RTEMS
6.1
bsps
arm
tms570
include
bsp
ti_herc
reg_pcr.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from PCR.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_PCR
50
#define LIBBSP_ARM_TMS570_PCR
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t PMPROTSET0;
/*Peripheral Memory Protection Set Register 0*/
56
uint32_t PMPROTSET1;
/*Peripheral Memory Protection Set Register 1*/
57
uint8_t reserved1 [8];
58
uint32_t PMPROTCLR0;
/*Peripheral Memory Protection Clear Register 0*/
59
uint32_t PMPROTCLR1;
/*Peripheral Memory Protection Clear Register 1*/
60
uint8_t reserved2 [8];
61
uint32_t PPROTSET0;
/*Peripheral Protection Set Register 0*/
62
uint32_t PPROTSET1;
/*Peripheral Protection Set Register 1*/
63
uint32_t PPROTSET2;
/*Peripheral Protection Set Register 2*/
64
uint32_t PPROTSET3;
/*Peripheral Protection Set Register 3*/
65
uint8_t reserved3 [16];
66
uint32_t PPROTCLR0;
/*Peripheral Protection Clear Register 0*/
67
uint32_t PPROTCLR1;
/*Peripheral Protection Clear Register 1*/
68
uint32_t PPROTCLR2;
/*Peripheral Protection Clear Register 2*/
69
uint32_t PPROTCLR3;
/*Peripheral Protection Clear Register 3*/
70
uint8_t reserved4 [16];
71
uint32_t PCSPWRDWNSET0;
/*Peripheral Memory Power-Down Set Register 0*/
72
uint32_t PCSPWRDWNSET1;
/*Peripheral Memory Power-Down Set Register 1*/
73
uint8_t reserved5 [8];
74
uint32_t PCSPWRDWNCLR0;
/*Peripheral Memory Power-Down Clear Register 0*/
75
uint32_t PCSPWRDWNCLR1;
/*Peripheral Memory Power-Down Clear Register 1*/
76
uint8_t reserved6 [8];
77
uint32_t PSPWRDWNSET0;
/*Peripheral Power-Down Set Register 0*/
78
uint32_t PSPWRDWNSET1;
/*Peripheral Power-Down Set Register 1*/
79
uint32_t PSPWRDWNSET2;
/*Peripheral Power-Down Set Register 2*/
80
uint32_t PSPWRDWNSET3;
/*Peripheral Power-Down Set Register 3*/
81
uint8_t reserved7 [16];
82
uint32_t PSPWRDWNCLR0;
/*Peripheral Power-Down Clear Register 0*/
83
uint32_t PSPWRDWNCLR1;
/*Peripheral Power-Down Clear Register 1*/
84
uint32_t PSPWRDWNCLR2;
/*Peripheral Power-Down Clear Register 2*/
85
uint32_t PSPWRDWNCLR3;
/*Peripheral Power-Down Clear Register 3*/
86
tms570_pcr_t
87
88
89
/*-------------------TMS570_PCR_PMPROTSET0-------------------*/
90
/* field: PCSPROTSET - Peripheral memory frame protection set. */
91
/* Whole 32 bits */
92
93
/*-------------------TMS570_PCR_PMPROTSET1-------------------*/
94
95
/* Whole 32 bits */
96
97
/*-------------------TMS570_PCR_PMPROTCLR0-------------------*/
98
/* field: PCSPROTCLR - Peripheral memory frame protection clear. */
99
/* Whole 32 bits */
100
101
/*-------------------TMS570_PCR_PMPROTCLR1-------------------*/
102
103
/* Whole 32 bits */
104
105
/*--------------------TMS570_PCR_PPROTSETx--------------------*/
106
/* field: PROTSET - Peripheral select quadrant protection set. */
107
/* Whole 32 bits */
108
109
/*--------------------TMS570_PCR_PPROTCLRx--------------------*/
110
/* field: PROTCLR - Peripheral select quadrant protection clear. */
111
/* Whole 32 bits */
112
113
/*------------------TMS570_PCR_PCSPWRDWNSETx------------------*/
114
/* field: PWRDNSET - Peripheral memory clock power-down set. */
115
/* Whole 32 bits */
116
117
/*------------------TMS570_PCR_PCSPWRDWNCLRx------------------*/
118
/* field: PWRDNCLR - Peripheral memory clock power-down clear. */
119
/* Whole 32 bits */
120
121
/*------------------TMS570_PCR_PSPWRDWNSETx------------------*/
122
/* field: PWRDWNSET - Peripheral select quadrant clock power-down set. */
123
/* Whole 32 bits */
124
125
/*------------------TMS570_PCR_PSPWRDWNCLRx------------------*/
126
/* field: PWRDWNCLR - Peripheral select quadrant clock power-down clear. */
127
/* Whole 32 bits */
128
129
130
#endif
/* LIBBSP_ARM_TMS570_PCR */
utility.h
This header file provides utility macros for BSPs.
tms570_pcr_t
Definition:
reg_pcr.h:54
