RTEMS 6.1
reg_sys.h
2
11/* The header file is generated by make_header.py from SYS.json */
12/* Current script's version can be found at: */
13/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15/*
16 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17 *
18 * Czech Technical University in Prague
19 * Zikova 1903/4
20 * 166 36 Praha 6
21 * Czech Republic
22 *
23 * All rights reserved.
24 *
25 * Redistribution and use in source and binary forms, with or without
26 * modification, are permitted provided that the following conditions are met:
27 *
28 * 1. Redistributions of source code must retain the above copyright notice, this
29 * list of conditions and the following disclaimer.
30 * 2. Redistributions in binary form must reproduce the above copyright notice,
31 * this list of conditions and the following disclaimer in the documentation
32 * and/or other materials provided with the distribution.
33 *
34 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44 *
45 * The views and conclusions contained in the software and documentation are those
46 * of the authors and should not be interpreted as representing official policies,
47 * either expressed or implied, of the FreeBSD Project.
48*/
49#ifndef LIBBSP_ARM_TMS570_SYS1
50#define LIBBSP_ARM_TMS570_SYS1
51
52#include <bsp/utility.h>
53
54typedef struct{
55 uint32_t SYSPC1; /*SYS Pin Control Register 1*/
56 uint32_t SYSPC2; /*SYS Pin Control Register 2*/
57 uint32_t SYSPC3; /*SYS Pin Control Register 3*/
58 uint32_t SYSPC4; /*SYS Pin Control Register 4*/
59 uint32_t SYSPC5; /*SYS Pin Control Register 5*/
60 uint32_t SYSPC6; /*SYS Pin Control Register 6*/
61 uint32_t SYSPC7; /*SYS Pin Control Register 7*/
62 uint32_t SYSPC8; /*SYS Pin Control Register 8*/
63 uint32_t SYSPC9; /*SYS Pin Control Register 9*/
64 uint8_t reserved1 [12];
65 uint32_t CSDIS; /*Clock Source Disable Register*/
66 uint32_t CSDISSET; /*Clock Source Disable Set Register*/
67 uint32_t CSDISCLR; /*Clock Source Disable Clear Register*/
68 uint32_t CDDIS; /*Clock Domain Disable Register*/
69 uint32_t CDDISSET; /*Clock Domain Disable Set Register*/
70 uint32_t CDDISCLR; /*Clock Domain Disable Clear Register*/
71 uint32_t GHVSRC; /*GCLK, HCLK, VCLK, and VCLK2 Source Register*/
72 uint32_t VCLKASRC; /*Peripheral Asynchronous Clock Source Register*/
73 uint32_t RCLKSRC; /*RTI Clock Source Register*/
74 uint32_t CSVSTAT; /*Clock Source Valid Status Register*/
75 uint32_t MSTGCR; /*Memory Self-Test Global Control Register*/
76 uint32_t MINITGCR; /*Memory Hardware Initialization Global Control Register*/
77 uint32_t MSIENA; /*Memory Self-Test/Initialization Enable Register*/
78 uint8_t reserved2 [4];
79 uint32_t MSTCGSTAT; /*MSTC Global Status Register*/
80 uint32_t MINISTAT; /*Memory Hardware Initialization Status Register*/
81 uint32_t PLLCTL1; /*PLL Control Register 1*/
82 uint32_t PLLCTL2; /*PLL Control Register 2*/
83 uint32_t SYSPC10; /*SYS Pin Control Register 10*/
84 uint32_t DIEIDL; /*Die Identification Register, Lower Word*/
85 uint32_t DIEIDH; /*Die Identification Register, Upper Word*/
86 uint8_t reserved3 [4];
87 uint32_t LPOMONCTL; /*LPO/Clock Monitor Control Register*/
88 uint32_t CLKTEST; /*Clock Test Register*/
89 uint32_t DFTCTRLREG1; /*DFT Control Register*/
90 uint32_t DFTCTRLREG2; /*DFT Control Register 2*/
91 uint8_t reserved4 [8];
92 uint32_t GPREG1; /*General Purpose Register*/
93 uint8_t reserved5 [4];
94 uint32_t IMPFASTS; /*Imprecise Fault Status Register*/
95 uint32_t IMPFTADD; /*Imprecise Fault Write Address Register*/
96 uint32_t SSIR1; /*System Software Interrupt Request 1 Register*/
97 uint32_t SSIR2; /*System Software Interrupt Request 2 Register*/
98 uint32_t SSIR3; /*System Software Interrupt Request 3 Register*/
99 uint32_t SSIR4; /*System Software Interrupt Request 4 Register*/
100 uint32_t RAMGCR; /*RAM Control Register*/
101 uint32_t BMMCR1; /*Bus Matrix Module Control Register 1*/
102 uint8_t reserved6 [4];
103 uint32_t CPURSTCR; /*CPU Reset Control Register*/
104 uint32_t CLKCNTL; /*Clock Control Register*/
105 uint32_t ECPCNTL; /*ECP Control Register*/
106 uint8_t reserved7 [4];
107 uint32_t DEVCR1; /*DEV Parity Control Register 1*/
108 uint32_t SYSECR; /*System Exception Control Register*/
109 uint32_t SYSESR; /*System Exception Status Register*/
110 uint32_t SYSTASR; /*System Test Abort Status Register*/
111 uint32_t GLBSTAT; /*Global Status Register*/
112 uint32_t DEVID; /*Device Identification Register*/
113 uint32_t SSIVEC; /*Software Interrupt Vector Register*/
114 uint32_t SSIF; /*System Software Interrupt Flag Register*/
116
117
