RTEMS 6.1
component_gmac.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAME70_GMAC_COMPONENT_
31#define _SAME70_GMAC_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __IO uint32_t GMAC_SAB;
43 __IO uint32_t GMAC_SAT;
44} GmacSa;
45
47typedef struct {
48 __IO uint32_t GMAC_ST2COM0;
49 __IO uint32_t GMAC_ST2COM1;
51
53#define GMACSA_NUMBER 4
54#define GMACST2COMPARE_NUMBER 24
55typedef struct {
56 __IO uint32_t GMAC_NCR;
57 __IO uint32_t GMAC_NCFGR;
58 __I uint32_t GMAC_NSR;
59 __IO uint32_t GMAC_UR;
60 __IO uint32_t GMAC_DCFGR;
61 __IO uint32_t GMAC_TSR;
62 __IO uint32_t GMAC_RBQB;
63 __IO uint32_t GMAC_TBQB;
64 __IO uint32_t GMAC_RSR;
65 __I uint32_t GMAC_ISR;
66 __O uint32_t GMAC_IER;
67 __O uint32_t GMAC_IDR;
68 __IO uint32_t GMAC_IMR;
69 __IO uint32_t GMAC_MAN;
70 __I uint32_t GMAC_RPQ;
71 __IO uint32_t GMAC_TPQ;
72 __IO uint32_t GMAC_TPSF;
73 __IO uint32_t GMAC_RPSF;
74 __IO uint32_t GMAC_RJFML;
75 __I uint32_t Reserved1[13];
76 __IO uint32_t GMAC_HRB;
77 __IO uint32_t GMAC_HRT;
78 GmacSa GMAC_SA[GMACSA_NUMBER];
79 __IO uint32_t GMAC_TIDM1;
80 __IO uint32_t GMAC_TIDM2;
81 __IO uint32_t GMAC_TIDM3;
82 __IO uint32_t GMAC_TIDM4;
83 __IO uint32_t GMAC_WOL;
84 __IO uint32_t GMAC_IPGS;
85 __IO uint32_t GMAC_SVLAN;
86 __IO uint32_t GMAC_TPFCP;
87 __IO uint32_t GMAC_SAMB1;
88 __IO uint32_t GMAC_SAMT1;
89 __I uint32_t Reserved2[3];
90 __IO uint32_t GMAC_NSC;
91 __IO uint32_t GMAC_SCL;
92 __IO uint32_t GMAC_SCH;
93 __I uint32_t GMAC_EFTSH;
94 __I uint32_t GMAC_EFRSH;
95 __I uint32_t GMAC_PEFTSH;
96 __I uint32_t GMAC_PEFRSH;
97 __I uint32_t Reserved3[2];
98 __I uint32_t GMAC_OTLO;
99 __I uint32_t GMAC_OTHI;
100 __I uint32_t GMAC_FT;
101 __I uint32_t GMAC_BCFT;
102 __I uint32_t GMAC_MFT;
103 __I uint32_t GMAC_PFT;
104 __I uint32_t GMAC_BFT64;
105 __I uint32_t GMAC_TBFT127;
106 __I uint32_t GMAC_TBFT255;
107 __I uint32_t GMAC_TBFT511;
111 __I uint32_t GMAC_TUR;
112 __I uint32_t GMAC_SCF;
113 __I uint32_t GMAC_MCF;
114 __I uint32_t GMAC_EC;
115 __I uint32_t GMAC_LC;
116 __I uint32_t GMAC_DTF;
117 __I uint32_t GMAC_CSE;
118 __I uint32_t GMAC_ORLO;
119 __I uint32_t GMAC_ORHI;
120 __I uint32_t GMAC_FR;
121 __I uint32_t GMAC_BCFR;
122 __I uint32_t GMAC_MFR;
123 __I uint32_t GMAC_PFR;
124 __I uint32_t GMAC_BFR64;
125 __I uint32_t GMAC_TBFR127;
126 __I uint32_t GMAC_TBFR255;
127 __I uint32_t GMAC_TBFR511;
130 __I uint32_t GMAC_TMXBFR;
131 __I uint32_t GMAC_UFR;
132 __I uint32_t GMAC_OFR;
133 __I uint32_t GMAC_JR;
134 __I uint32_t GMAC_FCSE;
135 __I uint32_t GMAC_LFFE;
136 __I uint32_t GMAC_RSE;
137 __I uint32_t GMAC_AE;
138 __I uint32_t GMAC_RRE;
139 __I uint32_t GMAC_ROE;
140 __I uint32_t GMAC_IHCE;
141 __I uint32_t GMAC_TCE;
142 __I uint32_t GMAC_UCE;
143 __I uint32_t Reserved4[2];
144 __IO uint32_t GMAC_TISUBN;
145 __IO uint32_t GMAC_TSH;
146 __I uint32_t Reserved5[3];
147 __IO uint32_t GMAC_TSL;
148 __IO uint32_t GMAC_TN;
149 __O uint32_t GMAC_TA;
150 __IO uint32_t GMAC_TI;
151 __I uint32_t GMAC_EFTSL;
152 __I uint32_t GMAC_EFTN;
153 __I uint32_t GMAC_EFRSL;
154 __I uint32_t GMAC_EFRN;
155 __I uint32_t GMAC_PEFTSL;
156 __I uint32_t GMAC_PEFTN;
157 __I uint32_t GMAC_PEFRSL;
158 __I uint32_t GMAC_PEFRN;
159 __I uint32_t Reserved6[128];
160 __I uint32_t GMAC_ISRPQ[2];
161 __I uint32_t Reserved7[14];
162 __IO uint32_t GMAC_TBQBAPQ[2];
163 __I uint32_t Reserved8[14];
164 __IO uint32_t GMAC_RBQBAPQ[2];
165 __I uint32_t Reserved9[6];
166 __IO uint32_t GMAC_RBSRPQ[2];
167 __I uint32_t Reserved10[5];
168 __IO uint32_t GMAC_CBSCR;
171 __I uint32_t Reserved11[14];
172 __IO uint32_t GMAC_ST1RPQ[4];
173 __I uint32_t Reserved12[12];
174 __IO uint32_t GMAC_ST2RPQ[8];
175 __I uint32_t Reserved13[12];
176 __I uint32_t Reserved14[28];
177 __O uint32_t GMAC_IERPQ[2];
178 __I uint32_t Reserved15[6];
179 __O uint32_t GMAC_IDRPQ[2];
180 __I uint32_t Reserved16[6];
181 __IO uint32_t GMAC_IMRPQ[2];
182 __I uint32_t Reserved17[38];
183 __IO uint32_t GMAC_ST2ER[4];
184 __I uint32_t Reserved18[4];
185 __IO GmacSt2Compare GMAC_ST2COMP[GMACST2COMPARE_NUMBER];
186} Gmac;
187#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
188/* -------- GMAC_NCR : (GMAC Offset: 0x000) Network Control Register -------- */
189#define GMAC_NCR_LBL (0x1u << 1)
190#define GMAC_NCR_RXEN (0x1u << 2)
191#define GMAC_NCR_TXEN (0x1u << 3)
192#define GMAC_NCR_MPE (0x1u << 4)
193#define GMAC_NCR_CLRSTAT (0x1u << 5)
194#define GMAC_NCR_INCSTAT (0x1u << 6)
195#define GMAC_NCR_WESTAT (0x1u << 7)
196#define GMAC_NCR_BP (0x1u << 8)
197#define GMAC_NCR_TSTART (0x1u << 9)
198#define GMAC_NCR_THALT (0x1u << 10)
199#define GMAC_NCR_TXPF (0x1u << 11)
200#define GMAC_NCR_TXZQPF (0x1u << 12)
201#define GMAC_NCR_SRTSM (0x1u << 15)
202#define GMAC_NCR_ENPBPR (0x1u << 16)
203#define GMAC_NCR_TXPBPF (0x1u << 17)
204#define GMAC_NCR_FNP (0x1u << 18)
205/* -------- GMAC_NCFGR : (GMAC Offset: 0x004) Network Configuration Register -------- */
206#define GMAC_NCFGR_SPD (0x1u << 0)
207#define GMAC_NCFGR_FD (0x1u << 1)
208#define GMAC_NCFGR_DNVLAN (0x1u << 2)
209#define GMAC_NCFGR_JFRAME (0x1u << 3)
210#define GMAC_NCFGR_CAF (0x1u << 4)
211#define GMAC_NCFGR_NBC (0x1u << 5)
212#define GMAC_NCFGR_MTIHEN (0x1u << 6)
213#define GMAC_NCFGR_UNIHEN (0x1u << 7)
214#define GMAC_NCFGR_MAXFS (0x1u << 8)
215#define GMAC_NCFGR_RTY (0x1u << 12)
216#define GMAC_NCFGR_PEN (0x1u << 13)
217#define GMAC_NCFGR_RXBUFO_Pos 14
218#define GMAC_NCFGR_RXBUFO_Msk (0x3u << GMAC_NCFGR_RXBUFO_Pos)
219#define GMAC_NCFGR_RXBUFO(value) ((GMAC_NCFGR_RXBUFO_Msk & ((value) << GMAC_NCFGR_RXBUFO_Pos)))
220#define GMAC_NCFGR_LFERD (0x1u << 16)
221#define GMAC_NCFGR_RFCS (0x1u << 17)
222#define GMAC_NCFGR_CLK_Pos 18
223#define GMAC_NCFGR_CLK_Msk (0x7u << GMAC_NCFGR_CLK_Pos)
224#define GMAC_NCFGR_CLK(value) ((GMAC_NCFGR_CLK_Msk & ((value) << GMAC_NCFGR_CLK_Pos)))
225#define GMAC_NCFGR_CLK_MCK_8 (0x0u << 18)
226#define GMAC_NCFGR_CLK_MCK_16 (0x1u << 18)
227#define GMAC_NCFGR_CLK_MCK_32 (0x2u << 18)
228#define GMAC_NCFGR_CLK_MCK_48 (0x3u << 18)
229#define GMAC_NCFGR_CLK_MCK_64 (0x4u << 18)
230#define GMAC_NCFGR_CLK_MCK_96 (0x5u << 18)
231#define GMAC_NCFGR_DBW_Pos 21
232#define GMAC_NCFGR_DBW_Msk (0x3u << GMAC_NCFGR_DBW_Pos)
233#define GMAC_NCFGR_DBW(value) ((GMAC_NCFGR_DBW_Msk & ((value) << GMAC_NCFGR_DBW_Pos)))
234#define GMAC_NCFGR_DCPF (0x1u << 23)
235#define GMAC_NCFGR_RXCOEN (0x1u << 24)
236#define GMAC_NCFGR_EFRHD (0x1u << 25)
237#define GMAC_NCFGR_IRXFCS (0x1u << 26)
238#define GMAC_NCFGR_IPGSEN (0x1u << 28)
239#define GMAC_NCFGR_RXBP (0x1u << 29)
240#define GMAC_NCFGR_IRXER (0x1u << 30)
241/* -------- GMAC_NSR : (GMAC Offset: 0x008) Network Status Register -------- */
242#define GMAC_NSR_MDIO (0x1u << 1)
243#define GMAC_NSR_IDLE (0x1u << 2)
244/* -------- GMAC_UR : (GMAC Offset: 0x00C) User Register -------- */
245#define GMAC_UR_RMII (0x1u << 0)
246/* -------- GMAC_DCFGR : (GMAC Offset: 0x010) DMA Configuration Register -------- */
247#define GMAC_DCFGR_FBLDO_Pos 0
248#define GMAC_DCFGR_FBLDO_Msk (0x1fu << GMAC_DCFGR_FBLDO_Pos)
249#define GMAC_DCFGR_FBLDO(value) ((GMAC_DCFGR_FBLDO_Msk & ((value) << GMAC_DCFGR_FBLDO_Pos)))
250#define GMAC_DCFGR_FBLDO_SINGLE (0x1u << 0)
251#define GMAC_DCFGR_FBLDO_INCR4 (0x4u << 0)
252#define GMAC_DCFGR_FBLDO_INCR8 (0x8u << 0)
253#define GMAC_DCFGR_FBLDO_INCR16 (0x10u << 0)
254#define GMAC_DCFGR_ESMA (0x1u << 6)
255#define GMAC_DCFGR_ESPA (0x1u << 7)
256#define GMAC_DCFGR_RXBMS_Pos 8
257#define GMAC_DCFGR_RXBMS_Msk (0x3u << GMAC_DCFGR_RXBMS_Pos)
258#define GMAC_DCFGR_RXBMS(value) ((GMAC_DCFGR_RXBMS_Msk & ((value) << GMAC_DCFGR_RXBMS_Pos)))
259#define GMAC_DCFGR_RXBMS_EIGHTH (0x0u << 8)
260#define GMAC_DCFGR_RXBMS_QUARTER (0x1u << 8)
261#define GMAC_DCFGR_RXBMS_HALF (0x2u << 8)
262#define GMAC_DCFGR_RXBMS_FULL (0x3u << 8)
263#define GMAC_DCFGR_TXPBMS (0x1u << 10)
264#define GMAC_DCFGR_TXCOEN (0x1u << 11)
265#define GMAC_DCFGR_DRBS_Pos 16
266#define GMAC_DCFGR_DRBS_Msk (0xffu << GMAC_DCFGR_DRBS_Pos)
267#define GMAC_DCFGR_DRBS(value) ((GMAC_DCFGR_DRBS_Msk & ((value) << GMAC_DCFGR_DRBS_Pos)))
268#define GMAC_DCFGR_DDRP (0x1u << 24)
269/* -------- GMAC_TSR : (GMAC Offset: 0x014) Transmit Status Register -------- */
270#define GMAC_TSR_UBR (0x1u << 0)
271#define GMAC_TSR_COL (0x1u << 1)
272#define GMAC_TSR_RLE (0x1u << 2)
273#define GMAC_TSR_TXGO (0x1u << 3)
274#define GMAC_TSR_TFC (0x1u << 4)
275#define GMAC_TSR_TXCOMP (0x1u << 5)
276#define GMAC_TSR_HRESP (0x1u << 8)
277/* -------- GMAC_RBQB : (GMAC Offset: 0x018) Receive Buffer Queue Base Address Register -------- */
278#define GMAC_RBQB_ADDR_Pos 2
279#define GMAC_RBQB_ADDR_Msk (0x3fffffffu << GMAC_RBQB_ADDR_Pos)
280#define GMAC_RBQB_ADDR(value) ((GMAC_RBQB_ADDR_Msk & ((value) << GMAC_RBQB_ADDR_Pos)))
281/* -------- GMAC_TBQB : (GMAC Offset: 0x01C) Transmit Buffer Queue Base Address Register -------- */
282#define GMAC_TBQB_ADDR_Pos 2
283#define GMAC_TBQB_ADDR_Msk (0x3fffffffu << GMAC_TBQB_ADDR_Pos)
284#define GMAC_TBQB_ADDR(value) ((GMAC_TBQB_ADDR_Msk & ((value) << GMAC_TBQB_ADDR_Pos)))
285/* -------- GMAC_RSR : (GMAC Offset: 0x020) Receive Status Register -------- */
286#define GMAC_RSR_BNA (0x1u << 0)
287#define GMAC_RSR_REC (0x1u << 1)
288#define GMAC_RSR_RXOVR (0x1u << 2)
289#define GMAC_RSR_HNO (0x1u << 3)
290/* -------- GMAC_ISR : (GMAC Offset: 0x024) Interrupt Status Register -------- */
291#define GMAC_ISR_MFS (0x1u << 0)
292#define GMAC_ISR_RCOMP (0x1u << 1)
293#define GMAC_ISR_RXUBR (0x1u << 2)
294#define GMAC_ISR_TXUBR (0x1u << 3)
295#define GMAC_ISR_TUR (0x1u << 4)
296#define GMAC_ISR_RLEX (0x1u << 5)
297#define GMAC_ISR_TFC (0x1u << 6)
298#define GMAC_ISR_TCOMP (0x1u << 7)
299#define GMAC_ISR_ROVR (0x1u << 10)
300#define GMAC_ISR_HRESP (0x1u << 11)
301#define GMAC_ISR_PFNZ (0x1u << 12)
302#define GMAC_ISR_PTZ (0x1u << 13)
303#define GMAC_ISR_PFTR (0x1u << 14)
304#define GMAC_ISR_DRQFR (0x1u << 18)
305#define GMAC_ISR_SFR (0x1u << 19)
306#define GMAC_ISR_DRQFT (0x1u << 20)
307#define GMAC_ISR_SFT (0x1u << 21)
308#define GMAC_ISR_PDRQFR (0x1u << 22)
309#define GMAC_ISR_PDRSFR (0x1u << 23)
310#define GMAC_ISR_PDRQFT (0x1u << 24)
311#define GMAC_ISR_PDRSFT (0x1u << 25)
312#define GMAC_ISR_SRI (0x1u << 26)
313#define GMAC_ISR_WOL (0x1u << 28)
314#define GMAC_ISR_TSU (0x1u << 29)
315/* -------- GMAC_IER : (GMAC Offset: 0x028) Interrupt Enable Register -------- */
316#define GMAC_IER_MFS (0x1u << 0)
317#define GMAC_IER_RCOMP (0x1u << 1)
318#define GMAC_IER_RXUBR (0x1u << 2)
