* -------- AFEC_EMR : (AFEC Offset: 0x08) AFEC Extended Mode Register -------- */
140#define AFEC_EMR_CMPMODE_Pos 0
141#define AFEC_EMR_CMPMODE_Msk (0x3u << AFEC_EMR_CMPMODE_Pos)
142#define AFEC_EMR_CMPMODE(value) ((AFEC_EMR_CMPMODE_Msk & ((value) << AFEC_EMR_CMPMODE_Pos)))
143#define AFEC_EMR_CMPMODE_LOW (0x0u << 0)
144#define AFEC_EMR_CMPMODE_HIGH (0x1u << 0)
145#define AFEC_EMR_CMPMODE_IN (0x2u << 0)
146#define AFEC_EMR_CMPMODE_OUT (0x3u << 0)
147#define AFEC_EMR_CMPSEL_Pos 3
148#define AFEC_EMR_CMPSEL_Msk (0x1fu << AFEC_EMR_CMPSEL_Pos)
149#define AFEC_EMR_CMPSEL(value) ((AFEC_EMR_CMPSEL_Msk & ((value) << AFEC_EMR_CMPSEL_Pos)))
150#define AFEC_EMR_CMPALL (0x1u << 9)
151#define AFEC_EMR_CMPFILTER_Pos 12
152#define AFEC_EMR_CMPFILTER_Msk (0x3u << AFEC_EMR_CMPFILTER_Pos)
153#define AFEC_EMR_CMPFILTER(value) ((AFEC_EMR_CMPFILTER_Msk & ((value) << AFEC_EMR_CMPFILTER_Pos)))
154#define AFEC_EMR_RES_Pos 16
155#define AFEC_EMR_RES_Msk (0x7u << AFEC_EMR_RES_Pos)
156#define AFEC_EMR_RES(value) ((AFEC_EMR_RES_Msk & ((value) << AFEC_EMR_RES_Pos)))
157#define AFEC_EMR_RES_NO_AVERAGE (0x0u << 16)
158#define AFEC_EMR_RES_OSR4 (0x2u << 16)
159#define AFEC_EMR_RES_OSR16 (0x3u << 16)
160#define AFEC_EMR_RES_OSR64 (0x4u << 16)
161#define AFEC_EMR_RES_OSR256 (0x5u << 16)
162#define AFEC_EMR_TAG (0x1u << 24)
163#define AFEC_EMR_STM (0x1u << 25)
164#define AFEC_EMR_SIGNMODE_Pos 28
165#define AFEC_EMR_SIGNMODE_Msk (0x3u << AFEC_EMR_SIGNMODE_Pos)
166#define AFEC_EMR_SIGNMODE(value) ((AFEC_EMR_SIGNMODE_Msk & ((value) << AFEC_EMR_SIGNMODE_Pos)))
167#define AFEC_EMR_SIGNMODE_SE_UNSG_DF_SIGN (0x0u << 28)
168#define AFEC_EMR_SIGNMODE_SE_SIGN_DF_UNSG (0x1u << 28)
169#define AFEC_EMR_SIGNMODE_ALL_UNSIGNED (0x2u << 28)
170#define AFEC_EMR_SIGNMODE_ALL_SIGNED (0x3u << 28)
171/* -------- AFEC_SEQ1R : (AFEC Offset: 0x0C) AFEC Channel Sequence 1 Register -------- */
172#define AFEC_SEQ1R_USCH0_Pos 0
173#define AFEC_SEQ1R_USCH0_Msk (0xfu << AFEC_SEQ1R_USCH0_Pos)
174#define AFEC_SEQ1R_USCH0(value) ((AFEC_SEQ1R_USCH0_Msk & ((value) << AFEC_SEQ1R_USCH0_Pos)))
175#define AFEC_SEQ1R_USCH1_Pos 4
176#define AFEC_SEQ1R_USCH1_Msk (0xfu << AFEC_SEQ1R_USCH1_Pos)
177#define AFEC_SEQ1R_USCH1(value) ((AFEC_SEQ1R_USCH1_Msk & ((value) << AFEC_SEQ1R_USCH1_Pos)))
178#define AFEC_SEQ1R_USCH2_Pos 8
179#define AFEC_SEQ1R_USCH2_Msk (0xfu << AFEC_SEQ1R_USCH2_Pos)