118/*---------------------TMS570_SYS1_SYSPCx---------------------*/
119/* field: ECPCLKFUN - ECLK function. This bit changes the function of the ECLK pin. */
120#define TMS570_SYS1_SYSPCx_ECPCLKFUN BSP_BIT32(0)
121
122
123/*---------------------TMS570_SYS1_CSDIS---------------------*/
124/* field: CLKSROFF - Clock source[7-0] off. 2 reserved */
125#define TMS570_SYS1_CSDIS_CLKSROFF(val) BSP_FLD32(val,0, 7)
126#define TMS570_SYS1_CSDIS_CLKSROFF_GET(reg) BSP_FLD32GET(reg,0, 7)
127#define TMS570_SYS1_CSDIS_CLKSROFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
128
129/* Clock Source 0 Oscillator */
130#define TMS570_SYS1_CSDIS_CLKSR_OSC_NUM 0
131#define TMS570_SYS1_CSDIS_CLKSROFF_OSC BSP_BIT32(0)
132
133/* Clock Source 1 PLL1 */
134#define TMS570_SYS1_CSDIS_CLKSR_PLL1_NUM 1
135#define TMS570_SYS1_CSDIS_CLKSROFF_PLL1 BSP_BIT32(1)
136
137/* Clock Source 3 EXTCLKIN */
138#define TMS570_SYS1_CSDIS_CLKSR_EXTCLKIN_NUM 3
139#define TMS570_SYS1_CSDIS_CLKSROFF_EXTCLKIN BSP_BIT32(3)
140
141/* Clock Source 4 Low Frequency LPO (Low Power Oscillator) clock */
142#define TMS570_SYS1_CSDIS_CLKSR_LPO_NUM 4
143#define TMS570_SYS1_CSDIS_CLKSROFF_LPO BSP_BIT32(4)
144
145/* Clock Source 5 High Frequency LPO (Low Power Oscillator) clock */
146#define TMS570_SYS1_CSDIS_CLKSR_HPO_NUM 5
147#define TMS570_SYS1_CSDIS_CLKSROFF_HPO BSP_BIT32(5)
148
149/* Clock Source 6 PLL2 */
150#define TMS570_SYS1_CSDIS_CLKSR_PLL2_NUM 6
151#define TMS570_SYS1_CSDIS_CLKSROFF_PLL2 BSP_BIT32(6)
152
153/* Clock Source 7 EXTCLKIN2 */
154#define TMS570_SYS1_CSDIS_CLKSR_EXTCLKIN2_NUM 7
155#define TMS570_SYS1_CSDIS_CLKSROFF_EXTCLKIN2 BSP_BIT32(7)
156
157/*--------------------TMS570_SYS1_CSDISSET--------------------*/
158/* field: SETCLKSR_OFF - Set clock source[7-0] to the disabled state. */
159#define TMS570_SYS1_CSDISSET_SETCLKSR_OFF(val) BSP_FLD32(val,0, 7)
160#define TMS570_SYS1_CSDISSET_SETCLKSR_OFF_GET(reg) BSP_FLD32GET(reg,0, 7)
161#define TMS570_SYS1_CSDISSET_SETCLKSR_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
162
163/*--------------------TMS570_SYS1_CSDISCLR--------------------*/
164/* field: CLRCLKSR_OFF - Enables clock source[7-0] */
165#define TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF(val) BSP_FLD32(val,0, 7)
166#define TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF_GET(reg) BSP_FLD32GET(reg,0, 7)
167#define TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
168
169/*---------------------TMS570_SYS1_CDDIS---------------------*/
170/* field: VCLKAOFF - VCLKA4 domain off. */
171#define TMS570_SYS1_CDDIS_VCLKAOFF4 BSP_BIT32(11)
172
173/* field: VCLKAOFF - VCLKA3 domain off. */
174#define TMS570_SYS1_CDDIS_VCLKAOFF3 BSP_BIT32(10)
175
176/* field: VCLK3OFF - VCLK3 domain off. */
177#define TMS570_SYS1_CDDIS_VCLK3OFF BSP_BIT32(8)
178
179/* field: RTICLK1OFF - RTICLK1 domain off. */
180#define TMS570_SYS1_CDDIS_RTICLK1OFF BSP_BIT32(6)
181
182/* field: VCLKAOFF - VCLKA2 domain off. */
183#define TMS570_SYS1_CDDIS_VCLKAOFF2 BSP_BIT32(5)
184
185/* field: VCLKAOFF - VCLKA1 domain off. */
186#define TMS570_SYS1_CDDIS_VCLKAOFF1 BSP_BIT32(4)
187
188/* field: VCLK2OFF - VCLK2 domain off. */
189#define TMS570_SYS1_CDDIS_VCLK2OFF BSP_BIT32(3)
190
191/* field: VCLKPOFF - VCLK_periph domain off. */
192#define TMS570_SYS1_CDDIS_VCLKPOFF BSP_BIT32(2)
193
194/* field: HCLKOFF - HCLK and VCLK_sys domains off. */
195#define TMS570_SYS1_CDDIS_HCLKOFF BSP_BIT32(1)
196
197/* field: GCLKOFF - GCLK domain off. */
198#define TMS570_SYS1_CDDIS_GCLKOFF BSP_BIT32(0)
199
200
201/*--------------------TMS570_SYS1_CDDISSET--------------------*/
202/* field: SETVCLKA_OFF - Set VCLKA[4-3] domain. */
203#define TMS570_SYS1_CDDISSET_SETVCLKA_OFF(val) BSP_FLD32(val,10, 11)
204#define TMS570_SYS1_CDDISSET_SETVCLKA_OFF_GET(reg) BSP_FLD32GET(reg,10, 11)
205#define TMS570_SYS1_CDDISSET_SETVCLKA_OFF_SET(reg,val) BSP_FLD32SET(reg, val,10, 11)
206
207/* field: SETVCLK3OFF - Set VCLK3 domain. */
208#define TMS570_SYS1_CDDISSET_SETVCLK3OFF BSP_BIT32(8)
209
210/* field: SETRTI1CLKOFF - Set RTICLK1 domain. */
211#define TMS570_SYS1_CDDISSET_SETRTI1CLKOFF BSP_BIT32(6)
212
213/* field: SETTVCLKA2OFF - Set VCLKA2 domain. */
214#define TMS570_SYS1_CDDISSET_SETTVCLKA2OFF BSP_BIT32(5)
215
216/* field: SETVCLKA1OFF - Set VCLKA1 domain. */
217#define TMS570_SYS1_CDDISSET_SETVCLKA1OFF BSP_BIT32(4)
218
219/* field: SETVCLK2OFF - Set VCLK2 domain. */
220#define TMS570_SYS1_CDDISSET_SETVCLK2OFF BSP_BIT32(3)
221
222/* field: SETVCLKPOFF - Set VCLK_periph domain. */
223#define TMS570_SYS1_CDDISSET_SETVCLKPOFF BSP_BIT32(2)
224
225/* field: SETHCLKOFF - Set HCLK and VCLK_sys domains. */
