RTEMS
6.1
bsps
arm
tms570
include
bsp
ti_herc
reg_dcc.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from DCC.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_DCC
50
#define LIBBSP_ARM_TMS570_DCC
51
52
bsp/utility.h
53
54
enum
tms570_dcc1_cnt0_clksrc
55
DCC1_CNT0_HF_LPO
= 0x5U,
56
DCC1_CNT0_TCK
= 0xAU,
57
DCC1_CNT0_OSCIN
= 0xFU,
58
59
60
typedef
struct
61
uint32_t GCTRL;
/*DCC Global Control Register*/
62
uint32_t REV;
/*DCC Revision Id Register*/
63
uint32_t CNT0SEED;
/*DCC Counter0 Seed Register*/
64
uint32_t VALID0SEED;
/*DCC Valid0 Seed Register*/
65
uint32_t CNT1SEED;
/*DCC Counter1 Seed Register*/
66
uint32_t STAT;
/*DCC Status Register*/
67
uint32_t CNT0;
/*DCC Counter0 Value Register*/
68
uint32_t VALID0;
/*DCC Valid0 Value Register*/
69
uint32_t CNT1;
/*DCC Counter1 Value Register*/
70
uint32_t CNT1CLKSRC;
/*DCC Counter1 Clock Source Selection Register*/
71
uint32_t CNT0CLKSRC;
/*DCC Counter0 Clock Source Selection Register*/
72
tms570_dcc_t
73
74
75
/*----------------------TMS570_DCC_GCTRL----------------------*/
76
/* field: DONE_INT_ENA - Done Interrupt Enable. */
77
#define TMS570_DCC_GCTRL_DONE_INT_ENA(val) BSP_FLD32(val,12, 15)
78
#define TMS570_DCC_GCTRL_DONE_INT_ENA_GET(reg) BSP_FLD32GET(reg,12, 15)
79
#define TMS570_DCC_GCTRL_DONE_INT_ENA_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
80
81
/* field: SINGLE_SHOT - Single-Shot Mode Enable. */
82
#define TMS570_DCC_GCTRL_SINGLE_SHOT(val) BSP_FLD32(val,8, 11)
83
#define TMS570_DCC_GCTRL_SINGLE_SHOT_GET(reg) BSP_FLD32GET(reg,8, 11)
84
#define TMS570_DCC_GCTRL_SINGLE_SHOT_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
85
86
/* field: ERR_ENA - Error Interrupt Enable. */
87
#define TMS570_DCC_GCTRL_ERR_ENA(val) BSP_FLD32(val,4, 7)
88
#define TMS570_DCC_GCTRL_ERR_ENA_GET(reg) BSP_FLD32GET(reg,4, 7)
89
#define TMS570_DCC_GCTRL_ERR_ENA_SET(reg,val) BSP_FLD32SET(reg, val,4, 7)
90
91
/* field: DCC_ENA - DCC Enable. */
92
#define TMS570_DCC_GCTRL_DCC_ENA(val) BSP_FLD32(val,0, 3)
93
#define TMS570_DCC_GCTRL_DCC_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
94
#define TMS570_DCC_GCTRL_DCC_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
95
96
97
/*-----------------------TMS570_DCC_REV-----------------------*/
98
/* field: SCHEME - Reads return 01, writes have no effect. */
99
#define TMS570_DCC_REV_SCHEME(val) BSP_FLD32(val,30, 31)
100
#define TMS570_DCC_REV_SCHEME_GET(reg) BSP_FLD32GET(reg,30, 31)
101
#define TMS570_DCC_REV_SCHEME_SET(reg,val) BSP_FLD32SET(reg, val,30, 31)
102
103
/* field: FUNC - Functional release number. Reads return 0x000, writes have no effect. */
104
#define TMS570_DCC_REV_FUNC(val) BSP_FLD32(val,16, 27)
105
#define TMS570_DCC_REV_FUNC_GET(reg) BSP_FLD32GET(reg,16, 27)
106
#define TMS570_DCC_REV_FUNC_SET(reg,val) BSP_FLD32SET(reg, val,16, 27)
107
108
/* field: RTL - Design release number. Reads return 0x00, writes have no effect. */
109
#define TMS570_DCC_REV_RTL(val) BSP_FLD32(val,11, 15)
110
#define TMS570_DCC_REV_RTL_GET(reg) BSP_FLD32GET(reg,11, 15)
111
#define TMS570_DCC_REV_RTL_SET(reg,val) BSP_FLD32SET(reg, val,11, 15)
112
113
/* field: MAJOR - Major revision number. Reads return 0x2, writes have no effect. */
114
#define TMS570_DCC_REV_MAJOR(val) BSP_FLD32(val,8, 10)
115
#define TMS570_DCC_REV_MAJOR_GET(reg) BSP_FLD32GET(reg,8, 10)
116
#define TMS570_DCC_REV_MAJOR_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
117
118
/* field: CUSTOM - Custom version number. Reads return 0x0, writes have no effect. */
119
#define TMS570_DCC_REV_CUSTOM(val) BSP_FLD32(val,6, 7)
120
#define TMS570_DCC_REV_CUSTOM_GET(reg) BSP_FLD32GET(reg,6, 7)
121
#define TMS570_DCC_REV_CUSTOM_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
122
123
/* field: MINOR - Minor revision number. Reads return 0x4, writes have no effect. */
124
#define TMS570_DCC_REV_MINOR(val) BSP_FLD32(val,0, 5)
125
#define TMS570_DCC_REV_MINOR_GET(reg) BSP_FLD32GET(reg,0, 5)
126
#define TMS570_DCC_REV_MINOR_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