319#define GMAC_IER_TXUBR (0x1u << 3)
320#define GMAC_IER_TUR (0x1u << 4)
321#define GMAC_IER_RLEX (0x1u << 5)
322#define GMAC_IER_TFC (0x1u << 6)
323#define GMAC_IER_TCOMP (0x1u << 7)
324#define GMAC_IER_ROVR (0x1u << 10)
325#define GMAC_IER_HRESP (0x1u << 11)
326#define GMAC_IER_PFNZ (0x1u << 12)
327#define GMAC_IER_PTZ (0x1u << 13)
328#define GMAC_IER_PFTR (0x1u << 14)
329#define GMAC_IER_EXINT (0x1u << 15)
330#define GMAC_IER_DRQFR (0x1u << 18)
331#define GMAC_IER_SFR (0x1u << 19)
332#define GMAC_IER_DRQFT (0x1u << 20)
333#define GMAC_IER_SFT (0x1u << 21)
334#define GMAC_IER_PDRQFR (0x1u << 22)
335#define GMAC_IER_PDRSFR (0x1u << 23)
336#define GMAC_IER_PDRQFT (0x1u << 24)
337#define GMAC_IER_PDRSFT (0x1u << 25)
338#define GMAC_IER_SRI (0x1u << 26)
339#define GMAC_IER_WOL (0x1u << 28)
340/* -------- GMAC_IDR : (GMAC Offset: 0x02C) Interrupt Disable Register -------- */
341#define GMAC_IDR_MFS (0x1u << 0)
342#define GMAC_IDR_RCOMP (0x1u << 1)
343#define GMAC_IDR_RXUBR (0x1u << 2)
344#define GMAC_IDR_TXUBR (0x1u << 3)
345#define GMAC_IDR_TUR (0x1u << 4)
346#define GMAC_IDR_RLEX (0x1u << 5)
347#define GMAC_IDR_TFC (0x1u << 6)
348#define GMAC_IDR_TCOMP (0x1u << 7)
349#define GMAC_IDR_ROVR (0x1u << 10)
350#define GMAC_IDR_HRESP (0x1u << 11)
351#define GMAC_IDR_PFNZ (0x1u << 12)
352#define GMAC_IDR_PTZ (0x1u << 13)
353#define GMAC_IDR_PFTR (0x1u << 14)
354#define GMAC_IDR_EXINT (0x1u << 15)
355#define GMAC_IDR_DRQFR (0x1u << 18)
356#define GMAC_IDR_SFR (0x1u << 19)
357#define GMAC_IDR_DRQFT (0x1u << 20)
358#define GMAC_IDR_SFT (0x1u << 21)
359#define GMAC_IDR_PDRQFR (0x1u << 22)
360#define GMAC_IDR_PDRSFR (0x1u << 23)
361#define GMAC_IDR_PDRQFT (0x1u << 24)
362#define GMAC_IDR_PDRSFT (0x1u << 25)
363#define GMAC_IDR_SRI (0x1u << 26)
364#define GMAC_IDR_WOL (0x1u << 28)
365/* -------- GMAC_IMR : (GMAC Offset: 0x030) Interrupt Mask Register -------- */
366#define GMAC_IMR_MFS (0x1u << 0)
367#define GMAC_IMR_RCOMP (0x1u << 1)
368#define GMAC_IMR_RXUBR (0x1u << 2)
369#define GMAC_IMR_TXUBR (0x1u << 3)
370#define GMAC_IMR_TUR (0x1u << 4)
371#define GMAC_IMR_RLEX (0x1u << 5)
372#define GMAC_IMR_TFC (0x1u << 6)
373#define GMAC_IMR_TCOMP (0x1u << 7)
374#define GMAC_IMR_ROVR (0x1u << 10)
375#define GMAC_IMR_HRESP (0x1u << 11)
376#define GMAC_IMR_PFNZ (0x1u << 12)
377#define GMAC_IMR_PTZ (0x1u << 13)
378#define GMAC_IMR_PFTR (0x1u << 14)
379#define GMAC_IMR_EXINT (0x1u << 15)
380#define GMAC_IMR_DRQFR (0x1u << 18)
381#define GMAC_IMR_SFR (0x1u << 19)
382#define GMAC_IMR_DRQFT (0x1u << 20)
383#define GMAC_IMR_SFT (0x1u << 21)
384#define GMAC_IMR_PDRQFR (0x1u << 22)
385#define GMAC_IMR_PDRSFR (0x1u << 23)
386#define GMAC_IMR_PDRQFT (0x1u << 24)
387#define GMAC_IMR_PDRSFT (0x1u << 25)
388/* -------- GMAC_MAN : (GMAC Offset: 0x034) PHY Maintenance Register -------- */
389#define GMAC_MAN_DATA_Pos 0
390#define GMAC_MAN_DATA_Msk (0xffffu << GMAC_MAN_DATA_Pos)
391#define GMAC_MAN_DATA(value) ((GMAC_MAN_DATA_Msk & ((value) << GMAC_MAN_DATA_Pos)))
392#define GMAC_MAN_WTN_Pos 16
393#define GMAC_MAN_WTN_Msk (0x3u << GMAC_MAN_WTN_Pos)
394#define GMAC_MAN_WTN(value) ((GMAC_MAN_WTN_Msk & ((value) << GMAC_MAN_WTN_Pos)))
395#define GMAC_MAN_REGA_Pos 18
396#define GMAC_MAN_REGA_Msk (0x1fu << GMAC_MAN_REGA_Pos)
397#define GMAC_MAN_REGA(value) ((GMAC_MAN_REGA_Msk & ((value) << GMAC_MAN_REGA_Pos)))
398#define GMAC_MAN_PHYA_Pos 23
399#define GMAC_MAN_PHYA_Msk (0x1fu << GMAC_MAN_PHYA_Pos)
400#define GMAC_MAN_PHYA(value) ((GMAC_MAN_PHYA_Msk & ((value) << GMAC_MAN_PHYA_Pos)))
401#define GMAC_MAN_OP_Pos 28
402#define GMAC_MAN_OP_Msk (0x3u << GMAC_MAN_OP_Pos)
403#define GMAC_MAN_OP(value) ((GMAC_MAN_OP_Msk & ((value) << GMAC_MAN_OP_Pos)))
404#define GMAC_MAN_CLTTO (0x1u << 30)
405#define GMAC_MAN_WZO (0x1u << 31)
406/* -------- GMAC_RPQ : (GMAC Offset: 0x038) Received Pause Quantum Register -------- */
407#define GMAC_RPQ_RPQ_Pos 0
408#define GMAC_RPQ_RPQ_Msk (0xffffu << GMAC_RPQ_RPQ_Pos)
409/* -------- GMAC_TPQ : (GMAC Offset: 0x03C) Transmit Pause Quantum Register -------- */
410#define GMAC_TPQ_TPQ_Pos 0
411#define GMAC_TPQ_TPQ_Msk (0xffffu << GMAC_TPQ_TPQ_Pos)
412#define GMAC_TPQ_TPQ(value) ((GMAC_TPQ_TPQ_Msk & ((value) << GMAC_TPQ_TPQ_Pos)))
413/* -------- GMAC_TPSF : (GMAC Offset: 0x040) TX Partial Store and Forward Register -------- */
414#define GMAC_TPSF_TPB1ADR_Pos 0
415#define GMAC_TPSF_TPB1ADR_Msk (0xfffu << GMAC_TPSF_TPB1ADR_Pos)
416#define GMAC_TPSF_TPB1ADR(value) ((GMAC_TPSF_TPB1ADR_Msk & ((value) << GMAC_TPSF_TPB1ADR_Pos)))
417#define GMAC_TPSF_ENTXP (0x1u << 31)
418/* -------- GMAC_RPSF : (GMAC Offset: 0x044) RX Partial Store and Forward Register -------- */
419#define GMAC_RPSF_RPB1ADR_Pos 0
420#define GMAC_RPSF_RPB1ADR_Msk (0xfffu << GMAC_RPSF_RPB1ADR_Pos)
421#define GMAC_RPSF_RPB1ADR(value) ((GMAC_RPSF_RPB1ADR_Msk & ((value) << GMAC_RPSF_RPB1ADR_Pos)))
422#define GMAC_RPSF_ENRXP (0x1u << 31)
423/* -------- GMAC_RJFML : (GMAC Offset: 0x048) RX Jumbo Frame Max Length Register -------- */
424#define GMAC_RJFML_FML_Pos 0
425#define GMAC_RJFML_FML_Msk (0x3fffu << GMAC_RJFML_FML_Pos)
426#define GMAC_RJFML_FML(value) ((GMAC_RJFML_FML_Msk & ((value) << GMAC_RJFML_FML_Pos)))
427/* -------- GMAC_HRB : (GMAC Offset: 0x080) Hash Register Bottom -------- */
428#define GMAC_HRB_ADDR_Pos 0
429#define GMAC_HRB_ADDR_Msk (0xffffffffu << GMAC_HRB_ADDR_Pos)
430#define GMAC_HRB_ADDR(value) ((GMAC_HRB_ADDR_Msk & ((value) << GMAC_HRB_ADDR_Pos)))
431/* -------- GMAC_HRT : (GMAC Offset: 0x084) Hash Register Top -------- */
432#define GMAC_HRT_ADDR_Pos 0
433#define GMAC_HRT_ADDR_Msk (0xffffffffu << GMAC_HRT_ADDR_Pos)
434#define GMAC_HRT_ADDR(value) ((GMAC_HRT_ADDR_Msk & ((value) << GMAC_HRT_ADDR_Pos)))
435/* -------- GMAC_SAB : (GMAC Offset: N/A) Specific Address 1 Bottom Register -------- */
436#define GMAC_SAB_ADDR_Pos 0
437#define GMAC_SAB_ADDR_Msk (0xffffffffu << GMAC_SAB_ADDR_Pos)
438#define GMAC_SAB_ADDR(value) ((GMAC_SAB_ADDR_Msk & ((value) << GMAC_SAB_ADDR_Pos)))
439/* -------- GMAC_SAT : (GMAC Offset: N/A) Specific Address 1 Top Register -------- */
440#define GMAC_SAT_ADDR_Pos 0
441#define GMAC_SAT_ADDR_Msk (0xffffu << GMAC_SAT_ADDR_Pos)
442#define GMAC_SAT_ADDR(value) ((GMAC_SAT_ADDR_Msk & ((value) << GMAC_SAT_ADDR_Pos)))
443/* -------- GMAC_TIDM1 : (GMAC Offset: 0x0A8) Type ID Match 1 Register -------- */
444#define GMAC_TIDM1_TID_Pos 0
445#define GMAC_TIDM1_TID_Msk (0xffffu << GMAC_TIDM1_TID_Pos)
446#define GMAC_TIDM1_TID(value) ((GMAC_TIDM1_TID_Msk & ((value) << GMAC_TIDM1_TID_Pos)))
447#define GMAC_TIDM1_ENID1 (0x1u << 31)
448/* -------- GMAC_TIDM2 : (GMAC Offset: 0x0AC) Type ID Match 2 Register -------- */
449#define GMAC_TIDM2_TID_Pos 0
450#define GMAC_TIDM2_TID_Msk (0xffffu << GMAC_TIDM2_TID_Pos)
451#define GMAC_TIDM2_TID(value) ((GMAC_TIDM2_TID_Msk & ((value) << GMAC_TIDM2_TID_Pos)))
452#define GMAC_TIDM2_ENID2 (0x1u << 31)
453/* -------- GMAC_TIDM3 : (GMAC Offset: 0x0B0) Type ID Match 3 Register -------- */
454#define GMAC_TIDM3_TID_Pos 0
455#define GMAC_TIDM3_TID_Msk (0xffffu << GMAC_TIDM3_TID_Pos)
456#define GMAC_TIDM3_TID(value) ((GMAC_TIDM3_TID_Msk & ((value) << GMAC_TIDM3_TID_Pos)))
457#define GMAC_TIDM3_ENID3 (0x1u << 31)
458/* -------- GMAC_TIDM4 : (GMAC Offset: 0x0B4) Type ID Match 4 Register -------- */
459#define GMAC_TIDM4_TID_Pos 0
460#define GMAC_TIDM4_TID_Msk (0xffffu << GMAC_TIDM4_TID_Pos)
461#define GMAC_TIDM4_TID(value) ((GMAC_TIDM4_TID_Msk & ((value) << GMAC_TIDM4_TID_Pos)))
462#define GMAC_TIDM4_ENID4 (0x1u << 31)
463/* -------- GMAC_WOL : (GMAC Offset: 0x0B8) Wake on LAN Register -------- */
464#define GMAC_WOL_IP_Pos 0
465#define GMAC_WOL_IP_Msk (0xffffu << GMAC_WOL_IP_Pos)
466#define GMAC_WOL_IP(value) ((GMAC_WOL_IP_Msk & ((value) << GMAC_WOL_IP_Pos)))
467#define GMAC_WOL_MAG (0x1u << 16)
468#define GMAC_WOL_ARP (0x1u << 17)
469#define GMAC_WOL_SA1 (0x1u << 18)
470#define GMAC_WOL_MTI (0x1u << 19)
471/* -------- GMAC_IPGS : (GMAC Offset: 0x0BC) IPG Stretch Register -------- */
472#define GMAC_IPGS_FL_Pos 0
473#define GMAC_IPGS_FL_Msk (0xffffu << GMAC_IPGS_FL_Pos)
474#define GMAC_IPGS_FL(value) ((GMAC_IPGS_FL_Msk & ((value) << GMAC_IPGS_FL_Pos)))
475/* -------- GMAC_SVLAN : (GMAC Offset: 0x0C0) Stacked VLAN Register -------- */
476#define GMAC_SVLAN_VLAN_TYPE_Pos 0
477#define GMAC_SVLAN_VLAN_TYPE_Msk (0xffffu << GMAC_SVLAN_VLAN_TYPE_Pos)
478#define GMAC_SVLAN_VLAN_TYPE(value) ((GMAC_SVLAN_VLAN_TYPE_Msk & ((value) << GMAC_SVLAN_VLAN_TYPE_Pos)))
479#define GMAC_SVLAN_ESVLAN (0x1u << 31)
480/* -------- GMAC_TPFCP : (GMAC Offset: 0x0C4) Transmit PFC Pause Register -------- */
481#define GMAC_TPFCP_PEV_Pos 0
482#define GMAC_TPFCP_PEV_Msk (0xffu << GMAC_TPFCP_PEV_Pos)
483#define GMAC_TPFCP_PEV(value) ((GMAC_TPFCP_PEV_Msk & ((value) << GMAC_TPFCP_PEV_Pos)))
484#define GMAC_TPFCP_PQ_Pos 8
485#define GMAC_TPFCP_PQ_Msk (0xffu << GMAC_TPFCP_PQ_Pos)
486#define GMAC_TPFCP_PQ(value) ((GMAC_TPFCP_PQ_Msk & ((value) << GMAC_TPFCP_PQ_Pos)))
487/* -------- GMAC_SAMB1 : (GMAC Offset: 0x0C8) Specific Address 1 Mask Bottom Register -------- */
488#define GMAC_SAMB1_ADDR_Pos 0
489#define GMAC_SAMB1_ADDR_Msk (0xffffffffu << GMAC_SAMB1_ADDR_Pos)
490#define GMAC_SAMB1_ADDR(value) ((GMAC_SAMB1_ADDR_Msk & ((value) << GMAC_SAMB1_ADDR_Pos)))
491/* -------- GMAC_SAMT1 : (GMAC Offset: 0x0CC) Specific Address 1 Mask Top Register -------- */
492#define GMAC_SAMT1_ADDR_Pos 0
493#define GMAC_SAMT1_ADDR_Msk (0xffffu << GMAC_SAMT1_ADDR_Pos)
494#define GMAC_SAMT1_ADDR(value) ((GMAC_SAMT1_ADDR_Msk & ((value) << GMAC_SAMT1_ADDR_Pos)))
495/* -------- GMAC_NSC : (GMAC Offset: 0x0DC) 1588 Timer Nanosecond Comparison Register -------- */
496#define GMAC_NSC_NANOSEC_Pos 0
497#define GMAC_NSC_NANOSEC_Msk (0x3fffffu << GMAC_NSC_NANOSEC_Pos)
498#define GMAC_NSC_NANOSEC(value) ((GMAC_NSC_NANOSEC_Msk & ((value) << GMAC_NSC_NANOSEC_Pos)))
499/* -------- GMAC_SCL : (GMAC Offset: 0x0E0) 1588 Timer Second Comparison Low Register -------- */
500#define GMAC_SCL_SEC_Pos 0
501#define GMAC_SCL_SEC_Msk (0xffffffffu << GMAC_SCL_SEC_Pos)
502#define GMAC_SCL_SEC(value) ((GMAC_SCL_SEC_Msk & ((value) << GMAC_SCL_SEC_Pos)))
503/* -------- GMAC_SCH : (GMAC Offset: 0x0E4) 1588 Timer Second Comparison High Register -------- */
504#define GMAC_SCH_SEC_Pos 0
505#define GMAC_SCH_SEC_Msk (0xffffu << GMAC_SCH_SEC_Pos)
506#define GMAC_SCH_SEC(value) ((GMAC_SCH_SEC_Msk & ((value) << GMAC_SCH_SEC_Pos)))