180#define AFEC_SEQ1R_USCH2(value) ((AFEC_SEQ1R_USCH2_Msk & ((value) << AFEC_SEQ1R_USCH2_Pos)))
181#define AFEC_SEQ1R_USCH3_Pos 12
182#define AFEC_SEQ1R_USCH3_Msk (0xfu << AFEC_SEQ1R_USCH3_Pos)
183#define AFEC_SEQ1R_USCH3(value) ((AFEC_SEQ1R_USCH3_Msk & ((value) << AFEC_SEQ1R_USCH3_Pos)))
184#define AFEC_SEQ1R_USCH4_Pos 16
185#define AFEC_SEQ1R_USCH4_Msk (0xfu << AFEC_SEQ1R_USCH4_Pos)
186#define AFEC_SEQ1R_USCH4(value) ((AFEC_SEQ1R_USCH4_Msk & ((value) << AFEC_SEQ1R_USCH4_Pos)))
187#define AFEC_SEQ1R_USCH5_Pos 20
188#define AFEC_SEQ1R_USCH5_Msk (0xfu << AFEC_SEQ1R_USCH5_Pos)
189#define AFEC_SEQ1R_USCH5(value) ((AFEC_SEQ1R_USCH5_Msk & ((value) << AFEC_SEQ1R_USCH5_Pos)))
190#define AFEC_SEQ1R_USCH6_Pos 24
191#define AFEC_SEQ1R_USCH6_Msk (0xfu << AFEC_SEQ1R_USCH6_Pos)
192#define AFEC_SEQ1R_USCH6(value) ((AFEC_SEQ1R_USCH6_Msk & ((value) << AFEC_SEQ1R_USCH6_Pos)))
193#define AFEC_SEQ1R_USCH7_Pos 28
194#define AFEC_SEQ1R_USCH7_Msk (0xfu << AFEC_SEQ1R_USCH7_Pos)
195#define AFEC_SEQ1R_USCH7(value) ((AFEC_SEQ1R_USCH7_Msk & ((value) << AFEC_SEQ1R_USCH7_Pos)))
196/* -------- AFEC_SEQ2R : (AFEC Offset: 0x10) AFEC Channel Sequence 2 Register -------- */
197#define AFEC_SEQ2R_USCH8_Pos 0
198#define AFEC_SEQ2R_USCH8_Msk (0xfu << AFEC_SEQ2R_USCH8_Pos)
199#define AFEC_SEQ2R_USCH8(value) ((AFEC_SEQ2R_USCH8_Msk & ((value) << AFEC_SEQ2R_USCH8_Pos)))
200#define AFEC_SEQ2R_USCH9_Pos 4
201#define AFEC_SEQ2R_USCH9_Msk (0xfu << AFEC_SEQ2R_USCH9_Pos)
202#define AFEC_SEQ2R_USCH9(value) ((AFEC_SEQ2R_USCH9_Msk & ((value) << AFEC_SEQ2R_USCH9_Pos)))
203#define AFEC_SEQ2R_USCH10_Pos 8
204#define AFEC_SEQ2R_USCH10_Msk (0xfu << AFEC_SEQ2R_USCH10_Pos)
205#define AFEC_SEQ2R_USCH10(value) ((AFEC_SEQ2R_USCH10_Msk & ((value) << AFEC_SEQ2R_USCH10_Pos)))
206#define AFEC_SEQ2R_USCH11_Pos 12
207#define AFEC_SEQ2R_USCH11_Msk (0xfu << AFEC_SEQ2R_USCH11_Pos)
208#define AFEC_SEQ2R_USCH11(value) ((AFEC_SEQ2R_USCH11_Msk & ((value) << AFEC_SEQ2R_USCH11_Pos)))
209#define AFEC_SEQ2R_USCH12_Pos 16
210#define AFEC_SEQ2R_USCH12_Msk (0xfu << AFEC_SEQ2R_USCH12_Pos)
211#define AFEC_SEQ2R_USCH12(value) ((AFEC_SEQ2R_USCH12_Msk & ((value) << AFEC_SEQ2R_USCH12_Pos)))
212#define AFEC_SEQ2R_USCH13_Pos 20
213#define AFEC_SEQ2R_USCH13_Msk (0xfu << AFEC_SEQ2R_USCH13_Pos)
214#define AFEC_SEQ2R_USCH13(value) ((AFEC_SEQ2R_USCH13_Msk & ((value) << AFEC_SEQ2R_USCH13_Pos)))
215#define AFEC_SEQ2R_USCH14_Pos 24
