RTEMS
6.1
bsps
arm
tms570
include
bsp
ti_herc
reg_tcr.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from TCR.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_TCR
50
#define LIBBSP_ARM_TMS570_TCR
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t TCR[128];
/*Transfer Configuration RAM*/
56
uint32_t TCR_Parity[128];
/*TCR Parity Test Mode*/
57
tms570_tcr_t
58
59
60
/*-----------------------TMS570_TCR_TCR-----------------------*/
61
/* field: STXR - Set Transmit Request. */
62
#define TMS570_TCR_TCR_STXR BSP_BIT32(18)
63
64
/* field: THTSM - Transfer Header to System Memory. */
65
#define TMS570_TCR_TCR_THTSM BSP_BIT32(17)
66
67
/* field: TPTSM - Transfer Payload to System Memory. */
68
#define TMS570_TCR_TCR_TPTSM BSP_BIT32(16)
69
70
/* field: THTCC - Transfer Header to Communication Controller. */
71
#define TMS570_TCR_TCR_THTCC BSP_BIT32(15)
72
73
/* field: TPTCC - Transfer Payload to Communication Controller. */
74
#define TMS570_TCR_TCR_TPTCC BSP_BIT32(14)
75
76
/* field: TSO - Transfer Start Offset. */
77
#define TMS570_TCR_TCR_TSO(val) BSP_FLD32(val,0, 13)
78
#define TMS570_TCR_TCR_TSO_GET(reg) BSP_FLD32GET(reg,0, 13)
79
#define TMS570_TCR_TCR_TSO_SET(reg,val) BSP_FLD32SET(reg, val,0, 13)
80
81
82
/*-------------------TMS570_TCR_TCR_Parity-------------------*/
83
/* field: PAB2 - Parity Bit for TCRx Byte 2. Parity information for byte 2 of TCRx(18-16). */
84
#define TMS570_TCR_TCR_Parity_PAB2 BSP_BIT32(16)
85
86
/* field: PAB1 - Parity Bit for TCRx Byte 1. Parity information for byte 1 of TCRx(15:8). */
87
#define TMS570_TCR_TCR_Parity_PAB1 BSP_BIT32(8)
88
89
/* field: PAB0 - Parity Bit for Byte 0. */
90
#define TMS570_TCR_TCR_Parity_PAB0 BSP_BIT32(0)
91
92
93
94
#endif
/* LIBBSP_ARM_TMS570_TCR */
utility.h
This header file provides utility macros for BSPs.
tms570_tcr_t
Definition:
reg_tcr.h:54