507/* -------- GMAC_EFTSH : (GMAC Offset: 0x0E8) PTP Event Frame Transmitted Seconds High Register -------- */
508#define GMAC_EFTSH_RUD_Pos 0
509#define GMAC_EFTSH_RUD_Msk (0xffffu << GMAC_EFTSH_RUD_Pos)
510/* -------- GMAC_EFRSH : (GMAC Offset: 0x0EC) PTP Event Frame Received Seconds High Register -------- */
511#define GMAC_EFRSH_RUD_Pos 0
512#define GMAC_EFRSH_RUD_Msk (0xffffu << GMAC_EFRSH_RUD_Pos)
513/* -------- GMAC_PEFTSH : (GMAC Offset: 0x0F0) PTP Peer Event Frame Transmitted Seconds High Register -------- */
514#define GMAC_PEFTSH_RUD_Pos 0
515#define GMAC_PEFTSH_RUD_Msk (0xffffu << GMAC_PEFTSH_RUD_Pos)
516/* -------- GMAC_PEFRSH : (GMAC Offset: 0x0F4) PTP Peer Event Frame Received Seconds High Register -------- */
517#define GMAC_PEFRSH_RUD_Pos 0
518#define GMAC_PEFRSH_RUD_Msk (0xffffu << GMAC_PEFRSH_RUD_Pos)
519/* -------- GMAC_OTLO : (GMAC Offset: 0x100) Octets Transmitted Low Register -------- */
520#define GMAC_OTLO_TXO_Pos 0
521#define GMAC_OTLO_TXO_Msk (0xffffffffu << GMAC_OTLO_TXO_Pos)
522/* -------- GMAC_OTHI : (GMAC Offset: 0x104) Octets Transmitted High Register -------- */
523#define GMAC_OTHI_TXO_Pos 0
524#define GMAC_OTHI_TXO_Msk (0xffffu << GMAC_OTHI_TXO_Pos)
525/* -------- GMAC_FT : (GMAC Offset: 0x108) Frames Transmitted Register -------- */
526#define GMAC_FT_FTX_Pos 0
527#define GMAC_FT_FTX_Msk (0xffffffffu << GMAC_FT_FTX_Pos)
528/* -------- GMAC_BCFT : (GMAC Offset: 0x10C) Broadcast Frames Transmitted Register -------- */
529#define GMAC_BCFT_BFTX_Pos 0
530#define GMAC_BCFT_BFTX_Msk (0xffffffffu << GMAC_BCFT_BFTX_Pos)
531/* -------- GMAC_MFT : (GMAC Offset: 0x110) Multicast Frames Transmitted Register -------- */
532#define GMAC_MFT_MFTX_Pos 0
533#define GMAC_MFT_MFTX_Msk (0xffffffffu << GMAC_MFT_MFTX_Pos)
534/* -------- GMAC_PFT : (GMAC Offset: 0x114) Pause Frames Transmitted Register -------- */
535#define GMAC_PFT_PFTX_Pos 0
536#define GMAC_PFT_PFTX_Msk (0xffffu << GMAC_PFT_PFTX_Pos)
537/* -------- GMAC_BFT64 : (GMAC Offset: 0x118) 64 Byte Frames Transmitted Register -------- */
538#define GMAC_BFT64_NFTX_Pos 0
539#define GMAC_BFT64_NFTX_Msk (0xffffffffu << GMAC_BFT64_NFTX_Pos)
540/* -------- GMAC_TBFT127 : (GMAC Offset: 0x11C) 65 to 127 Byte Frames Transmitted Register -------- */
541#define GMAC_TBFT127_NFTX_Pos 0
542#define GMAC_TBFT127_NFTX_Msk (0xffffffffu << GMAC_TBFT127_NFTX_Pos)
543/* -------- GMAC_TBFT255 : (GMAC Offset: 0x120) 128 to 255 Byte Frames Transmitted Register -------- */
544#define GMAC_TBFT255_NFTX_Pos 0
545#define GMAC_TBFT255_NFTX_Msk (0xffffffffu << GMAC_TBFT255_NFTX_Pos)
546/* -------- GMAC_TBFT511 : (GMAC Offset: 0x124) 256 to 511 Byte Frames Transmitted Register -------- */
547#define GMAC_TBFT511_NFTX_Pos 0
548#define GMAC_TBFT511_NFTX_Msk (0xffffffffu << GMAC_TBFT511_NFTX_Pos)
549/* -------- GMAC_TBFT1023 : (GMAC Offset: 0x128) 512 to 1023 Byte Frames Transmitted Register -------- */
550#define GMAC_TBFT1023_NFTX_Pos 0
551#define GMAC_TBFT1023_NFTX_Msk (0xffffffffu << GMAC_TBFT1023_NFTX_Pos)
552/* -------- GMAC_TBFT1518 : (GMAC Offset: 0x12C) 1024 to 1518 Byte Frames Transmitted Register -------- */
553#define GMAC_TBFT1518_NFTX_Pos 0
554#define GMAC_TBFT1518_NFTX_Msk (0xffffffffu << GMAC_TBFT1518_NFTX_Pos)
555/* -------- GMAC_GTBFT1518 : (GMAC Offset: 0x130) Greater Than 1518 Byte Frames Transmitted Register -------- */
556#define GMAC_GTBFT1518_NFTX_Pos 0
557#define GMAC_GTBFT1518_NFTX_Msk (0xffffffffu << GMAC_GTBFT1518_NFTX_Pos)
558/* -------- GMAC_TUR : (GMAC Offset: 0x134) Transmit Underruns Register -------- */
559#define GMAC_TUR_TXUNR_Pos 0
560#define GMAC_TUR_TXUNR_Msk (0x3ffu << GMAC_TUR_TXUNR_Pos)
561/* -------- GMAC_SCF : (GMAC Offset: 0x138) Single Collision Frames Register -------- */
562#define GMAC_SCF_SCOL_Pos 0
563#define GMAC_SCF_SCOL_Msk (0x3ffffu << GMAC_SCF_SCOL_Pos)
564/* -------- GMAC_MCF : (GMAC Offset: 0x13C) Multiple Collision Frames Register -------- */
565#define GMAC_MCF_MCOL_Pos 0
566#define GMAC_MCF_MCOL_Msk (0x3ffffu << GMAC_MCF_MCOL_Pos)
567/* -------- GMAC_EC : (GMAC Offset: 0x140) Excessive Collisions Register -------- */
568#define GMAC_EC_XCOL_Pos 0
569#define GMAC_EC_XCOL_Msk (0x3ffu << GMAC_EC_XCOL_Pos)
570/* -------- GMAC_LC : (GMAC Offset: 0x144) Late Collisions Register -------- */
571#define GMAC_LC_LCOL_Pos 0
572#define GMAC_LC_LCOL_Msk (0x3ffu << GMAC_LC_LCOL_Pos)
573/* -------- GMAC_DTF : (GMAC Offset: 0x148) Deferred Transmission Frames Register -------- */
574#define GMAC_DTF_DEFT_Pos 0
575#define GMAC_DTF_DEFT_Msk (0x3ffffu << GMAC_DTF_DEFT_Pos)
576/* -------- GMAC_CSE : (GMAC Offset: 0x14C) Carrier Sense Errors Register -------- */
577#define GMAC_CSE_CSR_Pos 0
578#define GMAC_CSE_CSR_Msk (0x3ffu << GMAC_CSE_CSR_Pos)
579/* -------- GMAC_ORLO : (GMAC Offset: 0x150) Octets Received Low Received Register -------- */
580#define GMAC_ORLO_RXO_Pos 0
581#define GMAC_ORLO_RXO_Msk (0xffffffffu << GMAC_ORLO_RXO_Pos)
582/* -------- GMAC_ORHI : (GMAC Offset: 0x154) Octets Received High Received Register -------- */
583#define GMAC_ORHI_RXO_Pos 0
584#define GMAC_ORHI_RXO_Msk (0xffffu << GMAC_ORHI_RXO_Pos)
585/* -------- GMAC_FR : (GMAC Offset: 0x158) Frames Received Register -------- */
586#define GMAC_FR_FRX_Pos 0
587#define GMAC_FR_FRX_Msk (0xffffffffu << GMAC_FR_FRX_Pos)
588/* -------- GMAC_BCFR : (GMAC Offset: 0x15C) Broadcast Frames Received Register -------- */
589#define GMAC_BCFR_BFRX_Pos 0
590#define GMAC_BCFR_BFRX_Msk (0xffffffffu << GMAC_BCFR_BFRX_Pos)
591/* -------- GMAC_MFR : (GMAC Offset: 0x160) Multicast Frames Received Register -------- */
592#define GMAC_MFR_MFRX_Pos 0
593#define GMAC_MFR_MFRX_Msk (0xffffffffu << GMAC_MFR_MFRX_Pos)
594/* -------- GMAC_PFR : (GMAC Offset: 0x164) Pause Frames Received Register -------- */
595#define GMAC_PFR_PFRX_Pos 0
596#define GMAC_PFR_PFRX_Msk (0xffffu << GMAC_PFR_PFRX_Pos)
597/* -------- GMAC_BFR64 : (GMAC Offset: 0x168) 64 Byte Frames Received Register -------- */
598#define GMAC_BFR64_NFRX_Pos 0
599#define GMAC_BFR64_NFRX_Msk (0xffffffffu << GMAC_BFR64_NFRX_Pos)
600/* -------- GMAC_TBFR127 : (GMAC Offset: 0x16C) 65 to 127 Byte Frames Received Register -------- */
601#define GMAC_TBFR127_NFRX_Pos 0
602#define GMAC_TBFR127_NFRX_Msk (0xffffffffu << GMAC_TBFR127_NFRX_Pos)
603/* -------- GMAC_TBFR255 : (GMAC Offset: 0x170) 128 to 255 Byte Frames Received Register -------- */
604#define GMAC_TBFR255_NFRX_Pos 0
605#define GMAC_TBFR255_NFRX_Msk (0xffffffffu << GMAC_TBFR255_NFRX_Pos)
606/* -------- GMAC_TBFR511 : (GMAC Offset: 0x174) 256 to 511 Byte Frames Received Register -------- */
607#define GMAC_TBFR511_NFRX_Pos 0
608#define GMAC_TBFR511_NFRX_Msk (0xffffffffu << GMAC_TBFR511_NFRX_Pos)
609/* -------- GMAC_TBFR1023 : (GMAC Offset: 0x178) 512 to 1023 Byte Frames Received Register -------- */
610#define GMAC_TBFR1023_NFRX_Pos 0
611#define GMAC_TBFR1023_NFRX_Msk (0xffffffffu << GMAC_TBFR1023_NFRX_Pos)
612/* -------- GMAC_TBFR1518 : (GMAC Offset: 0x17C) 1024 to 1518 Byte Frames Received Register -------- */
613#define GMAC_TBFR1518_NFRX_Pos 0
614#define GMAC_TBFR1518_NFRX_Msk (0xffffffffu << GMAC_TBFR1518_NFRX_Pos)
615/* -------- GMAC_TMXBFR : (GMAC Offset: 0x180) 1519 to Maximum Byte Frames Received Register -------- */
616#define GMAC_TMXBFR_NFRX_Pos 0
617#define GMAC_TMXBFR_NFRX_Msk (0xffffffffu << GMAC_TMXBFR_NFRX_Pos)
618/* -------- GMAC_UFR : (GMAC Offset: 0x184) Undersize Frames Received Register -------- */
619#define GMAC_UFR_UFRX_Pos 0
620#define GMAC_UFR_UFRX_Msk (0x3ffu << GMAC_UFR_UFRX_Pos)
621/* -------- GMAC_OFR : (GMAC Offset: 0x188) Oversize Frames Received Register -------- */
622#define GMAC_OFR_OFRX_Pos 0
623#define GMAC_OFR_OFRX_Msk (0x3ffu << GMAC_OFR_OFRX_Pos)
624/* -------- GMAC_JR : (GMAC Offset: 0x18C) Jabbers Received Register -------- */
625#define GMAC_JR_JRX_Pos 0
626#define GMAC_JR_JRX_Msk (0x3ffu << GMAC_JR_JRX_Pos)
627/* -------- GMAC_FCSE : (GMAC Offset: 0x190) Frame Check Sequence Errors Register -------- */
628#define GMAC_FCSE_FCKR_Pos 0
629#define GMAC_FCSE_FCKR_Msk (0x3ffu << GMAC_FCSE_FCKR_Pos)
630/* -------- GMAC_LFFE : (GMAC Offset: 0x194) Length Field Frame Errors Register -------- */
631#define GMAC_LFFE_LFER_Pos 0
632#define GMAC_LFFE_LFER_Msk (0x3ffu << GMAC_LFFE_LFER_Pos)
633/* -------- GMAC_RSE : (GMAC Offset: 0x198) Receive Symbol Errors Register -------- */
634#define GMAC_RSE_RXSE_Pos 0
635#define GMAC_RSE_RXSE_Msk (0x3ffu << GMAC_RSE_RXSE_Pos)
636/* -------- GMAC_AE : (GMAC Offset: 0x19C) Alignment Errors Register -------- */
637#define GMAC_AE_AER_Pos 0
638#define GMAC_AE_AER_Msk (0x3ffu << GMAC_AE_AER_Pos)
639/* -------- GMAC_RRE : (GMAC Offset: 0x1A0) Receive Resource Errors Register -------- */
640#define GMAC_RRE_RXRER_Pos 0
641#define GMAC_RRE_RXRER_Msk (0x3ffffu << GMAC_RRE_RXRER_Pos)
642/* -------- GMAC_ROE : (GMAC Offset: 0x1A4) Receive Overrun Register -------- */
643#define GMAC_ROE_RXOVR_Pos 0
644#define GMAC_ROE_RXOVR_Msk (0x3ffu << GMAC_ROE_RXOVR_Pos)
645/* -------- GMAC_IHCE : (GMAC Offset: 0x1A8) IP Header Checksum Errors Register -------- */
646#define GMAC_IHCE_HCKER_Pos 0
647#define GMAC_IHCE_HCKER_Msk (0xffu << GMAC_IHCE_HCKER_Pos)
648/* -------- GMAC_TCE : (GMAC Offset: 0x1AC) TCP Checksum Errors Register -------- */
649#define GMAC_TCE_TCKER_Pos 0
650#define GMAC_TCE_TCKER_Msk (0xffu << GMAC_TCE_TCKER_Pos)
651/* -------- GMAC_UCE : (GMAC Offset: 0x1B0) UDP Checksum Errors Register -------- */
652#define GMAC_UCE_UCKER_Pos 0
653#define GMAC_UCE_UCKER_Msk (0xffu << GMAC_UCE_UCKER_Pos)
654/* -------- GMAC_TISUBN : (GMAC Offset: 0x1BC) 1588 Timer Increment Sub-nanoseconds Register -------- */
655#define GMAC_TISUBN_LSBTIR_Pos 0
656#define GMAC_TISUBN_LSBTIR_Msk (0xffffu << GMAC_TISUBN_LSBTIR_Pos)
657#define GMAC_TISUBN_LSBTIR(value) ((GMAC_TISUBN_LSBTIR_Msk & ((value) << GMAC_TISUBN_LSBTIR_Pos)))
658/* -------- GMAC_TSH : (GMAC Offset: 0x1C0) 1588 Timer Seconds High Register -------- */
659#define GMAC_TSH_TCS_Pos 0
660#define GMAC_TSH_TCS_Msk (0xffffu << GMAC_TSH_TCS_Pos)
661#define GMAC_TSH_TCS(value) ((GMAC_TSH_TCS_Msk & ((value) << GMAC_TSH_TCS_Pos)))
662/* -------- GMAC_TSL : (GMAC Offset: 0x1D0) 1588 Timer Seconds Low Register -------- */
663#define GMAC_TSL_TCS_Pos 0
664#define GMAC_TSL_TCS_Msk (0xffffffffu << GMAC_TSL_TCS_Pos)
665#define GMAC_TSL_TCS(value) ((GMAC_TSL_TCS_Msk & ((value) << GMAC_TSL_TCS_Pos)))
666/* -------- GMAC_TN : (GMAC Offset: 0x1D4) 1588 Timer Nanoseconds Register -------- */