226#define TMS570_SYS1_CDDISSET_SETHCLKOFF BSP_BIT32(1)
227
228/* field: SETGCLKOFF - Set GCLK domain. */
229#define TMS570_SYS1_CDDISSET_SETGCLKOFF BSP_BIT32(0)
230
231
232/*--------------------TMS570_SYS1_CDDISCLR--------------------*/
233/* field: CLRVCLKAOFF - Clear VCLKA[4-3] domain. */
234#define TMS570_SYS1_CDDISCLR_CLRVCLKAOFF(val) BSP_FLD32(val,10, 11)
235#define TMS570_SYS1_CDDISCLR_CLRVCLKAOFF_GET(reg) BSP_FLD32GET(reg,10, 11)
236#define TMS570_SYS1_CDDISCLR_CLRVCLKAOFF_SET(reg,val) BSP_FLD32SET(reg, val,10, 11)
237
238/* field: Reserved - Reserved */
239#define TMS570_SYS1_CDDISCLR_Reserved BSP_BIT32(9)
240
241/* field: CLRVCLK3OFF - Clear VCLK3 domain. */
242#define TMS570_SYS1_CDDISCLR_CLRVCLK3OFF BSP_BIT32(8)
243
244/* field: CLRRTI1CLKOFF - Clear RTICLK1 domain. */
245#define TMS570_SYS1_CDDISCLR_CLRRTI1CLKOFF BSP_BIT32(6)
246
247/* field: CLRTVCLKA2OFF - Clear VCLKA2 domain. */
248#define TMS570_SYS1_CDDISCLR_CLRTVCLKA2OFF BSP_BIT32(5)
249
250/* field: CLRVCLKA1OFF - Clear VCLKA1 domain. */
251#define TMS570_SYS1_CDDISCLR_CLRVCLKA1OFF BSP_BIT32(4)
252
253/* field: CLRVCLK2OFF - Clear VCLK2 domain. */
254#define TMS570_SYS1_CDDISCLR_CLRVCLK2OFF BSP_BIT32(3)
255
256/* field: CLRVCLKPOFF - CLRVCLKPOFF */
257#define TMS570_SYS1_CDDISCLR_CLRVCLKPOFF BSP_BIT32(2)
258
259/* field: CLRHCLKOFF - Clear HCLK and VCLK_sys domains. */
260#define TMS570_SYS1_CDDISCLR_CLRHCLKOFF BSP_BIT32(1)
261
262/* field: CLRGCLKOFF - Clear GCLK domain. */
263#define TMS570_SYS1_CDDISCLR_CLRGCLKOFF BSP_BIT32(0)
264
265
266/*---------------------TMS570_SYS1_GHVSRC---------------------*/
267/* field: GHVWAKE - GCLK, HCLK, VCLK, VCLK2 source on wakeup. */
268#define TMS570_SYS1_GHVSRC_GHVWAKE(val) BSP_FLD32(val,24, 27)
269#define TMS570_SYS1_GHVSRC_GHVWAKE_GET(reg) BSP_FLD32GET(reg,24, 27)
270#define TMS570_SYS1_GHVSRC_GHVWAKE_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
271
272/* field: HVLPM - HCLK, VCLK, VCLK2 source on wakeup when GCLK is turned off. */
273#define TMS570_SYS1_GHVSRC_HVLPM(val) BSP_FLD32(val,16, 19)
274#define TMS570_SYS1_GHVSRC_HVLPM_GET(reg) BSP_FLD32GET(reg,16, 19)
275#define TMS570_SYS1_GHVSRC_HVLPM_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
276
277/* field: GHVSRC - GCLK, HCLK, VCLK, VCLK2 current source. */
278#define TMS570_SYS1_GHVSRC_GHVSRC(val) BSP_FLD32(val,0, 3)
279#define TMS570_SYS1_GHVSRC_GHVSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
280#define TMS570_SYS1_GHVSRC_GHVSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
281
282
283/*--------------------TMS570_SYS1_VCLKASRC--------------------*/
284/* field: VCLKA2S - Peripheral asynchronous clock2 source. */
285#define TMS570_SYS1_VCLKASRC_VCLKA2S(val) BSP_FLD32(val,8, 11)
286#define TMS570_SYS1_VCLKASRC_VCLKA2S_GET(reg) BSP_FLD32GET(reg,8, 11)
287#define TMS570_SYS1_VCLKASRC_VCLKA2S_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
288
289/* field: VCLKA1S - Peripheral asynchronous clock1 source. */
290#define TMS570_SYS1_VCLKASRC_VCLKA1S(val) BSP_FLD32(val,0, 3)
291#define TMS570_SYS1_VCLKASRC_VCLKA1S_GET(reg) BSP_FLD32GET(reg,0, 3)
292#define TMS570_SYS1_VCLKASRC_VCLKA1S_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
293
294
295/*--------------------TMS570_SYS1_RCLKSRC--------------------*/
296/* field: RTI1DIV - RTI clock1 Divider. */
297#define TMS570_SYS1_RCLKSRC_RTI1DIV(val) BSP_FLD32(val,8, 9)
298#define TMS570_SYS1_RCLKSRC_RTI1DIV_GET(reg) BSP_FLD32GET(reg,8, 9)
299#define TMS570_SYS1_RCLKSRC_RTI1DIV_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
300
301/* field: RTI1SRC - RTI clock1 source. */
302#define TMS570_SYS1_RCLKSRC_RTI1SRC(val) BSP_FLD32(val,0, 3)
303#define TMS570_SYS1_RCLKSRC_RTI1SRC_GET(reg) BSP_FLD32GET(reg,0, 3)
304#define TMS570_SYS1_RCLKSRC_RTI1SRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
305
306
307/*--------------------TMS570_SYS1_CSVSTAT--------------------*/
308/* field: CLKSRV - Clock source[7-0] valid. */
309#define TMS570_SYS1_CSVSTAT_CLKSRV(val) BSP_FLD32(val,3, 7)
310#define TMS570_SYS1_CSVSTAT_CLKSRV_GET(reg) BSP_FLD32GET(reg,3, 7)
311#define TMS570_SYS1_CSVSTAT_CLKSRV_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
312
313/* field: CLKSR - Clock source[1-0] valid. */
314#define TMS570_SYS1_CSVSTAT_CLKSR(val) BSP_FLD32(val,0, 1)
315#define TMS570_SYS1_CSVSTAT_CLKSR_GET(reg) BSP_FLD32GET(reg,0, 1)
316#define TMS570_SYS1_CSVSTAT_CLKSR_SET(reg,val) BSP_FLD32SET(reg, val,0, 1)
317
318
319/*---------------------TMS570_SYS1_MSTGCR---------------------*/
320/* field: ROM_DIV - Prescaler divider bits for ROM clock source. */
