RTEMS 6.1
recorddump.h
2
3/*
4 * Copyright (C) 2020 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef _RTEMS_RECORDDUMP_H
29#define _RTEMS_RECORDDUMP_H
30
31#include <rtems/record.h>
32
33#include <zlib.h>
34
35#ifdef __cplusplus
36extern "C" {
37#endif /* __cplusplus */
38
52typedef void ( *rtems_record_dump_chunk )(
53 void *arg,
54 const void *data,
55 size_t length
56);
57
68 void *arg
69);
70
79void rtems_record_dump_base64( void ( *put_char )( int, void * ), void *arg );
80
85typedef struct {
86 void ( *put_char )( int, void * );
87 void *arg;
88 int out;
89 unsigned char buf[ 57 ];
90 z_stream stream;
91 char *mem_begin;
92 size_t mem_available;
93 char mem[ 0x80000 ];
95
108 void ( *put_char )( int, void * ),
109 void *arg
110);
111
114#ifdef __cplusplus
115}
116#endif /* __cplusplus */
117
118#endif /* _RTEMS_RECORDDUMP_H */
void rtems_record_dump_zlib_base64(rtems_record_dump_base64_zlib_context *ctx, void(*put_char)(int, void *), void *arg)
Dumps the event records compressed with zlib in base64 encoding.
Definition: record-dump-zbase64.c:133
void(* rtems_record_dump_chunk)(void *arg, const void *data, size_t length)
Handler for record dumps to output a chunk of data.
Definition: recorddump.h:52
void rtems_record_dump(rtems_record_dump_chunk chunk, void *arg)
Dumps the record header, the thread names, and all items of all processors.
Definition: record-dump.c:83
void rtems_record_dump_base64(void(*put_char)(int, void *), void *arg)
Dumps the event records in base64 encoding.
The context for record dumps with zlib compression and base64 encoding.
Definition: recorddump.h:85
Definition: zlib.h:170