667#define GMAC_TN_TNS_Pos 0
668#define GMAC_TN_TNS_Msk (0x3fffffffu << GMAC_TN_TNS_Pos)
669#define GMAC_TN_TNS(value) ((GMAC_TN_TNS_Msk & ((value) << GMAC_TN_TNS_Pos)))
670/* -------- GMAC_TA : (GMAC Offset: 0x1D8) 1588 Timer Adjust Register -------- */
671#define GMAC_TA_ITDT_Pos 0
672#define GMAC_TA_ITDT_Msk (0x3fffffffu << GMAC_TA_ITDT_Pos)
673#define GMAC_TA_ITDT(value) ((GMAC_TA_ITDT_Msk & ((value) << GMAC_TA_ITDT_Pos)))
674#define GMAC_TA_ADJ (0x1u << 31)
675/* -------- GMAC_TI : (GMAC Offset: 0x1DC) 1588 Timer Increment Register -------- */
676#define GMAC_TI_CNS_Pos 0
677#define GMAC_TI_CNS_Msk (0xffu << GMAC_TI_CNS_Pos)
678#define GMAC_TI_CNS(value) ((GMAC_TI_CNS_Msk & ((value) << GMAC_TI_CNS_Pos)))
679#define GMAC_TI_ACNS_Pos 8
680#define GMAC_TI_ACNS_Msk (0xffu << GMAC_TI_ACNS_Pos)
681#define GMAC_TI_ACNS(value) ((GMAC_TI_ACNS_Msk & ((value) << GMAC_TI_ACNS_Pos)))
682#define GMAC_TI_NIT_Pos 16
683#define GMAC_TI_NIT_Msk (0xffu << GMAC_TI_NIT_Pos)
684#define GMAC_TI_NIT(value) ((GMAC_TI_NIT_Msk & ((value) << GMAC_TI_NIT_Pos)))
685/* -------- GMAC_EFTSL : (GMAC Offset: 0x1E0) PTP Event Frame Transmitted Seconds Low Register -------- */
686#define GMAC_EFTSL_RUD_Pos 0
687#define GMAC_EFTSL_RUD_Msk (0xffffffffu << GMAC_EFTSL_RUD_Pos)
688/* -------- GMAC_EFTN : (GMAC Offset: 0x1E4) PTP Event Frame Transmitted Nanoseconds Register -------- */
689#define GMAC_EFTN_RUD_Pos 0
690#define GMAC_EFTN_RUD_Msk (0x3fffffffu << GMAC_EFTN_RUD_Pos)
691/* -------- GMAC_EFRSL : (GMAC Offset: 0x1E8) PTP Event Frame Received Seconds Low Register -------- */
692#define GMAC_EFRSL_RUD_Pos 0
693#define GMAC_EFRSL_RUD_Msk (0xffffffffu << GMAC_EFRSL_RUD_Pos)
694/* -------- GMAC_EFRN : (GMAC Offset: 0x1EC) PTP Event Frame Received Nanoseconds Register -------- */
695#define GMAC_EFRN_RUD_Pos 0
696#define GMAC_EFRN_RUD_Msk (0x3fffffffu << GMAC_EFRN_RUD_Pos)
697/* -------- GMAC_PEFTSL : (GMAC Offset: 0x1F0) PTP Peer Event Frame Transmitted Seconds Low Register -------- */
698#define GMAC_PEFTSL_RUD_Pos 0
699#define GMAC_PEFTSL_RUD_Msk (0xffffffffu << GMAC_PEFTSL_RUD_Pos)
700/* -------- GMAC_PEFTN : (GMAC Offset: 0x1F4) PTP Peer Event Frame Transmitted Nanoseconds Register -------- */
701#define GMAC_PEFTN_RUD_Pos 0
702#define GMAC_PEFTN_RUD_Msk (0x3fffffffu << GMAC_PEFTN_RUD_Pos)
703/* -------- GMAC_PEFRSL : (GMAC Offset: 0x1F8) PTP Peer Event Frame Received Seconds Low Register -------- */
704#define GMAC_PEFRSL_RUD_Pos 0
705#define GMAC_PEFRSL_RUD_Msk (0xffffffffu << GMAC_PEFRSL_RUD_Pos)
706/* -------- GMAC_PEFRN : (GMAC Offset: 0x1FC) PTP Peer Event Frame Received Nanoseconds Register -------- */
707#define GMAC_PEFRN_RUD_Pos 0
708#define GMAC_PEFRN_RUD_Msk (0x3fffffffu << GMAC_PEFRN_RUD_Pos)
709/* -------- GMAC_ISRPQ[2] : (GMAC Offset: 0x400) Interrupt Status Register Priority Queue (index = 1) -------- */
710#define GMAC_ISRPQ_RCOMP (0x1u << 1)
711#define GMAC_ISRPQ_RXUBR (0x1u << 2)
712#define GMAC_ISRPQ_RLEX (0x1u << 5)
713#define GMAC_ISRPQ_TFC (0x1u << 6)
714#define GMAC_ISRPQ_TCOMP (0x1u << 7)
715#define GMAC_ISRPQ_ROVR (0x1u << 10)
716#define GMAC_ISRPQ_HRESP (0x1u << 11)
717/* -------- GMAC_TBQBAPQ[2] : (GMAC Offset: 0x440) Transmit Buffer Queue Base Address Register Priority Queue (index = 1) -------- */
718#define GMAC_TBQBAPQ_TXBQBA_Pos 2
719#define GMAC_TBQBAPQ_TXBQBA_Msk (0x3fffffffu << GMAC_TBQBAPQ_TXBQBA_Pos)
720#define GMAC_TBQBAPQ_TXBQBA(value) ((GMAC_TBQBAPQ_TXBQBA_Msk & ((value) << GMAC_TBQBAPQ_TXBQBA_Pos)))
721/* -------- GMAC_RBQBAPQ[2] : (GMAC Offset: 0x480) Receive Buffer Queue Base Address Register Priority Queue (index = 1) -------- */
722#define GMAC_RBQBAPQ_RXBQBA_Pos 2
723#define GMAC_RBQBAPQ_RXBQBA_Msk (0x3fffffffu << GMAC_RBQBAPQ_RXBQBA_Pos)
724#define GMAC_RBQBAPQ_RXBQBA(value) ((GMAC_RBQBAPQ_RXBQBA_Msk & ((value) << GMAC_RBQBAPQ_RXBQBA_Pos)))
725/* -------- GMAC_RBSRPQ[2] : (GMAC Offset: 0x4A0) Receive Buffer Size Register Priority Queue (index = 1) -------- */
726#define GMAC_RBSRPQ_RBS_Pos 0
727#define GMAC_RBSRPQ_RBS_Msk (0xffffu << GMAC_RBSRPQ_RBS_Pos)
728#define GMAC_RBSRPQ_RBS(value) ((GMAC_RBSRPQ_RBS_Msk & ((value) << GMAC_RBSRPQ_RBS_Pos)))
729/* -------- GMAC_CBSCR : (GMAC Offset: 0x4BC) Credit-Based Shaping Control Register -------- */
730#define GMAC_CBSCR_QBE (0x1u << 0)
731#define GMAC_CBSCR_QAE (0x1u << 1)
732/* -------- GMAC_CBSISQA : (GMAC Offset: 0x4C0) Credit-Based Shaping IdleSlope Register for Queue A -------- */
733#define GMAC_CBSISQA_IS_Pos 0
734#define GMAC_CBSISQA_IS_Msk (0xffffffffu << GMAC_CBSISQA_IS_Pos)
735#define GMAC_CBSISQA_IS(value) ((GMAC_CBSISQA_IS_Msk & ((value) << GMAC_CBSISQA_IS_Pos)))
736/* -------- GMAC_CBSISQB : (GMAC Offset: 0x4C4) Credit-Based Shaping IdleSlope Register for Queue B -------- */
737#define GMAC_CBSISQB_IS_Pos 0
738#define GMAC_CBSISQB_IS_Msk (0xffffffffu << GMAC_CBSISQB_IS_Pos)
739#define GMAC_CBSISQB_IS(value) ((GMAC_CBSISQB_IS_Msk & ((value) << GMAC_CBSISQB_IS_Pos)))
740/* -------- GMAC_ST1RPQ[4] : (GMAC Offset: 0x500) Screening Type 1 Register Priority Queue (index = 0) -------- */
741#define GMAC_ST1RPQ_QNB_Pos 0
742#define GMAC_ST1RPQ_QNB_Msk (0x7u << GMAC_ST1RPQ_QNB_Pos)
743#define GMAC_ST1RPQ_QNB(value) ((GMAC_ST1RPQ_QNB_Msk & ((value) << GMAC_ST1RPQ_QNB_Pos)))
744#define GMAC_ST1RPQ_DSTCM_Pos 4
745#define GMAC_ST1RPQ_DSTCM_Msk (0xffu << GMAC_ST1RPQ_DSTCM_Pos)
746#define GMAC_ST1RPQ_DSTCM(value) ((GMAC_ST1RPQ_DSTCM_Msk & ((value) << GMAC_ST1RPQ_DSTCM_Pos)))
747#define GMAC_ST1RPQ_UDPM_Pos 12
748#define GMAC_ST1RPQ_UDPM_Msk (0xffffu << GMAC_ST1RPQ_UDPM_Pos)
749#define GMAC_ST1RPQ_UDPM(value) ((GMAC_ST1RPQ_UDPM_Msk & ((value) << GMAC_ST1RPQ_UDPM_Pos)))
750#define GMAC_ST1RPQ_DSTCE (0x1u << 28)
751#define GMAC_ST1RPQ_UDPE (0x1u << 29)
752/* -------- GMAC_ST2RPQ[8] : (GMAC Offset: 0x540) Screening Type 2 Register Priority Queue (index = 0) -------- */
753#define GMAC_ST2RPQ_QNB_Pos 0
754#define GMAC_ST2RPQ_QNB_Msk (0x7u << GMAC_ST2RPQ_QNB_Pos)
755#define GMAC_ST2RPQ_QNB(value) ((GMAC_ST2RPQ_QNB_Msk & ((value) << GMAC_ST2RPQ_QNB_Pos)))
756#define GMAC_ST2RPQ_VLANP_Pos 4
757#define GMAC_ST2RPQ_VLANP_Msk (0x7u << GMAC_ST2RPQ_VLANP_Pos)
758#define GMAC_ST2RPQ_VLANP(value) ((GMAC_ST2RPQ_VLANP_Msk & ((value) << GMAC_ST2RPQ_VLANP_Pos)))
759#define GMAC_ST2RPQ_VLANE (0x1u << 8)
760#define GMAC_ST2RPQ_I2ETH_Pos 9
761#define GMAC_ST2RPQ_I2ETH_Msk (0x7u << GMAC_ST2RPQ_I2ETH_Pos)
762#define GMAC_ST2RPQ_I2ETH(value) ((GMAC_ST2RPQ_I2ETH_Msk & ((value) << GMAC_ST2RPQ_I2ETH_Pos)))
763#define GMAC_ST2RPQ_ETHE (0x1u << 12)
764#define GMAC_ST2RPQ_COMPA_Pos 13
765#define GMAC_ST2RPQ_COMPA_Msk (0x1fu << GMAC_ST2RPQ_COMPA_Pos)
766#define GMAC_ST2RPQ_COMPA(value) ((GMAC_ST2RPQ_COMPA_Msk & ((value) << GMAC_ST2RPQ_COMPA_Pos)))
767#define GMAC_ST2RPQ_COMPAE (0x1u << 18)
768#define GMAC_ST2RPQ_COMPB_Pos 19
769#define GMAC_ST2RPQ_COMPB_Msk (0x1fu << GMAC_ST2RPQ_COMPB_Pos)
770#define GMAC_ST2RPQ_COMPB(value) ((GMAC_ST2RPQ_COMPB_Msk & ((value) << GMAC_ST2RPQ_COMPB_Pos)))
771#define GMAC_ST2RPQ_COMPBE (0x1u << 24)
772#define GMAC_ST2RPQ_COMPC_Pos 25
773#define GMAC_ST2RPQ_COMPC_Msk (0x1fu << GMAC_ST2RPQ_COMPC_Pos)
774#define GMAC_ST2RPQ_COMPC(value) ((GMAC_ST2RPQ_COMPC_Msk & ((value) << GMAC_ST2RPQ_COMPC_Pos)))
775#define GMAC_ST2RPQ_COMPCE (0x1u << 30)
776/* -------- GMAC_IERPQ[2] : (GMAC Offset: 0x600) Interrupt Enable Register Priority Queue (index = 1) -------- */
777#define GMAC_IERPQ_RCOMP (0x1u << 1)
778#define GMAC_IERPQ_RXUBR (0x1u << 2)
779#define GMAC_IERPQ_RLEX (0x1u << 5)
780#define GMAC_IERPQ_TFC (0x1u << 6)
781#define GMAC_IERPQ_TCOMP (0x1u << 7)
782#define GMAC_IERPQ_ROVR (0x1u << 10)
783#define GMAC_IERPQ_HRESP (0x1u << 11)
784/* -------- GMAC_IDRPQ[2] : (GMAC Offset: 0x620) Interrupt Disable Register Priority Queue (index = 1) -------- */
785#define GMAC_IDRPQ_RCOMP (0x1u << 1)
786#define GMAC_IDRPQ_RXUBR (0x1u << 2)
787#define GMAC_IDRPQ_RLEX (0x1u << 5)
788#define GMAC_IDRPQ_TFC (0x1u << 6)
789#define GMAC_IDRPQ_TCOMP (0x1u << 7)
790#define GMAC_IDRPQ_ROVR (0x1u << 10)
791#define GMAC_IDRPQ_HRESP (0x1u << 11)
792/* -------- GMAC_IMRPQ[2] : (GMAC Offset: 0x640) Interrupt Mask Register Priority Queue (index = 1) -------- */
793#define GMAC_IMRPQ_RCOMP (0x1u << 1)
794#define GMAC_IMRPQ_RXUBR (0x1u << 2)
795#define GMAC_IMRPQ_RLEX (0x1u << 5)
796#define GMAC_IMRPQ_AHB (0x1u << 6)
797#define GMAC_IMRPQ_TCOMP (0x1u << 7)
798#define GMAC_IMRPQ_ROVR (0x1u << 10)
799#define GMAC_IMRPQ_HRESP (0x1u << 11)
800/* -------- GMAC_ST2ER[4] : (GMAC Offset: 0x6E0) Screening Type 2 Ethertype Register (index = 0) -------- */
801#define GMAC_ST2ER_COMPVAL_Pos 0
802#define GMAC_ST2ER_COMPVAL_Msk (0xffffu << GMAC_ST2ER_COMPVAL_Pos)
803#define GMAC_ST2ER_COMPVAL(value) ((GMAC_ST2ER_COMPVAL_Msk & ((value) << GMAC_ST2ER_COMPVAL_Pos)))
804/* -------- GMAC_ST2CW00 : (GMAC Offset: 0x700) Screening Type 2 Compare Word 0 Register (index = 0) -------- */
805#define GMAC_ST2CW00_MASKVAL_Pos 0
806#define GMAC_ST2CW00_MASKVAL_Msk (0xffffu << GMAC_ST2CW00_MASKVAL_Pos)
807#define GMAC_ST2CW00_MASKVAL(value) ((GMAC_ST2CW00_MASKVAL_Msk & ((value) << GMAC_ST2CW00_MASKVAL_Pos)))
808#define GMAC_ST2CW00_COMPVAL_Pos 16
809#define GMAC_ST2CW00_COMPVAL_Msk (0xffffu << GMAC_ST2CW00_COMPVAL_Pos)
810#define GMAC_ST2CW00_COMPVAL(value) ((GMAC_ST2CW00_COMPVAL_Msk & ((value) << GMAC_ST2CW00_COMPVAL_Pos)))
811/* -------- GMAC_ST2CW10 : (GMAC Offset: 0x704) Screening Type 2 Compare Word 1 Register (index = 0) -------- */
812#define GMAC_ST2CW10_OFFSVAL_Pos 0
813#define GMAC_ST2CW10_OFFSVAL_Msk (0x7fu << GMAC_ST2CW10_OFFSVAL_Pos)
814#define GMAC_ST2CW10_OFFSVAL(value) ((GMAC_ST2CW10_OFFSVAL_Msk & ((value) << GMAC_ST2CW10_OFFSVAL_Pos)))
815#define GMAC_ST2CW10_OFFSSTRT_Pos 7
816#define GMAC_ST2CW10_OFFSSTRT_Msk (0x3u << GMAC_ST2CW10_OFFSSTRT_Pos)
817#define GMAC_ST2CW10_OFFSSTRT(value) ((GMAC_ST2CW10_OFFSSTRT_Msk & ((value) << GMAC_ST2CW10_OFFSSTRT_Pos)))
818#define GMAC_ST2CW10_OFFSSTRT_FRAMESTART (0x0u << 7)
819#define GMAC_ST2CW10_OFFSSTRT_ETHERTYPE (0x1u << 7)
820#define GMAC_ST2CW10_OFFSSTRT_IP (0x2u << 7)
821#define GMAC_ST2CW10_OFFSSTRT_TCP_UDP (0x3u << 7)
822/* -------- GMAC_ST2CW01 : (GMAC Offset: 0x708) Screening Type 2 Compare Word 0 Register (index = 1) -------- */
823#define GMAC_ST2CW01_MASKVAL_Pos 0
824#define GMAC_ST2CW01_MASKVAL_Msk (0xffffu << GMAC_ST2CW01_MASKVAL_Pos)
825#define GMAC_ST2CW01_MASKVAL(value) ((GMAC_ST2CW01_MASKVAL_Msk & ((value) << GMAC_ST2CW01_MASKVAL_Pos)))