321#define TMS570_SYS1_MSTGCR_ROM_DIV(val) BSP_FLD32(val,8, 9)
322#define TMS570_SYS1_MSTGCR_ROM_DIV_GET(reg) BSP_FLD32GET(reg,8, 9)
323#define TMS570_SYS1_MSTGCR_ROM_DIV_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
324
325/* field: MSTGENA - Memory self-test controller global enable key */
326#define TMS570_SYS1_MSTGCR_MSTGENA(val) BSP_FLD32(val,0, 3)
327#define TMS570_SYS1_MSTGCR_MSTGENA_GET(reg) BSP_FLD32GET(reg,0, 3)
328#define TMS570_SYS1_MSTGCR_MSTGENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
329
330
331/*--------------------TMS570_SYS1_MINITGCR--------------------*/
332/* field: MINITGENA - Memory hardware initialization global enable key. */
333#define TMS570_SYS1_MINITGCR_MINITGENA(val) BSP_FLD32(val,0, 3)
334#define TMS570_SYS1_MINITGCR_MINITGENA_GET(reg) BSP_FLD32GET(reg,0, 3)
335#define TMS570_SYS1_MINITGCR_MINITGENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
336
337
338/*---------------------TMS570_SYS1_MSIENA---------------------*/
339/* field: MSIENA - PBIST controller and memory initialization enable register. */
340/* Whole 32 bits */
341
342/*-------------------TMS570_SYS1_MSTCGSTAT-------------------*/
343/* field: MINIDONE - Memory hardware initialization complete status. */
344#define TMS570_SYS1_MSTCGSTAT_MINIDONE BSP_BIT32(8)
345
346/* field: MSTDONE - Memory self-test run complete status. */
347#define TMS570_SYS1_MSTCGSTAT_MSTDONE BSP_BIT32(0)
348
349
350/*--------------------TMS570_SYS1_MINISTAT--------------------*/
351/* field: MIDONE - Memory hardware initialization status bit. */
352/* Whole 32 bits */
353
354/*--------------------TMS570_SYS1_PLLCTL1--------------------*/
355/* field: ROS - Reset on PLL Slip */
356#define TMS570_SYS1_PLLCTL1_ROS BSP_BIT32(31)
357
358/* field: BPOS - Bypass of PLL Slip */
359#define TMS570_SYS1_PLLCTL1_BPOS(val) BSP_FLD32(val,29, 30)
360#define TMS570_SYS1_PLLCTL1_BPOS_GET(reg) BSP_FLD32GET(reg,29, 30)
361#define TMS570_SYS1_PLLCTL1_BPOS_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
362
363/* field: MASK_SLIP - Mask detection of PLL slip */
364#define TMS570_SYS1_PLLCTL1_MASK_SLIP(val) BSP_FLD32(val,29, 30)
365#define TMS570_SYS1_PLLCTL1_MASK_SLIP_GET(reg) BSP_FLD32GET(reg,29, 30)
366#define TMS570_SYS1_PLLCTL1_MASK_SLIP_SET(reg,val) BSP_FLD32SET(reg, val,29, 30)
367
368/* field: PLLDIV - PLL Output Clock Divider */
369#define TMS570_SYS1_PLLCTL1_PLLDIV(val) BSP_FLD32(val,24, 28)
370#define TMS570_SYS1_PLLCTL1_PLLDIV_GET(reg) BSP_FLD32GET(reg,24, 28)
371#define TMS570_SYS1_PLLCTL1_PLLDIV_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
372
373/* field: ROF - Reset on Oscillator Fail */
374#define TMS570_SYS1_PLLCTL1_ROF BSP_BIT32(23)
375
376/* field: REFCLKDIV - Reference Clock Divider */
377#define TMS570_SYS1_PLLCTL1_REFCLKDIV(val) BSP_FLD32(val,16, 21)
378#define TMS570_SYS1_PLLCTL1_REFCLKDIV_GET(reg) BSP_FLD32GET(reg,16, 21)
379#define TMS570_SYS1_PLLCTL1_REFCLKDIV_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
380
381/* field: PLLMUL - PLL Multiplication Factor */
382#define TMS570_SYS1_PLLCTL1_PLLMUL(val) BSP_FLD32(val,0, 15)
383#define TMS570_SYS1_PLLCTL1_PLLMUL_GET(reg) BSP_FLD32GET(reg,0, 15)
384#define TMS570_SYS1_PLLCTL1_PLLMUL_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
385
386
387/*--------------------TMS570_SYS1_PLLCTL2--------------------*/
388/* field: FMENA - Frequency Modulation Enable. */
389#define TMS570_SYS1_PLLCTL2_FMENA BSP_BIT32(31)
390
391/* field: SPREADINGRATE - NS = SPREADINGRATE + 1 */
392#define TMS570_SYS1_PLLCTL2_SPREADINGRATE(val) BSP_FLD32(val,22, 30)
393#define TMS570_SYS1_PLLCTL2_SPREADINGRATE_GET(reg) BSP_FLD32GET(reg,22, 30)
394#define TMS570_SYS1_PLLCTL2_SPREADINGRATE_SET(reg,val) BSP_FLD32SET(reg, val,22, 30)
395
396/* field: MULMOD - Multiplier Correction when Frequency Modulation is enabled. */
397#define TMS570_SYS1_PLLCTL2_MULMOD(val) BSP_FLD32(val,12, 20)
398#define TMS570_SYS1_PLLCTL2_MULMOD_GET(reg) BSP_FLD32GET(reg,12, 20)
399#define TMS570_SYS1_PLLCTL2_MULMOD_SET(reg,val) BSP_FLD32SET(reg, val,12, 20)
400
401/* field: ODPLL - Internal PLL Output Divider. */
402#define TMS570_SYS1_PLLCTL2_ODPLL(val) BSP_FLD32(val,9, 11)
403#define TMS570_SYS1_PLLCTL2_ODPLL_GET(reg) BSP_FLD32GET(reg,9, 11)
404#define TMS570_SYS1_PLLCTL2_ODPLL_SET(reg,val) BSP_FLD32SET(reg, val,9, 11)
405
406/* field: SPR_AMOUNT - Spreading Amount. */
407#define TMS570_SYS1_PLLCTL2_SPR_AMOUNT(val) BSP_FLD32(val,0, 8)
408#define TMS570_SYS1_PLLCTL2_SPR_AMOUNT_GET(reg) BSP_FLD32GET(reg,0, 8)
409#define TMS570_SYS1_PLLCTL2_SPR_AMOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 8)