216#define AFEC_SEQ2R_USCH14_Msk (0xfu << AFEC_SEQ2R_USCH14_Pos)
217#define AFEC_SEQ2R_USCH14(value) ((AFEC_SEQ2R_USCH14_Msk & ((value) << AFEC_SEQ2R_USCH14_Pos)))
218#define AFEC_SEQ2R_USCH15_Pos 28
219#define AFEC_SEQ2R_USCH15_Msk (0xfu << AFEC_SEQ2R_USCH15_Pos)
220#define AFEC_SEQ2R_USCH15(value) ((AFEC_SEQ2R_USCH15_Msk & ((value) << AFEC_SEQ2R_USCH15_Pos)))
221/* -------- AFEC_CHER : (AFEC Offset: 0x14) AFEC Channel Enable Register -------- */
222#define AFEC_CHER_CH0 (0x1u << 0)
223#define AFEC_CHER_CH1 (0x1u << 1)
224#define AFEC_CHER_CH2 (0x1u << 2)
225#define AFEC_CHER_CH3 (0x1u << 3)
226#define AFEC_CHER_CH4 (0x1u << 4)
227#define AFEC_CHER_CH5 (0x1u << 5)
228#define AFEC_CHER_CH6 (0x1u << 6)
229#define AFEC_CHER_CH7 (0x1u << 7)
230#define AFEC_CHER_CH8 (0x1u << 8)
231#define AFEC_CHER_CH9 (0x1u << 9)
232#define AFEC_CHER_CH10 (0x1u << 10)
233#define AFEC_CHER_CH11 (0x1u << 11)
234/* -------- AFEC_CHDR : (AFEC Offset: 0x18) AFEC Channel Disable Register -------- */
235#define AFEC_CHDR_CH0 (0x1u << 0)
236#define AFEC_CHDR_CH1 (0x1u << 1)
237#define AFEC_CHDR_CH2 (0x1u << 2)
238#define AFEC_CHDR_CH3 (0x1u << 3)
239#define AFEC_CHDR_CH4 (0x1u << 4)
240#define AFEC_CHDR_CH5 (0x1u << 5)
241#define AFEC_CHDR_CH6 (0x1u << 6)
242#define AFEC_CHDR_CH7 (0x1u << 7)
243#define AFEC_CHDR_CH8 (0x1u << 8)
244#define AFEC_CHDR_CH9 (0x1u << 9)
245#define AFEC_CHDR_CH10 (0x1u << 10)
246#define AFEC_CHDR_CH11 (0x1u << 11)
247/* -------- AFEC_CHSR : (AFEC Offset: 0x1C) AFEC Channel Status Register -------- */
248#define AFEC_CHSR_CH0 (0x1u << 0)
249#define AFEC_CHSR_CH1 (0x1u << 1)
250#define AFEC_CHSR_CH2 (0x1u << 2)
251#define AFEC_CHSR_CH3 (0x1u << 3)
252#define AFEC_CHSR_CH4 (0x1u << 4)
253#define AFEC_CHSR_CH5 (0x1u << 5)
254#define AFEC_CHSR_CH6 (0x1u << 6)
255#define AFEC_CHSR_CH7 (0x1u << 7)
256#define AFEC_CHSR_CH8 (0x1u << 8)
257#define AFEC_CHSR_CH9 (0x1u << 9)
258#define AFEC_CHSR_CH10 (0x1u << 10)
259#define AFEC_CHSR_CH11 (0x1u << 11)
260/* -------- AFEC_LCDR : (AFEC Offset: 0x20) AFEC Last Converted Data Register -------- */
261#define AFEC_LCDR_LDATA_Pos 0
262#define AFEC_LCDR_LDATA_Msk (0xffffu << AFEC_LCDR_LDATA_Pos)
263#define AFEC_LCDR_CHNB_Pos 24
264#define AFEC_LCDR_CHNB_Msk (0xfu << AFEC_LCDR_CHNB_Pos)
265/* -------- AFEC_IER : (AFEC Offset: 0x24) AFEC Interrupt Enable Register -------- */