826#define GMAC_ST2CW01_COMPVAL_Pos 16
827#define GMAC_ST2CW01_COMPVAL_Msk (0xffffu << GMAC_ST2CW01_COMPVAL_Pos)
828#define GMAC_ST2CW01_COMPVAL(value) ((GMAC_ST2CW01_COMPVAL_Msk & ((value) << GMAC_ST2CW01_COMPVAL_Pos)))
829/* -------- GMAC_ST2CW11 : (GMAC Offset: 0x70C) Screening Type 2 Compare Word 1 Register (index = 1) -------- */
830#define GMAC_ST2CW11_OFFSVAL_Pos 0
831#define GMAC_ST2CW11_OFFSVAL_Msk (0x7fu << GMAC_ST2CW11_OFFSVAL_Pos)
832#define GMAC_ST2CW11_OFFSVAL(value) ((GMAC_ST2CW11_OFFSVAL_Msk & ((value) << GMAC_ST2CW11_OFFSVAL_Pos)))
833#define GMAC_ST2CW11_OFFSSTRT_Pos 7
834#define GMAC_ST2CW11_OFFSSTRT_Msk (0x3u << GMAC_ST2CW11_OFFSSTRT_Pos)
835#define GMAC_ST2CW11_OFFSSTRT(value) ((GMAC_ST2CW11_OFFSSTRT_Msk & ((value) << GMAC_ST2CW11_OFFSSTRT_Pos)))
836#define GMAC_ST2CW11_OFFSSTRT_FRAMESTART (0x0u << 7)
837#define GMAC_ST2CW11_OFFSSTRT_ETHERTYPE (0x1u << 7)
838#define GMAC_ST2CW11_OFFSSTRT_IP (0x2u << 7)
839#define GMAC_ST2CW11_OFFSSTRT_TCP_UDP (0x3u << 7)
840/* -------- GMAC_ST2CW02 : (GMAC Offset: 0x710) Screening Type 2 Compare Word 0 Register (index = 2) -------- */
841#define GMAC_ST2CW02_MASKVAL_Pos 0
842#define GMAC_ST2CW02_MASKVAL_Msk (0xffffu << GMAC_ST2CW02_MASKVAL_Pos)
843#define GMAC_ST2CW02_MASKVAL(value) ((GMAC_ST2CW02_MASKVAL_Msk & ((value) << GMAC_ST2CW02_MASKVAL_Pos)))
844#define GMAC_ST2CW02_COMPVAL_Pos 16
845#define GMAC_ST2CW02_COMPVAL_Msk (0xffffu << GMAC_ST2CW02_COMPVAL_Pos)
846#define GMAC_ST2CW02_COMPVAL(value) ((GMAC_ST2CW02_COMPVAL_Msk & ((value) << GMAC_ST2CW02_COMPVAL_Pos)))
847/* -------- GMAC_ST2CW12 : (GMAC Offset: 0x714) Screening Type 2 Compare Word 1 Register (index = 2) -------- */
848#define GMAC_ST2CW12_OFFSVAL_Pos 0
849#define GMAC_ST2CW12_OFFSVAL_Msk (0x7fu << GMAC_ST2CW12_OFFSVAL_Pos)
850#define GMAC_ST2CW12_OFFSVAL(value) ((GMAC_ST2CW12_OFFSVAL_Msk & ((value) << GMAC_ST2CW12_OFFSVAL_Pos)))
851#define GMAC_ST2CW12_OFFSSTRT_Pos 7
852#define GMAC_ST2CW12_OFFSSTRT_Msk (0x3u << GMAC_ST2CW12_OFFSSTRT_Pos)
853#define GMAC_ST2CW12_OFFSSTRT(value) ((GMAC_ST2CW12_OFFSSTRT_Msk & ((value) << GMAC_ST2CW12_OFFSSTRT_Pos)))
854#define GMAC_ST2CW12_OFFSSTRT_FRAMESTART (0x0u << 7)
855#define GMAC_ST2CW12_OFFSSTRT_ETHERTYPE (0x1u << 7)
856#define GMAC_ST2CW12_OFFSSTRT_IP (0x2u << 7)
857#define GMAC_ST2CW12_OFFSSTRT_TCP_UDP (0x3u << 7)
858/* -------- GMAC_ST2CW03 : (GMAC Offset: 0x718) Screening Type 2 Compare Word 0 Register (index = 3) -------- */
859#define GMAC_ST2CW03_MASKVAL_Pos 0
860#define GMAC_ST2CW03_MASKVAL_Msk (0xffffu << GMAC_ST2CW03_MASKVAL_Pos)
861#define GMAC_ST2CW03_MASKVAL(value) ((GMAC_ST2CW03_MASKVAL_Msk & ((value) << GMAC_ST2CW03_MASKVAL_Pos)))
862#define GMAC_ST2CW03_COMPVAL_Pos 16
863#define GMAC_ST2CW03_COMPVAL_Msk (0xffffu << GMAC_ST2CW03_COMPVAL_Pos)
864#define GMAC_ST2CW03_COMPVAL(value) ((GMAC_ST2CW03_COMPVAL_Msk & ((value) << GMAC_ST2CW03_COMPVAL_Pos)))
865/* -------- GMAC_ST2CW13 : (GMAC Offset: 0x71C) Screening Type 2 Compare Word 1 Register (index = 3) -------- */
866#define GMAC_ST2CW13_OFFSVAL_Pos 0
867#define GMAC_ST2CW13_OFFSVAL_Msk (0x7fu << GMAC_ST2CW13_OFFSVAL_Pos)
868#define GMAC_ST2CW13_OFFSVAL(value) ((GMAC_ST2CW13_OFFSVAL_Msk & ((value) << GMAC_ST2CW13_OFFSVAL_Pos)))
869#define GMAC_ST2CW13_OFFSSTRT_Pos 7
870#define GMAC_ST2CW13_OFFSSTRT_Msk (0x3u << GMAC_ST2CW13_OFFSSTRT_Pos)
871#define GMAC_ST2CW13_OFFSSTRT(value) ((GMAC_ST2CW13_OFFSSTRT_Msk & ((value) << GMAC_ST2CW13_OFFSSTRT_Pos)))
872#define GMAC_ST2CW13_OFFSSTRT_FRAMESTART (0x0u << 7)
873#define GMAC_ST2CW13_OFFSSTRT_ETHERTYPE (0x1u << 7)
874#define GMAC_ST2CW13_OFFSSTRT_IP (0x2u << 7)
875#define GMAC_ST2CW13_OFFSSTRT_TCP_UDP (0x3u << 7)
876/* -------- GMAC_ST2CW04 : (GMAC Offset: 0x720) Screening Type 2 Compare Word 0 Register (index = 4) -------- */
877#define GMAC_ST2CW04_MASKVAL_Pos 0
878#define GMAC_ST2CW04_MASKVAL_Msk (0xffffu << GMAC_ST2CW04_MASKVAL_Pos)
879#define GMAC_ST2CW04_MASKVAL(value) ((GMAC_ST2CW04_MASKVAL_Msk & ((value) << GMAC_ST2CW04_MASKVAL_Pos)))
880#define GMAC_ST2CW04_COMPVAL_Pos 16
881#define GMAC_ST2CW04_COMPVAL_Msk (0xffffu << GMAC_ST2CW04_COMPVAL_Pos)
882#define GMAC_ST2CW04_COMPVAL(value) ((GMAC_ST2CW04_COMPVAL_Msk & ((value) << GMAC_ST2CW04_COMPVAL_Pos)))
883/* -------- GMAC_ST2CW14 : (GMAC Offset: 0x724) Screening Type 2 Compare Word 1 Register (index = 4) -------- */
884#define GMAC_ST2CW14_OFFSVAL_Pos 0
885#define GMAC_ST2CW14_OFFSVAL_Msk (0x7fu << GMAC_ST2CW14_OFFSVAL_Pos)
886#define GMAC_ST2CW14_OFFSVAL(value) ((GMAC_ST2CW14_OFFSVAL_Msk & ((value) << GMAC_ST2CW14_OFFSVAL_Pos)))
887#define GMAC_ST2CW14_OFFSSTRT_Pos 7
888#define GMAC_ST2CW14_OFFSSTRT_Msk (0x3u << GMAC_ST2CW14_OFFSSTRT_Pos)
889#define GMAC_ST2CW14_OFFSSTRT(value) ((GMAC_ST2CW14_OFFSSTRT_Msk & ((value) << GMAC_ST2CW14_OFFSSTRT_Pos)))
890#define GMAC_ST2CW14_OFFSSTRT_FRAMESTART (0x0u << 7)
891#define GMAC_ST2CW14_OFFSSTRT_ETHERTYPE (0x1u << 7)
892#define GMAC_ST2CW14_OFFSSTRT_IP (0x2u << 7)
893#define GMAC_ST2CW14_OFFSSTRT_TCP_UDP (0x3u << 7)
894/* -------- GMAC_ST2CW05 : (GMAC Offset: 0x728) Screening Type 2 Compare Word 0 Register (index = 5) -------- */
895#define GMAC_ST2CW05_MASKVAL_Pos 0
896#define GMAC_ST2CW05_MASKVAL_Msk (0xffffu << GMAC_ST2CW05_MASKVAL_Pos)
897#define GMAC_ST2CW05_MASKVAL(value) ((GMAC_ST2CW05_MASKVAL_Msk & ((value) << GMAC_ST2CW05_MASKVAL_Pos)))
898#define GMAC_ST2CW05_COMPVAL_Pos 16
899#define GMAC_ST2CW05_COMPVAL_Msk (0xffffu << GMAC_ST2CW05_COMPVAL_Pos)
900#define GMAC_ST2CW05_COMPVAL(value) ((GMAC_ST2CW05_COMPVAL_Msk & ((value) << GMAC_ST2CW05_COMPVAL_Pos)))
901/* -------- GMAC_ST2CW15 : (GMAC Offset: 0x72C) Screening Type 2 Compare Word 1 Register (index = 5) -------- */
902#define GMAC_ST2CW15_OFFSVAL_Pos 0
903#define GMAC_ST2CW15_OFFSVAL_Msk (0x7fu << GMAC_ST2CW15_OFFSVAL_Pos)
904#define GMAC_ST2CW15_OFFSVAL(value) ((GMAC_ST2CW15_OFFSVAL_Msk & ((value) << GMAC_ST2CW15_OFFSVAL_Pos)))
905#define GMAC_ST2CW15_OFFSSTRT_Pos 7
906#define GMAC_ST2CW15_OFFSSTRT_Msk (0x3u << GMAC_ST2CW15_OFFSSTRT_Pos)
907#define GMAC_ST2CW15_OFFSSTRT(value) ((GMAC_ST2CW15_OFFSSTRT_Msk & ((value) << GMAC_ST2CW15_OFFSSTRT_Pos)))
908#define GMAC_ST2CW15_OFFSSTRT_FRAMESTART (0x0u << 7)
909#define GMAC_ST2CW15_OFFSSTRT_ETHERTYPE (0x1u << 7)
910#define GMAC_ST2CW15_OFFSSTRT_IP (0x2u << 7)
911#define GMAC_ST2CW15_OFFSSTRT_TCP_UDP (0x3u << 7)
912/* -------- GMAC_ST2CW06 : (GMAC Offset: 0x730) Screening Type 2 Compare Word 0 Register (index = 6) -------- */
913#define GMAC_ST2CW06_MASKVAL_Pos 0
914#define GMAC_ST2CW06_MASKVAL_Msk (0xffffu << GMAC_ST2CW06_MASKVAL_Pos)
915#define GMAC_ST2CW06_MASKVAL(value) ((GMAC_ST2CW06_MASKVAL_Msk & ((value) << GMAC_ST2CW06_MASKVAL_Pos)))
916#define GMAC_ST2CW06_COMPVAL_Pos 16
917#define GMAC_ST2CW06_COMPVAL_Msk (0xffffu << GMAC_ST2CW06_COMPVAL_Pos)
918#define GMAC_ST2CW06_COMPVAL(value) ((GMAC_ST2CW06_COMPVAL_Msk & ((value) << GMAC_ST2CW06_COMPVAL_Pos)))
919/* -------- GMAC_ST2CW16 : (GMAC Offset: 0x734) Screening Type 2 Compare Word 1 Register (index = 6) -------- */
920#define GMAC_ST2CW16_OFFSVAL_Pos 0
921#define GMAC_ST2CW16_OFFSVAL_Msk (0x7fu << GMAC_ST2CW16_OFFSVAL_Pos)
922#define GMAC_ST2CW16_OFFSVAL(value) ((GMAC_ST2CW16_OFFSVAL_Msk & ((value) << GMAC_ST2CW16_OFFSVAL_Pos)))
923#define GMAC_ST2CW16_OFFSSTRT_Pos 7
924#define GMAC_ST2CW16_OFFSSTRT_Msk (0x3u << GMAC_ST2CW16_OFFSSTRT_Pos)
925#define GMAC_ST2CW16_OFFSSTRT(value) ((GMAC_ST2CW16_OFFSSTRT_Msk & ((value) << GMAC_ST2CW16_OFFSSTRT_Pos)))
926#define GMAC_ST2CW16_OFFSSTRT_FRAMESTART (0x0u << 7)
927#define GMAC_ST2CW16_OFFSSTRT_ETHERTYPE (0x1u << 7)
928#define GMAC_ST2CW16_OFFSSTRT_IP (0x2u << 7)
929#define GMAC_ST2CW16_OFFSSTRT_TCP_UDP (0x3u << 7)
930/* -------- GMAC_ST2CW07 : (GMAC Offset: 0x738) Screening Type 2 Compare Word 0 Register (index = 7) -------- */
931#define GMAC_ST2CW07_MASKVAL_Pos 0
932#define GMAC_ST2CW07_MASKVAL_Msk (0xffffu << GMAC_ST2CW07_MASKVAL_Pos)
933#define GMAC_ST2CW07_MASKVAL(value) ((GMAC_ST2CW07_MASKVAL_Msk & ((value) << GMAC_ST2CW07_MASKVAL_Pos)))
934#define GMAC_ST2CW07_COMPVAL_Pos 16
935#define GMAC_ST2CW07_COMPVAL_Msk (0xffffu << GMAC_ST2CW07_COMPVAL_Pos)
936#define GMAC_ST2CW07_COMPVAL(value) ((GMAC_ST2CW07_COMPVAL_Msk & ((value) << GMAC_ST2CW07_COMPVAL_Pos)))
937/* -------- GMAC_ST2CW17 : (GMAC Offset: 0x73C) Screening Type 2 Compare Word 1 Register (index = 7) -------- */
938#define GMAC_ST2CW17_OFFSVAL_Pos 0
939#define GMAC_ST2CW17_OFFSVAL_Msk (0x7fu << GMAC_ST2CW17_OFFSVAL_Pos)
940#define GMAC_ST2CW17_OFFSVAL(value) ((GMAC_ST2CW17_OFFSVAL_Msk & ((value) << GMAC_ST2CW17_OFFSVAL_Pos)))
941#define GMAC_ST2CW17_OFFSSTRT_Pos 7
942#define GMAC_ST2CW17_OFFSSTRT_Msk (0x3u << GMAC_ST2CW17_OFFSSTRT_Pos)
943#define GMAC_ST2CW17_OFFSSTRT(value) ((GMAC_ST2CW17_OFFSSTRT_Msk & ((value) << GMAC_ST2CW17_OFFSSTRT_Pos)))
944#define GMAC_ST2CW17_OFFSSTRT_FRAMESTART (0x0u << 7)
945#define GMAC_ST2CW17_OFFSSTRT_ETHERTYPE (0x1u << 7)
946#define GMAC_ST2CW17_OFFSSTRT_IP (0x2u << 7)
947#define GMAC_ST2CW17_OFFSSTRT_TCP_UDP (0x3u << 7)
948/* -------- GMAC_ST2CW08 : (GMAC Offset: 0x740) Screening Type 2 Compare Word 0 Register (index = 8) -------- */
949#define GMAC_ST2CW08_MASKVAL_Pos 0
950#define GMAC_ST2CW08_MASKVAL_Msk (0xffffu << GMAC_ST2CW08_MASKVAL_Pos)
951#define GMAC_ST2CW08_MASKVAL(value) ((GMAC_ST2CW08_MASKVAL_Msk & ((value) << GMAC_ST2CW08_MASKVAL_Pos)))
952#define GMAC_ST2CW08_COMPVAL_Pos 16
953#define GMAC_ST2CW08_COMPVAL_Msk (0xffffu << GMAC_ST2CW08_COMPVAL_Pos)
954#define GMAC_ST2CW08_COMPVAL(value) ((GMAC_ST2CW08_COMPVAL_Msk & ((value) << GMAC_ST2CW08_COMPVAL_Pos)))
955/* -------- GMAC_ST2CW18 : (GMAC Offset: 0x744) Screening Type 2 Compare Word 1 Register (index = 8) -------- */
956#define GMAC_ST2CW18_OFFSVAL_Pos 0
957#define GMAC_ST2CW18_OFFSVAL_Msk (0x7fu << GMAC_ST2CW18_OFFSVAL_Pos)
958#define GMAC_ST2CW18_OFFSVAL(value) ((GMAC_ST2CW18_OFFSVAL_Msk & ((value) << GMAC_ST2CW18_OFFSVAL_Pos)))
959#define GMAC_ST2CW18_OFFSSTRT_Pos 7
960#define GMAC_ST2CW18_OFFSSTRT_Msk (0x3u << GMAC_ST2CW18_OFFSSTRT_Pos)
961#define GMAC_ST2CW18_OFFSSTRT(value) ((GMAC_ST2CW18_OFFSSTRT_Msk & ((value) << GMAC_ST2CW18_OFFSSTRT_Pos)))
962#define GMAC_ST2CW18_OFFSSTRT_FRAMESTART (0x0u << 7)
963#define GMAC_ST2CW18_OFFSSTRT_ETHERTYPE (0x1u << 7)
964#define GMAC_ST2CW18_OFFSSTRT_IP (0x2u << 7)
965#define GMAC_ST2CW18_OFFSSTRT_TCP_UDP (0x3u << 7)