410
411
412/*--------------------TMS570_SYS1_PLLCTL3--------------------*/
413/* field: ODPLL2 - Internal PLL Output Divider. */
414#define TMS570_SYS1_PLLCTL3_ODPLL2(val) BSP_FLD32(val, 29, 31)
415#define TMS570_SYS1_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg, 29, 31)
416#define TMS570_SYS1_PLLCTL3_ODPLL2_SET(reg,val) BSP_FLD32SET(reg, val, 29, 31)
417
418/* field: PLLDIV2 - PLL2 Output Clock Divider. */
419#define TMS570_SYS1_PLLCTL3_PLLDIV2(val) BSP_FLD32(val, 24, 28)
420#define TMS570_SYS1_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg, 24, 28)
421#define TMS570_SYS1_PLLCTL3_PLLDIV2_SET(reg,val) BSP_FLD32SET(reg, val, 24, 28)
422
423/* field: REFCLKDIV2 - Reference Clock Divider. */
424#define TMS570_SYS1_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val, 16, 21)
425#define TMS570_SYS1_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg, 16, 21)
426#define TMS570_SYS1_PLLCTL3_REFCLKDIV2_SET(reg,val) BSP_FLD32SET(reg, val, 16, 21)
427
428/* field: PLLMUL2 - PLL2 Multiplication Factor. */
429#define TMS570_SYS1_PLLCTL3_PLLMUL2(val) BSP_FLD32(val, 0, 15)
430#define TMS570_SYS1_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg, 0, 15)
431#define TMS570_SYS1_PLLCTL3_PLLMUL2_SET(reg,val) BSP_FLD32SET(reg, val, 0, 15)
432
433
434/*--------------------TMS570_SYS1_SYSPC10--------------------*/
435/* field: ECPCLK_SLEW - ECPCLK slew control. This bit controls between the fast or slow slew mode. */
436#define TMS570_SYS1_SYSPC10_ECPCLK_SLEW BSP_BIT32(0)
437
438
439/*---------------------TMS570_SYS1_DIEIDL---------------------*/
440/* field: LOT - These read only bits contain the lower 10 bits of the device lot number. */
441#define TMS570_SYS1_DIEIDL_LOT(val) BSP_FLD32(val,22, 31)
442#define TMS570_SYS1_DIEIDL_LOT_GET(reg) BSP_FLD32GET(reg,22, 31)
443#define TMS570_SYS1_DIEIDL_LOT_SET(reg,val) BSP_FLD32SET(reg, val,22, 31)
444
445/* field: WAFER - These read only bits contain the wafer number of the device. */
446#define TMS570_SYS1_DIEIDL_WAFER(val) BSP_FLD32(val,16, 21)
447#define TMS570_SYS1_DIEIDL_WAFER_GET(reg) BSP_FLD32GET(reg,16, 21)
448#define TMS570_SYS1_DIEIDL_WAFER_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
449
450/* field: Y_WAFER_COORDINATE - These read only bits contain the Y wafer coordinate of the device */
451#define TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE(val) BSP_FLD32(val,8, 15)
452#define TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE_GET(reg) BSP_FLD32GET(reg,8, 15)
453#define TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
454
455/* field: X_WAFER_COORDINATE - These read only bits contain the X wafer coordinate of the device */
456#define TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE(val) BSP_FLD32(val,0, 7)
457#define TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE_GET(reg) BSP_FLD32GET(reg,0, 7)
458#define TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
459
460
461/*---------------------TMS570_SYS1_DIEIDH---------------------*/
462/* field: LOT - This read-only register contains the upper 14 bits of the device lot number. */
463#define TMS570_SYS1_DIEIDH_LOT(val) BSP_FLD32(val,0, 13)
464#define TMS570_SYS1_DIEIDH_LOT_GET(reg) BSP_FLD32GET(reg,0, 13)
465#define TMS570_SYS1_DIEIDH_LOT_SET(reg,val) BSP_FLD32SET(reg, val,0, 13)
466
467
468/*-------------------TMS570_SYS1_LPOMONCTL-------------------*/
469/* field: BIAS_ENABLE - Bias enable. */
470#define TMS570_SYS1_LPOMONCTL_BIAS_ENABLE BSP_BIT32(24)
471
472/* field: OSCFRQCONFIGCNT - Configures the counter based on OSC frequency. */
473#define TMS570_SYS1_LPOMONCTL_OSCFRQCONFIGCNT BSP_BIT32(16)
474
475/* field: HFTRIM - High frequency oscillator trim value. */
476#define TMS570_SYS1_LPOMONCTL_HFTRIM(val) BSP_FLD32(val,8, 12)
477#define TMS570_SYS1_LPOMONCTL_HFTRIM_GET(reg) BSP_FLD32GET(reg,8, 12)
478#define TMS570_SYS1_LPOMONCTL_HFTRIM_SET(reg,val) BSP_FLD32SET(reg, val,8, 12)
479
480
481/*--------------------TMS570_SYS1_CLKTEST--------------------*/
482/* field: ALTLIMPCLOCKENABLE - This bit selects a clock driven by the GIOB[0] pin as an alternate limp clock to the clock */
483#define TMS570_SYS1_CLKTEST_ALTLIMPCLOCKENABLE BSP_BIT32(26)
484
485/* field: RANGEDETCTRL - Range detection control. */
486#define TMS570_SYS1_CLKTEST_RANGEDETCTRL BSP_BIT32(25)
487
488/* field: RANGEDETENASSEL - Selects range detection enable. This bit resets asynchronously on power on reset. */
489#define TMS570_SYS1_CLKTEST_RANGEDETENASSEL BSP_BIT32(24)
490
491/* field: CLK_TEST_EN - Clock test enable. This bit enables the clock going to the ECLK pin. */