266#define AFEC_IER_EOC0 (0x1u << 0)
267#define AFEC_IER_EOC1 (0x1u << 1)
268#define AFEC_IER_EOC2 (0x1u << 2)
269#define AFEC_IER_EOC3 (0x1u << 3)
270#define AFEC_IER_EOC4 (0x1u << 4)
271#define AFEC_IER_EOC5 (0x1u << 5)
272#define AFEC_IER_EOC6 (0x1u << 6)
273#define AFEC_IER_EOC7 (0x1u << 7)
274#define AFEC_IER_EOC8 (0x1u << 8)
275#define AFEC_IER_EOC9 (0x1u << 9)
276#define AFEC_IER_EOC10 (0x1u << 10)
277#define AFEC_IER_EOC11 (0x1u << 11)
278#define AFEC_IER_DRDY (0x1u << 24)
279#define AFEC_IER_GOVRE (0x1u << 25)
280#define AFEC_IER_COMPE (0x1u << 26)
281#define AFEC_IER_TEMPCHG (0x1u << 30)
282/* -------- AFEC_IDR : (AFEC Offset: 0x28) AFEC Interrupt Disable Register -------- */
283#define AFEC_IDR_EOC0 (0x1u << 0)
284#define AFEC_IDR_EOC1 (0x1u << 1)
285#define AFEC_IDR_EOC2 (0x1u << 2)
286#define AFEC_IDR_EOC3 (0x1u << 3)
287#define AFEC_IDR_EOC4 (0x1u << 4)
288#define AFEC_IDR_EOC5 (0x1u << 5)
289#define AFEC_IDR_EOC6 (0x1u << 6)
290#define AFEC_IDR_EOC7 (0x1u << 7)
291#define AFEC_IDR_EOC8 (0x1u << 8)
292#define AFEC_IDR_EOC9 (0x1u << 9)
293#define AFEC_IDR_EOC10 (0x1u << 10)
294#define AFEC_IDR_EOC11 (0x1u << 11)
295#define AFEC_IDR_DRDY (0x1u << 24)
296#define AFEC_IDR_GOVRE (0x1u << 25)
297#define AFEC_IDR_COMPE (0x1u << 26)
298#define AFEC_IDR_TEMPCHG (0x1u << 30)
299/* -------- AFEC_IMR : (AFEC Offset: 0x2C) AFEC Interrupt Mask Register -------- */
300#define AFEC_IMR_EOC0 (0x1u << 0)
301#define AFEC_IMR_EOC1 (0x1u << 1)
302#define AFEC_IMR_EOC2 (0x1u << 2)
303#define AFEC_IMR_EOC3 (0x1u << 3)
304#define AFEC_IMR_EOC4 (0x1u << 4)
305#define AFEC_IMR_EOC5 (0x1u << 5)
306#define AFEC_IMR_EOC6 (0x1u << 6)
307#define AFEC_IMR_EOC7 (0x1u << 7)
308#define AFEC_IMR_EOC8 (0x1u << 8)
309#define AFEC_IMR_EOC9 (0x1u << 9)
310#define AFEC_IMR_EOC10 (0x1u << 10)
311#define AFEC_IMR_EOC11 (0x1u << 11)
312#define AFEC_IMR_DRDY (0x1u << 24)
313#define AFEC_IMR_GOVRE (0x1u << 25)
314#define AFEC_IMR_COMPE (0x1u << 26)
315#define AFEC_IMR_TEMPCHG (0x1u << 30)
316/* -------- AFEC_ISR : (AFEC Offset: 0x30) AFEC Interrupt Status Register -------- */
317#define AFEC_ISR_EOC0 (0x1u << 0)
318#define AFEC_ISR_EOC1 (0x1u << 1)
319#define AFEC_ISR_EOC2 (0x1u << 2)
320#define AFEC_ISR_EOC3 (0x1u << 3)
321#define AFEC_ISR_EOC4 (0x1u << 4)
322#define AFEC_ISR_EOC5 (0x1u << 5)
323#define AFEC_ISR_EOC6 (0x1u << 6)
324#define AFEC_ISR_EOC7 (0x1u << 7)
