RTEMS 6.1
component_utmi.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMS70_UTMI_COMPONENT_
31#define _SAMS70_UTMI_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __I uint32_t Reserved1[4];
43 __IO uint32_t UTMI_OHCIICR;
44 __I uint32_t Reserved2[7];
45 __IO uint32_t UTMI_CKTRIM;
46} Utmi;
47#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
48/* -------- UTMI_OHCIICR : (UTMI Offset: 0x10) OHCI Interrupt Configuration Register -------- */
49#define UTMI_OHCIICR_RES0 (0x1u << 0)
50#define UTMI_OHCIICR_ARIE (0x1u << 4)
51#define UTMI_OHCIICR_APPSTART (0x1u << 5)
52#define UTMI_OHCIICR_UDPPUDIS (0x1u << 23)
53/* -------- UTMI_CKTRIM : (UTMI Offset: 0x30) UTMI Clock Trimming Register -------- */
54#define UTMI_CKTRIM_FREQ_Pos 0
55#define UTMI_CKTRIM_FREQ_Msk (0x3u << UTMI_CKTRIM_FREQ_Pos)
56#define UTMI_CKTRIM_FREQ(value) ((UTMI_CKTRIM_FREQ_Msk & ((value) << UTMI_CKTRIM_FREQ_Pos)))
57#define UTMI_CKTRIM_FREQ_XTAL12 (0x0u << 0)
58#define UTMI_CKTRIM_FREQ_XTAL16 (0x1u << 0)
61
62
63#endif /* _SAMS70_UTMI_COMPONENT_ */
#define __IO
Definition: core_cm4.h:239
#define __I
Definition: core_cm4.h:236
Utmi hardware registers.
Definition: component_utmi.h:41