492#define TMS570_SYS1_CLKTEST_CLK_TEST_EN(val) BSP_FLD32(val,16, 19)
493#define TMS570_SYS1_CLKTEST_CLK_TEST_EN_GET(reg) BSP_FLD32GET(reg,16, 19)
494#define TMS570_SYS1_CLKTEST_CLK_TEST_EN_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
495
496/* field: SEL_GIO_PIN - GIOB[0] pin clock source valid, clock source select */
497#define TMS570_SYS1_CLKTEST_SEL_GIO_PIN(val) BSP_FLD32(val,8, 11)
498#define TMS570_SYS1_CLKTEST_SEL_GIO_PIN_GET(reg) BSP_FLD32GET(reg,8, 11)
499#define TMS570_SYS1_CLKTEST_SEL_GIO_PIN_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
500
501/* field: SEL_ECP_PIN - ECLK pin clock source select */
502#define TMS570_SYS1_CLKTEST_SEL_ECP_PIN(val) BSP_FLD32(val,0, 3)
503#define TMS570_SYS1_CLKTEST_SEL_ECP_PIN_GET(reg) BSP_FLD32GET(reg,0, 3)
504#define TMS570_SYS1_CLKTEST_SEL_ECP_PIN_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
505
506
507/*------------------TMS570_SYS1_DFTCTRLREG1------------------*/
508/* field: DFTWRITE - DFT logic access. */
509#define TMS570_SYS1_DFTCTRLREG1_DFTWRITE(val) BSP_FLD32(val,12, 13)
510#define TMS570_SYS1_DFTCTRLREG1_DFTWRITE_GET(reg) BSP_FLD32GET(reg,12, 13)
511#define TMS570_SYS1_DFTCTRLREG1_DFTWRITE_SET(reg,val) BSP_FLD32SET(reg, val,12, 13)
512
513/* field: DFTREAD - DFT logic access. */
514#define TMS570_SYS1_DFTCTRLREG1_DFTREAD(val) BSP_FLD32(val,8, 9)
515#define TMS570_SYS1_DFTCTRLREG1_DFTREAD_GET(reg) BSP_FLD32GET(reg,8, 9)
516#define TMS570_SYS1_DFTCTRLREG1_DFTREAD_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
517
518/* field: TEST_MODE_KEY - Test mode key. This register is for internal TI use only. */
519#define TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY(val) BSP_FLD32(val,0, 3)
520#define TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
521#define TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
522
523
524/*------------------TMS570_SYS1_DFTCTRLREG2------------------*/
525/* field: IMPDF - DFT Implementation defined bits. */
526#define TMS570_SYS1_DFTCTRLREG2_IMPDF(val) BSP_FLD32(val,4, 31)
527#define TMS570_SYS1_DFTCTRLREG2_IMPDF_GET(reg) BSP_FLD32GET(reg,4, 31)
528#define TMS570_SYS1_DFTCTRLREG2_IMPDF_SET(reg,val) BSP_FLD32SET(reg, val,4, 31)
529
530/* field: TEST_MODE_KEY - Test mode key. This register is for internal TI use only. */
531#define TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY(val) BSP_FLD32(val,0, 3)
532#define TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY_GET(reg) BSP_FLD32GET(reg,0, 3)
533#define TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
534
535
536/*---------------------TMS570_SYS1_GPREG1---------------------*/
537/* field: EMIF_FUNC - Enable EMIF functions to be output. */
538#define TMS570_SYS1_GPREG1_EMIF_FUNC BSP_BIT32(31)
539
540/* field: PLL1_FBSLIP_FILTER__COUNT - FBSLIP down counter programmed value. */
541#define TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT(val) BSP_FLD32(val,20, 25)
542#define TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT_GET(reg) BSP_FLD32GET(reg,20, 25)
543#define TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT_SET(reg,val) BSP_FLD32SET(reg, val,20, 25)
544
545/* field: PLL1_RFSLIP_FILTER__KEY - Configures the system response when a FBSLIP is indicated by the */
546#define TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY(val) BSP_FLD32(val,16, 19)
547#define TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY_GET(reg) BSP_FLD32GET(reg,16, 19)
548#define TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
549
550/* field: OUTPUT_BUFFER_LOW_EMI_MODE - Control field for the low-EMI mode of output buffers for */
551#define TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE(val) BSP_FLD32(val,0, 15)
552#define TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_GET(reg) BSP_FLD32GET(reg,0, 15)
553#define TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
554
555
556/*--------------------TMS570_SYS1_IMPFASTS--------------------*/
557/* field: ECPCLKFUN - ECLK function. This bit changes the function of the ECLK pin. */
558#define TMS570_SYS1_IMPFASTS_ECPCLKFUN BSP_BIT32(0)
559
560
561/*--------------------TMS570_SYS1_IMPFTADD--------------------*/
562/* field: IMPFTADD - These bits contain the fault address when an imprecise abort occurs. */
563/* Whole 32 bits */
564
565/*---------------------TMS570_SYS1_SSIRx---------------------*/
566/* field: SSKEY1 - System software interrupt request key. A 075h written to these bits initiates IRQ/FIQ interrupts. */
567#define TMS570_SYS1_SSIRx_SSKEY1(val) BSP_FLD32(val,8, 15)