325#define AFEC_ISR_EOC8 (0x1u << 8)
326#define AFEC_ISR_EOC9 (0x1u << 9)
327#define AFEC_ISR_EOC10 (0x1u << 10)
328#define AFEC_ISR_EOC11 (0x1u << 11)
329#define AFEC_ISR_DRDY (0x1u << 24)
330#define AFEC_ISR_GOVRE (0x1u << 25)
331#define AFEC_ISR_COMPE (0x1u << 26)
332#define AFEC_ISR_TEMPCHG (0x1u << 30)
333/* -------- AFEC_OVER : (AFEC Offset: 0x4C) AFEC Overrun Status Register -------- */
334#define AFEC_OVER_OVRE0 (0x1u << 0)
335#define AFEC_OVER_OVRE1 (0x1u << 1)
336#define AFEC_OVER_OVRE2 (0x1u << 2)
337#define AFEC_OVER_OVRE3 (0x1u << 3)
338#define AFEC_OVER_OVRE4 (0x1u << 4)
339#define AFEC_OVER_OVRE5 (0x1u << 5)
340#define AFEC_OVER_OVRE6 (0x1u << 6)
341#define AFEC_OVER_OVRE7 (0x1u << 7)
342#define AFEC_OVER_OVRE8 (0x1u << 8)
343#define AFEC_OVER_OVRE9 (0x1u << 9)
344#define AFEC_OVER_OVRE10 (0x1u << 10)
345#define AFEC_OVER_OVRE11 (0x1u << 11)
346/* -------- AFEC_CWR : (AFEC Offset: 0x50) AFEC Compare Window Register -------- */
347#define AFEC_CWR_LOWTHRES_Pos 0
348#define AFEC_CWR_LOWTHRES_Msk (0xffffu << AFEC_CWR_LOWTHRES_Pos)
349#define AFEC_CWR_LOWTHRES(value) ((AFEC_CWR_LOWTHRES_Msk & ((value) << AFEC_CWR_LOWTHRES_Pos)))
350#define AFEC_CWR_HIGHTHRES_Pos 16
351#define AFEC_CWR_HIGHTHRES_Msk (0xffffu << AFEC_CWR_HIGHTHRES_Pos)
352#define AFEC_CWR_HIGHTHRES(value) ((AFEC_CWR_HIGHTHRES_Msk & ((value) << AFEC_CWR_HIGHTHRES_Pos)))
353/* -------- AFEC_CGR : (AFEC Offset: 0x54) AFEC Channel Gain Register -------- */
354#define AFEC_CGR_GAIN0_Pos 0
355#define AFEC_CGR_GAIN0_Msk (0x3u << AFEC_CGR_GAIN0_Pos)
356#define AFEC_CGR_GAIN0(value) ((AFEC_CGR_GAIN0_Msk & ((value) << AFEC_CGR_GAIN0_Pos)))
357#define AFEC_CGR_GAIN1_Pos 2
358#define AFEC_CGR_GAIN1_Msk (0x3u << AFEC_CGR_GAIN1_Pos)
359#define AFEC_CGR_GAIN1(value) ((AFEC_CGR_GAIN1_Msk & ((value) << AFEC_CGR_GAIN1_Pos)))
360#define AFEC_CGR_GAIN2_Pos 4
361#define AFEC_CGR_GAIN2_Msk (0x3u << AFEC_CGR_GAIN2_Pos)
362#define AFEC_CGR_GAIN2(value) ((AFEC_CGR_GAIN2_Msk & ((value) << AFEC_CGR_GAIN2_Pos)))
363#define AFEC_CGR_GAIN3_Pos 6
364#define AFEC_CGR_GAIN3_Msk (0x3u << AFEC_CGR_GAIN3_Pos)
365#define AFEC_CGR_GAIN3(value) ((AFEC_CGR_GAIN3_Msk & ((value) << AFEC_CGR_GAIN3_Pos)))
366#define AFEC_CGR_GAIN4_Pos 8
367#define AFEC_CGR_GAIN4_Msk (0x3u << AFEC_CGR_GAIN4_Pos)
368#define AFEC_CGR_GAIN4(value) ((AFEC_CGR_GAIN4_Msk & ((value) << AFEC_CGR_GAIN4_Pos)))
