RTEMS 6.1
amba.h
2
9/*
10 * AMBA Plag & Play Bus Driver Macros
11 *
12 * Macros used for AMBA Plug & Play bus scanning
13 *
14 * COPYRIGHT (c) 2004.
15 * Gaisler Research
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef __AMBA_H__
40#define __AMBA_H__
41
54#ifndef GRLIB_IO_AREA
55#define GRLIB_IO_AREA 0xfff00000
56#endif
57
58#define GRLIB_CONF_AREA 0xff000
59#define GRLIB_AHB_SLAVE_CONF_AREA (1 << 11)
60
61#define GRLIB_AHB_CONF_WORDS 8
62#define GRLIB_APB_CONF_WORDS 2
63#define GRLIB_AHB_MASTERS 64
64#define GRLIB_AHB_SLAVES 64
65#define GRLIB_APB_SLAVES 16
66
67#if defined(RTEMS_MULTIPROCESSING)
68 #define GRLIB_CLOCK_INDEX \
69 (rtems_configuration_get_user_multiprocessing_table() ? GRLIB_Cpu_Index : 0)
70#else
71 #define GRLIB_CLOCK_INDEX 0
72#endif
73
74#if defined(RTEMS_SMP)
75#define GRLIB_COUNTER_GPTIMER_INDEX (GRLIB_CLOCK_INDEX + 1)
76#else
77#define GRLIB_COUNTER_GPTIMER_INDEX GRLIB_CLOCK_INDEX
78#endif
79
80#define GRLIB_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000
81
82#define GRLIB_IRQMPSTATUS_CPUNR 28
83
84#include <grlib/ambapp.h>
85#include <grlib/grlib.h>
86
87#ifdef __cplusplus
88extern "C" {
89#endif
90
91extern uint32_t GRLIB_Cpu_Index;
92extern const unsigned char GRLIB_mp_irq;
93
94extern volatile struct irqmp_regs *GRLIB_IrqCtrl_Regs;
95extern struct ambapp_dev *GRLIB_IrqCtrl_Adev;
96extern int GRLIB_IrqCtrl_EIrq;
97extern volatile struct gptimer_regs *GRLIB_Timer_Regs;
98extern struct ambapp_dev *GRLIB_Timer_Adev;
99void gptimer_initialize(void);
100void irqmp_initialize(void);
101
102static inline uint32_t grlib_up_counter_frequency(void)
103{
104 /*
105 * For simplicity, assume that the interrupt controller uses the processor
106 * clock. This is at least true on the GR740.
107 */
108 return ambapp_freq_get(ambapp_plb(), GRLIB_IrqCtrl_Adev);
109}
110
111extern rtems_interrupt_lock GRLIB_IrqCtrl_Lock;
112
113
114static inline uint32_t grlib_get_cpu_count(
115 volatile struct irqmp_regs *irqmp
116)
117{
118 uint32_t mpstat = irqmp->mpstat;
119
120 return ((mpstat >> GRLIB_IRQMPSTATUS_CPUNR) & 0xf) + 1;
121}
122
123#define GRLIB_IRQCTRL_ACQUIRE( _lock_context ) \
124 rtems_interrupt_lock_acquire( &GRLIB_IrqCtrl_Lock, _lock_context )
125
126#define GRLIB_IRQCTRL_RELEASE( _lock_context ) \
127 rtems_interrupt_lock_release( &GRLIB_IrqCtrl_Lock, _lock_context )
128
129#define GRLIB_Cpu_Unmask_interrupt( _source, _cpu ) \
130 do { \
131 rtems_interrupt_lock_context _lock_context; \
132 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
133 GRLIB_IrqCtrl_Regs->mask[_cpu] |= (1U << (_source)); \
134 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
135 } while (0)
136
137#define GRLIB_Cpu_Mask_interrupt( _source, _cpu ) \
138 do { \
139 rtems_interrupt_lock_context _lock_context; \
140 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
141 GRLIB_IrqCtrl_Regs->mask[_cpu] &= ~(1U << (_source)); \
142 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
143 } while (0)
144
145#define GRLIB_Enable_interrupt_broadcast( _source ) \
146 do { \
147 rtems_interrupt_lock_context _lock_context; \
148 uint32_t _mask = 1U << ( _source ); \
149 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
150 GRLIB_IrqCtrl_Regs->bcast |= _mask; \
151 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
152 } while (0)
153
154#define GRLIB_Disable_interrupt_broadcast( _source ) \
155 do { \
156 rtems_interrupt_lock_context _lock_context; \
157 uint32_t _mask = 1U << ( _source ); \
158 GRLIB_IRQCTRL_ACQUIRE( &_lock_context ); \
159 GRLIB_IrqCtrl_Regs->bcast &= ~_mask; \
160 GRLIB_IRQCTRL_RELEASE( &_lock_context ); \
161 } while (0)
162
163#define BSP_Cpu_Is_interrupt_masked( _source, _cpu ) \
164 (!(GRLIB_IrqCtrl_Regs->mask[_cpu] & (1U << (_source))))
165
166#ifdef __cplusplus
167}
168#endif
169
172#endif /* __AMBA_H__ */
Common GRLIB AMBA Core Register definitions.
char rtems_interrupt_lock
This structure represents an ISR lock.
Definition: intr.h:532
struct ambapp_bus * ambapp_plb(void)
Gets the fully scanned AMBA Plug & Play Processor Local Bus (PLB).
Definition: bspstart.c:58
Definition: ambapp.h:94
Definition: grlib.h:129
Definition: grlib.h:83