966/* -------- GMAC_ST2CW09 : (GMAC Offset: 0x748) Screening Type 2 Compare Word 0 Register (index = 9) -------- */
967#define GMAC_ST2CW09_MASKVAL_Pos 0
968#define GMAC_ST2CW09_MASKVAL_Msk (0xffffu << GMAC_ST2CW09_MASKVAL_Pos)
969#define GMAC_ST2CW09_MASKVAL(value) ((GMAC_ST2CW09_MASKVAL_Msk & ((value) << GMAC_ST2CW09_MASKVAL_Pos)))
970#define GMAC_ST2CW09_COMPVAL_Pos 16
971#define GMAC_ST2CW09_COMPVAL_Msk (0xffffu << GMAC_ST2CW09_COMPVAL_Pos)
972#define GMAC_ST2CW09_COMPVAL(value) ((GMAC_ST2CW09_COMPVAL_Msk & ((value) << GMAC_ST2CW09_COMPVAL_Pos)))
973/* -------- GMAC_ST2CW19 : (GMAC Offset: 0x74C) Screening Type 2 Compare Word 1 Register (index = 9) -------- */
974#define GMAC_ST2CW19_OFFSVAL_Pos 0
975#define GMAC_ST2CW19_OFFSVAL_Msk (0x7fu << GMAC_ST2CW19_OFFSVAL_Pos)
976#define GMAC_ST2CW19_OFFSVAL(value) ((GMAC_ST2CW19_OFFSVAL_Msk & ((value) << GMAC_ST2CW19_OFFSVAL_Pos)))
977#define GMAC_ST2CW19_OFFSSTRT_Pos 7
978#define GMAC_ST2CW19_OFFSSTRT_Msk (0x3u << GMAC_ST2CW19_OFFSSTRT_Pos)
979#define GMAC_ST2CW19_OFFSSTRT(value) ((GMAC_ST2CW19_OFFSSTRT_Msk & ((value) << GMAC_ST2CW19_OFFSSTRT_Pos)))
980#define GMAC_ST2CW19_OFFSSTRT_FRAMESTART (0x0u << 7)
981#define GMAC_ST2CW19_OFFSSTRT_ETHERTYPE (0x1u << 7)
982#define GMAC_ST2CW19_OFFSSTRT_IP (0x2u << 7)
983#define GMAC_ST2CW19_OFFSSTRT_TCP_UDP (0x3u << 7)
984/* -------- GMAC_ST2CW010 : (GMAC Offset: 0x750) Screening Type 2 Compare Word 0 Register (index = 10) -------- */
985#define GMAC_ST2CW010_MASKVAL_Pos 0
986#define GMAC_ST2CW010_MASKVAL_Msk (0xffffu << GMAC_ST2CW010_MASKVAL_Pos)
987#define GMAC_ST2CW010_MASKVAL(value) ((GMAC_ST2CW010_MASKVAL_Msk & ((value) << GMAC_ST2CW010_MASKVAL_Pos)))
988#define GMAC_ST2CW010_COMPVAL_Pos 16
989#define GMAC_ST2CW010_COMPVAL_Msk (0xffffu << GMAC_ST2CW010_COMPVAL_Pos)
990#define GMAC_ST2CW010_COMPVAL(value) ((GMAC_ST2CW010_COMPVAL_Msk & ((value) << GMAC_ST2CW010_COMPVAL_Pos)))
991/* -------- GMAC_ST2CW110 : (GMAC Offset: 0x754) Screening Type 2 Compare Word 1 Register (index = 10) -------- */
992#define GMAC_ST2CW110_OFFSVAL_Pos 0
993#define GMAC_ST2CW110_OFFSVAL_Msk (0x7fu << GMAC_ST2CW110_OFFSVAL_Pos)
994#define GMAC_ST2CW110_OFFSVAL(value) ((GMAC_ST2CW110_OFFSVAL_Msk & ((value) << GMAC_ST2CW110_OFFSVAL_Pos)))
995#define GMAC_ST2CW110_OFFSSTRT_Pos 7
996#define GMAC_ST2CW110_OFFSSTRT_Msk (0x3u << GMAC_ST2CW110_OFFSSTRT_Pos)
997#define GMAC_ST2CW110_OFFSSTRT(value) ((GMAC_ST2CW110_OFFSSTRT_Msk & ((value) << GMAC_ST2CW110_OFFSSTRT_Pos)))
998#define GMAC_ST2CW110_OFFSSTRT_FRAMESTART (0x0u << 7)
999#define GMAC_ST2CW110_OFFSSTRT_ETHERTYPE (0x1u << 7)
1000#define GMAC_ST2CW110_OFFSSTRT_IP (0x2u << 7)
1001#define GMAC_ST2CW110_OFFSSTRT_TCP_UDP (0x3u << 7)
1002/* -------- GMAC_ST2CW011 : (GMAC Offset: 0x758) Screening Type 2 Compare Word 0 Register (index = 11) -------- */
1003#define GMAC_ST2CW011_MASKVAL_Pos 0
1004#define GMAC_ST2CW011_MASKVAL_Msk (0xffffu << GMAC_ST2CW011_MASKVAL_Pos)
1005#define GMAC_ST2CW011_MASKVAL(value) ((GMAC_ST2CW011_MASKVAL_Msk & ((value) << GMAC_ST2CW011_MASKVAL_Pos)))
1006#define GMAC_ST2CW011_COMPVAL_Pos 16
1007#define GMAC_ST2CW011_COMPVAL_Msk (0xffffu << GMAC_ST2CW011_COMPVAL_Pos)
1008#define GMAC_ST2CW011_COMPVAL(value) ((GMAC_ST2CW011_COMPVAL_Msk & ((value) << GMAC_ST2CW011_COMPVAL_Pos)))
1009/* -------- GMAC_ST2CW111 : (GMAC Offset: 0x75C) Screening Type 2 Compare Word 1 Register (index = 11) -------- */
1010#define GMAC_ST2CW111_OFFSVAL_Pos 0
1011#define GMAC_ST2CW111_OFFSVAL_Msk (0x7fu << GMAC_ST2CW111_OFFSVAL_Pos)
1012#define GMAC_ST2CW111_OFFSVAL(value) ((GMAC_ST2CW111_OFFSVAL_Msk & ((value) << GMAC_ST2CW111_OFFSVAL_Pos)))
1013#define GMAC_ST2CW111_OFFSSTRT_Pos 7
1014#define GMAC_ST2CW111_OFFSSTRT_Msk (0x3u << GMAC_ST2CW111_OFFSSTRT_Pos)
1015#define GMAC_ST2CW111_OFFSSTRT(value) ((GMAC_ST2CW111_OFFSSTRT_Msk & ((value) << GMAC_ST2CW111_OFFSSTRT_Pos)))
1016#define GMAC_ST2CW111_OFFSSTRT_FRAMESTART (0x0u << 7)
1017#define GMAC_ST2CW111_OFFSSTRT_ETHERTYPE (0x1u << 7)
1018#define GMAC_ST2CW111_OFFSSTRT_IP (0x2u << 7)
1019#define GMAC_ST2CW111_OFFSSTRT_TCP_UDP (0x3u << 7)
1020/* -------- GMAC_ST2CW012 : (GMAC Offset: 0x760) Screening Type 2 Compare Word 0 Register (index = 12) -------- */
1021#define GMAC_ST2CW012_MASKVAL_Pos 0
1022#define GMAC_ST2CW012_MASKVAL_Msk (0xffffu << GMAC_ST2CW012_MASKVAL_Pos)
1023#define GMAC_ST2CW012_MASKVAL(value) ((GMAC_ST2CW012_MASKVAL_Msk & ((value) << GMAC_ST2CW012_MASKVAL_Pos)))
1024#define GMAC_ST2CW012_COMPVAL_Pos 16
1025#define GMAC_ST2CW012_COMPVAL_Msk (0xffffu << GMAC_ST2CW012_COMPVAL_Pos)
1026#define GMAC_ST2CW012_COMPVAL(value) ((GMAC_ST2CW012_COMPVAL_Msk & ((value) << GMAC_ST2CW012_COMPVAL_Pos)))
1027/* -------- GMAC_ST2CW112 : (GMAC Offset: 0x764) Screening Type 2 Compare Word 1 Register (index = 12) -------- */
1028#define GMAC_ST2CW112_OFFSVAL_Pos 0
1029#define GMAC_ST2CW112_OFFSVAL_Msk (0x7fu << GMAC_ST2CW112_OFFSVAL_Pos)
1030#define GMAC_ST2CW112_OFFSVAL(value) ((GMAC_ST2CW112_OFFSVAL_Msk & ((value) << GMAC_ST2CW112_OFFSVAL_Pos)))
1031#define GMAC_ST2CW112_OFFSSTRT_Pos 7
1032#define GMAC_ST2CW112_OFFSSTRT_Msk (0x3u << GMAC_ST2CW112_OFFSSTRT_Pos)
1033#define GMAC_ST2CW112_OFFSSTRT(value) ((GMAC_ST2CW112_OFFSSTRT_Msk & ((value) << GMAC_ST2CW112_OFFSSTRT_Pos)))
1034#define GMAC_ST2CW112_OFFSSTRT_FRAMESTART (0x0u << 7)
1035#define GMAC_ST2CW112_OFFSSTRT_ETHERTYPE (0x1u << 7)
1036#define GMAC_ST2CW112_OFFSSTRT_IP (0x2u << 7)
1037#define GMAC_ST2CW112_OFFSSTRT_TCP_UDP (0x3u << 7)
1038/* -------- GMAC_ST2CW013 : (GMAC Offset: 0x768) Screening Type 2 Compare Word 0 Register (index = 13) -------- */
1039#define GMAC_ST2CW013_MASKVAL_Pos 0
1040#define GMAC_ST2CW013_MASKVAL_Msk (0xffffu << GMAC_ST2CW013_MASKVAL_Pos)
1041#define GMAC_ST2CW013_MASKVAL(value) ((GMAC_ST2CW013_MASKVAL_Msk & ((value) << GMAC_ST2CW013_MASKVAL_Pos)))
1042#define GMAC_ST2CW013_COMPVAL_Pos 16
1043#define GMAC_ST2CW013_COMPVAL_Msk (0xffffu << GMAC_ST2CW013_COMPVAL_Pos)
1044#define GMAC_ST2CW013_COMPVAL(value) ((GMAC_ST2CW013_COMPVAL_Msk & ((value) << GMAC_ST2CW013_COMPVAL_Pos)))
1045/* -------- GMAC_ST2CW113 : (GMAC Offset: 0x76C) Screening Type 2 Compare Word 1 Register (index = 13) -------- */
1046#define GMAC_ST2CW113_OFFSVAL_Pos 0
1047#define GMAC_ST2CW113_OFFSVAL_Msk (0x7fu << GMAC_ST2CW113_OFFSVAL_Pos)
1048#define GMAC_ST2CW113_OFFSVAL(value) ((GMAC_ST2CW113_OFFSVAL_Msk & ((value) << GMAC_ST2CW113_OFFSVAL_Pos)))
1049#define GMAC_ST2CW113_OFFSSTRT_Pos 7
1050#define GMAC_ST2CW113_OFFSSTRT_Msk (0x3u << GMAC_ST2CW113_OFFSSTRT_Pos)
1051#define GMAC_ST2CW113_OFFSSTRT(value) ((GMAC_ST2CW113_OFFSSTRT_Msk & ((value) << GMAC_ST2CW113_OFFSSTRT_Pos)))
1052#define GMAC_ST2CW113_OFFSSTRT_FRAMESTART (0x0u << 7)
1053#define GMAC_ST2CW113_OFFSSTRT_ETHERTYPE (0x1u << 7)
1054#define GMAC_ST2CW113_OFFSSTRT_IP (0x2u << 7)
1055#define GMAC_ST2CW113_OFFSSTRT_TCP_UDP (0x3u << 7)
1056/* -------- GMAC_ST2CW014 : (GMAC Offset: 0x770) Screening Type 2 Compare Word 0 Register (index = 14) -------- */
1057#define GMAC_ST2CW014_MASKVAL_Pos 0
1058#define GMAC_ST2CW014_MASKVAL_Msk (0xffffu << GMAC_ST2CW014_MASKVAL_Pos)
1059#define GMAC_ST2CW014_MASKVAL(value) ((GMAC_ST2CW014_MASKVAL_Msk & ((value) << GMAC_ST2CW014_MASKVAL_Pos)))
1060#define GMAC_ST2CW014_COMPVAL_Pos 16
1061#define GMAC_ST2CW014_COMPVAL_Msk (0xffffu << GMAC_ST2CW014_COMPVAL_Pos)
1062#define GMAC_ST2CW014_COMPVAL(value) ((GMAC_ST2CW014_COMPVAL_Msk & ((value) << GMAC_ST2CW014_COMPVAL_Pos)))
1063/* -------- GMAC_ST2CW114 : (GMAC Offset: 0x774) Screening Type 2 Compare Word 1 Register (index = 14) -------- */
1064#define GMAC_ST2CW114_OFFSVAL_Pos 0
1065#define GMAC_ST2CW114_OFFSVAL_Msk (0x7fu << GMAC_ST2CW114_OFFSVAL_Pos)
1066#define GMAC_ST2CW114_OFFSVAL(value) ((GMAC_ST2CW114_OFFSVAL_Msk & ((value) << GMAC_ST2CW114_OFFSVAL_Pos)))
1067#define GMAC_ST2CW114_OFFSSTRT_Pos 7
1068#define GMAC_ST2CW114_OFFSSTRT_Msk (0x3u << GMAC_ST2CW114_OFFSSTRT_Pos)
1069#define GMAC_ST2CW114_OFFSSTRT(value) ((GMAC_ST2CW114_OFFSSTRT_Msk & ((value) << GMAC_ST2CW114_OFFSSTRT_Pos)))
1070#define GMAC_ST2CW114_OFFSSTRT_FRAMESTART (0x0u << 7)
1071#define GMAC_ST2CW114_OFFSSTRT_ETHERTYPE (0x1u << 7)
1072#define GMAC_ST2CW114_OFFSSTRT_IP (0x2u << 7)
1073#define GMAC_ST2CW114_OFFSSTRT_TCP_UDP (0x3u << 7)
1074/* -------- GMAC_ST2CW015 : (GMAC Offset: 0x778) Screening Type 2 Compare Word 0 Register (index = 15) -------- */
1075#define GMAC_ST2CW015_MASKVAL_Pos 0
1076#define GMAC_ST2CW015_MASKVAL_Msk (0xffffu << GMAC_ST2CW015_MASKVAL_Pos)
1077#define GMAC_ST2CW015_MASKVAL(value) ((GMAC_ST2CW015_MASKVAL_Msk & ((value) << GMAC_ST2CW015_MASKVAL_Pos)))
1078#define GMAC_ST2CW015_COMPVAL_Pos 16
1079#define GMAC_ST2CW015_COMPVAL_Msk (0xffffu << GMAC_ST2CW015_COMPVAL_Pos)
1080#define GMAC_ST2CW015_COMPVAL(value) ((GMAC_ST2CW015_COMPVAL_Msk & ((value) << GMAC_ST2CW015_COMPVAL_Pos)))
1081/* -------- GMAC_ST2CW115 : (GMAC Offset: 0x77C) Screening Type 2 Compare Word 1 Register (index = 15) -------- */
1082#define GMAC_ST2CW115_OFFSVAL_Pos 0
1083#define GMAC_ST2CW115_OFFSVAL_Msk (0x7fu << GMAC_ST2CW115_OFFSVAL_Pos)
1084#define GMAC_ST2CW115_OFFSVAL(value) ((GMAC_ST2CW115_OFFSVAL_Msk & ((value) << GMAC_ST2CW115_OFFSVAL_Pos)))
1085#define GMAC_ST2CW115_OFFSSTRT_Pos 7
1086#define GMAC_ST2CW115_OFFSSTRT_Msk (0x3u << GMAC_ST2CW115_OFFSSTRT_Pos)
1087#define GMAC_ST2CW115_OFFSSTRT(value) ((GMAC_ST2CW115_OFFSSTRT_Msk & ((value) << GMAC_ST2CW115_OFFSSTRT_Pos)))
1088#define GMAC_ST2CW115_OFFSSTRT_FRAMESTART (0x0u << 7)
1089#define GMAC_ST2CW115_OFFSSTRT_ETHERTYPE (0x1u << 7)
1090#define GMAC_ST2CW115_OFFSSTRT_IP (0x2u << 7)
1091#define GMAC_ST2CW115_OFFSSTRT_TCP_UDP (0x3u << 7)
1092/* -------- GMAC_ST2CW016 : (GMAC Offset: 0x780) Screening Type 2 Compare Word 0 Register (index = 16) -------- */
1093#define GMAC_ST2CW016_MASKVAL_Pos 0
1094#define GMAC_ST2CW016_MASKVAL_Msk (0xffffu << GMAC_ST2CW016_MASKVAL_Pos)
1095#define GMAC_ST2CW016_MASKVAL(value) ((GMAC_ST2CW016_MASKVAL_Msk & ((value) << GMAC_ST2CW016_MASKVAL_Pos)))
1096#define GMAC_ST2CW016_COMPVAL_Pos 16
1097#define GMAC_ST2CW016_COMPVAL_Msk (0xffffu << GMAC_ST2CW016_COMPVAL_Pos)
1098#define GMAC_ST2CW016_COMPVAL(value) ((GMAC_ST2CW016_COMPVAL_Msk & ((value) << GMAC_ST2CW016_COMPVAL_Pos)))
1099/* -------- GMAC_ST2CW116 : (GMAC Offset: 0x784) Screening Type 2 Compare Word 1 Register (index = 16) -------- */
1100#define GMAC_ST2CW116_OFFSVAL_Pos 0
1101#define GMAC_ST2CW116_OFFSVAL_Msk (0x7fu << GMAC_ST2CW116_OFFSVAL_Pos)