369#define AFEC_CGR_GAIN5_Pos 10
370#define AFEC_CGR_GAIN5_Msk (0x3u << AFEC_CGR_GAIN5_Pos)
371#define AFEC_CGR_GAIN5(value) ((AFEC_CGR_GAIN5_Msk & ((value) << AFEC_CGR_GAIN5_Pos)))
372#define AFEC_CGR_GAIN6_Pos 12
373#define AFEC_CGR_GAIN6_Msk (0x3u << AFEC_CGR_GAIN6_Pos)
374#define AFEC_CGR_GAIN6(value) ((AFEC_CGR_GAIN6_Msk & ((value) << AFEC_CGR_GAIN6_Pos)))
375#define AFEC_CGR_GAIN7_Pos 14
376#define AFEC_CGR_GAIN7_Msk (0x3u << AFEC_CGR_GAIN7_Pos)
377#define AFEC_CGR_GAIN7(value) ((AFEC_CGR_GAIN7_Msk & ((value) << AFEC_CGR_GAIN7_Pos)))
378#define AFEC_CGR_GAIN8_Pos 16
379#define AFEC_CGR_GAIN8_Msk (0x3u << AFEC_CGR_GAIN8_Pos)
380#define AFEC_CGR_GAIN8(value) ((AFEC_CGR_GAIN8_Msk & ((value) << AFEC_CGR_GAIN8_Pos)))
381#define AFEC_CGR_GAIN9_Pos 18
382#define AFEC_CGR_GAIN9_Msk (0x3u << AFEC_CGR_GAIN9_Pos)
383#define AFEC_CGR_GAIN9(value) ((AFEC_CGR_GAIN9_Msk & ((value) << AFEC_CGR_GAIN9_Pos)))
384#define AFEC_CGR_GAIN10_Pos 20
385#define AFEC_CGR_GAIN10_Msk (0x3u << AFEC_CGR_GAIN10_Pos)
386#define AFEC_CGR_GAIN10(value) ((AFEC_CGR_GAIN10_Msk & ((value) << AFEC_CGR_GAIN10_Pos)))
387#define AFEC_CGR_GAIN11_Pos 22
388#define AFEC_CGR_GAIN11_Msk (0x3u << AFEC_CGR_GAIN11_Pos)
389#define AFEC_CGR_GAIN11(value) ((AFEC_CGR_GAIN11_Msk & ((value) << AFEC_CGR_GAIN11_Pos)))
390/* -------- AFEC_DIFFR : (AFEC Offset: 0x60) AFEC Channel Differential Register -------- */
391#define AFEC_DIFFR_DIFF0 (0x1u << 0)
392#define AFEC_DIFFR_DIFF1 (0x1u << 1)
393#define AFEC_DIFFR_DIFF2 (0x1u << 2)
394#define AFEC_DIFFR_DIFF3 (0x1u << 3)
395#define AFEC_DIFFR_DIFF4 (0x1u << 4)
396#define AFEC_DIFFR_DIFF5 (0x1u << 5)
397#define AFEC_DIFFR_DIFF6 (0x1u << 6)
398#define AFEC_DIFFR_DIFF7 (0x1u << 7)
399#define AFEC_DIFFR_DIFF8 (0x1u << 8)
400#define AFEC_DIFFR_DIFF9 (0x1u << 9)
401#define AFEC_DIFFR_DIFF10 (0x1u << 10)
402#define AFEC_DIFFR_DIFF11 (0x1u << 11)
403/* -------- AFEC_CSELR : (AFEC Offset: 0x64) AFEC Channel Selection Register -------- */
404#define AFEC_CSELR_CSEL_Pos 0
405#define AFEC_CSELR_CSEL_Msk (0xfu << AFEC_CSELR_CSEL_Pos)
406#define AFEC_CSELR_CSEL(value) ((AFEC_CSELR_CSEL_Msk & ((value) << AFEC_CSELR_CSEL_Pos)))
407/* -------- AFEC_CDR : (AFEC Offset: 0x68) AFEC Channel Data Register -------- */
408#define AFEC_CDR_DATA_Pos 0
409#define AFEC_CDR_DATA_Msk (0xffffu << AFEC_CDR_DATA_Pos)