568#define TMS570_SYS1_SSIRx_SSKEY1_GET(reg) BSP_FLD32GET(reg,8, 15)
569#define TMS570_SYS1_SSIRx_SSKEY1_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
570
571/* field: SSDATA1 - System software interrupt data. These bits contain user read/write register bits. */
572#define TMS570_SYS1_SSIRx_SSDATA1(val) BSP_FLD32(val,0, 7)
573#define TMS570_SYS1_SSIRx_SSDATA1_GET(reg) BSP_FLD32GET(reg,0, 7)
574#define TMS570_SYS1_SSIRx_SSDATA1_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
575
576
577/*---------------------TMS570_SYS1_RAMGCR---------------------*/
578/* field: RAM_DFT_EN - Functional mode RAM DFT (Design For Test) port enable key. */
579#define TMS570_SYS1_RAMGCR_RAM_DFT_EN(val) BSP_FLD32(val,16, 19)
580#define TMS570_SYS1_RAMGCR_RAM_DFT_EN_GET(reg) BSP_FLD32GET(reg,16, 19)
581#define TMS570_SYS1_RAMGCR_RAM_DFT_EN_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
582
583/* field: WST_AENA0 - eSRAM data phase wait state enable bit. */
584#define TMS570_SYS1_RAMGCR_WST_AENA0 BSP_BIT32(2)
585
586/* field: WST_DENA0 - eSRAM data phase wait state enable bit. */
587#define TMS570_SYS1_RAMGCR_WST_DENA0 BSP_BIT32(0)
588
589
590/*---------------------TMS570_SYS1_BMMCR1---------------------*/
591/* field: MEMSW - Memory swap key. */
592#define TMS570_SYS1_BMMCR1_MEMSW(val) BSP_FLD32(val,0, 3)
593#define TMS570_SYS1_BMMCR1_MEMSW_GET(reg) BSP_FLD32GET(reg,0, 3)
594#define TMS570_SYS1_BMMCR1_MEMSW_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
595
596
597/*--------------------TMS570_SYS1_CPURSTCR--------------------*/
598/* field: CPU_RESET - CPU Reset. */
599#define TMS570_SYS1_CPURSTCR_CPU_RESET BSP_BIT32(0)
600
601
602/*--------------------TMS570_SYS1_CLKCNTL--------------------*/
603/* field: VCLK2R - VBUS clock2 ratio. */
604#define TMS570_SYS1_CLKCNTL_VCLK2R(val) BSP_FLD32(val,24, 27)
605#define TMS570_SYS1_CLKCNTL_VCLK2R_GET(reg) BSP_FLD32GET(reg,24, 27)
606#define TMS570_SYS1_CLKCNTL_VCLK2R_SET(reg,val) BSP_FLD32SET(reg, val,24, 27)
607
608/* field: VCLKR - VBUS clock ratio. */
609#define TMS570_SYS1_CLKCNTL_VCLKR(val) BSP_FLD32(val,16, 19)
610#define TMS570_SYS1_CLKCNTL_VCLKR_GET(reg) BSP_FLD32GET(reg,16, 19)
611#define TMS570_SYS1_CLKCNTL_VCLKR_SET(reg,val) BSP_FLD32SET(reg, val,16, 19)
612
613/* field: PENA - Peripheral enable bit. */
614#define TMS570_SYS1_CLKCNTL_PENA BSP_BIT32(8)
615
616
617/*--------------------TMS570_SYS1_ECPCNTL--------------------*/
618/* field: ECPSSEL - This bit allows the selection between VCLK and OSCIN as the clock source for ECLK. */
619#define TMS570_SYS1_ECPCNTL_ECPSSEL BSP_BIT32(24)
620
621/* field: ECPCOS - ECP continue on suspend. */
622#define TMS570_SYS1_ECPCNTL_ECPCOS BSP_BIT32(23)
623
624/* field: ECPINSEL - Select ECP input clock source. */
625#define TMS570_SYS1_ECPCNTL_ECPINSEL(val) BSP_FLD32(val,6, 17)
626#define TMS570_SYS1_ECPCNTL_ECPINSEL_GET(reg) BSP_FLD32GET(reg,6, 17)
627#define TMS570_SYS1_ECPCNTL_ECPINSEL_SET(reg,val) BSP_FLD32SET(reg, val,6, 17)
628
629/* field: ECPDIV - ECP divider value. */
630#define TMS570_SYS1_ECPCNTL_ECPDIV(val) BSP_FLD32(val,0, 15)
631#define TMS570_SYS1_ECPCNTL_ECPDIV_GET(reg) BSP_FLD32GET(reg,0, 15)
632#define TMS570_SYS1_ECPCNTL_ECPDIV_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
633
634
635/*---------------------TMS570_SYS1_DEVCR1---------------------*/
636/* field: DEVPARSEL - Device parity select bit key. */
637#define TMS570_SYS1_DEVCR1_DEVPARSEL(val) BSP_FLD32(val,0, 3)
638#define TMS570_SYS1_DEVCR1_DEVPARSEL_GET(reg) BSP_FLD32GET(reg,0, 3)
639#define TMS570_SYS1_DEVCR1_DEVPARSEL_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
640
641
642/*---------------------TMS570_SYS1_SYSECR---------------------*/
643/* field: RESET - Software reset bits. Setting RESET1 or clearing RESET0 causes a system software reset. */
644#define TMS570_SYS1_SYSECR_RESET(val) BSP_FLD32(val,14, 15)
645#define TMS570_SYS1_SYSECR_RESET_GET(reg) BSP_FLD32GET(reg,14, 15)
646#define TMS570_SYS1_SYSECR_RESET_SET(reg,val) BSP_FLD32SET(reg, val,14, 15)
647
648
649/*---------------------TMS570_SYS1_SYSESR---------------------*/
650/* field: PORST - Power-up reset. This bit is set when VCCOR (VCC Out of Range) is detected. */
651#define TMS570_SYS1_SYSESR_PORST BSP_BIT32(15)
652
653/* field: OSCRST - Reset caused by an oscillator failure or PLL cycle slip. */
654#define TMS570_SYS1_SYSESR_OSCRST BSP_BIT32(14)
655
656/* field: WDRST - Watchdog reset flag. */
657#define TMS570_SYS1_SYSESR_WDRST BSP_BIT32(13)
658
659#if TMS570_VARIANT == 4357
660
661/* field: DBGRST - Debug reset flag. */
662#define TMS570_SYS1_SYSESR_DBGRST BSP_BIT32(11)