127
128
129
/*--------------------TMS570_DCC_CNT0SEED--------------------*/
130
/* field: COUNT0_SEED - Seed value for DCC Counter0. */
131
#define TMS570_DCC_CNT0SEED_COUNT0_SEED(val) BSP_FLD32(val,0, 19)
132
#define TMS570_DCC_CNT0SEED_COUNT0_SEED_GET(reg) BSP_FLD32GET(reg,0, 19)
133
#define TMS570_DCC_CNT0SEED_COUNT0_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
134
135
136
/*-------------------TMS570_DCC_VALID0SEED-------------------*/
137
/* field: VALID0_SEED - XXX */
138
#define TMS570_DCC_VALID0SEED_VALID0_SEED(val) BSP_FLD32(val,0, 15)
139
#define TMS570_DCC_VALID0SEED_VALID0_SEED_GET(reg) BSP_FLD32GET(reg,0, 15)
140
#define TMS570_DCC_VALID0SEED_VALID0_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
141
142
143
/*--------------------TMS570_DCC_CNT1SEED--------------------*/
144
/* field: COUNT1_SEED - Seed value for DCC Counter1. */
145
#define TMS570_DCC_CNT1SEED_COUNT1_SEED(val) BSP_FLD32(val,0, 19)
146
#define TMS570_DCC_CNT1SEED_COUNT1_SEED_GET(reg) BSP_FLD32GET(reg,0, 19)
147
#define TMS570_DCC_CNT1SEED_COUNT1_SEED_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
148
149
150
/*----------------------TMS570_DCC_STAT----------------------*/
151
/* field: DONE_FLG - Single-Shot Sequence Done flag. */
152
#define TMS570_DCC_STAT_DONE_FLG BSP_BIT32(1)
153
154
/* field: ERR_FLG - Error flag. Indicates that a DCC error has occurred. */
155
#define TMS570_DCC_STAT_ERR_FLG BSP_BIT32(0)
156
157
158
/*----------------------TMS570_DCC_CNT0----------------------*/
159
/* field: COUNT0 - Current value of DCC Counter0. */
160
#define TMS570_DCC_CNT0_COUNT0(val) BSP_FLD32(val,0, 19)
161
#define TMS570_DCC_CNT0_COUNT0_GET(reg) BSP_FLD32GET(reg,0, 19)
162
#define TMS570_DCC_CNT0_COUNT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
163
164
165
/*---------------------TMS570_DCC_VALID0---------------------*/
166
/* field: VALID0 - Current value for DCC Valid0. */
167
#define TMS570_DCC_VALID0_VALID0(val) BSP_FLD32(val,0, 15)
168
#define TMS570_DCC_VALID0_VALID0_GET(reg) BSP_FLD32GET(reg,0, 15)
169
#define TMS570_DCC_VALID0_VALID0_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
170
171
172
/*----------------------TMS570_DCC_CNT1----------------------*/
173
/* field: COUNT1 - Current value for DCC Counter1. */
174
#define TMS570_DCC_CNT1_COUNT1(val) BSP_FLD32(val,0, 19)
175
#define TMS570_DCC_CNT1_COUNT1_GET(reg) BSP_FLD32GET(reg,0, 19)
176
#define TMS570_DCC_CNT1_COUNT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 19)
177
178
179
/*-------------------TMS570_DCC_CNT1CLKSRC-------------------*/
180
/* field: KEY - Key to enable clock source selection for Counter1. */
181
#define TMS570_DCC_CNT1CLKSRC_KEY(val) BSP_FLD32(val,12, 15)
182
#define TMS570_DCC_CNT1CLKSRC_KEY_GET(reg) BSP_FLD32GET(reg,12, 15)
183
#define TMS570_DCC_CNT1CLKSRC_KEY_SET(reg,val) BSP_FLD32SET(reg, val,12, 15)
184
185
/* field: CNT1_CLKSRC - Clock Source for Counter1 when KEY is programmed to be 0xA. */
186
#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC(val) BSP_FLD32(val,0, 3)
187
#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
188
#define TMS570_DCC_CNT1CLKSRC_CNT1_CLKSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
189
190
191
/*-------------------TMS570_DCC_CNT0CLKSRC-------------------*/
192
/* field: CNT0_CLKSRC - Clock Source for Counter0 */
193
#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC(val) BSP_FLD32(val,0, 3)
194
#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC_GET(reg) BSP_FLD32GET(reg,0, 3)
195
#define TMS570_DCC_CNT0CLKSRC_CNT0_CLKSRC_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
196
197
198
199
#endif
/* LIBBSP_ARM_TMS570_DCC */
utility.h
This header file provides utility macros for BSPs.
Definition:
reg_dcc.h:54
DCC1_CNT0_HF_LPO
@ DCC1_CNT0_HF_LPO
Definition:
reg_dcc.h:55
DCC1_CNT0_TCK
@ DCC1_CNT0_TCK
Definition:
reg_dcc.h:56
DCC1_CNT0_OSCIN
@ DCC1_CNT0_OSCIN
Definition:
reg_dcc.h:57
tms570_dcc_t
Definition:
reg_dcc.h:60