410/* -------- AFEC_COCR : (AFEC Offset: 0x6C) AFEC Channel Offset Compensation Register -------- */
411#define AFEC_COCR_AOFF_Pos 0
412#define AFEC_COCR_AOFF_Msk (0x3ffu << AFEC_COCR_AOFF_Pos)
413#define AFEC_COCR_AOFF(value) ((AFEC_COCR_AOFF_Msk & ((value) << AFEC_COCR_AOFF_Pos)))
414/* -------- AFEC_TEMPMR : (AFEC Offset: 0x70) AFEC Temperature Sensor Mode Register -------- */
415#define AFEC_TEMPMR_RTCT (0x1u << 0)
416#define AFEC_TEMPMR_TEMPCMPMOD_Pos 4
417#define AFEC_TEMPMR_TEMPCMPMOD_Msk (0x3u << AFEC_TEMPMR_TEMPCMPMOD_Pos)
418#define AFEC_TEMPMR_TEMPCMPMOD(value) ((AFEC_TEMPMR_TEMPCMPMOD_Msk & ((value) << AFEC_TEMPMR_TEMPCMPMOD_Pos)))
419#define AFEC_TEMPMR_TEMPCMPMOD_LOW (0x0u << 4)
420#define AFEC_TEMPMR_TEMPCMPMOD_HIGH (0x1u << 4)
421#define AFEC_TEMPMR_TEMPCMPMOD_IN (0x2u << 4)
422#define AFEC_TEMPMR_TEMPCMPMOD_OUT (0x3u << 4)
423/* -------- AFEC_TEMPCWR : (AFEC Offset: 0x74) AFEC Temperature Compare Window Register -------- */
424#define AFEC_TEMPCWR_TLOWTHRES_Pos 0
425#define AFEC_TEMPCWR_TLOWTHRES_Msk (0xffffu << AFEC_TEMPCWR_TLOWTHRES_Pos)
426#define AFEC_TEMPCWR_TLOWTHRES(value) ((AFEC_TEMPCWR_TLOWTHRES_Msk & ((value) << AFEC_TEMPCWR_TLOWTHRES_Pos)))
427#define AFEC_TEMPCWR_THIGHTHRES_Pos 16
428#define AFEC_TEMPCWR_THIGHTHRES_Msk (0xffffu << AFEC_TEMPCWR_THIGHTHRES_Pos)
429#define AFEC_TEMPCWR_THIGHTHRES(value) ((AFEC_TEMPCWR_THIGHTHRES_Msk & ((value) << AFEC_TEMPCWR_THIGHTHRES_Pos)))
430/* -------- AFEC_ACR : (AFEC Offset: 0x94) AFEC Analog Control Register -------- */
431#define AFEC_ACR_PGA0EN (0x1u << 2)
432#define AFEC_ACR_PGA1EN (0x1u << 3)
433#define AFEC_ACR_IBCTL_Pos 8
434#define AFEC_ACR_IBCTL_Msk (0x3u << AFEC_ACR_IBCTL_Pos)
435#define AFEC_ACR_IBCTL(value) ((AFEC_ACR_IBCTL_Msk & ((value) << AFEC_ACR_IBCTL_Pos)))
436/* -------- AFEC_SHMR : (AFEC Offset: 0xA0) AFEC Sample & Hold Mode Register -------- */
437#define AFEC_SHMR_DUAL0 (0x1u << 0)
438#define AFEC_SHMR_DUAL1 (0x1u << 1)
439#define AFEC_SHMR_DUAL2 (0x1u << 2)
440#define AFEC_SHMR_DUAL3 (0x1u << 3)
441#define AFEC_SHMR_DUAL4 (0x1u << 4)
442#define AFEC_SHMR_DUAL5 (0x1u << 5)
443#define AFEC_SHMR_DUAL6 (0x1u << 6)
444#define AFEC_SHMR_DUAL7 (0x1u << 7)
445#define AFEC_SHMR_DUAL8 (0x1u << 8)
446#define AFEC_SHMR_DUAL9 (0x1u << 9)
447#define AFEC_SHMR_DUAL10 (0x1u << 10)
448#define AFEC_SHMR_DUAL11 (0x1u << 11)
449/* -------- AFEC_COSR : (AFEC Offset: 0xD0) AFEC Correction Select Register -------- */
