RTEMS 6.1
rtd316.h
2
11/*
12 * COPYRIGHT (c) 1989-2014.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _BSP_RTD_316_h
38#define _BSP_RTD_316_h
39
40#ifdef __cplusplus
41extern "C" {
42#endif
43
48#define RTD316_DRIVER_TABLE_ENTRY \
49 { rtd316_initialize, NULL, NULL, NULL, NULL, NULL }
50
66 void *arg
67);
68
79uint8_t rtd316_com_get_register(uintptr_t addr, uint8_t reg);
80
89void rtd316_com_set_register(uintptr_t addr,uint8_t reg, uint8_t val);
90
91#ifdef __cplusplus
92}
93#endif
94
95#endif
96/* end of include file */
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
void rtd316_com_set_register(uintptr_t addr, uint8_t reg, uint8_t val)
RTD316 Set Register Helper.
Definition: rtd316.c:63
rtems_device_driver rtd316_initialize(rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
RTD316 Initialization Entry Point.
Definition: rtd316.c:70
RTD316 Obtain Register Helper.
Definition: rtd316.c:52