663
664/* field: ICSTRST - Interconnect reset flag. */
665#define TMS570_SYS1_SYSESR_ICSTRST BSP_BIT32(7)
666
667#endif
668
669/* field: CPURST - CPU reset flag. This bit is set when the CPU is reset. */
670#define TMS570_SYS1_SYSESR_CPURST BSP_BIT32(5)
671
672/* field: SWRST - Software reset flag. This bit is set when a software system reset has occurred. */
673#define TMS570_SYS1_SYSESR_SWRST BSP_BIT32(4)
674
675/* field: EXTRST - External reset flag. This bit is set when a reset is caused by the external reset pin nRST. */
676#define TMS570_SYS1_SYSESR_EXTRST BSP_BIT32(3)
677
678/* field: MPMODE - This indicates the current memory protection unit (MPU) mode. */
679#define TMS570_SYS1_SYSESR_MPMODE BSP_BIT32(0)
680
681
682/*--------------------TMS570_SYS1_SYSTASR--------------------*/
683/* field: EFUSE_Abort - Test Abort status flag. */
684#define TMS570_SYS1_SYSTASR_EFUSE_Abort(val) BSP_FLD32(val,0, 4)
685#define TMS570_SYS1_SYSTASR_EFUSE_Abort_GET(reg) BSP_FLD32GET(reg,0, 4)
686#define TMS570_SYS1_SYSTASR_EFUSE_Abort_SET(reg,val) BSP_FLD32SET(reg, val,0, 4)
687
688
689/*--------------------TMS570_SYS1_GLBSTAT--------------------*/
690/* field: FBSLIP - PLL over cycle slip detection. */
691#define TMS570_SYS1_GLBSTAT_FBSLIP BSP_BIT32(9)
692
693/* field: RFSLIP - PLL under cycle slip detection. */
694#define TMS570_SYS1_GLBSTAT_RFSLIP BSP_BIT32(8)
695
696/* field: OSCFAIL - Oscillator fail flag bit. */
697#define TMS570_SYS1_GLBSTAT_OSCFAIL BSP_BIT32(0)
698
699
700/*---------------------TMS570_SYS1_DEVID---------------------*/
701/* field: CP15 - CP15 CPU. This bit indicates whether the CPU has a coprocessor 15 (CP15). */
702#define TMS570_SYS1_DEVID_CP15 BSP_BIT32(31)
703
704/* field: TECH - These bits define the process technology by which the device was manufactured. */
705#define TMS570_SYS1_DEVID_TECH(val) BSP_FLD32(val,13, 16)
706#define TMS570_SYS1_DEVID_TECH_GET(reg) BSP_FLD32GET(reg,13, 16)
707#define TMS570_SYS1_DEVID_TECH_SET(reg,val) BSP_FLD32SET(reg, val,13, 16)
708
709/* field: I_O_VOLTAGE - Input/output voltage. This bit defines the I/O voltage of the device. */
710#define TMS570_SYS1_DEVID_I_O_VOLTAGE BSP_BIT32(12)
711
712/* field: PERIPHERAL_PARITY - The peripheral memories have no parity. */
713#define TMS570_SYS1_DEVID_PERIPHERAL_PARITY BSP_BIT32(11)
714
715/* field: FLASH_ECC - These bits indicate which parity is present for the program memory. */
716#define TMS570_SYS1_DEVID_FLASH_ECC(val) BSP_FLD32(val,9, 10)
717#define TMS570_SYS1_DEVID_FLASH_ECC_GET(reg) BSP_FLD32GET(reg,9, 10)
718#define TMS570_SYS1_DEVID_FLASH_ECC_SET(reg,val) BSP_FLD32SET(reg, val,9, 10)
719
720/* field: RAM_ECC - RAM ECC. This bit indicates whether or not RAM memory ECC is present. */
721#define TMS570_SYS1_DEVID_RAM_ECC BSP_BIT32(8)
722
723/* field: VERSION - Version. These bits provide the revision of the device. */
724#define TMS570_SYS1_DEVID_VERSION(val) BSP_FLD32(val,3, 7)
725#define TMS570_SYS1_DEVID_VERSION_GET(reg) BSP_FLD32GET(reg,3, 7)
726#define TMS570_SYS1_DEVID_VERSION_SET(reg,val) BSP_FLD32SET(reg, val,3, 7)
727
728/* field: PLATFORM_ID - The device is part of the TMS570Px family. The TMS570Px ID is always 5h. */
729#define TMS570_SYS1_DEVID_PLATFORM_ID(val) BSP_FLD32(val,0, 2)
730#define TMS570_SYS1_DEVID_PLATFORM_ID_GET(reg) BSP_FLD32GET(reg,0, 2)
731#define TMS570_SYS1_DEVID_PLATFORM_ID_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
732
733
734/*---------------------TMS570_SYS1_SSIVEC---------------------*/
735/* field: SSIDATA - System software interrupt data key. */
736#define TMS570_SYS1_SSIVEC_SSIDATA(val) BSP_FLD32(val,8, 15)
737#define TMS570_SYS1_SSIVEC_SSIDATA_GET(reg) BSP_FLD32GET(reg,8, 15)
738#define TMS570_SYS1_SSIVEC_SSIDATA_SET(reg,val) BSP_FLD32SET(reg, val,8, 15)
739
740/* field: SSIVECT - These bits contain the source for the system software interrupt. */
741#define TMS570_SYS1_SSIVEC_SSIVECT(val) BSP_FLD32(val,0, 7)
742#define TMS570_SYS1_SSIVEC_SSIVECT_GET(reg) BSP_FLD32GET(reg,0, 7)
743#define TMS570_SYS1_SSIVEC_SSIVECT_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
744
745
746/*----------------------TMS570_SYS1_SSIF----------------------*/
747/* field: SSI_FLAG - System software interrupt flag[4-1]. */
748#define TMS570_SYS1_SSIF_SSI_FLAG(val) BSP_FLD32(val,0, 3)
749#define TMS570_SYS1_SSIF_SSI_FLAG_GET(reg) BSP_FLD32GET(reg,0, 3)
750#define TMS570_SYS1_SSIF_SSI_FLAG_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
751
752
753
754#endif /* LIBBSP_ARM_TMS570_SYS1 */
This header file provides utility macros for BSPs.
Definition: reg_sys.h:54