450#define AFEC_COSR_CSEL (0x1u << 0)
451/* -------- AFEC_CVR : (AFEC Offset: 0xD4) AFEC Correction Values Register -------- */
452#define AFEC_CVR_OFFSETCORR_Pos 0
453#define AFEC_CVR_OFFSETCORR_Msk (0xffffu << AFEC_CVR_OFFSETCORR_Pos)
454#define AFEC_CVR_OFFSETCORR(value) ((AFEC_CVR_OFFSETCORR_Msk & ((value) << AFEC_CVR_OFFSETCORR_Pos)))
455#define AFEC_CVR_GAINCORR_Pos 16
456#define AFEC_CVR_GAINCORR_Msk (0xffffu << AFEC_CVR_GAINCORR_Pos)
457#define AFEC_CVR_GAINCORR(value) ((AFEC_CVR_GAINCORR_Msk & ((value) << AFEC_CVR_GAINCORR_Pos)))
458/* -------- AFEC_CECR : (AFEC Offset: 0xD8) AFEC Channel Error Correction Register -------- */
459#define AFEC_CECR_ECORR0 (0x1u << 0)
460#define AFEC_CECR_ECORR1 (0x1u << 1)
461#define AFEC_CECR_ECORR2 (0x1u << 2)
462#define AFEC_CECR_ECORR3 (0x1u << 3)
463#define AFEC_CECR_ECORR4 (0x1u << 4)
464#define AFEC_CECR_ECORR5 (0x1u << 5)
465#define AFEC_CECR_ECORR6 (0x1u << 6)
466#define AFEC_CECR_ECORR7 (0x1u << 7)
467#define AFEC_CECR_ECORR8 (0x1u << 8)
468#define AFEC_CECR_ECORR9 (0x1u << 9)
469#define AFEC_CECR_ECORR10 (0x1u << 10)
470#define AFEC_CECR_ECORR11 (0x1u << 11)
471/* -------- AFEC_WPMR : (AFEC Offset: 0xE4) AFEC Write Protection Mode Register -------- */
472#define AFEC_WPMR_WPEN (0x1u << 0)
473#define AFEC_WPMR_WPKEY_Pos 8
474#define AFEC_WPMR_WPKEY_Msk (0xffffffu << AFEC_WPMR_WPKEY_Pos)
475#define AFEC_WPMR_WPKEY(value) ((AFEC_WPMR_WPKEY_Msk & ((value) << AFEC_WPMR_WPKEY_Pos)))
476#define AFEC_WPMR_WPKEY_PASSWD (0x414443u << 8)
477/* -------- AFEC_WPSR : (AFEC Offset: 0xE8) AFEC Write Protection Status Register -------- */
478#define AFEC_WPSR_WPVS (0x1u << 0)
479#define AFEC_WPSR_WPVSRC_Pos 8
480#define AFEC_WPSR_WPVSRC_Msk (0xffffu << AFEC_WPSR_WPVSRC_Pos)
481/* -------- AFEC_VERSION : (AFEC Offset: 0xFC) AFEC Version Register -------- */
482#define AFEC_VERSION_VERSION_Pos 0
483#define AFEC_VERSION_VERSION_Msk (0xfffu << AFEC_VERSION_VERSION_Pos)
484#define AFEC_VERSION_MFN_Pos 16
485#define AFEC_VERSION_MFN_Msk (0x7u << AFEC_VERSION_MFN_Pos)
488
489
490#endif /* _SAMV71_AFEC_COMPONENT_ */
#define __O
Definition: core_cm4.h:238
#define __IO
Definition: core_cm4.h:239
#define __I
Definition: core_cm4.h:236
Afec hardware registers.
Definition: component_afec.h:41
(Afec Offset: 0xFC) AFEC Version Register
Definition: component_afec.h:78
