RTEMS 6.1
cpu_asm.h
1
11/*
12 * COPYRIGHT (c) 1989-1999.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
25 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
28 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
29 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
30 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
31 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
32 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
33 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
34 * SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_SCORE_CPU_ASM_H
38#define _RTEMS_SCORE_CPU_ASM_H
39
40/* pull in the generated offsets */
41
42/*
43#include <rtems/score/offsets.h>
44*/
45
46/*
47 * Hardware General Registers
48 */
49
50/* put something here */
51
52/*
53 * Hardware Floating Point Registers
54 */
55
56/* put something here */
57
58/*
59 * Hardware Control Registers
60 */
61
62/* put something here */
63
64/*
65 * Calling Convention
66 */
67
68/* put something here */
69
70/*
71 * Temporary registers
72 */
73
74/* put something here */
75
76/*
77 * Floating Point Registers - SW Conventions
78 */
79
80/* put something here */
81
82/*
83 * Temporary floating point registers
84 */
85
86/* put something here */
87
88#endif
89
90/* end of file */