1102#define GMAC_ST2CW116_OFFSVAL(value) ((GMAC_ST2CW116_OFFSVAL_Msk & ((value) << GMAC_ST2CW116_OFFSVAL_Pos)))
1103#define GMAC_ST2CW116_OFFSSTRT_Pos 7
1104#define GMAC_ST2CW116_OFFSSTRT_Msk (0x3u << GMAC_ST2CW116_OFFSSTRT_Pos)
1105#define GMAC_ST2CW116_OFFSSTRT(value) ((GMAC_ST2CW116_OFFSSTRT_Msk & ((value) << GMAC_ST2CW116_OFFSSTRT_Pos)))
1106#define GMAC_ST2CW116_OFFSSTRT_FRAMESTART (0x0u << 7)
1107#define GMAC_ST2CW116_OFFSSTRT_ETHERTYPE (0x1u << 7)
1108#define GMAC_ST2CW116_OFFSSTRT_IP (0x2u << 7)
1109#define GMAC_ST2CW116_OFFSSTRT_TCP_UDP (0x3u << 7)
1110/* -------- GMAC_ST2CW017 : (GMAC Offset: 0x788) Screening Type 2 Compare Word 0 Register (index = 17) -------- */
1111#define GMAC_ST2CW017_MASKVAL_Pos 0
1112#define GMAC_ST2CW017_MASKVAL_Msk (0xffffu << GMAC_ST2CW017_MASKVAL_Pos)
1113#define GMAC_ST2CW017_MASKVAL(value) ((GMAC_ST2CW017_MASKVAL_Msk & ((value) << GMAC_ST2CW017_MASKVAL_Pos)))
1114#define GMAC_ST2CW017_COMPVAL_Pos 16
1115#define GMAC_ST2CW017_COMPVAL_Msk (0xffffu << GMAC_ST2CW017_COMPVAL_Pos)
1116#define GMAC_ST2CW017_COMPVAL(value) ((GMAC_ST2CW017_COMPVAL_Msk & ((value) << GMAC_ST2CW017_COMPVAL_Pos)))
1117/* -------- GMAC_ST2CW117 : (GMAC Offset: 0x78C) Screening Type 2 Compare Word 1 Register (index = 17) -------- */
1118#define GMAC_ST2CW117_OFFSVAL_Pos 0
1119#define GMAC_ST2CW117_OFFSVAL_Msk (0x7fu << GMAC_ST2CW117_OFFSVAL_Pos)
1120#define GMAC_ST2CW117_OFFSVAL(value) ((GMAC_ST2CW117_OFFSVAL_Msk & ((value) << GMAC_ST2CW117_OFFSVAL_Pos)))
1121#define GMAC_ST2CW117_OFFSSTRT_Pos 7
1122#define GMAC_ST2CW117_OFFSSTRT_Msk (0x3u << GMAC_ST2CW117_OFFSSTRT_Pos)
1123#define GMAC_ST2CW117_OFFSSTRT(value) ((GMAC_ST2CW117_OFFSSTRT_Msk & ((value) << GMAC_ST2CW117_OFFSSTRT_Pos)))
1124#define GMAC_ST2CW117_OFFSSTRT_FRAMESTART (0x0u << 7)
1125#define GMAC_ST2CW117_OFFSSTRT_ETHERTYPE (0x1u << 7)
1126#define GMAC_ST2CW117_OFFSSTRT_IP (0x2u << 7)
1127#define GMAC_ST2CW117_OFFSSTRT_TCP_UDP (0x3u << 7)
1128/* -------- GMAC_ST2CW018 : (GMAC Offset: 0x790) Screening Type 2 Compare Word 0 Register (index = 18) -------- */
1129#define GMAC_ST2CW018_MASKVAL_Pos 0
1130#define GMAC_ST2CW018_MASKVAL_Msk (0xffffu << GMAC_ST2CW018_MASKVAL_Pos)
1131#define GMAC_ST2CW018_MASKVAL(value) ((GMAC_ST2CW018_MASKVAL_Msk & ((value) << GMAC_ST2CW018_MASKVAL_Pos)))
1132#define GMAC_ST2CW018_COMPVAL_Pos 16
1133#define GMAC_ST2CW018_COMPVAL_Msk (0xffffu << GMAC_ST2CW018_COMPVAL_Pos)
1134#define GMAC_ST2CW018_COMPVAL(value) ((GMAC_ST2CW018_COMPVAL_Msk & ((value) << GMAC_ST2CW018_COMPVAL_Pos)))
1135/* -------- GMAC_ST2CW118 : (GMAC Offset: 0x794) Screening Type 2 Compare Word 1 Register (index = 18) -------- */
1136#define GMAC_ST2CW118_OFFSVAL_Pos 0
1137#define GMAC_ST2CW118_OFFSVAL_Msk (0x7fu << GMAC_ST2CW118_OFFSVAL_Pos)
1138#define GMAC_ST2CW118_OFFSVAL(value) ((GMAC_ST2CW118_OFFSVAL_Msk & ((value) << GMAC_ST2CW118_OFFSVAL_Pos)))
1139#define GMAC_ST2CW118_OFFSSTRT_Pos 7
1140#define GMAC_ST2CW118_OFFSSTRT_Msk (0x3u << GMAC_ST2CW118_OFFSSTRT_Pos)
1141#define GMAC_ST2CW118_OFFSSTRT(value) ((GMAC_ST2CW118_OFFSSTRT_Msk & ((value) << GMAC_ST2CW118_OFFSSTRT_Pos)))
1142#define GMAC_ST2CW118_OFFSSTRT_FRAMESTART (0x0u << 7)
1143#define GMAC_ST2CW118_OFFSSTRT_ETHERTYPE (0x1u << 7)
1144#define GMAC_ST2CW118_OFFSSTRT_IP (0x2u << 7)
1145#define GMAC_ST2CW118_OFFSSTRT_TCP_UDP (0x3u << 7)
1146/* -------- GMAC_ST2CW019 : (GMAC Offset: 0x798) Screening Type 2 Compare Word 0 Register (index = 19) -------- */
1147#define GMAC_ST2CW019_MASKVAL_Pos 0
1148#define GMAC_ST2CW019_MASKVAL_Msk (0xffffu << GMAC_ST2CW019_MASKVAL_Pos)
1149#define GMAC_ST2CW019_MASKVAL(value) ((GMAC_ST2CW019_MASKVAL_Msk & ((value) << GMAC_ST2CW019_MASKVAL_Pos)))
1150#define GMAC_ST2CW019_COMPVAL_Pos 16
1151#define GMAC_ST2CW019_COMPVAL_Msk (0xffffu << GMAC_ST2CW019_COMPVAL_Pos)
1152#define GMAC_ST2CW019_COMPVAL(value) ((GMAC_ST2CW019_COMPVAL_Msk & ((value) << GMAC_ST2CW019_COMPVAL_Pos)))
1153/* -------- GMAC_ST2CW119 : (GMAC Offset: 0x79C) Screening Type 2 Compare Word 1 Register (index = 19) -------- */
1154#define GMAC_ST2CW119_OFFSVAL_Pos 0
1155#define GMAC_ST2CW119_OFFSVAL_Msk (0x7fu << GMAC_ST2CW119_OFFSVAL_Pos)
1156#define GMAC_ST2CW119_OFFSVAL(value) ((GMAC_ST2CW119_OFFSVAL_Msk & ((value) << GMAC_ST2CW119_OFFSVAL_Pos)))
1157#define GMAC_ST2CW119_OFFSSTRT_Pos 7
1158#define GMAC_ST2CW119_OFFSSTRT_Msk (0x3u << GMAC_ST2CW119_OFFSSTRT_Pos)
1159#define GMAC_ST2CW119_OFFSSTRT(value) ((GMAC_ST2CW119_OFFSSTRT_Msk & ((value) << GMAC_ST2CW119_OFFSSTRT_Pos)))
1160#define GMAC_ST2CW119_OFFSSTRT_FRAMESTART (0x0u << 7)
1161#define GMAC_ST2CW119_OFFSSTRT_ETHERTYPE (0x1u << 7)
1162#define GMAC_ST2CW119_OFFSSTRT_IP (0x2u << 7)
1163#define GMAC_ST2CW119_OFFSSTRT_TCP_UDP (0x3u << 7)
1164/* -------- GMAC_ST2CW020 : (GMAC Offset: 0x7A0) Screening Type 2 Compare Word 0 Register (index = 20) -------- */
1165#define GMAC_ST2CW020_MASKVAL_Pos 0
1166#define GMAC_ST2CW020_MASKVAL_Msk (0xffffu << GMAC_ST2CW020_MASKVAL_Pos)
1167#define GMAC_ST2CW020_MASKVAL(value) ((GMAC_ST2CW020_MASKVAL_Msk & ((value) << GMAC_ST2CW020_MASKVAL_Pos)))
1168#define GMAC_ST2CW020_COMPVAL_Pos 16
1169#define GMAC_ST2CW020_COMPVAL_Msk (0xffffu << GMAC_ST2CW020_COMPVAL_Pos)
1170#define GMAC_ST2CW020_COMPVAL(value) ((GMAC_ST2CW020_COMPVAL_Msk & ((value) << GMAC_ST2CW020_COMPVAL_Pos)))
1171/* -------- GMAC_ST2CW120 : (GMAC Offset: 0x7A4) Screening Type 2 Compare Word 1 Register (index = 20) -------- */
1172#define GMAC_ST2CW120_OFFSVAL_Pos 0
1173#define GMAC_ST2CW120_OFFSVAL_Msk (0x7fu << GMAC_ST2CW120_OFFSVAL_Pos)
1174#define GMAC_ST2CW120_OFFSVAL(value) ((GMAC_ST2CW120_OFFSVAL_Msk & ((value) << GMAC_ST2CW120_OFFSVAL_Pos)))
1175#define GMAC_ST2CW120_OFFSSTRT_Pos 7
1176#define GMAC_ST2CW120_OFFSSTRT_Msk (0x3u << GMAC_ST2CW120_OFFSSTRT_Pos)
1177#define GMAC_ST2CW120_OFFSSTRT(value) ((GMAC_ST2CW120_OFFSSTRT_Msk & ((value) << GMAC_ST2CW120_OFFSSTRT_Pos)))
1178#define GMAC_ST2CW120_OFFSSTRT_FRAMESTART (0x0u << 7)
1179#define GMAC_ST2CW120_OFFSSTRT_ETHERTYPE (0x1u << 7)
1180#define GMAC_ST2CW120_OFFSSTRT_IP (0x2u << 7)
1181#define GMAC_ST2CW120_OFFSSTRT_TCP_UDP (0x3u << 7)
1182/* -------- GMAC_ST2CW021 : (GMAC Offset: 0x7A8) Screening Type 2 Compare Word 0 Register (index = 21) -------- */
1183#define GMAC_ST2CW021_MASKVAL_Pos 0
1184#define GMAC_ST2CW021_MASKVAL_Msk (0xffffu << GMAC_ST2CW021_MASKVAL_Pos)
1185#define GMAC_ST2CW021_MASKVAL(value) ((GMAC_ST2CW021_MASKVAL_Msk & ((value) << GMAC_ST2CW021_MASKVAL_Pos)))
1186#define GMAC_ST2CW021_COMPVAL_Pos 16
1187#define GMAC_ST2CW021_COMPVAL_Msk (0xffffu << GMAC_ST2CW021_COMPVAL_Pos)
1188#define GMAC_ST2CW021_COMPVAL(value) ((GMAC_ST2CW021_COMPVAL_Msk & ((value) << GMAC_ST2CW021_COMPVAL_Pos)))
1189/* -------- GMAC_ST2CW121 : (GMAC Offset: 0x7AC) Screening Type 2 Compare Word 1 Register (index = 21) -------- */
1190#define GMAC_ST2CW121_OFFSVAL_Pos 0
1191#define GMAC_ST2CW121_OFFSVAL_Msk (0x7fu << GMAC_ST2CW121_OFFSVAL_Pos)
1192#define GMAC_ST2CW121_OFFSVAL(value) ((GMAC_ST2CW121_OFFSVAL_Msk & ((value) << GMAC_ST2CW121_OFFSVAL_Pos)))
1193#define GMAC_ST2CW121_OFFSSTRT_Pos 7
1194#define GMAC_ST2CW121_OFFSSTRT_Msk (0x3u << GMAC_ST2CW121_OFFSSTRT_Pos)
1195#define GMAC_ST2CW121_OFFSSTRT(value) ((GMAC_ST2CW121_OFFSSTRT_Msk & ((value) << GMAC_ST2CW121_OFFSSTRT_Pos)))
1196#define GMAC_ST2CW121_OFFSSTRT_FRAMESTART (0x0u << 7)
1197#define GMAC_ST2CW121_OFFSSTRT_ETHERTYPE (0x1u << 7)
1198#define GMAC_ST2CW121_OFFSSTRT_IP (0x2u << 7)
1199#define GMAC_ST2CW121_OFFSSTRT_TCP_UDP (0x3u << 7)
1200/* -------- GMAC_ST2CW022 : (GMAC Offset: 0x7B0) Screening Type 2 Compare Word 0 Register (index = 22) -------- */
1201#define GMAC_ST2CW022_MASKVAL_Pos 0
1202#define GMAC_ST2CW022_MASKVAL_Msk (0xffffu << GMAC_ST2CW022_MASKVAL_Pos)
1203#define GMAC_ST2CW022_MASKVAL(value) ((GMAC_ST2CW022_MASKVAL_Msk & ((value) << GMAC_ST2CW022_MASKVAL_Pos)))
1204#define GMAC_ST2CW022_COMPVAL_Pos 16
1205#define GMAC_ST2CW022_COMPVAL_Msk (0xffffu << GMAC_ST2CW022_COMPVAL_Pos)
1206#define GMAC_ST2CW022_COMPVAL(value) ((GMAC_ST2CW022_COMPVAL_Msk & ((value) << GMAC_ST2CW022_COMPVAL_Pos)))
1207/* -------- GMAC_ST2CW122 : (GMAC Offset: 0x7B4) Screening Type 2 Compare Word 1 Register (index = 22) -------- */
1208#define GMAC_ST2CW122_OFFSVAL_Pos 0
1209#define GMAC_ST2CW122_OFFSVAL_Msk (0x7fu << GMAC_ST2CW122_OFFSVAL_Pos)
1210#define GMAC_ST2CW122_OFFSVAL(value) ((GMAC_ST2CW122_OFFSVAL_Msk & ((value) << GMAC_ST2CW122_OFFSVAL_Pos)))
1211#define GMAC_ST2CW122_OFFSSTRT_Pos 7
1212#define GMAC_ST2CW122_OFFSSTRT_Msk (0x3u << GMAC_ST2CW122_OFFSSTRT_Pos)
1213#define GMAC_ST2CW122_OFFSSTRT(value) ((GMAC_ST2CW122_OFFSSTRT_Msk & ((value) << GMAC_ST2CW122_OFFSSTRT_Pos)))
1214#define GMAC_ST2CW122_OFFSSTRT_FRAMESTART (0x0u << 7)
1215#define GMAC_ST2CW122_OFFSSTRT_ETHERTYPE (0x1u << 7)
1216#define GMAC_ST2CW122_OFFSSTRT_IP (0x2u << 7)
1217#define GMAC_ST2CW122_OFFSSTRT_TCP_UDP (0x3u << 7)
1218/* -------- GMAC_ST2CW023 : (GMAC Offset: 0x7B8) Screening Type 2 Compare Word 0 Register (index = 23) -------- */
1219#define GMAC_ST2CW023_MASKVAL_Pos 0
1220#define GMAC_ST2CW023_MASKVAL_Msk (0xffffu << GMAC_ST2CW023_MASKVAL_Pos)
1221#define GMAC_ST2CW023_MASKVAL(value) ((GMAC_ST2CW023_MASKVAL_Msk & ((value) << GMAC_ST2CW023_MASKVAL_Pos)))
1222#define GMAC_ST2CW023_COMPVAL_Pos 16
1223#define GMAC_ST2CW023_COMPVAL_Msk (0xffffu << GMAC_ST2CW023_COMPVAL_Pos)
1224#define GMAC_ST2CW023_COMPVAL(value) ((GMAC_ST2CW023_COMPVAL_Msk & ((value) << GMAC_ST2CW023_COMPVAL_Pos)))
1225/* -------- GMAC_ST2CW123 : (GMAC Offset: 0x7BC) Screening Type 2 Compare Word 1 Register (index = 23) -------- */
1226#define GMAC_ST2CW123_OFFSVAL_Pos 0
1227#define GMAC_ST2CW123_OFFSVAL_Msk (0x7fu << GMAC_ST2CW123_OFFSVAL_Pos)
1228#define GMAC_ST2CW123_OFFSVAL(value) ((GMAC_ST2CW123_OFFSVAL_Msk & ((value) << GMAC_ST2CW123_OFFSVAL_Pos)))
1229#define GMAC_ST2CW123_OFFSSTRT_Pos 7
1230#define GMAC_ST2CW123_OFFSSTRT_Msk (0x3u << GMAC_ST2CW123_OFFSSTRT_Pos)
1231#define GMAC_ST2CW123_OFFSSTRT(value) ((GMAC_ST2CW123_OFFSSTRT_Msk & ((value) << GMAC_ST2CW123_OFFSSTRT_Pos)))
1232#define GMAC_ST2CW123_OFFSSTRT_FRAMESTART (0x0u << 7)
1233#define GMAC_ST2CW123_OFFSSTRT_ETHERTYPE (0x1u << 7)
1234#define GMAC_ST2CW123_OFFSSTRT_IP (0x2u << 7)
1235#define GMAC_ST2CW123_OFFSSTRT_TCP_UDP (0x3u << 7)
1238
1239
1240#endif /* _SAME70_GMAC_COMPONENT_ */
#define __O
Definition: core_cm4.h:238
#define __IO
Definition: core_cm4.h:239
#define __I
Definition: core_cm4.h:236
GmacSa hardware registers.
