RTEMS 6.1
pwmout-defs.h
1
9/*
10 * Copyright (c) 2014 Taller Technologies.
11 *
12 * @author Diaz Marcos (marcos.diaz@tallertechnologies.com)
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 */
18
19#ifndef LPC176X_PWMOUT_DEFS_H
20#define LPC176X_PWMOUT_DEFS_H
21
22#include <bsp/lpc176x.h>
23#include <bsp/pwmout.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif /* __cplusplus */
28
29#define PWM_DEFAULT_PERIOD 20000u
30#define PWM_DEFAULT_PULSEWIDTH 0u
31
32#define PWM_PRESCALER_USECOND ( LPC176X_CCLK / 1000000 )
33#define PWM_MCR_RESET_ON_MATCH0 ( 1 << 1 )
34#define PWM_PCR_ENABLE_PWM( pwmout ) ( 1 << ( 9 + pwmout ) )
35#define PWM_TCR_RESET ( 1 << 1 )
36#define PWM_TCR_ENABLE ( 1u )
37#define PWM_TCR_PWM ( 1 << 3 )
38#define PWM_LER_LATCH_MATCH_0 1u
39#define PWM_LER_LATCH( match ) ( 1 << ( ( match ) + 1 ) )
40
44typedef struct {
45 volatile uint32_t IR;
46 volatile uint32_t TCR;
47 volatile uint32_t TC;
48 volatile uint32_t PR;
49 volatile uint32_t PC;
50 volatile uint32_t MCR;
51 volatile uint32_t MR0;
52 volatile uint32_t MR1;
53 volatile uint32_t MR2;
54 volatile uint32_t MR3;
55 volatile uint32_t CCR;
56 volatile uint32_t CR0;
57 volatile uint32_t CR1;
58 volatile uint32_t CR2;
59 volatile uint32_t CR3;
60 volatile uint32_t RESERVED0;
61 volatile uint32_t MR4;
62 volatile uint32_t MR5;
63 volatile uint32_t MR6;
64 volatile uint32_t PCR;
65 volatile uint32_t LER;
66 volatile uint32_t RESERVED1[ 7 ];
67 volatile uint32_t CTCR;
69
74typedef struct {
75 uint32_t pin_number;
76 lpc176x_pin_function pin_function;
78
82typedef enum {
83 PWMO_1,
84 PWMO_2,
85 PWMO_3,
86 PWMO_4,
87 PWMO_5,
88 PWMO_6,
89 PWM_OUTPUT_NUMBER
91
95typedef enum {
96 PWM_FIRST_PIN,
97 PWM_SECOND_PIN,
98 PWM_NUMBER_OF_PINS
100
101#ifdef __cplusplus
102}
103#endif /* __cplusplus */
104
105#endif
#define MCR
Modem Control Register.
Definition: uart.h:91
Defines the functions according to the pin.
Definition: io-defs.h:68
Specific register definitions according to lpc176x family boards.
lpc176x_pwm_pin_number
A pin for each PWM output.
Definition: pwmout-defs.h:95
lpc176x_pwm_number
The PWM outputs of the board.
Definition: pwmout-defs.h:82
PWM-Out controller for the mbed lpc1768 board.
Definition: hexdump.h:39
The low-level PWM output device.
Definition: pwmout-defs.h:44
Represents one pin and the respective function to be set for each PWM output.
Definition: pwmout-defs.h:74