Definition: component_gmac.h:41
__IO uint32_t GMAC_SAT
(GmacSa Offset: 0x4) Specific Address 1 Top Register
Definition: component_gmac.h:43
__IO uint32_t GMAC_SAB
(GmacSa Offset: 0x0) Specific Address 1 Bottom Register
Definition: component_gmac.h:42
GmacSt2Compare hardware registers.
Definition: component_gmac.h:47
__IO uint32_t GMAC_ST2COM0
31:16 - Compare Value. 15:0 - Mask Value.
Definition: component_gmac.h:48
__IO uint32_t GMAC_ST2COM1
31:9 - Reserved; 8:7 - Offset location in frame; 6:0 Offset value in bytes
Definition: component_gmac.h:49
Definition: component_gmac.h:55
__IO uint32_t GMAC_SAMT1
(Gmac Offset: 0x0CC) Specific Address 1 Mask Top Register
Definition: component_gmac.h:88
__I uint32_t GMAC_NSR
(Gmac Offset: 0x008) Network Status Register
Definition: component_gmac.h:58
__I uint32_t GMAC_MCF
(Gmac Offset: 0x13C) Multiple Collision Frames Register
Definition: component_gmac.h:113
__I uint32_t GMAC_ORHI
(Gmac Offset: 0x154) Octets Received High Received Register
Definition: component_gmac.h:119
__I uint32_t GMAC_PEFTSL
(Gmac Offset: 0x1F0) PTP Peer Event Frame Transmitted Seconds Low Register
Definition: component_gmac.h:155
__I uint32_t GMAC_BCFR
(Gmac Offset: 0x15C) Broadcast Frames Received Register
Definition: component_gmac.h:121
__I uint32_t GMAC_EC
(Gmac Offset: 0x140) Excessive Collisions Register
Definition: component_gmac.h:114
__IO uint32_t GMAC_IPGS
(Gmac Offset: 0x0BC) IPG Stretch Register
Definition: component_gmac.h:84
__IO uint32_t GMAC_TIDM2
(Gmac Offset: 0x0AC) Type ID Match 2 Register
Definition: component_gmac.h:80
__I uint32_t GMAC_PFT
(Gmac Offset: 0x114) Pause Frames Transmitted Register
Definition: component_gmac.h:103
__I uint32_t GMAC_JR
(Gmac Offset: 0x18C) Jabbers Received Register
Definition: component_gmac.h:133
__IO uint32_t GMAC_CBSISQA
(Gmac Offset: 0x4C0) Credit-Based Shaping IdleSlope Register for Queue A
Definition: component_gmac.h:169
__I uint32_t GMAC_EFRSL
(Gmac Offset: 0x1E8) PTP Event Frame Received Seconds Low Register
Definition: component_gmac.h:153
__I uint32_t GMAC_BFR64
(Gmac Offset: 0x168) 64 Byte Frames Received Register
Definition: component_gmac.h:124
__I uint32_t GMAC_TBFT1518
(Gmac Offset: 0x12C) 1024 to 1518 Byte Frames Transmitted Register
Definition: component_gmac.h:109
__IO uint32_t GMAC_SCL
(Gmac Offset: 0x0E0) 1588 Timer Second Comparison Low Register
Definition: component_gmac.h:91
__I uint32_t GMAC_EFRSH
(Gmac Offset: 0x0EC) PTP Event Frame Received Seconds High Register
Definition: component_gmac.h:94
__I uint32_t GMAC_TBFR127
(Gmac Offset: 0x16C) 65 to 127 Byte Frames Received Register
Definition: component_gmac.h:125
__I uint32_t GMAC_TBFR1023
(Gmac Offset: 0x178) 512 to 1023 Byte Frames Received Register
Definition: component_gmac.h:128
__I uint32_t GMAC_TBFT127
(Gmac Offset: 0x11C) 65 to 127 Byte Frames Transmitted Register
Definition: component_gmac.h:105
__IO uint32_t GMAC_TSL
(Gmac Offset: 0x1D0) 1588 Timer Seconds Low Register
Definition: component_gmac.h:147
__IO uint32_t GMAC_TSH
(Gmac Offset: 0x1C0) 1588 Timer Seconds High Register
Definition: component_gmac.h:145
__I uint32_t GMAC_PEFTN
(Gmac Offset: 0x1F4) PTP Peer Event Frame Transmitted Nanoseconds Register
Definition: component_gmac.h:156
__I uint32_t GMAC_IHCE
(Gmac Offset: 0x1A8) IP Header Checksum Errors Register
Definition: component_gmac.h:140
__I uint32_t GMAC_PEFRSH
(Gmac Offset: 0x0F4) PTP Peer Event Frame Received Seconds High Register
Definition: component_gmac.h:96
__O uint32_t GMAC_IER
(Gmac Offset: 0x028) Interrupt Enable Register
Definition: component_gmac.h:66
__IO uint32_t GMAC_WOL
(Gmac Offset: 0x0B8) Wake on LAN Register
Definition: component_gmac.h:83
__I uint32_t GMAC_TBFT511
(Gmac Offset: 0x124) 256 to 511 Byte Frames Transmitted Register
Definition: component_gmac.h:107
__I uint32_t GMAC_UFR
(Gmac Offset: 0x184) Undersize Frames Received Register
Definition: component_gmac.h:131
__IO uint32_t GMAC_HRB
(Gmac Offset: 0x080) Hash Register Bottom
Definition: component_gmac.h:76
__IO uint32_t GMAC_MAN
(Gmac Offset: 0x034) PHY Maintenance Register
Definition: component_gmac.h:69
__IO uint32_t GMAC_UR
(Gmac Offset: 0x00C) User Register
Definition: component_gmac.h:59
__I uint32_t GMAC_TMXBFR
(Gmac Offset: 0x180) 1519 to Maximum Byte Frames Received Register
Definition: component_gmac.h:130
(Gmac Offset: 0x1DC) 1588 Timer Increment Register
Definition: component_gmac.h:150
__I uint32_t GMAC_CSE
(Gmac Offset: 0x14C) Carrier Sense Errors Register
Definition: component_gmac.h:117
__I uint32_t GMAC_BFT64
(Gmac Offset: 0x118) 64 Byte Frames Transmitted Register
Definition: component_gmac.h:104
__I uint32_t GMAC_BCFT
(Gmac Offset: 0x10C) Broadcast Frames Transmitted Register
Definition: component_gmac.h:101
__IO uint32_t GMAC_SCH
(Gmac Offset: 0x0E4) 1588 Timer Second Comparison High Register
Definition: component_gmac.h:92
__I uint32_t GMAC_RRE
(Gmac Offset: 0x1A0) Receive Resource Errors Register
Definition: component_gmac.h:138
__I uint32_t GMAC_MFR
(Gmac Offset: 0x160) Multicast Frames Received Register
Definition: component_gmac.h:122
__IO uint32_t GMAC_RJFML
(Gmac Offset: 0x048) RX Jumbo Frame Max Length Register
Definition: component_gmac.h:74
__I uint32_t GMAC_EFTSH
(Gmac Offset: 0x0E8) PTP Event Frame Transmitted Seconds High Register
Definition: component_gmac.h:93
__I uint32_t GMAC_TBFR1518
(Gmac Offset: 0x17C) 1024 to 1518 Byte Frames Received Register
Definition: component_gmac.h:129
__IO uint32_t GMAC_HRT
(Gmac Offset: 0x084) Hash Register Top
Definition: component_gmac.h:77
__I uint32_t GMAC_TCE
(Gmac Offset: 0x1AC) TCP Checksum Errors Register
Definition: component_gmac.h:141
__IO uint32_t GMAC_NSC
(Gmac Offset: 0x0DC) 1588 Timer Nanosecond Comparison Register
Definition: component_gmac.h:90
__I uint32_t GMAC_FR
(Gmac Offset: 0x158) Frames Received Register
Definition: component_gmac.h:120
__I uint32_t GMAC_TBFT255
(Gmac Offset: 0x120) 128 to 255 Byte Frames Transmitted Register
Definition: component_gmac.h:106
__I uint32_t GMAC_OTLO
(Gmac Offset: 0x100) Octets Transmitted Low Register
Definition: component_gmac.h:98
__I uint32_t GMAC_PEFRSL
(Gmac Offset: 0x1F8) PTP Peer Event Frame Received Seconds Low Register
Definition: component_gmac.h:157
__IO uint32_t GMAC_TIDM3
(Gmac Offset: 0x0B0) Type ID Match 3 Register
Definition: component_gmac.h:81
__IO uint32_t GMAC_SVLAN
(Gmac Offset: 0x0C0) Stacked VLAN Register
Definition: component_gmac.h:85
__IO uint32_t GMAC_NCFGR
(Gmac Offset: 0x004) Network Configuration Register
Definition: component_gmac.h:57
__I uint32_t GMAC_RSE
(Gmac Offset: 0x198) Receive Symbol Errors Register
Definition: component_gmac.h:136
__IO uint32_t GMAC_TN
(Gmac Offset: 0x1D4) 1588 Timer Nanoseconds Register
Definition: component_gmac.h:148
__IO uint32_t GMAC_TISUBN
(Gmac Offset: 0x1BC) 1588 Timer Increment Sub-nanoseconds Register
Definition: component_gmac.h:144
__I uint32_t GMAC_EFRN
(Gmac Offset: 0x1EC) PTP Event Frame Received Nanoseconds Register
Definition: component_gmac.h:154
__IO uint32_t GMAC_TSR
(Gmac Offset: 0x014) Transmit Status Register
Definition: component_gmac.h:61
__I uint32_t GMAC_ISR
(Gmac Offset: 0x024) Interrupt Status Register
Definition: component_gmac.h:65
__I uint32_t GMAC_FCSE
(Gmac Offset: 0x190) Frame Check Sequence Errors Register
Definition: component_gmac.h:134
__I uint32_t GMAC_DTF
(Gmac Offset: 0x148) Deferred Transmission Frames Register
Definition: component_gmac.h:116
__IO uint32_t GMAC_RBQB
(Gmac Offset: 0x018) Receive Buffer Queue Base Address Register
Definition: component_gmac.h:62
__I uint32_t GMAC_EFTN
(Gmac Offset: 0x1E4) PTP Event Frame Transmitted Nanoseconds Register
Definition: component_gmac.h:152
__IO uint32_t GMAC_DCFGR
(Gmac Offset: 0x010) DMA Configuration Register
Definition: component_gmac.h:60
__IO uint32_t GMAC_TPSF
(Gmac Offset: 0x040) TX Partial Store and Forward Register
Definition: component_gmac.h:72
__I uint32_t GMAC_TBFT1023
(Gmac Offset: 0x128) 512 to 1023 Byte Frames Transmitted Register
Definition: component_gmac.h:108
__I uint32_t GMAC_TBFR511
(Gmac Offset: 0x174) 256 to 511 Byte Frames Received Register
Definition: component_gmac.h:127
__I uint32_t GMAC_OFR
(Gmac Offset: 0x188) Oversize Frames Received Register
Definition: component_gmac.h:132
__I uint32_t GMAC_ROE
(Gmac Offset: 0x1A4) Receive Overrun Register
Definition: component_gmac.h:139
__IO uint32_t GMAC_CBSISQB
(Gmac Offset: 0x4C4) Credit-Based Shaping IdleSlope Register for Queue B
Definition: component_gmac.h:170
__I uint32_t GMAC_FT
(Gmac Offset: 0x108) Frames Transmitted Register
Definition: component_gmac.h:100
__I uint32_t GMAC_PFR
(Gmac Offset: 0x164) Pause Frames Received Register
Definition: component_gmac.h:123
__IO uint32_t GMAC_TPFCP
(Gmac Offset: 0x0C4) Transmit PFC Pause Register
Definition: component_gmac.h:86
__IO uint32_t GMAC_SAMB1
(Gmac Offset: 0x0C8) Specific Address 1 Mask Bottom Register
Definition: component_gmac.h:87
__IO uint32_t GMAC_RPSF
(Gmac Offset: 0x044) RX Partial Store and Forward Register
Definition: component_gmac.h:73
__I uint32_t GMAC_TBFR255
(Gmac Offset: 0x170) 128 to 255 Byte Frames Received Register
Definition: component_gmac.h:126
__I uint32_t GMAC_OTHI
(Gmac Offset: 0x104) Octets Transmitted High Register
Definition: component_gmac.h:99
__IO uint32_t GMAC_CBSCR
(Gmac Offset: 0x4BC) Credit-Based Shaping Control Register
Definition: component_gmac.h:168
__I uint32_t GMAC_EFTSL
(Gmac Offset: 0x1E0) PTP Event Frame Transmitted Seconds Low Register
Definition: component_gmac.h:151
__I uint32_t GMAC_LFFE
(Gmac Offset: 0x194) Length Field Frame Errors Register
Definition: component_gmac.h:135
__I uint32_t GMAC_PEFRN
(Gmac Offset: 0x1FC) PTP Peer Event Frame Received Nanoseconds Register
Definition: component_gmac.h:158
__I uint32_t GMAC_GTBFT1518
(Gmac Offset: 0x130) Greater Than 1518 Byte Frames Transmitted Register
Definition: component_gmac.h:110
__I uint32_t GMAC_TUR
(Gmac Offset: 0x134) Transmit Underruns Register
Definition: component_gmac.h:111
__IO uint32_t GMAC_TBQB
(Gmac Offset: 0x01C) Transmit Buffer Queue Base Address Register
Definition: component_gmac.h:63
__I uint32_t GMAC_PEFTSH
(Gmac Offset: 0x0F0) PTP Peer Event Frame Transmitted Seconds High Register
Definition: component_gmac.h:95
__IO uint32_t GMAC_RSR
(Gmac Offset: 0x020) Receive Status Register
Definition: component_gmac.h:64
__IO uint32_t GMAC_TPQ
(Gmac Offset: 0x03C) Transmit Pause Quantum Register
Definition: component_gmac.h:71
__IO uint32_t GMAC_TIDM4
(Gmac Offset: 0x0B4) Type ID Match 4 Register
Definition: component_gmac.h:82
__I uint32_t GMAC_AE
(Gmac Offset: 0x19C) Alignment Errors Register
Definition: component_gmac.h:137
__I uint32_t GMAC_RPQ
(Gmac Offset: 0x038) Received Pause Quantum Register
Definition: component_gmac.h:70
__I uint32_t GMAC_UCE
(Gmac Offset: 0x1B0) UDP Checksum Errors Register
Definition: component_gmac.h:142
__I uint32_t GMAC_SCF
(Gmac Offset: 0x138) Single Collision Frames Register
Definition: component_gmac.h:112
__IO uint32_t GMAC_TIDM1
(Gmac Offset: 0x0A8) Type ID Match 1 Register
Definition: component_gmac.h:79
__IO uint32_t GMAC_IMR
(Gmac Offset: 0x030) Interrupt Mask Register
Definition: component_gmac.h:68
__O uint32_t GMAC_TA
(Gmac Offset: 0x1D8) 1588 Timer Adjust Register
Definition: component_gmac.h:149
__O uint32_t GMAC_IDR
(Gmac Offset: 0x02C) Interrupt Disable Register
Definition: component_gmac.h:67
__I uint32_t GMAC_MFT
(Gmac Offset: 0x110) Multicast Frames Transmitted Register
Definition: component_gmac.h:102
__I uint32_t GMAC_LC
(Gmac Offset: 0x144) Late Collisions Register
Definition: component_gmac.h:115
__IO uint32_t GMAC_NCR
(Gmac Offset: 0x000) Network Control Register
Definition: component_gmac.h:56
__I uint32_t GMAC_ORLO
(Gmac Offset: 0x150) Octets Received Low Received Register
Definition: component_gmac.h:118
